path: root/arch/arm/mach-s5pv210
2011-09-27ARM: S5PV210: Rename sclk_cam clocks for FIMC media driverSylwester Nawrocki
The sclk_cam clocks are now controlled by the top level FIMC media device driver bound to "s5p-fimc-md" platform device. Rename sclk_cam clocks so they accessible by the corresponding driver. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: S5PV210: Fix build warningAbhilash Kesavan
Fixed the following warning for S5PV210. arch/arm/mach-s5pv210/pm.c: In function 's5pv210_pm_add': arch/arm/mach-s5pv210/pm.c:139: warning: assignment from incompatible pointer type Also, staticized the function. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] s5pv210: make needlessly global symbols static [CPUFREQ] exynos4210: make needlessly global symbols static [CPUFREQ] S3C6410: Add some lower frequencies for 800MHz base clock operation [CPUFREQ] S5PV210: Add reboot notifier to prevent system hang [CPUFREQ] S5PV210: Adjust udelay prior to voltage scaling down [CPUFREQ] S5PV210: Lock a mutex while changing the cpu frequency [CPUFREQ] S5PV210: Add pm_notifier to prevent system unstable [CPUFREQ] S5PV210: Add arm/int voltage control support [CPUFREQ] S5PV210: Add additional symantics for "relation" in cpufreq with pm [CPUFREQ] S3C64xx: Notify transition complete as soon as frequency changed [CPUFREQ] S3C6410: Support 800MHz operation in cpufreq [CPUFREQ] s5pv210-cpufreq.c: Add missing clk_put [CPUFREQ] Move compile for S3C64XX cpufreq to /drivers/cpufreq [CPUFREQ] Remove some vi noise that escaped into the Makefile. [CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/ [CPUFREQ/S3C64xx] Move S3C64xx CPUfreq driver into drivers/cpufreq [CPUFREQ] Handle CPUs with different capabilities in acpi-cpufreq
2011-07-22Merge branches 'btc', 'dma', 'entry', 'fixes', 'linker-layout', 'misc', ↵Russell King
'mmci', 'suspend' and 'vfp' into for-next
2011-07-21ARM: S5PV210: Enable MFC on GoniKamil Debski
Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: S5P: Add support for MFC deviceKamil Debski
Add support for MFC device to plat-s5p, mach-exynos4, mach-s5pv210: - clock support - memory mapping and reserving - s5p_device_mfc platform device Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-develKukjin Kim
2011-07-21ARM: SAMSUNG: Add IRQ_I2S0 definitionSangbeom Kim
To handle i2s0 interrupt and To fix compilation error adds IRQ_I2S0 for exynos4, s3c64xx, s5p64x0 Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> [kgene.kim@samsung.com: Fixed build failure due to inclusion] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: SAMSUNG: Add platform device for idmaSangbeom Kim
Exynos4 and S5PC110(S5PV210) has Internal dma(idma) in AUDSS. To support idma, register idma platform device. and Exynos4 and S5PC110 has different IDMA address. TO handle different IDMA address, register idma platform data Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210Ajay Kumar
Use plat/regs-fb-v4.h in machine files instead of mach/regs-fb.h. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: S5PV210: Add PWM backlight support on SMDKV210Banajit Goswami
This patch adds support for LCD backlight using PWM timer for Samsung SMDKV210 board. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: SAMSUNG: Move duplicate code for SPDIF opsNaveen Krishna Chatradhi
Move the duplicated code for SPDIF ops from S5PV210 and S5PC100. So, the same can be used in EXYNOS4. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-cleanupKukjin Kim
2011-07-21ARM: SAMSUNG: Added mach/clkdev.hThomas Abraham
This is temporary patch for building with clkdev. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: S5PV210: Support ADCMyungJoo Ham
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: SAMSUNG: Add support for pre-sleep/post-restore gpio controlBen Dooks
Add a callback so that per-arch can do pre-sleep and post-resume gpio configuration so that for the S3C64XX, the GPIO configuration is restored before the sleep mode is cleared. For the S3C64XX case, it means that the GPIOs get set back to normal operation after the restore code puts the original configurations back in after the Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: S5PV210: Add clkdev supportThomas Abraham
2011-07-13[CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/Kukjin Kim
According to discussion of the ARM arch subsystem migration, ARM cpufreq drivers move to drivers/cpufreq. So this patch adds Kconfig.arm for ARM like x86 and adds Samsung S5PV210 and EXYNOS4210 cpufreq driver compile in there. As a note, otherw will be moved. Cc: Dave Jones <davej@redhat.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Dave Jones <davej@redhat.com>
2011-07-06ARM: SAMSUNG: Add tx_st_done variablePadmavathi Venna
tx_st_done is required for checking the transmission status of SPI channels with different fifo levels Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-24ARM: pm: samsung: move cpu_suspend into C codeRussell King
Move the call to cpu_suspend into C code, and noticing that all the s3c_cpu_save implementations are now identical, we can move this into the common samsung code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-24ARM: pm: mach-s5pv210: cleanup s3c_cpu_saveRussell King
s3c_cpu_save does not need to save any registers with the new cpu_suspend calling convention. Remove these redundant instructions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-24ARM: pm: convert cpu_suspend() to a normal functionRussell King
cpu_suspend() has a weird calling method which makes it only possible to call from assembly code: it returns with a modified stack pointer to finish the suspend, but on resume, it 'returns' via a provided pointer. We can make cpu_suspend() appear to be a normal function merely by swapping the resume pointer argument and the link register. Do so, and update all callers to take account of this more traditional behaviour. Acked-by: Frank Hofmann <frank.hofmann@tomtom.com> Tested-by: Kevin Hilman <khilman@ti.com> Acked-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-01ARM: S5PV210: Fix possible null pointer dereferenceJonghwan Choi
