path: root/arch/arm/mach-s3c64xx/mach-smdk6400.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-05-12ARM: SAMSUNG: Remove old email address for ben-linux@fluff.orgBen Dooks
The address ben@fluff.org is old, ben-linux@fluff.org has been in use for a long time, and we should fixup all the occasions of the older address to avoid confusion. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-02-20ARM: S3C64XX: Move core support to mach-s3c64xxBen Dooks
Move the core S3C64XX support to mach-s3c64xx as it is unlikely to be used outside of this directory. Also move the SoC header files in with it. This includes the clock, cpu, cpufreq, dma, gpiolib and pll support. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-01-26ARM: S3C64XX: Merge mach-s3c6400 and mach-s3c6410Ben Dooks
As per discussions with Russell King on linux-arm-kernel, it appears that both mach-s3c6400 and mach-s3c6410 are so close together that they should simply be merged into mach-s3c64xx. Note, this patch does not eliminate any of the bits that are still common, it is simply a move of the two directories together, any further common code will be eliminated or moved in further patches. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
