path: root/arch/arm/mach-s3c64xx/setup-ide.c
2010-10-25ARM: S3C64XX: Ensure s3c64xx_ide_setup_gpio() is prototypedMark Brown
Since it's exported we should make sure we're using the prototype others see. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S3C64XX: 2nd Change to using s3c_gpio_cfgall_range()Kukjin Kim
This patch changes the code setting range of GPIO pins' configuration and pull state to use the recently introduced s3c_gpio_cfgpin_range(). NOTE: This is for missed things from the previous patch. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-05ARM: S3C64XX: Add support for Compact Flash driver on SMDK6410Abhilash Kesavan
Following is added for the CF-ATA driver: - Platform data strucure instantiation - Platform device enabling code - Addition of cfcon clock - Platform-specific gpio setup code Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
