[ Upstream commit 63a0666bca9311f35017be454587f3ba903644b8 ]
Fix lack of keyboard interrupts for RiscPC due to incorrect conversion.
Fixes: e8d36d5dbb6a ("ARM: kill off set_irq_flags usage")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit ffd9a1ba9fdb7f2bd1d1ad9b9243d34e96756ba2 ]
DMA got broken a while back in two different ways:
1) a change in the behaviour of disable_irq() to wait for the interrupt
to finish executing causes us to deadlock at the end of DMA.
2) a change to avoid modifying the scatterlist left the first transfer
uninitialised.
DMA is only used with expansion cards, so has gone unnoticed.
Fixes: fa4e99899932 ("[ARM] dma: RiscPC: don't modify DMA SG entries")
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is
a useless habit.
They are non-exported variables; therefore they are always empty
whenever descending into each subdirectory.
(Moreorver, obj-y and obj-m are also set to empty at the beginning
of scripts/Makefile.build)
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Peter Foley <pefoley2@pefoley.com>
<mach/memory.h>
The platforms selecting NEED_MACH_MEMORY_H defined the start address of
their physical memory in the respective <mach/memory.h>. With
ARM_PATCH_PHYS_VIRT=y (which is quite common today) this is useless
though because the definition isn't used but determined dynamically.
So remove the definitions from all <mach/memory.h> and provide the
Kconfig symbol PHYS_OFFSET with the respective defaults in case
ARM_PATCH_PHYS_VIRT isn't enabled.
This allows to drop the dependency of PHYS_OFFSET on !NEED_MACH_MEMORY_H
which prevents compiling an integrator nommu-kernel.
(CONFIG_PAGE_OFFSET which has "default PHYS_OFFSET if !MMU" expanded to
"0x" because CONFIG_PHYS_OFFSET doesn't exist as INTEGRATOR selects
NEED_MACH_MEMORY_H.)
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
This patch removes the use of the IRQF_DISABLED flag
from miscellaneous code in mach-xxx and plat-xxx
This flag is a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Acked-by: Greg Ungerer <gerg@uclinux.org>
While <mach/timex.h> isn't used for multi-platform builds since long it
still is for "normal" builds. As the previous patches fix all sites to
not make use of this per-platform file, it can go now for good also for
platforms that are not (yet) converted to multi-platform.
While at it there are no users of CLOCK_TICK_RATE any more, so also drop
the dummy #define.
The rpc timekeeping code uses the symbol LATCH which depends on
CLOCK_TICK_RATE which is defined in rpc's <mach/timex.h>. As this header
will go away in a later patch introduce a local variable holding the
same value as LATCH and use that instead.
Now that the 8250 debug include can stand alone without requiring
platforms to provide any macros, move it into the debug directory
so it can be directly included. This allows us to get rid of a lot
of debug-macros include files.
Move the definition of the UART register addresses out of the platform
specific header file into the Kconfig files.
Move the definition of the UART register shift out of the platform
Move the definition out of the machine class debug-macro.S header
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup
From Shawn Guo:
The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which
are unused on ARM architecure. Samsung has some code setting up wdog
in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined
nowhere, it will not run. Otherwise, system can not boot at all when
wdog is set up but no one pats it.
* tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: samsung: remove unused arch_decomp_wdog() code
ARM: remove unused arch_decomp_wdog()
ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c,
all the arch_decomp_wdog() definition at platform level is unneeded.
Remmove it.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
remove ARM's struct sys_timer .offset function pointer, and instead
directly set the arch_gettimeoffset function pointer when the timer
driver is initialized. This requires multiplying all function results
by 1000, since the removed arm_gettimeoffset() did this. Also,
s/unsigned long/u32/ just to make the function prototypes exactly
match that of arch_gettimeoffset.
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
device_register is marked __must_check, so we better propagate the error
value by returning it from ecard_probe.
