path: root/arch/arm/mach-s5pv210/mach-aquila.c
2012-04-08ARM: S5PV210: fix unused LDO supply field from wm8994_pdataKukjin Kim
According to commit 719a4240("mfd: Remove unused LDO supply field from WM8994 pdata"), the LDO supply field should be removed from the initializer. Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-01-31ARM: S5PV210: Add missing FIMC media device to AquilaSachin Kamat
FIMC media device (md) registers all required video nodes. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-01-09Merge branch 'samsung/dt' into samsung/cleanupArnd Bergmann
Conflicts: arch/arm/mach-s3c64xx/Makefile arch/arm/mach-s5pc100/Makefile arch/arm/mach-s5pv210/Makefile Pull in previously resolved conflicts: The Makefiles were reorganized in the "rmk/restart" series and modified in the "samsung/cleanup series". This also pulls in the other conflict resolutions from the restart series against the samsung/dt series. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: 7252/1: restart: S5PV210: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). [kgene.kim@samsung.com: according to local header, updated] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-24ARM: S5PV210: Use gpio_request_oneJingoo Han
By using gpio_request_one it is possible to set the direction and initial value in one shot. Thus, using gpio_request_one can make the code simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-12-23ARM: 7248/1: S5PV210: introduce arch/arm/mach-s5pv210/common.[ch]Kukjin Kim
This patch introduces common.[ch] which are used only in the arch/arm/mach-s5pv210/ directory. The common.c file merges the cpu.c and init.c which are used commonly on S5PCV210/S5PC100 SoC and the common.h local header file replaces with plat/s5pv210.h file. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-15ARM: samsung: convert to MULTI_IRQ_HANDLERJamie Iles
Now that there is a generic IRQ handler for multiple VIC devices use it for samsung to help building multi platform kernels. Cc: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-08-21ARM: mach-s5pc100, mach-s5pv210: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-21ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210Ajay Kumar
Use plat/regs-fb-v4.h in machine files instead of mach/regs-fb.h. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Update machine of S5P64X0 and S5PV210 for HRTSangbeom Kim
This patch adds support HRT for machines of S5P64X0 and S5PV210. Basically, PWM Timer3 is used for clockevent and PWM Timer4 is used for clocksource. Since PWM Timer3 is used for other purpose, PWM Timer2 is used on SMDKV210. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Use REGULATOR_SUPPLY macro for regulator consumersKukjin Kim
To use REGULATOR_SUPPLY macro is cleaner for initializing regulator consumer supply. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-18ARM: S5PV210: Fix regulator namesMarek Szyprowski
Since commit 1130e5b3ff4 regulators are exported to debugfs. The names of the regulators that contains slash ('/') causes an ops during kernel boot. This patch fixes this issue. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-18ARM: S5PV210: Update max8998_platform_dataMarek Szyprowski
Max8998 PMIC driver's platform data has been changed once again in commit 735a3d9efdc. This patch fixes build break caused by that commit. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-17ARM: S5PV210: update MAX8998 platform data to get rid of WARN()Marek Szyprowski
This patch adds new entries required by the new version of MAX8998 driver. Without them, the driver fails to init. See commit 50f19a4596 Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-28Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mach-s3c64xx/dev-audio.c
2010-10-25ARM: S5PV210: Add voltage consumer of WM8994 to the regulator frameworkChanwoo Choi
This patch add cose related to regulator. To control powre consumeption have registered the voltage consumer of WM8994 to the regulator framework. Additionally, I explain the constraints of the regulator of WM8994 codec. All these consumer supply of WM8994 codec connected the regulator(VCC_1.8V) on a circuit diagram. "VCC_1.8V" regulator is always enabled, because it is used to many devices on Goni/Aquila board. This is required especially when there are many devices physically attached to "VCC_1.8V" and some of they did not "register" as consumers to "VCC_1.8V". "VCC_1.8V" might be turned off by those who are registered while "unregistered" are still active Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PV210: Add init code of audio to Goni and Auqila boardChanwoo Choi
This patch add initialization code of audio and I2S platform drivers to Goni and Aquila board. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-25ARM: S5PV210: Add i2c information to Goni and Aquila boardChanwoo Choi
