commit e2477233145f2156434afb799583bccd878f3e9f upstream.
Fix boolean expressions by using logical AND operator '&&' instead of
bitwise operator '&'.
This issue was detected with the help of Coccinelle.
Fixes: 4fa084af28ca ("ARM: OSIRIS: DVS (Dynamic Voltage Scaling) supoort.")
Cc: stable@vger.kernel.org
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[krzk: Fix -Wparentheses warning]
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull ARM/arm64 SoC platform updates from Olof Johansson: "This branch
contains platform updates for 32- and 64-bit ARM, including defconfig
updates to enable new options, drivers and platforms. There are also a
few fixes and cleanups for some existing vendors.
Some of the things worth highlighting here are:
- Enabling new crypt drivers on arm64 defconfig
- QCOM IPQ8074 clocks and pinctrl drivers on arm64 defconfig
- Debug support enabled for Renesas r8a7743
- Various config updates for Renesas platforms (sound, USB, other
drivers)
- Platform support (including SMP) for TI dra762
- OMAP cleanups: Move to use generic 8250 debug_ll, removal of stale
DMA code"
* tag 'armsoc-platforms' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: multi_v7_defconfig: make eSDHC driver built-in
arm64: defconfig: enable rockchip graphics
MAINTAINERS: Update Cavium ThunderX2 entry
ARM: config: aspeed: Add I2C, VUART, LPC Snoop
ARM: configs: aspeed: Update Aspeed G4 with VMSPLIT_2G
ARM: s3c24xx: Fix NAND ECC mode for mini2440 board
ARM: davinci_all_defconfig: enable tinydrm and ST7586
arm64: defconfig: Enable QCOM IPQ8074 clock and pinctrl
ARM: defconfig: tegra: Enable ChipIdea UDC driver
ARM: configs: Add Tegra I2S interfaces to multi_v7_defconfig
ARM: tegra: Add Tegra I2S interfaces to defconfig
ARM: tegra: Update default configuration for v4.13-rc1
MAINTAINERS: update ARM/ZTE entry
soc: versatile: remove unnecessary static in realview_soc_probe()
ARM: Convert to using %pOF instead of full_name
ARM: hisi: Fix typo in comment
ARM: multi_v7_defconfig: add CONFIG_BRCMSTB_THERMAL
arm64: defconfig: add CONFIG_BRCMSTB_THERMAL
arm64: defconfig: add recently added crypto drivers as modules
arm64: defconfig: enable CONFIG_UNIPHIER_WATCHDOG
Pull MTD updates from Boris Brezillon:
"General updates:
- Constify pci_device_id in various drivers
- Constify device_type
- Remove pad control code from the Gemini driver
- Use %pOF to print OF node full_name
- Various fixes in the physmap_of driver
- Remove unused vars in mtdswap
- Check devm_kzalloc() return value in the spear_smi driver
- Check clk_prepare_enable() return code in the st_spi_fsm driver
- Create per MTD device debugfs enties
NAND updates, from Boris Brezillon:
- Fix memory leaks in the core
- Remove unused NAND locking support
- Rename nand.h into rawnand.h (preparing support for spi NANDs)
- Use NAND_MAX_ID_LEN where appropriate
- Fix support for 20nm Hynix chips
- Fix support for Samsung and Hynix SLC NANDs
- Various cleanup, improvements and fixes in the qcom driver
- Fixes for bugs detected by various static code analysis tools
- Fix mxc ooblayout definition
- Add a new part_parsers to tmio and sharpsl platform data in order
to define a custom list of partition parsers
- Request the reset line in exclusive mode in the sunxi driver
- Fix a build error in the orion-nand driver when compiled for ARMv4
- Allow 64-bit mvebu platforms to select the PXA3XX driver
SPI NOR updates, from Cyrille Pitchen and Marek Vasut:
- add support to the JEDEC JESD216B specification (SFDP tables).
- add support to the Intel Denverton SPI flash controller.
- fix error recovery for Spansion/Cypress SPI NOR memories.
- fix 4-byte address management for the Aspeed SPI controller.
