path: root/arch/arm/mach-s3c24xx/mach-s3c2416-dt.c
2016-06-23arm: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Ray Jui <rjui@broadcom.com> Cc: Lee Jones <lee@kernel.org> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Kukjin Kim <kgene@kernel.org> Cc: Rob Herring <robh@kernel.org> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com> Cc: Tony Prisk <linux@prisktech.co.nz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2015-07-28ARM: appropriate __init annotation for const dataNicolas Pitre
Init data marked const should be annotated with __initconst for correctness and not __initdata. In some cases the array gathering references to that data has to be marked const as well. This fixes LTO builds that otherwise fail with section mismatch errors. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-14ARM: S3C24XX: remove separate restart codeHeiko Stuebner
The restart-handler series from Guenter Roeck got accepted recently and implements among other things also the restart handler in the samsung watchdog driver and where applicable in the clock drivers. So there is no need for having the restart callbacks in s3c24xx boards anymore. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-04-15ARM: S3C24XX: Convert s3c2416 and s3c2443 to common clock frameworkHeiko Stuebner
This converts the mentioned platforms to use the newly introduced driver for the common clock framework for them. With this the whole legacy clock structure can go away too. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-02-14ARM: SAMSUNG: Replace inclusion of plat/regs-serial.h header fileTushar Behera
regs-serial.h only includes linux/serial_s3c.h. Include this header directly to remove unnecessary platform dependency. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> [broonie@linaro.org: Acked for S3C64XX related changes] Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-06-19ARM: S3C24XX: update uart addresses in s3c2416-dt auxdataHeiko Stuebner
Commit 9ee51f01eee8 (tty: serial/samsung: make register definitions global) removed the S3C2410_PA_UARTX defines that the newly merged s3c2416 dt support still expected. So update mach-s3c2416-dt.c to use the S3C24XX_PA_UART constant until we have support for the common clock framework the the s3c2416-dt. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-05-21ARM: dts: add devicetree support for s3c2416-smdk2416Heiko Stuebner
Definitions in s3c24xx.dtsi are usable for all s3c24xx SoCs, but some need to be extended with proper compatible properties, as can be seen in s3c2416.dtsi. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
