path: root/arch/arm/mach-rpc
2020-01-27ARM: riscpc: fix lack of keyboard interrupts after irq conversionRussell King
[ Upstream commit 63a0666bca9311f35017be454587f3ba903644b8 ] Fix lack of keyboard interrupts for RiscPC due to incorrect conversion. Fixes: e8d36d5dbb6a ("ARM: kill off set_irq_flags usage") Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-08-06ARM: riscpc: fix DMARussell King
[ Upstream commit ffd9a1ba9fdb7f2bd1d1ad9b9243d34e96756ba2 ] DMA got broken a while back in two different ways: 1) a change in the behaviour of disable_irq() to wait for the interrupt to finish executing causes us to deadlock at the end of DMA. 2) a change to avoid modifying the scatterlist left the first transfer uninitialised. DMA is only used with expansion cards, so has gone unnoticed. Fixes: fa4e99899932 ("[ARM] dma: RiscPC: don't modify DMA SG entries") Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Sasha Levin <sashal@kernel.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27ARM: rpc: rename RAM_SIZE macroArnd Bergmann
The RAM_SIZE macro in mach/hardware.h conflicts with macros of the same name in multiple drivers, leading to annoying build warnings: In file included from drivers/net/ethernet/cirrus/cs89x0.c:79:0: drivers/net/ethernet/cirrus/cs89x0.h:324:0: error: "RAM_SIZE" redefined [-Werror] #define RAM_SIZE 0x1000 /* The card has 4k bytes or RAM */ ^ In file included from /git/arm-soc/arch/arm/mach-rpc/include/mach/io.h:16:0, from /git/arm-soc/arch/arm/include/asm/io.h:194, from /git/arm-soc/include/linux/scatterlist.h:8, from /git/arm-soc/include/linux/dmaengine.h:24, from /git/arm-soc/include/linux/netdevice.h:38, from /git/arm-soc/drivers/net/ethernet/cirrus/cs89x0.c:54: arch/arm/mach-rpc/include/mach/hardware.h:28:0: note: this is the location of the previous definition #define RAM_SIZE 0x10000000 We don't use RAM_SIZE/RAM_START at all, so we could just remove them, but it might be nice to leave them for documentation purposes, so this renames them to RPC_RAM_SIZE/RPC_RAM_START in order to avoid the build warnings Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-06-14arm: mach-rpc: ecard: fix build errorGreg Kroah-Hartman
The last commit from me had a missing ';' which broke the build. Thanks to Arnd for pointing out the issue. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-10arm: ecard: fix dev_groups patch typoGreg Kroah-Hartman
Commit 71d1e5d71cec ("arm: ecard: use dev_groups and not dev_attrs for bus_type") had a typo in the resource attribute definition. Fix that up. Reported-by: kbuild test robot <fengguang.wu@intel.com> Fixes: 71d1e5d71cec ("arm: ecard: use dev_groups and not dev_attrs for bus_type") Cc: Russell King <linux@armlinux.org.uk> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
2017-06-09arm: ecard: use dev_groups and not dev_attrs for bus_typeGreg Kroah-Hartman
The dev_attrs field has long been "depreciated" and is finally being removed, so move the driver to use the "correct" dev_groups field instead for struct bus_type. Cc: Russell King <linux@armlinux.org.uk> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/mm.h> We are going to split <linux/sched/mm.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/mm.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. The APIs that are going to be moved first are: mm_alloc() __mmdrop() mmdrop() mmdrop_async_fn() mmdrop_async() mmget_not_zero() mmput() mmput_async() get_task_mm() mm_access() mm_release() Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-26ARM: document and update UNCACHEABLE_ADDR definitionsRussell King
Document the UNCACHEABLE_ADDR definitions for footbridge and SA1100 so that we know where they're located and/or what they're accessing. Change RiscPC to calculate the UNCACHEABLE_ADDR value from FLUSH_BASE as that's where we locate that. UNCACHEABLE_ADDR is used to perform an uncached access (ARMv4 terminology) necessary to force a CPU clock-switch to the memory- speed clock, as required for entering WFI. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2016-02-22ARM: 8532/1: uncompress: mark putc as inlineArnd Bergmann
When CONFIG_DEBUG_ICEDCC is set, we don't use the platform specific putc() function, but use icedcc_putc() instead, so putc is unused and causes a compile time warning: In file included from ../arch/arm/boot/compressed/misc.c:28:0: arch/arm/mach-rpc/include/mach/uncompress.h:79:13: warning: 'putc' defined but not used [-Wunused-function] arch/arm/mach-w90x900/include/mach/uncompress.h:30:13: warning: 'putc' defined but not used [-Wunused-function] On most platforms, this does not happen, because putc is defined as 'static inline' so the compiler will automatically drop it when it's unused. This changes the remaining seven platforms to behave the same way. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-07-28ARM: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Gregory Clement <gregory.clement@free-electrons.com> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Imre Kaloz <kaloz@openwrt.org> Acked-by: Krzysztof Halasa <khalasa@piap.pl> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Tony Lindgren <tony@atomide.com> Cc: Daniel Mack <daniel@zonque.org> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Simtec Linux Team <linux@simtec.co.uk> Cc: Kukjin Kim <kgene@kernel.org> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-02kbuild: remove unnecessary variable initializaionsMasahiro Yamada
