path: root/arch/arm/mach-s3c64xx/mach-real6410.c
2018-01-03ARM: S3C64XX: Add SPDX license identifiersKrzysztof Kozlowski
Replace GPL license statements with SPDX license identifiers (GPL-2.0 and GPL-2.0+). Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
2016-11-07mtd: s3c2410: make ecc mode configurable via platform dataSergio Prado
Removing CONFIG_MTD_NAND_S3C2410_HWECC option and adding a ecc_mode field in the drivers's platform data structure so it can be selectable via platform data. Also setting this field to NAND_ECC_SOFT in all boards using this driver since none of them had CONFIG_MTD_NAND_S3C2410_HWECC enabled. Signed-off-by: Sergio Prado <sergio.prado@e-labworks.com> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2015-12-01ARM: s3c64xx: use new adc/touchscreen driverArnd Bergmann
The old ADC and touchscreen drivers are not compatible with multiplatform support, but we can use the exynos-adc driver as a replacement. This changes the common device creation functions for s3c64xx (but not s3c24xx for now) to use the new driver. To do this, we have to pass the interrupt resources in the opposite order and pass the platform data in the adc device node. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-01ARM: s3c64xx: enable sparse IRQ supportArnd Bergmann
This is another prerequisite for enabling multiplatform support, and it is the part I am least certain about. I assume it will cause the extra boot message "Cannot allocate irq_descs @ IRQ%d, assuming pre-allocated" to be printed, but otherwise work ok. This definitely needs to be tested on real hardware to see if it works. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-09ARM: s3c64xx: Leave disabling of unused PM domains to genpdUlf Hansson
Since genpd at late init, will try to disable unused PM domains we don't need to do it from the machine specific code as well. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-14ARM: SAMSUNG: Replace inclusion of plat/regs-serial.h header fileTushar Behera
regs-serial.h only includes linux/serial_s3c.h. Include this header directly to remove unnecessary platform dependency. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> [broonie@linaro.org: Acked for S3C64XX related changes] Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-01-14ARM: S3C[24|64]xx: move includes back under <mach/> scopeLinus Walleij
When refactoring and breaking out the includes for the machine-specific GPIO configuration, two files were created in <linux/platform_data/gpio-samsung-s3c[24|64]xx.h>, but as that namespace shall be used for defining data exchanged between machines and drivers, using it for these broad macros and config settings is wrong. Move the headers back into the machine-local <mach/gpio-samsung.h> file and think about the next step. Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-samsung-soc@vger.kernel.org Acked-by: Mark Brown <broonie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: s3c64xx: get rid of custom <mach/gpio.h>Linus Walleij
This isolates the custom S3C64xx GPIO definition table to <linux/platform_data/gpio-samsung-s3x64xx.h> as this is used in a few different places in the kernel, removing the need to depend on the implicit inclusion of <mach/gpio.h> from <linux/gpio.h> and thus getting rid of a few nasty cross-dependencies. Also delete the CONFIG_SAMSUNG_GPIO_EXTRA stuff. Instead roof the number of GPIOs for this platform: First sum up all the GPIO banks from A to Q: 187 GPIOs. Add the 16 "board GPIOs" and the roof for SAMSUNG_GPIO_EXTRA, 128, so in total maximum 187+16+128 = 331 GPIOs, so let's take the same roof as for S3C24XX: 512. This way we can do away with the GPIO calculation macros for GPIO_BOARD_START, BOARD_NR_GPIOS and the definition of ARCH_NR_GPIOS. Cc: Mark Brown <broonie@kernel.org> [on Mini6410 board] Tested-by: Tomasz Figa <t.figa@samsung.com> [for changes in mach-s3c64xx] Acked-by: Tomasz Figa <t.figa@samsung.com> Tested-by: Mark Brown <broonie@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-03-05ARM: S3C64XX: Add samsung-time support for s3c64xxRomain Naour
