ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/board' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: S3C64XX: Configure backup battery charger on Cragganmore
ARM: S3C64XX: Fix WM8915 IRQ polarity on Cragganmore
ARM: S3C64XX: Configure supplies for all Cragganmore regulators
ARM: S3C64XX: Refresh Cragganmore support
ARM: S3C64XX: Initial support for Wolfson/Simtec Cragganmore/Banff
OMAP4: Keyboard: Mux changes in the board file
omap: blaze: add mmc5/wl1283 device support
omap: 4430SDP: Register the card detect GPIO properly
arm: omap3: cm-t35: add support for cm-t3730
OMAP3: beagle: add support for beagleboard xM revision C
OMAP3: rx-51: Add full regulator definitions
omap: rx51: Platform support for lp5523 led chip
To handle i2s0 interrupt and To fix compilation error
adds IRQ_I2S0 for exynos4, s3c64xx, s5p64x0
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
[kgene.kim@samsung.com: Fixed build failure due to inclusion]
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Use plat/regs-fb-v4.h in machine files instead of mach/regs-fb.h.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
This is temporary patch for building with clkdev.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
The Cragganmore carrier card and Banff CPU module are used on Wolfson
Microelectronics reference systems. This initial support covers the
core system which is a fairly generic S3C6410 based design, further
patches will add support for the key features of the reference system.
The initial board bringup and therefore much of the key code was done by
Ben Dooks for Simtec, with additional work (especially around the
integration of the Wolfson devices) being done by myself.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
[kgene.kim@samsung.com: removed inclusion of <mach/regs-fb.h>]
Add a callback so that per-arch can do pre-sleep and post-resume
gpio configuration so that for the S3C64XX, the GPIO configuration
is restored before the sleep mode is cleared.
For the S3C64XX case, it means that the GPIOs get set back to normal
operation after the restore code puts the original configurations
back in after the
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Any interrupts based off either of the onboard VICs cannot be resumed
from any more as it seems set_irq_wake() is now checking the error code
returned from the low level handlers and not setting the wake-state on
the interrupt if this fails.
Ensure that we make the interrupts we can resume from available on the
VIC and then do a pre-sleep mask of all the VIC interrupts as the wakeup
is handled by a seperate block.
The gpio-bank-X header files of S3C64XX have definitions
which can be substituted by other common GPIO API.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
arch/arm/mach-s3c64xx/dev-audio.c
This patch changes VMALLOC_END from 0xE0000000 to 0xF6000000, because
some systems want to use more vmalloc()/ioremap() area and now don't use
from at 0xE0000000 to 0xF6000000 (the start of Samsung SoCs' VA space)
Cc: Ben Dooks <ben-linux@fluff.org>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Fix this warning:
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:644: warning: format '%08lx' expects type
'long unsigned int', but argument 12 has type 'unsigned int'
And removes the useless parens and white space.
Reported-by: Kyungmin Park <kyungmin.park@samsung.com>
* 'for-linus/samsung-2635' of git://git.fluff.org/bjdooks/linux:
DMAENGINE: correct PL080 register header file
ARM: SAMSUNG: Fix on build warning about dependency in Kconfig
ARM: SMDK6410: Make virtual screen twice depth of real
ARM: S3C64XX: Update consistent DMA size to 8MiB
ARM: S3C64XX: Add audio support to SmartQ
ARM: S3C64XX: Framebuffer fix for SmartQ5
ARM: S3C64XX: Set wifi and iNAND as permanently connected SD devices on SmartQ boards
ARM: S3C64XX: Move SmartQ LCD control platform definition to shared file
ARM: mach-real6410: add sdhc device support
ARM: mach-real6410: add dm9000 ethernet support for mach-real6410
ARM: S3C64XX: Support for Real6410
Fix up trivial conflicts in arch/arm/mach-s3c64xx/mach-smartq5.c
("remove pixclock" vs "Framebuffer fix for SmartQ5")
Change the area available for consitent DMA allocations from the
default to 8MiB to allow drivers such as the framebuffer to get
more memory (for situations where larger virtual screen resolutions
are needed).
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits)
ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions}
ARM: 6324/1: cam60: move cam60_spi_devices to .init.data
ARM: 6322/1: imx/pca100: Fix name of spi platform data
ARM: 6321/1: fix syntax error in main Kconfig file
ARM: 6297/1: move U300 timer to dynamic clock lookup
ARM: 6296/1: clock U300 intcon and timer properly
ARM: 6295/1: fix U300 apb_pclk split
ARM: 6306/1: fix inverted MMC card detect in U300
ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID
ARM: 6294/1: etm: do a dummy read from OSSRR during initialization
ARM: 6292/1: coresight: add ETM management registers
ARM: 6288/1: ftrace: document mcount formats
ARM: 6287/1: ftrace: clean up mcount assembly indentation
ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR"
ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE
ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h>
ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3
ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig
ARM: S5PV210: Override FIMC driver name on Aquila board
ARM: S5PC100: enable FIMC on SMDKC100
Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to
different subsystem 'setname' calls, and trivial port types in
include/linux/serial_core.h
Remove the various header files that configure this driver and use the
platform device name to select the correct configuration at probe time.