Without this patch, building rpc_defconfig results in:
arch/arm/mach-rpc/ecard.c: In function 'ecard_probe':
arch/arm/mach-rpc/ecard.c:963:17: warning: ignoring return value of 'device_register', declared with attribute warn_unused_result [-Wunused-result]
The commit a2be01b (ARM: only include mach/irqs.h for !SPARSE_IRQ)
makes mach/irqs.h only be included for !SPARSE_IRQ build. There are
a nubmer of platforms have FIQ_START defined in mach/irqs.h for FIQ
support.
arch/arm/mach-rpc/include/mach/irqs.h:#define FIQ_START 64
arch/arm/mach-s3c24xx/include/mach/irqs.h:#define FIQ_START IRQ_EINT0
arch/arm/plat-mxc/include/mach/irqs.h:#define FIQ_START 0
If SPARSE_IRQ is enabled for any of these platforms, the following
compile error will be seen.
arch/arm/kernel/fiq.c: In function ‘enable_fiq’:
arch/arm/kernel/fiq.c:127:19: error: ‘FIQ_START’ undeclared (first use in this function)
arch/arm/kernel/fiq.c:127:19: note: each undeclared identifier is reported only once for each function it appears in
arch/arm/kernel/fiq.c: In function ‘disable_fiq’:
arch/arm/kernel/fiq.c:132:20: error: ‘FIQ_START’ undeclared (first use in this function)
The patch changes fiq code to have init_FIQ take FIQ_START from
platforms as a parameter and assign it to variable fiq_start which
is to replace FIQ_START uses in enable_fiq/disable_fiq.
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Pull "ARM: cleanups of io includes" from Olof Johansson:
"Rob Herring has done a sweeping change cleaning up all of the
mach/io.h includes, moving some of the oft-repeated macros to a common
location and removing a bunch of boiler plate. This is another step
closer to a common zImage for multiple platforms."
Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes
around it, tegra localtimer.o is *still* gone, yadda-yadda).
* tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: tegra: Include assembler.h in sleep.S to fix build break
ARM: pxa: use common IOMEM definition
ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol
ARM: __io abuse cleanup
ARM: create a common IOMEM definition
ARM: iop13xx: fix missing declaration of iop13xx_init_early
ARM: fix ioremap/iounmap for !CONFIG_MMU
ARM: kill off __mem_pci
ARM: remove bunch of now unused mach/io.h files
ARM: make mach/io.h include optional
ARM: clps711x: remove unneeded include of mach/io.h
ARM: dove: add explicit include of dove.h to addr-map.c
ARM: at91: add explicit include of hardware.h to uncompressor
ARM: ep93xx: clean-up mach/io.h
ARM: tegra: clean-up mach/io.h
ARM: orion5x: clean-up mach/io.h
ARM: davinci: remove unneeded mach/io.h include
[media] davinci: remove includes of mach/io.h
ARM: OMAP: Remove remaining includes for mach/io.h
ARM: msm: clean-up mach/io.h
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
Pull ARM platform updates from Russell King:
"This covers platform stuff for platforms I have a direct interest in
(iow, I have the hardware). Essentially:
- as we no longer support any other Acorn platforms other than RiscPC
anymore, we can collect all that code into mach-rpc.
- convert Acorn expansion card stuff to use IRQ allocation functions,
and get rid of NO_IRQ from there.
- cleanups to the ebsa110 platform to move some private stuff out of
its header files.
- large amount of SA11x0 updates:
- conversion of private DMA implementation to DMA engine support
(this actually gives us greater flexibility in drivers over the old
API.)
- re-worked ucb1x00 updates - convert to genirq, remove sa11x0
dependencies, fix various minor issues
- move platform specific sa11x0 framebuffer data into platform files
in arch/arm instead of keeping this in the driver itself
- update sa11x0 IrDA driver for DMA engine, and allow it to use DMA
for SIR transmissions as well as FIR
- rework sa1111 support for genirq, and irq allocation
- fix sa1111 IRQ support so it works again
- use sparse IRQ support
After this, I have one more pull request remaining from my current
set, which I think is going to be the most problematical as it
generates 8 conflicts."
Fixed up the trivial conflict in arch/arm/mach-rpc/Makefile as per
Russell.