- add support to some Microchip SST26 memory parts
- remove unneeded pinctrl header Write a message for tag:"
* tag 'for-linus-20170904' of git://git.infradead.org/linux-mtd: (74 commits)
mtd: nand: complain loudly when chip->bits_per_cell is not correctly initialized
mtd: nand: make Samsung SLC NAND usable again
mtd: nand: tmio: Register partitions using the parsers
mfd: tmio: Add partition parsers platform data
mtd: nand: sharpsl: Register partitions using the parsers
mtd: nand: sharpsl: Add partition parsers platform data
mtd: nand: qcom: Support for IPQ8074 QPIC NAND controller
mtd: nand: qcom: support for IPQ4019 QPIC NAND controller
dt-bindings: qcom_nandc: IPQ8074 QPIC NAND documentation
dt-bindings: qcom_nandc: IPQ4019 QPIC NAND documentation
dt-bindings: qcom_nandc: fix the ipq806x device tree example
mtd: nand: qcom: support for different DEV_CMD register offsets
mtd: nand: qcom: QPIC data descriptors handling
mtd: nand: qcom: enable BAM or ADM mode
mtd: nand: qcom: erased codeword detection configuration
mtd: nand: qcom: support for read location registers
mtd: nand: qcom: support for passing flags in DMA helper functions
mtd: nand: qcom: add BAM DMA descriptor handling
mtd: nand: qcom: allocate BAM transaction
mtd: nand: qcom: DMA mapping support for register read buffer
After commit e9f66ae23c20 ("mtd: s3c2410: make ecc mode configurable via
platform data") booting of the mini2440 board is broken, since
for this board we have CONFIG_MTD_NAND_S3C2410_HWECC set. The console
gets flooded with errors reported by the mtd subsystem.
This patch changes ecc_mode to NAND_ECC_HW which restores proper
operation of the NAND flash memory.
Cc: Sergio Prado <sergio.prado@e-labworks.com>
Fixes: e9f66ae23c20 ("mtd: s3c2410: make ecc mode configurable via platform data")
Signed-off-by: Sylwester Nawrocki <snawrocki@kernel.org>
include/linux/i2c is not for client devices. Move the header file to a
more appropriate location.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Peter Pan <peterpandong@micron.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
Acked-by: Han Xu <han.xu@nxp.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-By: Harvey Hunt <harveyhuntnexus@gmail.com>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Bluetooth is only supported when network support is part of the kernel,
so it is a bit pointless to build the hi1940-bt support without networking.
If we try anyway, we get a Kconfig warning:
warning: (TOSA_BT && H1940BT) selects RFKILL which has unmet direct dependencies (NET)
This turns the 'select' into 'depends on' as Krzysztof suggested when
I first sent a fix.
Suggested-by: Krzysztof Kozlowski <krzk@kernel.org>
Link: https://patchwork.kernel.org/patch/8164161/
Drop CONFIG_ prefix from a local DEBUG_RESUME define guarding some
debugging code to avoid any confusion with Kconfig options.
There is no CONFIG_SND_SOC_SMDK2443_WM9710 so get rid of it.
There is no CONFIG_CPU_S3C2413 so get rid of it.
The config option name is now renamed to 'TIMER_OF' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Pull ARM updates from Russell King:
- nommu updates from Afzal Mohammed cleaning up the vectors support
- allow DMA memory "mapping" for nommu Benjamin Gaignard
- fixing a correctness issue with R_ARM_PREL31 relocations in the
module linker
- add strlen() prototype for the decompressor
- support for DEBUG_VIRTUAL from Florian Fainelli
- adjusting memory bounds after memory reservations have been
registered
- unipher cache handling updates from Masahiro Yamada
- initrd and Thumb Kconfig cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (23 commits)
ARM: mm: round the initrd reservation to page boundaries
ARM: mm: clean up initrd initialisation
ARM: mm: move initrd init code out of arm_memblock_init()
ARM: 8655/1: improve NOMMU definition of pgprot_*()
ARM: 8654/1: decompressor: add strlen prototype
ARM: 8652/1: cache-uniphier: clean up active way setup code
ARM: 8651/1: cache-uniphier: include <linux/errno.h> instead of <linux/types.h>
ARM: 8650/1: module: handle negative R_ARM_PREL31 addends correctly
ARM: 8649/2: nommu: remove Hivecs configuration is asm
ARM: 8648/2: nommu: display vectors base
ARM: 8647/2: nommu: dynamic exception base address setting
ARM: 8646/1: mmu: decouple VECTORS_BASE from Kconfig
ARM: 8644/1: Reduce "CPU: shutdown" message to debug level
ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol
ARM: 8640/1: Add support for CONFIG_DEBUG_VIRTUAL
ARM: 8639/1: Define KERNEL_START and KERNEL_END
ARM: 8638/1: mtd: lart: Rename partition defines to be prefixed with PART_
ARM: 8637/1: Adjust memory boundaries after reservations
ARM: 8636/1: Cleanup sanity_check_meminfo
ARM: add CPU_THUMB_CAPABLE to indicate possible Thumb support
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/soc
Samsung mach/soc update for v4.11. Mostly cleanups:
1. Removal of unused platform data in S3C24XX and S3C64xx as follow up of
conversion to new DMA channel request API.
