path: root/arch/arm/mach-s3c2410
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-05Merge branch 'next/devel2' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/devel2' of git://git.linaro.org/people/arnd/arm-soc: (30 commits) ARM: mmp: register internal sram bank ARM: mmp: register audio sram bank ARM: mmp: add sram allocator gpio/samsung: Complain loudly if we don't know the SoC ARM: S3C64XX: Fix SoC identification for S3C64xx devices ARM: S3C2443: Remove redundant s3c_register_clocks call for init_clocks ARM: S3C24XX: Add devname for hsmmc1 pclk ARM: S3C24XX: use clk_get_rate to init fclk in common_setup_clocks ARM: S3C2443: Accommodate cpufreq frequency scheme in armdiv ARM: S3C2443: handle unset armdiv values gracefully ARM: S3C2443: Add get_rate operation for clk_armdiv ARM: S3C2416: Add comment describing the armdiv/armclk ARM: S3C2443: Move clk_arm and clk_armdiv to common code ARM: S3C24XX: Add infrastructure to transmit armdiv to common code ARM: S3C2416: Add armdiv_mask constant ARM: EXYNOS4: Add support for M-5MOLS camera on Nuri board ARM: EXYNOS4: Enable MFC on ORIGEN ARM: SAMSUNG: Add support s3c2416-adc for S3C2416/S3C2450 ARM: SAMSUNG: Add support s3c2443-adc for S3C2443 ARM: SAMSUNG: Allow overriding of adc device name for S3C24XX ...
2011-11-05Merge branch 'next/cleanup3' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup3' of git://git.linaro.org/people/arnd/arm-soc: (79 commits) ARM: SAMSUNG: Move fimc plat. device from board files to plat-samsung ARM: SAMSUNG: Cleanup resources by using macro ARM: SAMSUNG: Cleanup plat-samsung/devs.c and devs.h ARM: S5P: To merge devs.c files to one devs.c ARM: S3C64XX: To merge devs.c files to one devs.c ARM: S3C24XX: To merge s3c24xx devs.c files to one devs.c ARM: S5P64X0: Add Power Management support ARM: S5P: Make the sleep code common for S5P series SoCs ARM: S5P: Make the common S5P PM code conditionally compile ARM: SAMSUNG: Move S5P header files to plat-samsung ARM: SAMSUNG: Move S3C24XX header files to plat-samsung ARM: SAMSUNG: Moving each SoC support header files ARM: SAMSUNG: Consolidate plat/pll.h ARM: SAMSUNG: Consolidate plat/pwm-clock.h ARM: SAMSUNG: Cleanup mach/clkdev.h ARM: SAMSUNG: remove sdhci default configuration setup platform helper ARM: EXYNOS4: Add FIMC device on SMDKV310 board ARM: EXYNOS4: Add header file protection macros ARM: EXYNOS4: Add usb ehci device to the SMDKV310 ARM: S3C2443: Add hsspi-clock from pclk and rename S3C2443 hsspi sclk ... Fix up conflicts in - arch/arm/mach-exynos4/{Kconfig,clock.c} ARM_CPU_SUSPEND, various random device tables (gah!) - drivers/gpio/Makefile sa1100 gpio added, samsung gpio drivers merged
2011-11-04Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (63 commits) dmaengine: mid_dma: mask_peripheral_interrupt only when dmac is idle dmaengine/ep93xx_dma: add module.h include pch_dma: Reduce wasting memory pch_dma: Fix suspend issue dma/timberdale: free_irq() on an error path dma: shdma: transfer based runtime PM dmaengine: shdma: protect against the IRQ handler dmaengine i.MX DMA/SDMA: add missing include of linux/module.h dmaengine: delete redundant chan_id and chancnt initialization in dma drivers dmaengine/amba-pl08x: Check txd->llis_va before freeing dma_pool dmaengine/amba-pl08x: Add support for sg len greater than one for slave transfers serial: sh-sci: don't filter on DMA device, use only channel ID ARM: SAMSUNG: Remove Samsung specific enum type for dma direction ASoC: Samsung: Update DMA interface spi/s3c64xx: Merge dma control code spi/s3c64xx: Add support DMA engine API ARM: SAMSUNG: Remove S3C-PL330-DMA driver ARM: S5P64X0: Use generic DMA PL330 driver ARM: S5PC100: Use generic DMA PL330 driver ARM: S5PV210: Use generic DMA PL330 driver ... Fix up fairly trivial conflicts in - arch/arm/mach-exynos4/{Kconfig,clock.c} - arch/arm/mach-s5p64x0/dma.c