This patch the I2C board information for the WM8994 used in the Goni/Aquila as audio codec and adds the I2C platform drivers. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-18ARM: S5P: Move OneNAND device definitions in plat-s5pKukjin Kim
This patch moves OneNAND device definitions from mach-s5pv210 to plat-s5p so that can support it commonly. Note: S5PC110 and S5PC210 have same OneNAND driver. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits) ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions} ARM: 6324/1: cam60: move cam60_spi_devices to .init.data ARM: 6322/1: imx/pca100: Fix name of spi platform data ARM: 6321/1: fix syntax error in main Kconfig file ARM: 6297/1: move U300 timer to dynamic clock lookup ARM: 6296/1: clock U300 intcon and timer properly ARM: 6295/1: fix U300 apb_pclk split ARM: 6306/1: fix inverted MMC card detect in U300 ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID ARM: 6294/1: etm: do a dummy read from OSSRR during initialization ARM: 6292/1: coresight: add ETM management registers ARM: 6288/1: ftrace: document mcount formats ARM: 6287/1: ftrace: clean up mcount assembly indentation ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR" ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h> ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3 ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig ARM: S5PV210: Override FIMC driver name on Aquila board ARM: S5PC100: enable FIMC on SMDKC100 ... Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to different subsystem 'setname' calls, and trivial port types in include/linux/serial_core.h
2010-08-11arm: samsung: remove pixclock from several boardsMaurus Cuelenaere
Since "s3c-fb: Automatically calculate pixel clock when none is given", there's no need for manually calculating the pixel clock anymore so remove these lines and add the correct refresh rate where appropriately. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Cc: Pawel Osciak <p.osciak@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09ARM: S5PV210: Override FIMC driver name on Aquila boardSylwester Nawrocki
Change variant of the FIMC driver for compatibility with older SoC version (EVT0) used on Aquila board. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-09ARM: S5PV210: enable FIMC on AquilaSylwester Nawrocki
Add support for FIMC on Samsung Aquila board. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-06Merge branch 'next-s5p' into for-nextKukjin Kim
Conflicts: arch/arm/mach-s5pv210/mach-aquila.c arch/arm/mach-s5pv210/mach-goni.c
2010-08-05ARM: S5PV210: Add SDHCI devices for Aquila boardMarek Szyprowski
This patch add support for SDHCI blocks on Samsung Aquila board. The following host controllers are defined: 1. Internal MoviNAND device (permanently wired to the controller) 2. Internal WiFI SDIO device (card is activated by power regualor) 3. External MMC/SD socket (card detection is provided by external gpio interrupt) Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-05ARM: S5PV210: Add MAX8998 PMIC support for AquilaMarek Szyprowski
This patch adds required platform definitions for MAX8998 PMIC driver. Power regulators for LDO and BUCK outputs has been defined as well as a simple gpio-keys button for power key (to enable wakeup functionality with external interrupt). Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [broonie@opensource.wolfsonmicro.com: For the regulator API usage] Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [kgene.kim@samsung.com: minor title fix] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-05ARM: S5PV210: Add OneNAND device to the Aquila boardJoonyoung Shim
This patch is to support OneNAND device to the Aquila board. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-05ARM: S5PV210: Fix Aquila board UART FIFO mode configrationJoonyoung Shim
The Aquila board uses max UART FIFO size to each UART channels. UART0 supports 256 bytes FIFO, but Aquila board supports 128 bytes FIFO because of initial chip bug. Also, this patch fixes to "s/smdkv210/aquila". Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-08-05ARM: S5P: Changes the definition name of default UART registersKukjin Kim
This patch changes the definition name of default UCON, ULCON, and UFCON UART registers from ARCH(SoC) to Machine(Board). Because it depends on machine. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-05-20ARM: S5PV210: add support for s3c-fb driver on Aquila machineMarek Szyprowski
This patch adds required platform definitions to enable s3c-fb driver. Two framebuffer windows in 480x800x16bpp mode are defined. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-20ARM: S5PV210: add Aquila boardMarek Szyprowski
Add basic support for Samsung Aquila board. This board is based on S5PC110 SoC. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
