Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch modifies the following.
1. Moves the SROM controller mapping from S5PV210 specific code to
S5P common code. The SROM controller mapping can be used for all
S5P SoCs.
2. Define the SROM controller physical address for S5P64X0, S5P6442,
S5PC100, S5PV210 and S5PV310.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Add the necessary definitions and mapping information to enable the
s3c-hsotg gadget to build.
This patch adds DMC(DRAM Memory Controller) map_desc table.
Because some driver such as CPUFREQ need to access DMC register.
Signed-off-by: Jaecheol Lee <jc.lee@samsung.com>
This patch moves some initial maps from plat-s5p to machine,
so that can merge mach-s5p6440 and mach-s5p6450.
This patch adds header <linux/sched.h> into the below files for build with
CONFIG_PREEMPT_NONE.
arch/arm/mach-s5p6440/cpu.c
arch/arm/mach-s5p6442/cpu.c
arch/arm/mach-s5pc100/cpu.c
arch/arm/mach-s5pv210/cpu.c
Following is error message of in case of s5pv210_defconfig with CONFIG_PREEMPT_NONE.
arch/arm/mach-s5pv210/cpu.c:91: error: implicit declaration of function 'need_resched'
Signed-off-by: SeungChull Suh <sc.suh@samsung.com>
[kgene.kim@samsung.com: removed mach-s5p64x0/cpu.c]
[kgene.kim@samsung.com: added fix mach-s5p6440/cpu.c]
It's enough to use 4KiB.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits)
ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions}
ARM: 6324/1: cam60: move cam60_spi_devices to .init.data
ARM: 6322/1: imx/pca100: Fix name of spi platform data
ARM: 6321/1: fix syntax error in main Kconfig file
ARM: 6297/1: move U300 timer to dynamic clock lookup
ARM: 6296/1: clock U300 intcon and timer properly
ARM: 6295/1: fix U300 apb_pclk split
ARM: 6306/1: fix inverted MMC card detect in U300
ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID
ARM: 6294/1: etm: do a dummy read from OSSRR during initialization
ARM: 6292/1: coresight: add ETM management registers
ARM: 6288/1: ftrace: document mcount formats
ARM: 6287/1: ftrace: clean up mcount assembly indentation
ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR"
ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE
ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h>
ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3
ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig
ARM: S5PV210: Override FIMC driver name on Aquila board
ARM: S5PC100: enable FIMC on SMDKC100
Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to
different subsystem 'setname' calls, and trivial port types in
include/linux/serial_core.h
Add framebuffer device name initialization calls for S3C2443, S3C64xx and
S5P machines.
Signed-off-by: Pawel Osciak <p.osciak@samsung.com>
Cc: InKi Dae <inki.dae@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
arch/arm/mach-s5p6440/Kconfig
arch/arm/mach-s5p6442/Kconfig
arch/arm/mach-s5pc100/Kconfig
arch/arm/mach-s5pv210/Kconfig
arch/arm/plat-samsung/include/plat/sdhci.h
FIMC (CAMIF) device is a camera interface embedded in S3C/S5P Samsung
SOC series. It supports ITU-R BT.601/656 and MIPI-CSI2 standards,
memory to memory operations, color conversion, resizing and rotation.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
This patch implements s3c_adc_setname() for Samsung SoCs.
Also updates its usage in S3C64XX, S5P6440, and S5PV210.
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
This patch adds s5pv210_sw_reset() which includes SWRESET for S5PV210/S5PC110.
Signed-off-by: Jongpill Lee <boyko.lee@samsung.com>
This patch adds support HSMMC on SMDKV210, and gpio configuration for
S5PV210 hsmmc3.
Signed-off-by: Hyuk Lee <hyuk1.lee@samsung.com>
This patch adds the keypad device platform helpers for S5PV210 cpu.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Following is added for the CF-ATA driver:
- Platform data strucure instantiation
- Platform device enabling code
- Platform-specific gpio setup code
- Fixed IRQ naming to match across 64xx and v210
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Ensure the ADC device is touched only if S3C_DEV_ADC
is selected.
Fixes:
arch/arm/mach-s5pv210/built-in.o: In function `s5pv210_map_io':
/home/kgene/bjdooks/arch/arm/mach-s5pv210/cpu.c:92: undefined reference to `s3c_device_adc'
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Merge branch 'for-2635-4/s5pv210-boards' into for-2635-4/partial1
arch/arm/mach-s5pv210/include/mach/map.h
This patch adds sdhci platform helpers required by sdhci-s3c driver.
This patch adds I2C platform helpers required by s3c2440-i2c driver.
This patch adds touchscreen support for S5PV210.
Note: TSADC in S5PV210 support 2 touchscreen interfaces,
Only 1 is implemented as of now.
[ben-linux@fluff.org: minor title fix]
This patch removes static of s5p6440_sysclass, s5p6442_sysclass,
and s5pv210_sysclass for defintion as extern.
This patch adds support for Samsung S5PV210 CPU. This patch also adds
an entry for S5PV210 cpu in plat-s5p cpu table.
