Replace GPL license statements with SPDX license identifiers (GPL-2.0
and GPL-2.0+).
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
When refactoring and breaking out the includes for the
machine-specific GPIO configuration, two files were created
in <linux/platform_data/gpio-samsung-s3c[24|64]xx.h>, but as
that namespace shall be used for defining data exchanged
between machines and drivers, using it for these broad macros
and config settings is wrong.
Move the headers back into the machine-local
<mach/gpio-samsung.h> file and think about the next step.
Cc: Tomasz Figa <tomasz.figa@gmail.com>
Cc: Sylwester Nawrocki <sylvester.nawrocki@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-samsung-soc@vger.kernel.org
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
This isolates the custom S3C64xx GPIO definition table to
<linux/platform_data/gpio-samsung-s3x64xx.h> as this is
used in a few different places in the kernel, removing the
need to depend on the implicit inclusion of <mach/gpio.h>
from <linux/gpio.h> and thus getting rid of a few nasty
cross-dependencies.
Also delete the CONFIG_SAMSUNG_GPIO_EXTRA stuff. Instead
roof the number of GPIOs for this platform:
First sum up all the GPIO banks from A to Q: 187 GPIOs.
Add the 16 "board GPIOs" and the roof for SAMSUNG_GPIO_EXTRA,
128, so in total maximum 187+16+128 = 331 GPIOs, so let's
take the same roof as for S3C24XX: 512. This way we can do
away with the GPIO calculation macros for GPIO_BOARD_START,
BOARD_NR_GPIOS and the definition of ARCH_NR_GPIOS.
Cc: Mark Brown <broonie@kernel.org>
[on Mini6410 board]
Tested-by: Tomasz Figa <t.figa@samsung.com>
[for changes in mach-s3c64xx]
Acked-by: Tomasz Figa <t.figa@samsung.com>
Tested-by: Mark Brown <broonie@linaro.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
The extern is only useful on prototypes.
Cc: stable@kernel.org
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Use plat/regs-fb-v4.h in machine files instead of mach/regs-fb.h.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
This patch changes code setting special-function and no pull-up
to use the s3c_gpio_cfgrange_nopull() wrapper.
NOTE: This is for missed things from the previous patch.
Change the code setting a range of GPIO pins' configuration and
pull state to use the recently introduced s3c_gpio_cfgall_range().
Mop up a few missed s3c_gpio_cfgpin_range() changes.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
[kgene.kim@samsung.com: Fix small comments]
This patch fixes on inclusion <mach/gpio.h> to <linux/gpio.h>
Move the S3C64XX specific device and setup files into mach-s3c64xx as
they are unlikely to be used outside of this code.