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-05-26gpio: Move the s5pv210 GPIO to drivers/gpioKyungmin Park
Move the Samsung s5pv210 SoC GPIO driver to drivers/gpio Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-24ARM / Samsung: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by Samsung platforms with struct syscore_ops objects that are simpler. This generally reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-28ARM: S5PV210: Remove duplicated inclusionHuang Weiyi
Remove duplicated #include('s) in arch/arm/mach-s5pv210/mach-smdkv210.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-28ARM: S5PV210: Fix security engine interrupt namesVladimir Zapolskiy
This change is intended to correct security subsystem interrupt names for Samsung S5PV210 and S5PC110 SoCs. Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits) Input: tsc2005 - remove 'disable' sysfs attribute Input: tsc2005 - add open/close Input: tsc2005 - handle read errors from SPI layer Input: tsc2005 - do not rearm timer in hardirq handler Input: tsc2005 - don't use work for 'pen up' handling Input: tsc2005 - do not use 0 in place of NULL Input: tsc2005 - use true/false for boolean variables Input: tsc2005 - hide selftest attribute if we can't reset Input: tsc2005 - rework driver initialization code Input: tsc2005 - set up bus type in input device Input: tsc2005 - set up parent device Input: tsc2005 - clear driver data after unbinding Input: tsc2005 - add module description Input: tsc2005 - remove driver banner message Input: tsc2005 - remove incorrect module alias Input: tsc2005 - convert to using dev_pm_ops Input: tsc2005 - use spi_get/set_drvdata() Input: introduce tsc2005 driver Input: xen-kbdfront - move to drivers/input/misc Input: xen-kbdfront - add grant reference for shared page ...
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] pcc-cpufreq: remove duplicate statements [CPUFREQ] Remove the pm_message_t argument from driver suspend [CPUFREQ] Remove unneeded locks [CPUFREQ] Remove old, deprecated per cpu ondemand/conservative sysfs files [CPUFREQ] Remove deprecated sysfs file sampling_rate_max [CPUFREQ] powernow-k8: The table index is not worth displaying [CPUFREQ] calculate delay after dbs_check_cpu [CPUFREQ] Add documentation for sampling_down_factor [CPUFREQ] drivers/cpufreq: Remove unnecessary semicolons
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-16[CPUFREQ] Remove the pm_message_t argument from driver suspendRafael J. Wysocki
None of the existing cpufreq drivers uses the second argument of its .suspend() callback (which isn't useful anyway), so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-15ARM: S5P: Add function to register gpio interrupt bank dataMarek Szyprowski
This patch removes all global data from common s5p gpio interrupt handler code. This enables to reuse this code on EXYNOS4 platform. Instead of global data (IRQ_GPIOINT interrupt number, S5P_GPIOINT_GROUP_MAXNR groups count), a s5p_register_gpioint_bank() function is introduced. It is aimed to be called from gpiolib init. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Update defconfig for HRT supportSangbeom Kim
This patch updates s5pv210_defconfig and s5p64x0_defconfig for HRT support and CONFIG_S5P_HRT is used for its configuration. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Update machine of S5P64X0 and S5PV210 for HRTSangbeom Kim
This patch adds support HRT for machines of S5P64X0 and S5PV210. Basically, PWM Timer3 is used for clockevent and PWM Timer4 is used for clocksource. Since PWM Timer3 is used for other purpose, PWM Timer2 is used on SMDKV210. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Add support for common MIPI CSIS/DSIM D-PHY controlSylwester Nawrocki
Add common code for MIPI-CSIS and MIPI-DSIM drivers to support their corresponding D-PHY's enable and reset control. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Add platform helpers for camera GPIO configurationSylwester Nawrocki
Add functions for configuration of the parallel camera bus pins on S5PV210 and Exynos4 SoC. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11Merge branch 'dev/pwm-backlight' into for-nextKukjin Kim
Conflicts: arch/arm/mach-s3c64xx/mach-smdk6410.c
2011-03-03ARM: SAMSUNG: Add PWM backlight support on Samsung S5PV210Banajit Goswami
This patch adds support for LCD backlight control using PWM timer for Samsung's SMDKV210 board. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-24ARM: S5PV210: Add power consumers for hsotg for GONI boardMarek Szyprowski
This patch adds definitions for power consumers for s3c-hsotg driver on Goni board. The consumers are defined as arrays, because later more entries for MIPI and ADC will be defined. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-24ARM: S5PV210: Disable unused power regulators on GONI boardMarek Szyprowski
A lot of power regulator has been enabled by default causing the board to consume a lot of power. This patch fixes this issue. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: pm: convert samsung platforms to generic suspend/resume supportRussell King
Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-22ARM: S5PV210: Change framebuffer window 0 size on GONISylwester Nawrocki
Increase virtual size of the frambuffer window 0 for display panning support. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Add supplies for CIF camera on GONI boardSylwester Nawrocki
Add regulator supplies required for NOON010PC30 CIF sensor. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Enable I2C0 bus on GONI boardSylwester Nawrocki
Add I2C0 bus platform device for camera sensors. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Use REGULATOR_SUPPLY macro for regulator consumersKukjin Kim
To use REGULATOR_SUPPLY macro is cleaner for initializing regulator consumer supply. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
