This patch changes the code setting range of GPIO pins' configuration and
pull state to use the recently introduced s3c_gpio_cfgpin_range().
NOTE: This is for missed things from the previous patch.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Change the code setting a range of GPIO pins' configuration and
pull state to use the recently introduced s3c_gpio_cfgall_range().
Mop up a few missed s3c_gpio_cfgpin_range() changes.
This patch changes the code setting ranges of GPIO pins in mach-s5p64x0 using
s3c_gpio_cfgpin() to use the recently introduced s3c_gpio_cfgpin_range().
Change the code setting ranges of GPIO pins using s3c_gpio_cfgpin() to
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
[kgene.kim@samsung.com: modified to s5p64x0 from s5p6440]
This patch removes redundant selection PLAT_S5P in the CPU_S5P64XX config.
Because PLAT_S5P is selected if select ARCH_S5P64XX in the plat-s5p/Kconfig.
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
This patch adds header <linux/sched.h> into the below files for build with
CONFIG_PREEMPT_NONE.
arch/arm/mach-s5p64x0/cpu.c
Signed-off-by: Seung-Chull Suh <sc.suh@samsung.com>
[kgene.kim@samsung.com: edited title and message]
The patch removes s3c_gpio_lock/unlock to avoid acquiring the lock
recursively as lock is already acquired by calling function.
Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com>
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
[kgene.kim@samsung.com: removed useless variable due to this]
Fix the touch screen device name from s3c64x0-adc to s3c64xx-adc.
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
This patch moves smdk6440 board file from mach-s5p6440 into the new
mach-s5p64x0 directory and adds smdk6450 board file.
This patch moves S5P6440 GPIO support files from mach-s5p6440
into the new mach-s5p64x0 for merge S5P6440 and S5P6450 SocS.
NOTE: Not supported S5P6450 GPIO yet. Will be supported soon.
This patch adds S5P6450 I2C support in the ARCH_S5P64X0. And
moves S5P6440 I2C support files into the mach-s5p64x0 together.
This patch moves DMA support files in the mach-s5p64x0
for S5P6440 and S5P6450 SoCs.
Cc: Jassi Brar <jassi.brar@samsung.com>
This patch updates Audio and SPI for S5P6440 and S5P6450 SoCs.
This patch updates timer support for S5P6440 and S5P6450 SoCs.
This patch updates IRQ support for S5P6440 and S5P6450 SoCs.
This patch updates regarding clock files for supporting S5P6440 and
S5P6450 with one kernel image. The mach-s5p64x0/clock.c is for common
of them and there are specific clock files for each SoCs.
This patch adds ARCH_S5P64X0 which can support S5P6440 and S5P6450 with
one kernel image. So moved some files of mach-s5p6440 into the new ARCH
directory mach-s5p64x0.
This patch updates the Kconfig and Makefile for the S5P6440 and S5P6450
machines. It also updates arch/arm/ Kconfig and Makefile to include for
support ARCH_S5P64X0 with one kernel image.