2. Adding const and __ro_after_init to various data in Samsung platforms.
* tag 'samsung-soc-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: s3c64xx: Constify wake_irqs
ARM: s3c24xx: Constify wake_irqs
ARM: SAMSUNG: Constify array of wake irqs passed to samsung_sync_wakemask
ARM: s3c64xx: Annotate external clock frequencies __ro_after_init
ARM: s3c24xx: Constify few integer tables
ARM: EXYNOS: Annotate iomem and pm_data pointers __ro_after_init
ARM: EXYNOS: Constify list of retention registers
ARM: s3c24xx: Drop unused struct s3c_audio_pdata entries
ARM: s3c64xx: Drop initialization of unused struct s3c_audio_pdata fields
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into fixes
Samsung mach/soc update for v4.10:
1. Minor cleanup in smp_operations.
2. Another step in switching s3c24xx to new DMA API.
3. Drop fixed requirement for HZ=200 on Samsung platforms.
* tag 'samsung-soc-4.10-2' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: Drop fixed 200 Hz timer requirement from Samsung platforms
ARM: S3C24XX: Add DMA slave maps for remaining s3c24xx SoCs
ARM: EXYNOS: Remove smp_init_cpus hook from platsmp.c
samsung_sync_wakemask() accepts pointer to const data so wake_irqs can
be made const to increase safeness.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
These arrays are not modified so they can be made const.
Removing CONFIG_MTD_NAND_S3C2410_HWECC option and adding a ecc_mode
field in the drivers's platform data structure so it can be selectable
via platform data.
Also setting this field to NAND_ECC_SOFT in all boards using this
driver since none of them had CONFIG_MTD_NAND_S3C2410_HWECC enabled.
Signed-off-by: Sergio Prado <sergio.prado@e-labworks.com>
This patch adds DMA slave map tables for the remaining s3c24xx
SoC types so the whole platform can be switched to the new API.
A few devices for which there was no DMA support with current
code are omitted from the tables.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- We get support for running in big-endian mode on two platforms:
sunxi (Allwinner) and s3c24xx (old Samsung).
- The recently added Uniphier platform now uses standard PSCI methods
for SMP booting and we remove support for old bootloader versions
that did not support it yet.
- In sunxi, we gain support for the "Nextthing GR8" SoC, which is a
close relative of the Allwinner A13 and R8 chips.
- PXA completes its move over to the generic dmaengine framework and
removes its old private API
- mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC
with integrated 802.11ac wireless networking"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
ARM: imx legacy: pca100: move peripheral initialization to .init_late
ARM: imx legacy: mx27ads: move peripheral initialization to .init_late
ARM: imx legacy: mx21ads: move peripheral initialization to .init_late
ARM: imx legacy: pcm043: move peripheral initialization to .init_late
ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late
ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late
ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late
ARM: imx legacy: vpr200: move peripheral initialization to .init_late
ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late
ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late
ARM: imx legacy: qong: move peripheral initialization to .init_late
ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late
ARM: imx legacy: pcm037: move peripheral initialization to .init_late
ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late
ARM: imx legacy: mx31ads: move peripheral initialization to .init_late
ARM: imx legacy: mx31lite: move peripheral initialization to .init_late
ARM: imx legacy: kzm: move peripheral initialization to .init_late
MAINTAINERS: update list of Oxnas maintainers
ARM: orion5x: remove extraneous NO_IRQ
ARM: orion: simplify orion_ge00_switch_init
Pull dmaengine updates from Vinod Koul:
"This is bit large pile of code which bring in some nice additions:
- Error reporting: we have added a new mechanism for users of
dmaenegine to register a callback_result which tells them the
result of the dma transaction. Right now only one user (ntb) is
using it.