Signed-off-by: Naour Romain <romain.naour@openwide.fr> [tomasz.figa@gmail.com: tested on a Tiny6410 board] Reviewed-and-Tested-by: Tomasz Figa <tomasz.figa@gmail.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-02-04Merge branch 'next/cleanup-header' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup From Kukjin Kim: AS I commented, this makes <mach/*.h> local so that they could be removed. * 'next/cleanup-header' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (26 commits) ARM: S3C64XX: Fix missing header error with CONFIG_CPU_IDLE enabled ARM: S3C64XX: make regs-syscon-power.h local ARM: S3C64XX: make regs-sys.h local ARM: S3C64XX: make regs-srom.h local ARM: S3C64XX: make regs-modem.h local ARM: S3C64XX: make regs-gpio-memport.h local ARM: S3C64XX: make crag6410.h local ARM: S3C24XX: remove dsc.c and make regs-dsc.h local ARM: S3C24XX: remove idle.h ARM: S3C2412: cleanup regs-s3c2412.h ARM: S3C2416: remove regs-s3c2416-mem.h and regs-s3c2416.h ARM: S3C24XX: make vr1000-cpld.h, vr1000-irq.h and vr1000-map.h local ARM: S3C24XX: make otom-map.h local ARM: S3C24XX: make osiris-cpld.h and osiris-map.h local ARM: S3C24XX: make h1940.h and h1940-latch.h local ARM: S3C24XX: make gta02.h local ARM: S3C24XX: make bast-cpld.h, bast-irq.h and bast-map.h local ARM: S3C24XX: make anubis-cpld, anubis-irq and anubis-map local ARM: SAMSUNG: cleanup mach/gpio-fns.h gpio-track.h and gpio-nrs.h ARM: SAMSUNG: cleanup mach/regs-audss.h file ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-12ARM: remove unneeded vic.h includesRob Herring
Numerous includes of asm/hardware/vic.h aren't needed, so remove them. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-By: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: linux-samsung-soc@vger.kernel.org Cc: patches@opensource.wolfsonmicro.com Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-12ARM: remove mach .handle_irq for VIC usersRob Herring
Now that the VIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Move vic_handle_irq to avoid a forward declaration. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-10ARM: S3C64XX: make regs-srom.h localKukjin Kim
The header file can be local in mach-s3c64xx/. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-01-10ARM: S3C64XX: make regs-modem.h localKukjin Kim
The header can be local in mach-s3c64xx/. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-12Merge tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: "This includes: - large updates for OMAP - basic OMAP5 DSS support for DPI and DSI outputs - large cleanups and restructuring - some update to Exynos and da8xx-fb - removal of the pnx4008 driver (arch removed) - various other small patches" Fix up some trivial conflicts (mostly just include line changes, but also some due to the renaming of the deferred work functions by Tejun). * tag 'fbdev-updates-for-3.7' of git://github.com/schandinat/linux-2.6: (193 commits) gbefb: fix compile error video: mark nuc900fb_map_video_memory as __devinit video/mx3fb: set .owner to prevent module unloading while being used video: exynos_dp: use clk_prepare_enable and clk_disable_unprepare drivers/video/exynos/exynos_mipi_dsi.c: fix error return code drivers/video/savage/savagefb_driver.c: fix error return code video: s3c-fb: use clk_prepare_enable and clk_disable_unprepare da8xx-fb: save and restore LCDC context across suspend/resume cycle da8xx-fb: add pm_runtime support video/udlfb: fix line counting in fb_write OMAPDSS: add missing include for string.h OMAPDSS: DISPC: Configure color conversion coefficients for writeback OMAPDSS: DISPC: Add manager like functions for writeback OMAPDSS: DISPC: Configure writeback FIFOs OMAPDSS: DISPC: Configure writeback specific parameters in dispc_wb_setup() OMAPDSS: DISPC: Configure overlay-like parameters in dispc_wb_setup OMAPDSS: DISPC: Add function to set channel in for writeback OMAPDSS: DISPC: Don't set chroma resampling bit for writeback OMAPDSS: DISPC: Downscale chroma if plane is writeback OMAPDSS: DISPC: Configure input and output sizes for writeback ...
