path: root/arch/arm/mach-s3c24xx/mach-h1940.c
2016-02-19ARM: s3c24xx: switch to gpiochip_add_data()Linus Walleij
We're planning to remove the gpiochip_add() function to swith to gpiochip_add_data() with NULL for data argument. Cc: arm@kernel.org Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-10-13ARM: S3C24XX: Use PWM lookup table for mach-h1940Thierry Reding
Use a PWM lookup table to provide the PWM to the pwm-backlight device. The driver has a legacy code path that is required only because boards still use the legacy method of requesting PWMs by global ID. Replacing these usages allows that legacy fallback to be removed. Signed-off-by: Thierry Reding <thierry.reding@gmail.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2014-11-04leds: leds-gpio: Convert gpio_blink_set() to use GPIO descriptorsMika Westerberg
Commit 21f2aae91e902aad ("leds: leds-gpio: Add support for GPIO descriptors") already converted most of the driver to use GPIO descriptors. What is still missing is the platform specific hook gpio_blink_set() and board files which pass legacy GPIO numbers to this driver in platform data. In this patch we handle the former and convert gpio_blink_set() to take GPIO descriptor instead. In order to do this we convert the existing four users to accept GPIO descriptor and translate it to legacy GPIO number in the platform code. This effectively "pushes" legacy GPIO number usage from the driver to platforms. Also add comment to the remaining block describing that it is legacy code path and we are getting rid of it eventually. Suggested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-14ARM: S3C24XX: remove separate restart codeHeiko Stuebner
The restart-handler series from Guenter Roeck got accepted recently and implements among other things also the restart handler in the samsung watchdog driver and where applicable in the clock drivers. So there is no need for having the restart callbacks in s3c24xx boards anymore. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-19ARM: SAMSUNG: Remove legacy clock codeTomasz Figa
Since S5PV210 now has a complete clock driver using Common Clock Framework, there is no reason to keep the old code. Remove it together with the whole legacy Samsung-specific clock framework which no longer has any users. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-05-13ARM: S3C24XX: convert s3c2410 to common clock frameworkHeiko Stuebner
Convert the machines using the s3c2410 to use the new driver based on the common clock framework instead of the legacy Samsung clock driver. As with the s3c244x, machines using the clkout output will need a fixup from someone with the hardware. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-02-14ARM: SAMSUNG: Replace inclusion of plat/regs-serial.h header fileTushar Behera
regs-serial.h only includes linux/serial_s3c.h. Include this header directly to remove unnecessary platform dependency. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> [broonie@linaro.org: Acked for S3C64XX related changes] Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-01-14ARM: S3C[24|64]xx: move includes back under <mach/> scopeLinus Walleij
When refactoring and breaking out the includes for the machine-specific GPIO configuration, two files were created in <linux/platform_data/gpio-samsung-s3c[24|64]xx.h>, but as that namespace shall be used for defining data exchanged between machines and drivers, using it for these broad macros and config settings is wrong. Move the headers back into the machine-local <mach/gpio-samsung.h> file and think about the next step. Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-samsung-soc@vger.kernel.org Acked-by: Mark Brown <broonie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: s3c24xx: get rid of custom <mach/gpio.h>Linus Walleij
This isolates the custom S3C24xx GPIO definition table to <linux/platform_data/gpio-samsung-s3x24xx.h> as this is used in a few different places in the kernel, removing the need to depend on the implicit inclusion of <mach/gpio.h> from <linux/gpio.h> and thus getting rid of a few nasty cross-dependencies. We also delete the nifty CONFIG_S3C24XX_GPIO_EXTRA stuff. The biggest this can ever be for the S3C24XX is CONFIG_S3C24XX_GPIO_EXTRA = 128, and then for CPU_S3C2443 or CPU_S3C2416 32*12 GPIOs are added, so 32*12+128 = 512 is the absolute roof value on this platform. So we set the size of ARCH_NR_GPIO to this and the GPIOs array will fit any S3C24XX platform, as per pattern from other archs. ChangeLog v2->v3: - Move the movement of the S3C64XX gpio.h file out of this patch and into the follow-up patch where it belongs. ChangeLog v1->v2: - Added an #ifdef ARCH_S3C24XX around the header inclusion in drivers/gpio/gpio-samsung.c as we would otherwise have colliding definitions when compiling S3C64XX. - Rename inclusion guard in the header file. Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: linux-samsung-soc@vger.kernel.org Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-10-16ARM: SAMSUNG: Initialize PWM backlight enable_gpio fieldThierry Reding
The GPIO API defines 0 as being a valid GPIO number, so this field needs to be initialized explicitly. Signed-off-by: Thierry Reding <treding@nvidia.com>
2013-08-12ARM: SAMSUNG: Modify board files to use new PWM platform deviceTomasz Figa
This patch modifies any board files using the legacy PWM device to use the new device instead. Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Tested-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Mark Brown <broonie@linaro.org> Tested-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-03-07ARM: S3C24XX: move s3c24xx_init_irq to s3c2410_init_irqHeiko Stuebner
