path: root/arch/arm/mach-s5pc100/setup-i2c0.c
2010-10-23ARM: S5PC100: 2nd Change to using s3c_gpio_cfgall_range()Kukjin Kim
This patch changes the code setting range of GPIO pins' configuration and pull state to use the recently introduced s3c_gpio_cfgpin_range(). NOTE: This is for missed things from the previous patch. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-05-19ARM: S5PC100: Move i2c helpers from plat-s5pc1xx to mach-s5pc100Marek Szyprowski
Move i2c helpers from plat-s5pc1xx to mach-s5pc100. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