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is a useless habit. They are non-exported variables; therefore they are always empty whenever descending into each subdirectory. (Moreorver, obj-y and obj-m are also set to empty at the beginning of scripts/Makefile.build) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-29ARM: 8113/1: remove remaining definitions of PLAT_PHYS_OFFSET from ↵Uwe Kleine-König
<mach/memory.h> The platforms selecting NEED_MACH_MEMORY_H defined the start address of their physical memory in the respective <mach/memory.h>. With ARM_PATCH_PHYS_VIRT=y (which is quite common today) this is useless though because the definition isn't used but determined dynamically. So remove the definitions from all <mach/memory.h> and provide the Kconfig symbol PHYS_OFFSET with the respective defaults in case ARM_PATCH_PHYS_VIRT isn't enabled. This allows to drop the dependency of PHYS_OFFSET on !NEED_MACH_MEMORY_H which prevents compiling an integrator nommu-kernel. (CONFIG_PAGE_OFFSET which has "default PHYS_OFFSET if !MMU" expanded to "0x" because CONFIG_PHYS_OFFSET doesn't exist as INTEGRATOR selects NEED_MACH_MEMORY_H.) Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-03-12ARM: 8000/1: misc: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch removes the use of the IRQF_DISABLED flag from miscellaneous code in mach-xxx and plat-xxx This flag is a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-12-20ARM: rpc: stop using <mach/timex.h>Uwe Kleine-König
The rpc timekeeping code uses the symbol LATCH which depends on CLOCK_TICK_RATE which is defined in rpc's <mach/timex.h>. As this header will go away in a later patch introduce a local variable holding the same value as LATCH and use that instead. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-08-25ARM: debug: move 8250 debug include into arch/arm/include/debug/Russell King
Now that the 8250 debug include can stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart register shift configuration optionRussell King
Move the definition of the UART register shift out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart flow control configuration optionRussell King
Move the definition out of the machine class debug-macro.S header into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-24ARM: set arch_gettimeoffset directlyStephen Warren
remove ARM's struct sys_timer .offset function pointer, and instead directly set the arch_gettimeoffset function pointer when the timer driver is initialized. This requires multiplying all function results by 1000, since the removed arm_gettimeoffset() did this. Also, s/unsigned long/u32/ just to make the function prototypes exactly match that of arch_gettimeoffset. Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-07ARM: rpc: check device_register return code in ecard_probeArnd Bergmann
device_register is marked __must_check, so we better propagate the error value by returning it from ecard_probe. Without this patch, building rpc_defconfig results in: arch/arm/mach-rpc/ecard.c: In function 'ecard_probe': arch/arm/mach-rpc/ecard.c:963:17: warning: ignoring return value of 'device_register', declared with attribute warn_unused_result [-Wunused-result] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-01ARM: fiq: change FIQ_START to a variableShawn Guo
The commit a2be01b (ARM: only include mach/irqs.h for !SPARSE_IRQ) makes mach/irqs.h only be included for !SPARSE_IRQ build. There are a nubmer of platforms have FIQ_START defined in mach/irqs.h for FIQ support. arch/arm/mach-rpc/include/mach/irqs.h:#define FIQ_START 64 arch/arm/mach-s3c24xx/include/mach/irqs.h:#define FIQ_START IRQ_EINT0 arch/arm/plat-mxc/include/mach/irqs.h:#define FIQ_START 0 If SPARSE_IRQ is enabled for any of these platforms, the following compile error will be seen. arch/arm/kernel/fiq.c: In function ‘enable_fiq’: arch/arm/kernel/fiq.c:127:19: error: ‘FIQ_START’ undeclared (first use in this function) arch/arm/kernel/fiq.c:127:19: note: each undeclared identifier is reported only once for each function it appears in arch/arm/kernel/fiq.c: In function ‘disable_fiq’: arch/arm/kernel/fiq.c:132:20: error: ‘FIQ_START’ undeclared (first use in this function) The patch changes fiq code to have init_FIQ take FIQ_START from platforms as a parameter and assign it to variable fiq_start which is to replace FIQ_START uses in enable_fiq/disable_fiq. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Rob Herring <rob.herring@calxeda.