2012-09-19ARM: samsung: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the samsung include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Sylwester Nawrocki <s.nawrocki@samsung.com> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Felipe Balbi <balbi@ti.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Liam Girdwood <lrg@ti.com> Cc: linux-samsung-soc@vger.kernel.org
2012-08-08include/video: move fimd register headers from platform to include/videoLeela Krishna Amudala
This patch moves the contents from regs-fb-v4.h and regs-fb.h to include/video/samsung_fimd.h. Also updates the header inclusion in machine files and driver files accordingly. Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-06-01Merge tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: - driver for AUO-K1900 and AUO-K1901 epaper controller - large updates for OMAP (e.g. decouple HDMI audio and video) - some updates for Exynos and SH Mobile - various other small fixes and cleanups * tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits) video: bfin_adv7393fb: Fix cleanup code video: exynos_dp: reduce delay time when configuring video setting video: exynos_dp: move sw reset prioir to enabling sw defined function video: exynos_dp: use devm_ functions fb: handle NULL pointers in framebuffer release OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request OMAPDSS: Apply VENC timings even if panel is disabled OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC OMAPDSS: DISPC: Support rotation through TILER OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n OMAPFB: remove compiler warnings when CONFIG_BUG=n OMAPDSS: remove compiler warnings when CONFIG_BUG=n OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods OMAPDSS: DISPC: Update Accumulator configuration for chroma plane drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers video: exynos mipi dsi: support reverse panel type video: exynos mipi dsi: Properly interpret the interrupt source flags video: exynos mipi dsi: Avoid races in probe() ...
2012-05-26Merge tag 'cleanup-initcall' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson: "This is a patch series from Shawn Guo that moves from individual late_initcalls() to using a member in the machine structure to invoke a platform's late initcalls. This cleanup is a step in the move towards multiplatform kernels since it would reduce the need to check for compatible platforms in each and every initcall." Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c, imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and, in the case of cpuimx51.c the board support being deleted) * tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: ux500: use machine specific hook for late init ARM: tegra: use machine specific hook for late init ARM: shmobile: use machine specific hook for late init ARM: sa1100: use machine specific hook for late init ARM: s3c64xx: use machine specific hook for late init ARM: prima2: use machine specific hook for late init ARM: pnx4008: use machine specific hook for late init ARM: omap2: use machine specific hook for late init ARM: omap1: use machine specific hook for late init ARM: msm: use machine specific hook for late init ARM: imx: use machine specific hook for late init ARM: exynos: use machine specific hook for late init ARM: ep93xx: use machine specific hook for late init ARM: davinci: use machine specific hook for late init ARM: provide a late_initcall hook for platform initialization
2012-05-12ARM: S3C64XX: Use common macro to define resources on mach-real6410.cTushar Behera
Cc: Darius Augulis <augulis.darius@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-05-08ARM: s3c64xx: use machine specific hook for late initShawn Guo
Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2012-04-09ARM: Samsung: Rework platform data of s3c-fb driverThomas Abraham
For all the Samsung SoC based boards which have the platform data for s3c-fb driver, the 'default_win' element in the platform data is removed and the lcd panel video timing values are moved out of individual window configuration data. Acked-by: Jingoo Han <jg1.han@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: JeongHyeon Kim <jhkim@insignal.co.kr> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kwangwoo Lee <kwangwoo.lee@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Darius Augulis <augulis.darius@gmail.com> Cc: Maurus Cuelenaere <mcuelenaere@gmail.com> Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-04-09ARM: s3c64xx: Decouple lcd type from display controller window dataThomas Abraham
The display controller window data should contain window configuration data for only one type of lcd panel. So, for real6410 and mini6410 boards, split the existing display controller window data, which contains window configuration data for two different types of lcd panels, into two seperate instances and register one of them depending on the type of the lcd panel detected at runtime. This is a prerequisite change for a subsequent commit that reorders the platform data of display controller by moving video interface timing out of window setup data. Cc: Darius Augulis <augulis.darius@gmail.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: 7266/1: restart: S3C64XX: use new restart hookKukjin Kim
