path: root/arch/arm/mach-s5pv210/common.h
2012-01-05ARM: 7252/1: restart: S5PV210: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). [kgene.kim@samsung.com: according to local header, updated] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-23ARM: 7248/1: S5PV210: introduce arch/arm/mach-s5pv210/common.[ch]Kukjin Kim
This patch introduces common.[ch] which are used only in the arch/arm/mach-s5pv210/ directory. The common.c file merges the cpu.c and init.c which are used commonly on S5PCV210/S5PC100 SoC and the common.h local header file replaces with plat/s5pv210.h file. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