2011-11-01Merge branch 'next/cleanup' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits) ARM: mach-mxs: fix machines' initializers order mmc: mxcmmc: explicitly includes mach/hardware.h arm/imx: explicitly includes mach/hardware.h in pm-imx27.c arm/imx: remove mx27_setup_weimcs() from mx27.h arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c arm/imx: remove mx31_setup_weimcs() from mx31.h ARM: tegra: devices.c should include devices.h ARM: tegra: cpu-tegra: unexport two functions ARM: tegra: cpu-tegra: sparse type fix ARM: tegra: dma: staticify some tables and functions ARM: tegra: tegra2_clocks: don't export some tables ARM: tegra: tegra_powergate_is_powered should be static ARM: tegra: tegra_rtc_read_ms should be static ARM: tegra: tegra_init_cache should be static ARM: tegra: pcie: 0 -> NULL changes ARM: tegra: pcie: include board.h ARM: tegra: pcie: don't cast __iomem pointers ARM: tegra: tegra2_clocks: 0 -> NULL changes ARM: tegra: tegra2_clocks: don't cast __iomem pointers ARM: tegra: timer: don't cast __iomem pointers ... Fix up trivial conflicts in arch/arm/mach-omap2/Makefile, arch/arm/mach-u300/{Makefile.boot,core.c} arch/arm/plat-{mxc,omap}/devices.c
2011-11-01Merge branch 'depends/rmk/memory_h' into next/cleanup2Arnd Bergmann
There are lots of conflicts between the omap and exynos cleanups and the memory.h remove series. Conflicts: arch/arm/mach-exynos4/mach-smdkc210.c arch/arm/mach-exynos4/mach-smdkv310.c arch/arm/mach-imx/mach-cpuimx27.c arch/arm/mach-omap1/board-ams-delta.c arch/arm/mach-omap1/board-generic.c arch/arm/mach-omap1/board-h2.c arch/arm/mach-omap1/board-h3.c arch/arm/mach-omap1/board-nokia770.c arch/arm/mach-omap1/board-osk.c arch/arm/mach-omap1/board-palmte.c arch/arm/mach-omap1/board-palmtt.c arch/arm/mach-omap1/board-palmz71.c arch/arm/mach-omap1/board-sx1.c arch/arm/mach-omap1/board-voiceblue.c arch/arm/mach-omap1/io.c arch/arm/mach-omap2/board-generic.c arch/arm/mach-omap2/io.c arch/arm/plat-omap/io.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-31arm: Add export.h to ARM specific files as required.Paul Gortmaker
These files all make use of one of the EXPORT_SYMBOL variants or the THIS_MODULE macro. So they will need <linux/export.h> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31Merge branch 'next/fixes' into next/cleanupArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/gpio.h arch/arm/plat-mxc/include/mach/gpio.h drivers/video/omap/lcd_apollon.c drivers/video/omap/lcd_ldp.c drivers/video/omap/lcd_overo.c
2011-10-31Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
Fix up all conflicts between the memory.h cleanup and bug fixes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-30Merge branch 'pxa/devel' into next/devel2Arnd Bergmann
Conflicts: arch/arm/mach-s3c2416/s3c2416.c
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-25Merge branch 'misc' into for-linusRussell King
Conflicts: arch/arm/mach-integrator/integrator_ap.c
2011-10-25Merge branches 'arnd-randcfg-fixes', 'debug', 'io' (early part), 'l2x0', ↵Russell King
'p2v', 'pgt' (early part) and 'smp' into for-linus
2011-10-22ARM: S3C24XX: Fix s3c24xx build errors if !CONFIG_PMDomenico Andreoli
v2: - register_syscore_ops(&s3c24xx_irq_syscore_ops) does not need to be conditionally compiled out, it is already optimized out on !CONFIG_PM - fix also s3c2412 and s3c2416 affected by the same build issue v1: s3c2440.c fails to build if !CONFIG_PM because in such case s3c2410_pm_syscore_ops is not defined. Same error should happen also in s3c2410.c and s3c2442.c Signed-off-by: Domenico Andreoli <cavokz@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-14ARM: S3C2416: Add armdiv_mask constantHeiko Stuebner
The S3C2416/2450 has only 3 bits for the armdiv setting instead of the 4 bits of the S3C2443. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-13ARM: mach-s3c2410: remove memory.hNicolas Pitre