* 'platforms' of git://git.linaro.org/people/rmk/linux-arm: (125 commits)
ARM: 7343/1: sa11x0: convert to sparse IRQ
ARM: 7342/2: sa1100: prepare for sparse irq conversion
ARM: 7341/1: input: prepare jornada720 keyboard and ts for sa11x0 sparse irq
ARM: 7340/1: rtc: sa1100: include mach/irqs.h instead of asm/irq.h
ARM: sa11x0: remove unused DMA controller definitions
ARM: sa11x0: remove old SoC private DMA driver
USB: sa1111: add hcd .reset method
USB: sa1111: add OHCI shutdown methods
USB: sa1111: reorganize ohci-sa1111.c
USB: sa1111: get rid of nasty printk(KERN_DEBUG "%s: ...", __FILE__)
USB: sa1111: sparse and checkpatch cleanups
ARM: sa11x0: don't static map sa1111
ARM: sa1111: use dev_err() rather than printk()
ARM: sa1111: cleanup sub-device registration and unregistration
ARM: sa1111: only setup DMA for DMA capable devices
ARM: sa1111: register sa1111 devices with dmabounce in bus notifier
ARM: sa1111: move USB interface register definitions to ohci-sa1111.c
ARM: sa1111: move PCMCIA interface register definitions to sa1111_generic.c
ARM: sa1111: move PS/2 interface register definitions to sa1111p2.c
ARM: sa1111: delete unused physical GPIO register definitions
Get rid of the NO_IRQ madness from Acorn expansion card handling code.
Thankfully, are relatively few users of this here, and so it's easy to
audit.
Use DEFINE_RES_xxx() to define device resources.
This register is only present on older platforms, and not on RiscPC,
so lets remove this unused support.
Use irq_alloc_descs() to allocate IRQs for expansion cards.
Use irq chip data to store the expansion card data pointer, rather
than converting from the interrupt number to a slot number. This
allows the interrupt chip methods to avoid knowing about interrupt
numbering.
RiscPC is the only platform using the Acorn expansion card support, so
move it into its mach-* directory.
Use IRQ_TIMER0 instead, which is the same thing.
Rather than using a plain integer, use the definition already provided.
Rather than including asm/irq.h into the keyboard driver, pass the
IRQ numbers via the platform device instead.
Nothing but RiscPC makes use of the Acorn timekeeping code, so move
it into mach-rpc.
Several platforms create IOMEM defines for casting to 'void __iomem *',
and other platforms are incorrectly using __io() macro for the same
purpose. This creates a common definition and removes all the platform
specific versions. Rather than try to make linux/io.h and asm/io.h
assembly safe, the assembly version of IOMEM is moved into
asm/assembler.h.
Cc: Kevin Hilman <khilman@ti.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Paul Walmsley <paul@pwsan.com>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Stephen Warren <swarren@nvidia.com>
__mem_pci is only used to enable readl/writel and friends. Just condition
this on readl being defined and remove all the __mem_pci defines.
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Nicolas Pitre <nico@fluxnic.net>
into for-armsoc
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Only rpc uses disable_fiq macro. Change it to a run-time installed
default FIQ handler. The handler is installed before FIQ is enabled
so the behavior should be unchanged.
When this is the only content remaining in mach/system.h then the
whole file is removed.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com>
arch/arm/mach-exynos/cpu.c
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Remove the now empty arch_reset() from all the mach/system.h includes,
and remove its callsite. Remove arm_machine_restart() as this function
no longer does anything useful.
For samsung platforms, remove the include of mach/system-reset.h and
plat/system-reset.h from their respective mach/system.h headers as these
just define their arch_reset functions. As a result, the s3c2410 and
plat-samsung system-reset.h files are no longer referenced, so remove
these files entirely.
Hook the RiscPC restart code into the new restart hook.
devel-stable
We only need to set the system up for a soft-restart if we're going to
be doing a soft-restart. Provide a new function (soft_restart()) which
does the setup and final call for this, and make platforms use it.
Eliminate the call to setup_restart() from the default handler.
This means that platforms arch_reset() function is no longer called with
the page tables prepared for a soft-restart, and caches will still be
enabled.
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
arch/arm/mach-integrator/integrator_ap.c
Boards used to specify zreladdr in their Makefile.boot with
zreladdr-y := x, so conflicting zreladdrs were silently overwritten.
This patch changes this to zreladdr-y += x, so that we end
up with multiple words in zreladdr in such a case. We can
detect this later and complain if necessary.
