path: root/arch/arm/mach-rpc
2008-02-06Rename: linux/pata_platform.h to linux/ata_platform.hJeff Garzik
2007-07-20[ARM] rpc: convert an outb() to writeb()Russell King
2007-05-03[ARM] Add platform support for PATA on RiscPCRussell King
Add pata_platform device for RiscPC, thereby converting the primary IDE channel on the machine to PATA. Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] Remove '__address' from scatterlist and convert to DMA APIRussell King
The old __address element in struct scatterlist remained from older kernels because the ARM DMA emulation code made use of it. Move this field into struct dma_struct, and convert DMA emulation code to setup a SG entry as required. Also, convert DMA emulation code to use the new DMA API rather than the PCI DMA API. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2989/1: Replace map_desc.physical with map_desc.pfn: RiscPCDeepak Saxena
Patch from Deepak Saxena RiscPC map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-22[PATCH] ARM: Allow riscpc to parse "acorn" boot info tagRussell King
