path: root/arch/arm/mach-s5p64x0
2010-10-28Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mach-s3c64xx/dev-audio.c
2010-10-25ARM: S5P: Change VMALLOC_END to use more vmalloc()/ioremap() areaKukjin Kim
This patch changes VMALLOC_END from 0xE0000000 to 0xF6000000, because some systems want to use more vmalloc()/ioremap() area and now don't use from at 0xE0000000 to 0xF6000000 (the start of Samsung SoCs' VA space) Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P: Reorder DMA platform device idSeungwhan Youn
This patch is matched-up DMA platform device id to its clock id. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P64X0: Set DMA clock disable as defaultSeungwhan Youn
This patch modify to DMA operation clock into disable list for default clock setting. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P: Add EPLL rate change warningSeungwhan Youn
This patch adds warning about changing EPLL rate to notice that other driver that controls H/W, which is using EPLL, will has unknown effects by this EPLL rate change. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5P: Reduce duplicated EPLL control codesSeungwhan Youn
S5P Samsung SoCs has a EPLL to support various PLL clock sources for other H/W blocks. Until now, to control EPLL, each of SoCs make their own functions in 'mach-s5pxxx/clock.c'. But some of functions, 'xxx_epll_get_rate()' and 'xxx_epll_enable()', are exactly same in all S5P SoCs, so this patch move these duplicated codes to common EPLL functions that use platform wide. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25Merge branch 'next-gpio-update' into for-nextKukjin Kim
2010-10-23ARM: S5P64X0: 2nd Change to using s3c_gpio_cfgall_range()Kukjin Kim
This patch changes the code setting range of GPIO pins' configuration and pull state to use the recently introduced s3c_gpio_cfgpin_range(). NOTE: This is for missed things from the previous patch. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5P64X0: Change to using s3c_gpio_cfgall_range()Kukjin Kim
Change the code setting a range of GPIO pins' configuration and pull state to use the recently introduced s3c_gpio_cfgall_range(). Mop up a few missed s3c_gpio_cfgpin_range() changes. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5P64X0: 2nd Change to using s3c_gpio_cfgpin_range()Kukjin Kim
This patch changes the code setting ranges of GPIO pins in mach-s5p64x0 using s3c_gpio_cfgpin() to use the recently introduced s3c_gpio_cfgpin_range(). NOTE: This is for missed things from the previous patch. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-23ARM: S5P64X0: Change to using s3c_gpio_cfgpin_range()Ben Dooks
Change the code setting ranges of GPIO pins using s3c_gpio_cfgpin() to use the recently introduced s3c_gpio_cfgpin_range(). Signed-off-by: Ben Dooks <ben-linux@fluff.org> [kgene.kim@samsung.com: modified to s5p64x0 from s5p6440] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-21ARM: S5P64XX: Remove redundant selection PLAT_S5P.Kukjin Kim
This patch removes redundant selection PLAT_S5P in the CPU_S5P64XX config. Because PLAT_S5P is selected if select ARCH_S5P64XX in the plat-s5p/Kconfig. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-18ARM: S5P64X0: Bug fix on errors of build with CONFIG_PREEMPT_NONESeungChull Suh
This patch adds header <linux/sched.h> into the below files for build with CONFIG_PREEMPT_NONE. arch/arm/mach-s5p64x0/cpu.c Signed-off-by: Seung-Chull Suh <sc.suh@samsung.com> [kgene.kim@samsung.com: edited title and message] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Fix GPIO rbank supportAtul Dahiya
The patch removes s3c_gpio_lock/unlock to avoid acquiring the lock recursively as lock is already acquired by calling function. Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> [kgene.kim@samsung.com: removed useless variable due to this] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: FIX typo in the ADC device nameNaveen Krishna Ch
Fix the touch screen device name from s3c64x0-adc to s3c64xx-adc. Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Move SMDK6440 board file and Add SMDK6450 board fileKukjin Kim
This patch moves smdk6440 board file from mach-s5p6440 into the new mach-s5p64x0 directory and adds smdk6450 board file. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Move GPIO support files for merge S5P64X0Kukjin Kim
This patch moves S5P6440 GPIO support files from mach-s5p6440 into the new mach-s5p64x0 for merge S5P6440 and S5P6450 SocS. NOTE: Not supported S5P6450 GPIO yet. Will be supported soon. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Add S5P6450 I2C supportKukjin Kim
This patch adds S5P6450 I2C support in the ARCH_S5P64X0. And moves S5P6440 I2C support files into the mach-s5p64x0 together. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Move DMA support for S5P64X0Kukjin Kim
This patch moves DMA support files in the mach-s5p64x0 for S5P6440 and S5P6450 SoCs. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Jassi Brar <jassi.brar@samsung.com>
2010-10-18ARM: S5P64X0: Update Audio supportKukjin Kim
This patch updates Audio and SPI for S5P6440 and S5P6450 SoCs. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Jassi Brar <jassi.brar@samsung.com>
2010-10-18ARM: S5P64X0: Update Timer supportKukjin Kim
This patch updates timer support for S5P6440 and S5P6450 SoCs. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Update IRQ supportKukjin Kim
This patch updates IRQ support for S5P6440 and S5P6450 SoCs. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Update Clock for S5P6440 and S5P6450Kukjin Kim
This patch updates regarding clock files for supporting S5P6440 and S5P6450 with one kernel image. The mach-s5p64x0/clock.c is for common of them and there are specific clock files for each SoCs. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Add S5P64X0(S5P6440 and S5P6450) initialization supportKukjin Kim
This patch adds ARCH_S5P64X0 which can support S5P6440 and S5P6450 with one kernel image. So moved some files of mach-s5p6440 into the new ARCH directory mach-s5p64x0. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-18ARM: S5P64X0: Update Kconfig and MakefileKukjin Kim
This patch updates the Kconfig and Makefile for the S5P6440 and S5P6450 machines. It also updates arch/arm/ Kconfig and Makefile to include for support ARCH_S5P64X0 with one kernel image. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