- As we discussed on KS mailing list and pointed out NO_IRQ has no
place in kernel, this also remove NO_IRQ from dmaengine subsystem
(both arm and ppc users)
- Support for IOMMU slave transfers and its implementation for arm.
- To get better build coverage, enable COMPILE_TEST for bunch of
driver, and fix the warning and sparse complaints on these.
- Apart from above, usual updates spread across drivers"
* tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (169 commits)
async_pq_val: fix DMA memory leak
dmaengine: virt-dma: move function declarations
dmaengine: omap-dma: Enable burst and data pack for SG
DT: dmaengine: rcar-dmac: document R8A7743/5 support
dmaengine: fsldma: Unmap region obtained by of_iomap
dmaengine: jz4780: fix resource leaks on error exit return
dma-debug: fix ia64 build, use PHYS_PFN
dmaengine: coh901318: fix integer overflow when shifting more than 32 places
dmaengine: edma: avoid uninitialized variable use
dma-mapping: fix m32r build warning
dma-mapping: fix ia64 build, use PHYS_PFN
dmaengine: ti-dma-crossbar: enable COMPILE_TEST
dmaengine: omap-dma: enable COMPILE_TEST
dmaengine: edma: enable COMPILE_TEST
dmaengine: ti-dma-crossbar: Fix of_device_id data parameter usage
dmaengine: ti-dma-crossbar: Correct type for of_find_property() third parameter
dmaengine/ARM: omap-dma: Fix the DMAengine compile test on non OMAP configs
dmaengine: edma: Rename set_bits and remove unused clear_bits helper
dmaengine: edma: Use correct type for of_find_property() third parameter
dmaengine: edma: Fix of_device_id data parameter usage (legacy vs TPCC)
This patch updates the s3c24xx dma driver to be able to pass a
dma_slave_map array via the platform data. This is needed to
be able to use the new, simpler dmaengine API [1].
I used the virtual DMA channels as a parameter for the dma_filter
function. By doing that, I could reuse the existing filter function in
drivers/dma/s3c24xx-dma.c.
I have tested this on my mini2440 board with the audio driver.
According to my observations, dma_request_slave_channel in the
function dmaengine_pcm_new in the file
sound/soc/soc-generic-dmaengine-pcm.c now returns a valid DMA channel
whereas before no DMA channel was returned at that point.
Entries for DMACH_XD0, DMACH_XD1 and DMACH_TIMER are missing because I
don't realy know which driver to use for these.
[1]
http://lists.infradead.org/pipermail/linux-arm-kernel/2015-December/393635.html
Signed-off-by: Sam Van Den Berge <sam.van.den.berge@telenet.be>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Addition of s3c2440_device_dma was missed during conversion
from the Samsung legacy to the regular DMA API.
Add it so any devices using DMA, e.g I2S controller can
work properly.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The dma_mask assignments seem to be missed during refactoring
of arch/arm/mach-s3c24xx. Add them to avoid DMA allocation
failures. Without this patch sound is broken on s3c24xx
with errors reported like:
s3c24xx-dma s3c2410-dma.0: coherent DMA mask is unset
ALSA pcmC0D0p,0:: cannot preallocate for size 524288
s3c24xx-iis s3c24xx-iis: Failed to get DMA channel capabilities,
falling back to period counting: -6
ALSA pcmC0D0c,0:: cannot preallocate for size 524288
The L3 bus GPIOs are specified in the board file rather than through
the sound card's device platform_data. This allows to ensure the codec
driver doesn't get probed with uninitialized platform_data field of
its corresponding platform device.
Signed-off-by: Mark Brown <broonie@kernel.org>
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
After patch "of/platform: Add common method to populate default bus",
it is possible for arch code to remove unnecessary callers of
of_platform_populate with default match table.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Lee Jones <lee@kernel.org>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Santosh Shilimkar <ssantosh@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Cc: Tony Prisk <linux@prisktech.co.nz>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Signed-off-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/cleanup
Samsung mach/soc update for v4.8:
1. Minor cleanups.
* tag 'samsung-soc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: s3c24xx: Sort cpufreq tables
ARM: SAMSUNG: Fix typos
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
Some later changes in cpufreq core require these tables to be sorted
based on ascending order of their frequencies. There was only one
offender. Fix it and add comments over the arrays.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Fix some language typos in comments.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Call pwm_apply_args() just after requesting the PWM device so that the
polarity and period are initialized according to the information
provided in pwm_args.
