Prepare to remove the large number of S3C2410_GPxn defines
by moving to S3C2410_GPx(n) in arch/arm.
The following perl was used to change the files:
perl -pi~ -e 's/S3C2410_GP([A-Z])([0-9]+)([^_^0-9])/S3C2410_GP\1\(\2\)\3/g'
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Move all the gpio functions out of <mach/hardware.h> as
this file is for defining the generic IO base addresses
for the kernel IO calls.
Make a new header <mach/gpio-fns.h> to take this and
include it via the chain from <linux/gpio.h> which is
what most of these files should be using (and will be
changed as soon as possible).
Note, this does make minor changes to some drivers but
should not mess up any pending merges.
CC: Richard Purdie <rpurdie@rpsys.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CC: David Brownell <dbrownell@users.sourceforge.net>
Add common definition for USB OHCI platform device, add a Kconfig
to selectively compile it and add update all the users.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
The alterations to the suspend code missed adding a
call to the cache flushing routines during the suspend
path of the S3C2412.
The <mach/dma.h> is for the driver API for the DMA system and should
not have anything relying on the CPU specific registers.
Remove the registers to <plat/dma-regs.h> for the code that really
needs to know about them.
Move the platform dma.h to dma-plat.h to ensure it doen't get
confused with plat/dma.h
Make 'jive_vgg2432a4_display' and 'jive_lcd_config' static as
they are not exported, and are generating the following sparse
warnings:
mach-jive.c:280:26: warning: symbol 'jive_vgg2432a4_display' was not declared. Should it be static?
mach-jive.c:313:28: warning: symbol 'jive_lcd_config' was not declared. Should it be static?
Remove duplicated #include in arch/arm/mach-s3c2412/mach-jive.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
The platform data for the i2c-s3c2410 driver used to allow a min,
max and desired frequency for the I2C bus. This patch reduces it
to simply a desired frequency ceiling and corrects all the uses
of the platform data appropriately.
This means, for example, that on a system with a 66MHz fclk, a
request for 100KHz will achieve 65KHz which is safe and
acceptable, rather than 378KHz which it would have achieved
without this change.
Signed-off-by: Simtec Linux Team <linux@simtec.co.uk>
Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
[ben-linux@fluff.org: tidy subject and description]
sound/soc/pxa/pxa2xx-i2s.c
Rename s3c2410_cpu_resume to s3c_cpu_resume and s3c2410_cpu_save to
s3c_cpu_save to remove the CPU specific naming of these functions
which are now in the generic PM code.
Since we have moved a large proportion of the PM code to the common
support area, remove the cpu specific name from the initialisation
function.
Start moving the PM code by moving all the common support functions
to a common location in arch/arm/plat-s3c. With the move we rename
the functions from s3cxxx_ to s3c_ to fit the new location.
Move the IIS headers to their correct place.
As per Russell King's last review comment, find and remove
all unnecessary includes of <linux/delay.h> in the files
that do not need them.
arch/arm/mach-s3c2440/mach-at2440evb.c
Fix the name of the driver, as well as the fact we are not
passing the number of chipselects to the driver.
The S3C64XX timer is running at the wrong rate due to the
assumptions made in the timer initialisation about the way
the pwm dividers work. This means that time on the S3C64XX
runs twice as fast as it should.
Fix the problem by moving to using the clk framework to setup
the pwm timer clock muxes, as the pwm-clock code has all the
necessary knowledge of how the timer clock inputs are routed.
Make the device i2c0 common to plat-s3c and move the
definitions from arch/arm/plat-s3c24xx/devs.c
Add the initial clocks definitions for the s3c6400
and s3c6410. Move the epll and ext clock from the
s3c2443 support into the common code.
Update the clock settings on resume for suspend/resume
support so that if the boot loader changes anything or
the system's PLL is reset then we return with the correct
settings.
Move the PLL calculation code into it's own header
file for re-use with the other plat-s3c24xx based
systems such as the S3C24A0.
Note, we change the name of s3c2410_get_pll to the
more generically named s3c24xx_get_pll as well as
the related defintions.