Currently this does not remove the header files, only updates the driver
and the relevant platform files.
Signed-off-by: Pawel Osciak <p.osciak@samsung.com>
Cc: InKi Dae <inki.dae@samsung.com>
Cc: KyungMin Park <kyungmin.park.samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
This patch is to support keypad device to the SMDK6410 board.
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
Following is added for the CF-ATA driver:
- Platform data strucure instantiation
- Platform device enabling code
- Addition of cfcon clock
- Platform-specific gpio setup code
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Merge branch 'for-2635-4/onenand' into for-2635-4/partial2
arch/arm/mach-s5pc100/cpu.c
arch/arm/mach-s5pc100/include/mach/map.h
arch/arm/mach-s5pv210/Makefile
This patch adds support for Watchdog timer for Samsung S3C6410
Signed-off-by: Banajit Goswami <banajit.g@samsung.com>
This patch adds setup code for Samsung OneNAND controller driver. The
driver needs to be aware on which SoC it is running, so the actual
device id is being changed in cpu init code. S3C64xx SoCs have 2 OneNAND
controllers while S5PC100 and S5PC110 has only one.
[ben-linux@fluff.org: sort map.h entries]
Merge branch 'for-2635/samsung-rtc' into for-linus/samsung2
arch/arm/mach-s3c64xx/include/mach/map.h
arch/arm/plat-samsung/Kconfig
arch/arm/plat-samsung/Makefile
Merge branch 'for-2635/samsung-ts' into for-linus/samsung2
Merge branch 'for-2635/fb-updates1' into for-linus/samsung2
This patch moves RTC device definitions from mach-s3c64xx
to plat-samsung, to enable the other SoCs to use same device
definition.
Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com>
This patch moves ADC device definition to plat-samsung.
Because that is generic to the S3C64XX and S5P Series SoCs.
Define S3C6410 specific register - CLK_SRC2
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
The S3C6400 EPLL code matches the S3C2416 and compatible SoCs, so move
it from mach-s3c64xx into <plat/pll.h> for easy reuse.
Commit 4e6d488af37980d224cbf298224db6173673f362 either missed out the
following machine files or somehow managed to clash between merges.
Fixup the three files missing the second parameter to addruart macro
to allow them to build.
Fixes the following warnings in arch/arm/kernel/debug.c:
arch/arm/kernel/debug.S: Assembler messages:
arch/arm/kernel/debug.S:167: Error: too many positional arguments
arch/arm/kernel/debug.S:183: Error: too many positional arguments
Follow the scheme used for IRQs. By default 16 GPIOs are allocated
for board use.
The Wolfson Microelectronics 1192-EV1 is a plug in module for the
SMDK6410 providing power using a WM8312 PMIC. This patch provides
initial hookup sufficient to initialise the board, though not all
features are fully described yet.
As part of this supplies for the system that are provided as a
single supply by one of the currently merged PMIC boards are
factored out so they can be reused between different regulators.
Move the include/mach files out of plat-s3c and into the relevant
machine files. This does mean copying the files, but there is nowhere
else to put them.
dma-plat.h is the last file left in plat-s3c64xx, but to remove it we
must also change the use of dma-plat.h by the core code and the s3c24xx
implementation.
Rename the s3c24xx dma-plat.h in the common plat-samsung directory as it
may be used for other ports. Move the specific dma bits into the
mach-s3c64xx directory and update the build as needed.
Move the pm-core.h to the machine include directory in the process of
eliminating the plat-s3c64xx.
Turn the init sequence of
s3c24xx_register_baseclocks(xtal);
s3c64xx_register_clocks();
s3c6400_register_clocks(S3C6410_CLKDIV0_ARM_MASK);
into a single call as this is now contained within one file.
Move the core S3C64XX support to mach-s3c64xx as it is unlikely to be used
outside of this directory. Also move the SoC header files in with it.
This includes the clock, cpu, cpufreq, dma, gpiolib and pll support.
Move the S3C64XX specific device and setup files into mach-s3c64xx as
they are unlikely to be used outside of this code.
Move IRQ support to mach-s3c64xx as it is unlikely to be re-used outside
this machine.
Move the register and GPIO definition files from plat-s3c64xx into the
machine include direcotry as they are unlikely to be reused outside
mach-s3c64xx.
This move includes removing the empty <mach/regs-clock.h> and replacing
it with the <plat/regs-clock.h> implementation.
As per discussions with Russell King on linux-arm-kernel, it appears that
both mach-s3c6400 and mach-s3c6410 are so close together that they should
simply be merged into mach-s3c64xx.
Note, this patch does not eliminate any of the bits that are still common,
it is simply a move of the two directories together, any further common
code will be eliminated or moved in further patches.