This is an intermediate state, and pwm_apply_args() should be dropped as
soon as the atomic PWM infrastructure is in place and the driver makes
use of it.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Pull ARM SoC 64-bit changes from Arnd Bergmann:
"Here's our branch of ARM64 contents for this merge window, now
containing all ARM64 changes other than device tree files.
- Various new platforms get added:
* Allwinner A64 SoC
* Annapurna Labs Alpine SoCs
* Broadcom Vulcan
* Marvell Armada 3700 SoCs
* Amlogic S905
- Various defconfig changes to enable platform specific drivers
This branch includes the clk git tree to resolve a build-time
dependency"
* tag 'armsoc-arm64' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
arm64: defconfig: Increase MMC_BLOCK_MINORS to 16
arm64: defconfig: Add Qualcomm sdhci and restart functionality
ARM64: Enable Amlogic Meson GXBaby platform
arm64: defconfig: Enable Samsung MFD and related configs
arm64: alpine: select the Alpine MSI controller driver
arm64: defconfig: enable the Alpine family
arm64: add Alpine SoC family
arm64: defconfig: Enable exynos thermal config
arm64: add defconfig options for Allwinner SoCs
arm64: defconfig: Enable DesignWare APB GPIO controller
arm64: defconfig: Add Renesas R-Car Gen3 USB 2.0 phy driver support
arm64: EXYNOS: Consolidate ARCH_EXYNOS7 symbol into ARCH_EXYNOS
clk: samsung: Don't build ARMv8 clock drivers on ARMv7
MAINTAINERS: Add entry for Broadcom Vulcan SoC
arm64: cputype info for Broadcom Vulcan
arm64: Broadcom Vulcan support
arm64: defconfig: Add Broadcom Vulcan to defconfig
arm64: update ARCH_MVEBU for Marvell Armada 7K/8K support
Documentation: arm: add Marvell Armada 7K and 8K families
Documentation: arm: add link to Armada 38x Functional Spec
"Newly added support for additional SoCs:
- Axis Artpec-6 SoC family
- Allwinner A83T SoC
- Mediatek MT7623
- NXP i.MX6QP SoC
- ST Microelectronics stm32f469 microcontroller
New features:
- SMP support for Mediatek mt2701
- Big-endian support for NXP i.MX
- DaVinci now uses the new DMA engine dma_slave_map
- OMAP now uses the new DMA engine dma_slave_map
- earlyprintk support for palmchip uart on mach-tango
- delay timer support for orion
Other:
- Exynos PMU driver moved out to drivers/soc/
- Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP,
uniphier"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: uniphier: rework SMP code to support new System Bus binding
ARM: uniphier: add missing of_node_put()
ARM: at91: avoid defining CONFIG_* symbols in source code
ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1
ARM: imx: Make reset_control_ops const
ARM: imx: Do L2 errata only if the L2 cache isn't enabled
ARM: imx: select ARM_CPU_SUSPEND only for imx6
dmaengine: pxa_dma: fix the maximum requestor line
ARM: alpine: select the Alpine MSI controller driver
ARM: pxa: add the number of DMA requestor lines
dmaengine: mmp-pdma: add number of requestors
dma: mmp_pdma: Add the #dma-requests DT property documentation
ARM: OMAP2+: Add rtc hwmod configuration for ti81xx
ARM: s3c24xx: Avoid warning for inb/outb
ARM: zynq: Move early printk virtual address to vmalloc area
ARM: DRA7: hwmod: Add custom reset handler for PCIeSS
ARM: SAMSUNG: Remove unused register offset definition
ARM: EXYNOS: Cleanup header files inclusion
drivers: soc: samsung: Enable COMPILE_TEST
MAINTAINERS: Add maintainers entry for drivers/soc/samsung
Pull ARM SoC non-urgent fixes from Arnd Bergmann:
"As usual, we queue up a few fixes that don't seem urgent enough to go
in through -rc.