This also removes the mach/s3c2400 version which was probably never used due to the fact that we have this line in arch/arm/Makefile: machine-$(CONFIG_ARCH_S3C2410) := s3c2410 s3c2400 [...] This is later used to construct the search path for: The compiler would be looking into mach-s3c2410 and picking up this version first. Any config that was actually expecting the mach-s3c2400 version was therefore producing a broken kernel binary. Not relying on any of them anymore would fix that issue. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-10-12ARM: S3C2410: fix S3C_GPIO_SPACE #error message to match realityPeter Korsgaard
S3C_GPIO_SPACE cannont be NON-zero, not zero. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-10-06ARM: SAMSUNG: Cleanup resources by using macroKukjin Kim
This patch cleans up the Samsung resources in plat-samsung/devs.c by using defined helpers at <linux/ioport.h>. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-06ARM: S3C24XX: To merge s3c24xx devs.c files to one devs.cKukjin Kim
This patch moves regarding s3c24xx dev files to one devs.c file in plat-samsung directory and this is required to merge to plat-samsung. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-04Merge branch 'next-samsung-cleanup-2' into next-samsung-devel-2Kukjin Kim
Conflicts: arch/arm/plat-s5p/include/plat/pll.h
2011-10-04Merge branch 'next-samsung-devel' into next-samsung-devel-2Kukjin Kim
Conflicts: arch/arm/mach-exynos4/clock.c arch/arm/mach-s3c2412/gpio.c arch/arm/mach-s5p64x0/dma.c arch/arm/mach-s5p64x0/gpiolib.c
2011-10-04ARM: SAMSUNG: Consolidate plat/pll.hKukjin Kim
Removed - arch/arm/plat-s3c24xx/include/plat/pll.h - arch/arm/mach-s3c64xx/include/mach/pll.h - arch/arm/plat-s5p/include/plat/pll.h - arch/arm/plat-samsung/include/plat/pll6553x.h And created - arch/arm/plat-samsung/include/plat/pll.h Cc: Ben Dooks <ben-linux@fluff.org> [kgene.kim@samsung.com: changed title] [kgene.kim@samsung.com: fixed conflicts in plat-s5p/include/pll.h] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-04ARM: S3C2443: Define constant for HSSPI pclkHeiko Stuebner
It's the same clock for 2443/2416/2450. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-10-04Merge branch 'next/topic-gpio-samsung' into next-samsung-develKukjin Kim
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-21ARM: SAMSUNG: Remove useless Samsung GPIO related CONFIGsKukjin Kim
2011-09-21ARM: SAMSUNG: Update the name of regarding Samsung GPIOKukjin Kim
According to gpio-samsung.c, this patch updates the name of regarding Samsung GPIO. Basically the samsung_xxx prefix is used in gpio-samsung.c instead of s3c_xxx, because unified name can reduce its complexity. Note: some s3c_xxx stil remains because it is used widely. It will be updated next time. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-21gpio/s3c24xx: move gpio driver into drivers/gpio/Kukjin Kim
Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-17Merge branch 'next/topic-plat-samsung-1' into next-samsung-cleanupKukjin Kim
2011-09-16ARM: SAMSUNG: Move map header file into plat-samsungKukjin Kim
This is required to work consolidation Samsung platform. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-16ARM: S3C24XX: remove unused gpio codesKukjin Kim
Cc: Ben Dooks <ben-linux@fluff.org> [kgene.kim@samsung.com: fix build error] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-16ARM: S3C24XX: Remove hw_addr from s3c24xx dma channel declarationsHeiko Stuebner
According to commit c4806174c516d26bf4a72db1789cfc96e4950d07 (ARM: S3C2412: DMA: Remove I2S FIFO address) the S3C DMA API does not make use of hw_addr.to/from declared for some of the channels in mach-s3c24XX/dma.c Grepping through the kernel also did non reveal any new users of these properties since the mentioned commit. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-14ARM: SAMSUNG: Remove Samsung specific enum type for dma directionBoojin Kim
This patch removes the samsung specific enum type 's3c2410_dmasrc' and uses 'dma_data_direction' instead. Signed-off-by: Boojin Kim <boojin.kim@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-09-14ASoC: Samsung: Update DMA interfaceBoojin Kim
