We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Peter Pan <peterpandong@micron.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Han Xu <han.xu@nxp.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-By: Harvey Hunt <harveyhuntnexus@gmail.com>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Removing CONFIG_MTD_NAND_S3C2410_HWECC option and adding a ecc_mode
field in the drivers's platform data structure so it can be selectable
via platform data.
Also setting this field to NAND_ECC_SOFT in all boards using this
driver since none of them had CONFIG_MTD_NAND_S3C2410_HWECC enabled.
Signed-off-by: Sergio Prado <sergio.prado@e-labworks.com>
The restart-handler series from Guenter Roeck got accepted recently and
implements among other things also the restart handler in the samsung
watchdog driver and where applicable in the clock drivers. So there is
no need for having the restart callbacks in s3c24xx boards anymore.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Since S5PV210 now has a complete clock driver using Common Clock
Framework, there is no reason to keep the old code. Remove it together
with the whole legacy Samsung-specific clock framework which no longer
has any users.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Convert all machines using these cpus to use the ccf clock driver
instead of the legacy Samsung clock implementation.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
regs-serial.h only includes linux/serial_s3c.h. Include this header
directly to remove unnecessary platform dependency.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
[broonie@linaro.org: Acked for S3C64XX related changes]
Acked-by: Mark Brown <broonie@linaro.org>
This includes defining the mapping for the request sources.
Combines the two independent init steps for the irqs into one.
Signed-off-by: Naour Romain <romain.naour@openwide.fr>
Reviewed-by: Tomasz Figa <tomasz.figa@gmail.com>
[heiko@sntech.de: tested on a s3c2416 based machine]
Reviewed-and-Tested-by: Heiko Stuebner <heiko@sntech.de>
The different soc functions are now only used in the mach-s3c24xx
directory, so it's not necessary anymore to keep the globally
visible.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup
From Kukjin Kim:
AS I commented, this makes <mach/*.h> local so that they could be removed.
* 'next/cleanup-header' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (26 commits)
ARM: S3C64XX: Fix missing header error with CONFIG_CPU_IDLE enabled
ARM: S3C64XX: make regs-syscon-power.h local
ARM: S3C64XX: make regs-sys.h local
ARM: S3C64XX: make regs-srom.h local
ARM: S3C64XX: make regs-modem.h local
ARM: S3C64XX: make regs-gpio-memport.h local
ARM: S3C64XX: make crag6410.h local
ARM: S3C24XX: remove dsc.c and make regs-dsc.h local
ARM: S3C24XX: remove idle.h
ARM: S3C2412: cleanup regs-s3c2412.h
ARM: S3C2416: remove regs-s3c2416-mem.h and regs-s3c2416.h
ARM: S3C24XX: make vr1000-cpld.h, vr1000-irq.h and vr1000-map.h local
ARM: S3C24XX: make otom-map.h local
ARM: S3C24XX: make osiris-cpld.h and osiris-map.h local
ARM: S3C24XX: make h1940.h and h1940-latch.h local
ARM: S3C24XX: make gta02.h local
ARM: S3C24XX: make bast-cpld.h, bast-irq.h and bast-map.h local
ARM: S3C24XX: make anubis-cpld, anubis-irq and anubis-map local
ARM: SAMSUNG: cleanup mach/gpio-fns.h gpio-track.h and gpio-nrs.h
ARM: SAMSUNG: cleanup mach/regs-audss.h file
The <mach/idle.h> is no longer used.
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the samsung include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: Liam Girdwood <lrg@ti.com>
Cc: linux-samsung-soc@vger.kernel.org
This patch moves S3C2412 stuff into mach-s3c24xx/ directory
so that we can merge the s3c24 series' directories to the
just one mach-s3c24xx/ directory.
And this patch is including following.
- re-ordered alphabetically by option text at Kconfig and Makefile
[heiko@sntech.de: move 'config S3C2412_PM_SLEEP' to use it for S3C2416]