- a number of randconfig warning fixes from Arnd
- various small fixes for OMAP
- one somewhat larger patch to restore the OMAP3 cpuidle tuning that
was lost in a cleanup
- a small regression fix for cns3xxx PCI"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (26 commits)
CNS3xxx: Fix PCI cns3xxx_write_config()
MAINTAINERS: unify email addrs for Kevin Hilman
CNS3xxx: remove unused *_VIRT definitions
ARM: OMAP2+: Fix hwmod clock for l4_ls
soc: TI knav_qmss: fix dma_addr_t printing
ARM: prima2: always enable reset controller
ARM: socfpga: hide unused functions
ARM: ux500: fix ureachable iounmap()
ARM: ks8695: fix __initdata annotation
ARM: mvebu: mark mvebu_hwcc_pci_nb as __maybe_unused
ARM: mv78xx0: avoid unused function warning
ARM: orion: only select I2C_BOARDINFO when using I2C
ARM: OMAP2+: Fix out of range register access with syscon_config.max_register
ARM: OMAP3: Add cpuidle parameters table for omap3430
ARM: davinci: make I2C support optional
ARM: davinci: DA8xx+DMx combined kernels need PATCH_PHYS_VIRT
ARM: davinci: avoid unused mityomapl138_pn_info variable
ARM: davinci: limit DT support to DA850
ARM: DRA7: hwmod: Add reset data for PCIe
ARM: DRA7: hwmod: Fix OCP2SCP sysconfig
s3c24xx implements its own inb/outb macros, but the implementation
prints warnings when the port number argument is not a 32-bit scalar:
drivers/scsi/pas16.c: In function 'NCR5380_pwrite':
arch/arm/mach-s3c24xx/include/mach/io.h:193:68: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
#define __ioaddrc(port) ((__PORT_PCIO(port) ? PCIO_BASE + (port) : (void __iomem *)(port)))
This slightly modifies the definition of the __ioaddrc macro to avoid
the warning.
This patch cleans up various map.h under mach-exynos, mach-s3c24xx and
plat-samsung by removing unused register offset. This patch also does a
minor nitpick of changing EXYNOS4 to EXYNOS from comment section of
header file "mach-exynos/include/mach/map.h".
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
We're planning to remove the gpiochip_add() function to swith
to gpiochip_add_data() with NULL for data argument.
Cc: arm@kernel.org
Acked-by: Olof Johansson <olof@lixom.net>
gta02_configure_pmu_for_charger is only used when CONFIG_PCF50633_ADC
is set, and otherwise we get a warning about an unused symbol:
arch/arm/mach-s3c24xx/mach-gta02.c:158:1: warning: 'gta02_configure_pmu_for_charger' defined but not used [-Wunused-function]
gta02_configure_pmu_for_charger(struct pcf50633 *pcf, void *unused, int res)
This adds an #ifdef to shut up the warning.
The S3C2440_XTAL_16934400 and S3C2440_XTAL_12000000 symbols are used
for both s3c2442 and s3c2440, but Kconfig only allows it to be selected
if CPU_S3C2440 is enabled, which can lead to a warning otherwise:
warning: (MACH_RX1950) selects S3C2440_XTAL_16934400 which has unmet direct dependencies (ARCH_S3C24XX && CPU_S3C2440)
This changes the dependencies to make it possible also for CPU_S3C2442-only
configurations.
EEPROM_AT24 depends on both I2C and SYSFS. We have in the past
added I2C 'select' statements to avoid build problems with the
first, but we still get a warning because of the second:
warning: (MACH_DAVINCI_EVM && MACH_SFFSDR && MACH_DAVINCI_DM6467_EVM && MACH_DAVINCI_DM365_EVM && MACH_DAVINCI_DA830_EVM && MACH_MITYOMAPL138 && MACH_MINI2440) selects EEPROM_AT24 which has unmet direct dependencies (I2C && SYSFS)
This removes the 'select' statements again, and forces users to
enable the driver in their configuration files, as we do for
most other drivers.
Move all vendor's Kconfig into CCF menu section to prevent
new drivers putting their Kconfig files in a wrong place.
Some Kconfigs need to be modified at the same time to avoid build
warnings.