We need to add plat-s3c to the build to get the headers
that will go in here once moved from include/asm-arm so
we may as well put some useful common s3c code in here
to stop the errors generated form having nothing built.
The cpu setup is now passed the cpu idcode and the table
of supported cpus to s3c_init_cpu() to abstract the
cpu identification out of the initial io setup.
As well as moving the cpu initialisation code, we move the
map of the board specific items up to the calling code as
none of the map_io() functions actually do anything other
than pass this to iotable_init().
This patch does not rename any of the init functions that
will be common to s3c24xx and any other s3c architectures
as this can be done at a later date as it will touch all
the board support files which use functions such as
s3c24xx_init_clocks() and s3c24xx_init_uarts().
Note, the header arch/arm/plat-s3c24xx/include/plat/cpu.h
still has functions that are used by both the cpu and
board initialisation functions. This means that each board
has definitions specific to the cpu support included and
the vice-versa.
When ISA_DMA_API is unset, we're not implementing the ISA DMA API,
so there's no point in publishing the prototypes via asm/dma.h, nor
including the machine dependent parts of that API.
This allows us to remove a lot of mach/dma.h files which don't contain
any useful code. Unfortunately though, some platforms put their own
private non-ISA definitions into mach/dma.h, so we leave these behind
and fix the appropriate #include statments.
Rather than:
config CPU_BLAH
bool
depends on ARCH_FOO || MACH_BAR
default y if ARCH_FOO || MACH_BAR
arrange for ARCH_FOO and MACH_BAR to select CPU_BLAH directly.
Acked-by: Nicolas Pitre <nico@marvell.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Acked-by: Brian Swetland <swetland@google.com>
Acked-by: Eric Miao <eric.miao@marvell.com>
Acked-by: Nicolas Bellido <ml@acolin.be>
Move plat/regs-spi.h to arch/arm/plat-s3c/include/plat ready
ready to clean out old include directories.
Move the udc headers to the proper home in
arch/arm/plat-s3c24xx/include/plat ready to clean out
the old include directories.
Move regs-ac97.h to arch/arm/plat-s3c/include/plat ready
Move nand headers to arch/arm/plat-s3c/include/plat
ready to clean out the old include directories.
Move the i2c headers to arch/arm/plat-s3c/include/plat
arch/arm/mach-versatile/core.c
arch/arm/mach-pxa/Kconfig
arch/arm/mach-pxa/corgi.c
arch/arm/mach-pxa/include/mach/hardware.h
arch/arm/mach-pxa/spitz.c
arch/arm/Kconfig
desc_handle_irq() was declared as obsolete since long ago.
Replace it with generic_handle_irq()
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Continue moving the include files into arch/arm
First move of items out of include/asm-arm/plat-s3c* to their
new homes under arch/arm/plat-s3c/include/plat and
arch/arm/plat-s3c24xx/include/plat directories.
Note, we have to create a dummy arch/arm/plat-s3c/Makefile to
allow us to add arch/arm/plat-s3c/include/plat to the path.
The first spi bus is registered with number 0, but
the board data says that the device on it is registered
on bus 1.
Move the spi bus to bus 1 to keep the compatibility with the
original board-support patches.
Removed duplicated include file <linux/mtd/mtd.h> and <linux/mtd/partitions.h>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
For s3c2412, set parent for clk_erefclk and clk_urefclk.
This allow for example to use xtal or extclk for i2s clock.
Signed-off-by: Matthieu Castet <matthieu.castet@parrot.com>
Add pm_power_off hook to allow the Logitech Jive to shutdown
when asked to halt.
Add i2c bus definition for the LIS302DL sensor driver
which is connected on the i2c bus.
Add board definitions for the audio device connected
on the Logitech Jive.
Add the setup information for the LCD display
connected to the device.
Add the definitions for the VGG2432A4 intelligent
LCD display conneected via an GPIO-based SPI bus
Signed-of-by: Ben Dooks <ben-linux@fluff.org>