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-23ARM: 7245/1: S3C64XX: introduce arch/arm/mach-s3c64xx/common.[ch]Kukjin Kim
This patch introduces common.[ch] which are used only in the arch/arm/mach-s3c64xx/ directory. The common.c file merges the cpu.c, irq.c and irq-eint.c which are used commonly on S3C64XX SoCs and the common.h file replaces with plat/s3c6400.h and plat/s3c6410.h files. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-15ARM: s3c64xx: convert to MULTI_IRQ_HANDLERJamie Iles
Now that there is a generic IRQ handler for multiple VIC devices use it for s3c64xx to help building multi platform kernels. Cc: Ben Dooks <ben-linux@fluff.org> Tested-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-11-01Merge branch 'depends/rmk/memory_h' into next/cleanup2Arnd Bergmann
There are lots of conflicts between the omap and exynos cleanups and the memory.h remove series. Conflicts: arch/arm/mach-exynos4/mach-smdkc210.c arch/arm/mach-exynos4/mach-smdkv310.c arch/arm/mach-imx/mach-cpuimx27.c arch/arm/mach-omap1/board-ams-delta.c arch/arm/mach-omap1/board-generic.c arch/arm/mach-omap1/board-h2.c arch/arm/mach-omap1/board-h3.c arch/arm/mach-omap1/board-nokia770.c arch/arm/mach-omap1/board-osk.c arch/arm/mach-omap1/board-palmte.c arch/arm/mach-omap1/board-palmtt.c arch/arm/mach-omap1/board-palmz71.c arch/arm/mach-omap1/board-sx1.c arch/arm/mach-omap1/board-voiceblue.c arch/arm/mach-omap1/io.c arch/arm/mach-omap2/board-generic.c arch/arm/mach-omap2/io.c arch/arm/plat-omap/io.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-04ARM: SAMSUNG: Moving each SoC support header filesKukjin Kim
This patch moves SoC header files for supporting each SoCs to plat-samsung directory. This is required to make one plat- directory for Samsung SoCs. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-16ARM: SAMSUNG: Remove unnecessary duplication of plat_data on TSADCNaveen Krishna Chatradhi
The default plat_data struct for TSADC is added in devs-ts.c and duplication is removed from the following machines. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-21ARM: mach-s3c64xx: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-21ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xxAjay Kumar
Use plat/regs-fb-v4.h in machine files instead of mach/regs-fb.h. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-25ARM: S3C64XX: fix uart clock setup for mini6410/real6410Darius Augulis
Don't rewrite clock config in UCON preconfigured by bootloader. No need to set 10th bit in UCON because [11:10] 2'b00 means source clock is PCLK too. If set, console does not work if bootloader has preconfigured [11:10] with 2'b00. If not set, console works with any bootloader config value (2'bxx). More information about clock setup in UCON is available in "S3C6410X RISC Microprocessor User's Manual, Revision 1.20" p. 31-13 (Chapter 31.6.2 UART CONTROL REGISTER). Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-28Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mach-s3c64xx/dev-audio.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-19ARM: S3C64XX: add USB host support for mach-real6410Darius Augulis
Add USB host device support for mach-real6410 Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-19ARM: S3C64XX: add touchscreen support for mach-real6410Darius Augulis
Add touchscreen device support for mach-real6410 Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-19ARM: S3C64XX: add nand support for mach-real6410Darius Augulis
Add nand device support and mtd partition table for mach-real6410 Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-19ARM: S3C64XX: add frame buffer support for mach-real6410Darius Augulis
Add support for frame buffer device for mach-real6410. Patch also adds support for feature string parsing for real6410. The feature string is kernel command line passed and currently lets select only LCD configuration. At the moment there is support for two LCD configurations - 4.3" and 7.0". Feature parser is mach-mini2440 based. Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-09-18ARM: S3C64XX: Add IORESOURCE_IRQ_HIGHLEVEL flag to dm9000 on mach-real6410Darius Augulis
Add IORESOURCE_IRQ_HIGHLEVEL irq flag to dm9000 driver platform data in board mach-real6410. Signed-off-by: Darius Augulis <augulis.darius@gmail.com> [kgene.kim@samsung.com: minor title fix] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-09-18ARM: S3C64XX: Fix coding style errors on mach-real6410Darius Augulis
Fix errors reported by checkpatch.pl script Signed-off-by: Darius Augulis <augulis.darius@gmail.com> [kgene.kim@samsung.com: minor title fix] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-14ARM: mach-real6410: add sdhc device supportDarius Augulis
Register SHDCI devices Signed-off-by: Darius Augulis <augulis.darius@gmail.com> [ben-linux@fluff.org: rewrite header[ Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-08-14ARM: mach-real6410: add dm9000 ethernet support for mach-real6410Darius Augulis
This patch is based on "[PATCH v2] Support for Real6410" Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-08-14ARM: S3C64XX: Support for Real6410Darius Augulis
Add support for CoreWind Real6410 board, based on Samsung s3c6410 processor. Signed-off-by: Darius Augulis <augulis.darius@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