Signed-off-by: James Liao <jamesjj.liao@mediatek.com>
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[sboyd@codeaurora.org: Fix typos in commit message]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
For a long time, gcc has warned about odd configurations on s3c64xx:
In file included from arch/arm/plat-samsung/pm.c:34:0:
arch/arm/mach-s3c64xx/include/mach/pm-core.h:61:0: warning: "s3c_irqwake_eintallow" redefined
#define s3c_irqwake_eintallow ((1 << 28) - 1)
In file included from arch/arm/plat-samsung/pm.c:33:0:
arch/arm/plat-samsung/include/plat/pm.h:49:0: note: this is the location of the previous definition
#define s3c_irqwake_eintallow 0
The definitions of s3c_irqwake_intallow and s3c_irqwake_eintallow are a
bit consistent between the various platforms. Things have become easier
now that it's only s3c24xx and s3c64xx that use them at all, so I've tried
to rearrange the definitions to make it more obvious what is going on.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
s3c2410_plls_add is a device notifier that may be called at runtime and
is correctly not marked __init. However it calls s3c_plltab_register()
which is marked __init, and that triggers a build error when we are
checking for section mismatches:
WARNING: vmlinux.o(.text+0x195e0): Section mismatch in reference from the function s3c2410_plls_add() to the function .init.text:s3c_plltab_register()
The function s3c2410_plls_add() references
the function __init s3c_plltab_register().
This is often because s3c2410_plls_add lacks a __init
annotation or the annotation of s3c_plltab_register is wrong.
This removes the __init annotation from s3c2410_plls_add as well as the
__initdata section annotations from s3c2440_plls_12 and s3c2440_plls_169344,
which in turn are referenced from s3c2410_plls_add.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
Samsung SoC updates for v4.4
- use PWM lookup table with pwm_add_table() for the following boards
: s3c24xx h1940 and rx1950
: s3c64xx smdk6410, crag6410, hmt and smartq
- document: update bootloader interface on exynos542x
* tag 'samsung-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
Documentation: EXYNOS: Update bootloader interface on exynos542x
ARM: S3C64XX: Use PWM lookup table for mach-smartq
ARM: S3C64XX: Use PWM lookup table for mach-hmt
ARM: S3C64XX: Use PWM lookup table for mach-crag6410
ARM: S3C64XX: Use PWM lookup table for smdk6410
ARM: S3C24XX: Use PWM lookup table for mach-rx1950
ARM: S3C24XX: Use PWM lookup table for mach-h1940
Use a PWM lookup table to provide the PWM to the pwm-backlight device.
The driver has a legacy code path that is required only because boards
still use the legacy method of requesting PWMs by global ID. Replacing
these usages allows that legacy fallback to be removed.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup
Samsung cleanup for v4.3
- make the following headers local
watchdog-reset, onenand-core, irq-uart, backlight,
ata-core, regs-usb-hsotg-phy, spi-core, nand-core,
fb-core and regs-srom headers
- make the following c file local
s5p-dev-mfc, dev-backlight and setup-camif c file
- remove keypad-core.h file
- drop owner assignment in pmu.c
- remove duplicated define of SLEEP_MAGIC
- make exynos5420_powerdown_conf() staic
* tag 'samsung-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: SAMSUNG: remove keypad-core header in plat-samsung
ARM: SAMSUNG: local watchdog-reset header in mach-s3c64xx
ARM: SAMSUNG: local onenand-core header in mach-s3c64xx
ARM: SAMSUNG: local irq-uart header in mach-s3c64xx
ARM: SAMSUNG: local backlight header in mach-s3c64xx
ARM: SAMSUNG: local ata-core header in mach-s3c64xx
ARM: SAMSUNG: local regs-usb-hsotg-phy header in mach-s3c64xx
ARM: SAMSUNG: local spi-core header in mach-s3c24xx
ARM: SAMSUNG: local nand-core header in mach-s3c24xx
ARM: SAMSUNG: local fb-core header in mach-s3c24xx
ARM: SAMSUNG: local regs-srom header in mach-exynos
ARM: SAMSUNG: make local s5p-dev-mfc in mach-exynos
ARM: SAMSUNG: make local dev-backlight in mach-s3c64xx
ARM: SAMSUNG: make local setup-camif in mach-s3c24xx
ARM: EXYNOS: Drop owner assignment in pmu.c
ARM: EXYNOS: Remove duplicated define of SLEEP_MAGIC
ARM: EXYNOS: Make local function static