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-27Merge branch 'platforms' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM platform updates from Russell King: "This covers platform stuff for platforms I have a direct interest in (iow, I have the hardware). Essentially: - as we no longer support any other Acorn platforms other than RiscPC anymore, we can collect all that code into mach-rpc. - convert Acorn expansion card stuff to use IRQ allocation functions, and get rid of NO_IRQ from there. - cleanups to the ebsa110 platform to move some private stuff out of its header files. - large amount of SA11x0 updates: - conversion of private DMA implementation to DMA engine support (this actually gives us greater flexibility in drivers over the old API.) - re-worked ucb1x00 updates - convert to genirq, remove sa11x0 dependencies, fix various minor issues - move platform specific sa11x0 framebuffer data into platform files in arch/arm instead of keeping this in the driver itself - update sa11x0 IrDA driver for DMA engine, and allow it to use DMA for SIR transmissions as well as FIR - rework sa1111 support for genirq, and irq allocation - fix sa1111 IRQ support so it works again - use sparse IRQ support After this, I have one more pull request remaining from my current set, which I think is going to be the most problematical as it generates 8 conflicts." Fixed up the trivial conflict in arch/arm/mach-rpc/Makefile as per Russell. * 'platforms' of git://git.linaro.org/people/rmk/linux-arm: (125 commits) ARM: 7343/1: sa11x0: convert to sparse IRQ ARM: 7342/2: sa1100: prepare for sparse irq conversion ARM: 7341/1: input: prepare jornada720 keyboard and ts for sa11x0 sparse irq ARM: 7340/1: rtc: sa1100: include mach/irqs.h instead of asm/irq.h ARM: sa11x0: remove unused DMA controller definitions ARM: sa11x0: remove old SoC private DMA driver USB: sa1111: add hcd .reset method USB: sa1111: add OHCI shutdown methods USB: sa1111: reorganize ohci-sa1111.c USB: sa1111: get rid of nasty printk(KERN_DEBUG "%s: ...", __FILE__) USB: sa1111: sparse and checkpatch cleanups ARM: sa11x0: don't static map sa1111 ARM: sa1111: use dev_err() rather than printk() ARM: sa1111: cleanup sub-device registration and unregistration ARM: sa1111: only setup DMA for DMA capable devices ARM: sa1111: register sa1111 devices with dmabounce in bus notifier ARM: sa1111: move USB interface register definitions to ohci-sa1111.c ARM: sa1111: move PCMCIA interface register definitions to sa1111_generic.c ARM: sa1111: move PS/2 interface register definitions to sa1111p2.c ARM: sa1111: delete unused physical GPIO register definitions ...
2012-03-24ARM: ecard: get rid of NO_IRQ madnessRussell King
Get rid of the NO_IRQ madness from Acorn expansion card handling code. Thankfully, are relatively few users of this here, and so it's easy to audit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: use DEFINE_RES_xxx()Russell King
Use DEFINE_RES_xxx() to define device resources. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: remove expansion card irq mask registerRussell King
This register is only present on older platforms, and not on RiscPC, so lets remove this unused support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: convert ecard to use irq_alloc_descs()Russell King
Use irq_alloc_descs() to allocate IRQs for expansion cards. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: use irq chip data in ecard.cRussell King
Use irq chip data to store the expansion card data pointer, rather than converting from the interrupt number to a slot number. This allows the interrupt chip methods to avoid knowing about interrupt numbering. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: move ecard.c to arch/arm/mach-rpcRussell King
RiscPC is the only platform using the Acorn expansion card support, so move it into its mach-* directory. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: remove IRQ_TIMERRussell King
Use IRQ_TIMER0 instead, which is the same thing. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: use definition for serial port interruptRussell King
Rather than using a plain integer, use the definition already provided. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: pass IRQ resources into keyboard driverRussell King
Rather than including asm/irq.h into the keyboard driver, pass the IRQ numbers via the platform device instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-24ARM: riscpc: move time-acorn.c to mach-rpcRussell King
Nothing but RiscPC makes use of the Acorn timekeeping code, so move it into mach-rpc. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-13ARM: create a common IOMEM definitionRob Herring
Several platforms create IOMEM defines for casting to 'void __iomem *', and other platforms are incorrectly using __io() macro for the same purpose. This creates a common definition and removes all the platform specific versions. Rather than try to make linux/io.h and asm/io.h assembly safe, the assembly version of IOMEM is moved into asm/assembler.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Paul Walmsley <paul@pwsan.com> Acked-by: Viresh Kumar <viresh.kumar@st.com> Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-03-06ARM: kill off __mem_pciRob Herring
__mem_pci is only used to enable readl/writel and friends. Just condition this on readl being defined and remove all the __mem_pci defines. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Nicolas Pitre <nico@fluxnic.net> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Stephen Warren <swarren@nvidia.com>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-02-21ARM: rpc: make default fiq handler run-time installedRob Herring
Only rpc uses disable_fiq macro. Change it to a run-time installed default FIQ handler. The handler is installed before FIQ is enabled so the behavior should be unchanged. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