The s3c24xx_init_irq function that was the base for all irq inits is now only used to initialize the real s3c2410 irqs. Therefore rename it and also move its declaration from plat/cpu.h to common.h The eint declaration is used by the vast majority of the SoCs and gets therefore placed outside any ifdefs. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-03-05ARM: S3C24XX: Add samsung-time support for s3c24xxRomain Naour
Signed-off-by: Naour Romain <romain.naour@openwide.fr> Reviewed-by: Tomasz Figa <tomasz.figa@gmail.com> [heiko@sntech.de: tested on a s3c2416 based machine] Reviewed-and-Tested-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-02-04Merge branch 'next/cleanup-header' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup From Kukjin Kim: AS I commented, this makes <mach/*.h> local so that they could be removed. * 'next/cleanup-header' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (26 commits) ARM: S3C64XX: Fix missing header error with CONFIG_CPU_IDLE enabled ARM: S3C64XX: make regs-syscon-power.h local ARM: S3C64XX: make regs-sys.h local ARM: S3C64XX: make regs-srom.h local ARM: S3C64XX: make regs-modem.h local ARM: S3C64XX: make regs-gpio-memport.h local ARM: S3C64XX: make crag6410.h local ARM: S3C24XX: remove dsc.c and make regs-dsc.h local ARM: S3C24XX: remove idle.h ARM: S3C2412: cleanup regs-s3c2412.h ARM: S3C2416: remove regs-s3c2416-mem.h and regs-s3c2416.h ARM: S3C24XX: make vr1000-cpld.h, vr1000-irq.h and vr1000-map.h local ARM: S3C24XX: make otom-map.h local ARM: S3C24XX: make osiris-cpld.h and osiris-map.h local ARM: S3C24XX: make h1940.h and h1940-latch.h local ARM: S3C24XX: make gta02.h local ARM: S3C24XX: make bast-cpld.h, bast-irq.h and bast-map.h local ARM: S3C24XX: make anubis-cpld, anubis-irq and anubis-map local ARM: SAMSUNG: cleanup mach/gpio-fns.h gpio-track.h and gpio-nrs.h ARM: SAMSUNG: cleanup mach/regs-audss.h file ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-10ARM: S3C24XX: make h1940.h and h1940-latch.h localKukjin Kim
The headers can be local in mach-s3c24xx/. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-01-10ARM: SAMSUNG: cleanup mach/gpio-fns.h gpio-track.h and gpio-nrs.hKukjin Kim
remove <mach/gpio-fns.h>, <mach/gpio-track.h> and <plat/gpio-fns.h> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-07ASoC: Samsung: Do not register samsung audio dma device as pdevPadmavathi Venna
Previously, the ASoC 'platform' (PCM/DMA) object was instantiated via a platform_device. This didn't represent the hardware well, since there was no separate hardware associated with this platform_device; it was a virtual device with sole purpose to call snd_soc_register_platform(). This change removes the platform_device completely. Each Samsung DAI now registers the ASoC 'platform' itself. Machine drivers are adjusted for the new 'platform' name. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-09-21ARM: S3C24XX: removes unnecessary semicolonPeter Senna Tschudin
removes unnecessary semicolon Found by Coccinelle: http://coccinelle.lip6.fr/ Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-09-21ARM: S3C24xx: delete double assignmentJulia Lawall
Delete successive assignments to the same location. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression i; @@ *i = ...; i = ...; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-09-19ARM: samsung: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the samsung include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Sylwester Nawrocki <s.nawrocki@samsung.com> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Felipe Balbi <balbi@ti.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Liam Girdwood <lrg@ti.com> Cc: linux-samsung-soc@vger.kernel.org
2012-05-12ARM: S3C24XX: Use common macro to define resources on mach-h1940.cTushar Behera
Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-03-08Merge branch 'next/cleanup-s3c24xx' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup * 'next/cleanup-s3c24xx' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (24 commits) ARM: S3C24XX: remove call to s3c24xx_setup_clocks ARM: S3C24XX: add get_rate for clk_p on S3C2416/2443 ARM: S3C24XX: add get_rate for clk_h on S3C2416/2443 ARM: S3C24XX: remove XXX_setup_clocks method from S3C2443 ARM: S3C24XX: remove obsolete S3C2416_DMA option ARM: S3C24XX: Reuse S3C2443 dma for S3C2416 ARM: S3C24XX: Fix indentation of dma-s3c2443 ARM: S3C24XX: Move device setup files to mach directory ARM: S3C24XX: Consolidate Simtec extensions ARM: S3C24XX: move simtec-specific code to mach directory ARM: S3C24XX: Move common-smdk code to mach directory ARM: S3C24XX: Move s3c2443-clock.c to mach-s3c24xx ARM: s3c2410_defconfig: update s3c2410_defconfig ARM: S3C2443: move mach-s3c2443/* into mach-s3c24xx/ ARM: S3C2440: move mach-s3c2440/* into mach-s3c24xx/ ARM: S3C2416: move mach-s3c2416/* into mach-s3c24xx/ ARM: S3C2412: move mach-s3c2412/* into mach-s3c24xx/ ARM: S3C2410: move mach-s3c2410/* into mach-s3c24xx/ ARM: S3C24XX: change the ARCH_S3C2410 to ARCH_S3C24XX ARM: S3C2410: move s3c2410_baseclk_add to clock.h ...
2012-03-03ARM: S3C2410: move mach-s3c2410/* into mach-s3c24xx/Kukjin Kim
This patch moves S3C2410 stuff into mach-s3c24xx/ directory so that we can merge the s3c24 series' directories to the just one mach-s3c24xx/ directory. And this patch is including following. - re-ordered alphabetically by option text at Kconfig and Makefile - removed unused option, MACH_N35 - fixed duplcated option name, S3C2410_DMA to S3C24XX_DMA which is in plat-s3c24xx/ Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