This patch adds to support the DMA PL330 driver that uses DMA generic API. Samsung sound driver uses DMA generic API if architecture supports it. Otherwise, use samsung specific S3C-PL330 API driver to transfer PCM data. Signed-off-by: Boojin Kim <boojin.kim@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: Jassi Brar <jassisinghbrar@gmail.com> Cc: Liam Girdwood <lrg@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [kgene.kim@samsung.com: removed useless variable] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-09-14ARM: SAMSUNG: Add common DMA operationsBoojin Kim
This patch adds common DMA operations which are used for Samsung DMA drivers. Currently there are two types of DMA driver for Samsung SoCs. The one is S3C-DMA for S3C SoCs and the other is PL330-DMA for S5P SoCs. This patch provides funcion pointers for common DMA operations to DMA client driver like SPI and Audio. It makes DMA client drivers support multi-platform. In addition, this common DMA operations implement the shared actions that are needed for DMA client driver. For example shared actions are filter() function for dma_request_channel() and parameter passing for device_prep_slave_sg(). Signed-off-by: Boojin Kim <boojin.kim@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-08-21ARM: mach-s3c24*: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-17ARM: io: s3c2410: remove ioaddr()Russell King
There is only one user of ioaddr() in the kernel, and that is the Acorn expansion card core code. S3C2410 does not use this code, and so the definition of ioaddr() is redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: make trivial GPIOLIB implementation the defaultRussell King
Rather than marking the mach/gpio.h header files which want to use the trivial GPIOLIB implementation, mark those which do not want to use it instead. This means that by default, you get the trivial implementation and only have to do something extra if you need to. This should encourage the use of the trivial default implementation. As an additional bonus, several gpio.h header files become empty. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate gpio_to_irqRussell King
Many of the gpio_to_irq implementations use the gpiolib version of this function. Provide the standard gpiolib gpio_to_irq() for everyone, but allow platforms to override it if they wish. Add the neccessary overrides for those platforms which do not use the standard definition. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate trivial gpiolib implementationsRussell King
Consolidate 24 trivial gpiolib implementions out of mach/gpio.h into asm/gpio.h. This is basically the include of asm-generic/gpio.h and the definition of gpio_get_value, gpio_set_value, and gpio_cansleep as described in Documentation/gpio.txt Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: David Brown <davidb@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Tested-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25Merge branch 'next/deletion' of ↵Linus Torvalds
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: mach-loki: delete ARM: mach-s3c2400: delete ARM: mach-s3c24a0: delete
2011-07-20ARM: SAMSUNG: Add support for pre-sleep/post-restore gpio controlBen Dooks
Add a callback so that per-arch can do pre-sleep and post-resume gpio configuration so that for the S3C64XX, the GPIO configuration is restored before the sleep mode is cleared. For the S3C64XX case, it means that the GPIOs get set back to normal operation after the restore code puts the original configurations back in after the Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-18ARM: mach-s3c2400: deleteNicolas Pitre
On Tue, 28 Jun 2011, Ben Dooks wrote: > On Tue, Jun 28, 2011 at 11:22:57PM +0200, Arnd Bergmann wrote: > > > On a related note, what about mach-s3c2400? It seems to be even more > > incomplete. > > Probably the same fate awaits that. It is so old that there's little > incentive to do anything with it. So out it goes as well. The PORT_S3C2400 definition in include/linux/serial_core.h is left there to prevent a reuse of the same number for another port type. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
