path: root/arch/arm/mach-s5pv210
2011-07-06ARM: SAMSUNG: Add tx_st_done variablePadmavathi Venna
tx_st_done is required for checking the transmission status of SPI channels with different fifo levels Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-01ARM: S5PV210: Fix possible null pointer dereferenceJonghwan Choi
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-05-26gpio: Move the s5pv210 GPIO to drivers/gpioKyungmin Park
Move the Samsung s5pv210 SoC GPIO driver to drivers/gpio Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-24ARM / Samsung: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by Samsung platforms with struct syscore_ops objects that are simpler. This generally reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-28ARM: S5PV210: Remove duplicated inclusionHuang Weiyi
Remove duplicated #include('s) in arch/arm/mach-s5pv210/mach-smdkv210.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-28ARM: S5PV210: Fix security engine interrupt namesVladimir Zapolskiy
This change is intended to correct security subsystem interrupt names for Samsung S5PV210 and S5PC110 SoCs. Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits) Input: tsc2005 - remove 'disable' sysfs attribute Input: tsc2005 - add open/close Input: tsc2005 - handle read errors from SPI layer Input: tsc2005 - do not rearm timer in hardirq handler Input: tsc2005 - don't use work for 'pen up' handling Input: tsc2005 - do not use 0 in place of NULL Input: tsc2005 - use true/false for boolean variables Input: tsc2005 - hide selftest attribute if we can't reset Input: tsc2005 - rework driver initialization code Input: tsc2005 - set up bus type in input device Input: tsc2005 - set up parent device Input: tsc2005 - clear driver data after unbinding Input: tsc2005 - add module description Input: tsc2005 - remove driver banner message Input: tsc2005 - remove incorrect module alias Input: tsc2005 - convert to using dev_pm_ops Input: tsc2005 - use spi_get/set_drvdata() Input: introduce tsc2005 driver Input: xen-kbdfront - move to drivers/input/misc Input: xen-kbdfront - add grant reference for shared page ...
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] pcc-cpufreq: remove duplicate statements [CPUFREQ] Remove the pm_message_t argument from driver suspend [CPUFREQ] Remove unneeded locks [CPUFREQ] Remove old, deprecated per cpu ondemand/conservative sysfs files [CPUFREQ] Remove deprecated sysfs file sampling_rate_max [CPUFREQ] powernow-k8: The table index is not worth displaying [CPUFREQ] calculate delay after dbs_check_cpu [CPUFREQ] Add documentation for sampling_down_factor [CPUFREQ] drivers/cpufreq: Remove unnecessary semicolons
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-16[CPUFREQ] Remove the pm_message_t argument from driver suspendRafael J. Wysocki
None of the existing cpufreq drivers uses the second argument of its .suspend() callback (which isn't useful anyway), so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-15ARM: S5P: Add function to register gpio interrupt bank dataMarek Szyprowski
This patch removes all global data from common s5p gpio interrupt handler code. This enables to reuse this code on EXYNOS4 platform. Instead of global data (IRQ_GPIOINT interrupt number, S5P_GPIOINT_GROUP_MAXNR groups count), a s5p_register_gpioint_bank() function is introduced. It is aimed to be called from gpiolib init. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Update defconfig for HRT supportSangbeom Kim
This patch updates s5pv210_defconfig and s5p64x0_defconfig for HRT support and CONFIG_S5P_HRT is used for its configuration. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-12ARM: S5P: Update machine of S5P64X0 and S5PV210 for HRTSangbeom Kim
This patch adds support HRT for machines of S5P64X0 and S5PV210. Basically, PWM Timer3 is used for clockevent and PWM Timer4 is used for clocksource. Since PWM Timer3 is used for other purpose, PWM Timer2 is used on SMDKV210. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Add support for common MIPI CSIS/DSIM D-PHY controlSylwester Nawrocki
Add common code for MIPI-CSIS and MIPI-DSIM drivers to support their corresponding D-PHY's enable and reset control. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: S5P: Add platform helpers for camera GPIO configurationSylwester Nawrocki
Add functions for configuration of the parallel camera bus pins on S5PV210 and Exynos4 SoC. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11Merge branch 'dev/pwm-backlight' into for-nextKukjin Kim
Conflicts: arch/arm/mach-s3c64xx/mach-smdk6410.c
2011-03-03ARM: SAMSUNG: Add PWM backlight support on Samsung S5PV210Banajit Goswami
This patch adds support for LCD backlight control using PWM timer for Samsung's SMDKV210 board. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-24ARM: S5PV210: Add power consumers for hsotg for GONI boardMarek Szyprowski
This patch adds definitions for power consumers for s3c-hsotg driver on Goni board. The consumers are defined as arrays, because later more entries for MIPI and ADC will be defined. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-24ARM: S5PV210: Disable unused power regulators on GONI boardMarek Szyprowski
A lot of power regulator has been enabled by default causing the board to consume a lot of power. This patch fixes this issue. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: pm: convert samsung platforms to generic suspend/resume supportRussell King
Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-22ARM: S5PV210: Change framebuffer window 0 size on GONISylwester Nawrocki
Increase virtual size of the frambuffer window 0 for display panning support. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Add supplies for CIF camera on GONI boardSylwester Nawrocki
Add regulator supplies required for NOON010PC30 CIF sensor. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Enable I2C0 bus on GONI boardSylwester Nawrocki
Add I2C0 bus platform device for camera sensors. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-22ARM: S5PV210: Use REGULATOR_SUPPLY macro for regulator consumersKukjin Kim
To use REGULATOR_SUPPLY macro is cleaner for initializing regulator consumer supply. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-21Input: atmel_mxt_ts - allow board code to specify IRQ flagsIiro Valkonen
Different board have different requirements/setups so let's be more flexible. Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-21Input: atmel_mxt_ts - get rid of qt602240 prefixes in namesIiro Valkonen
Change prefixes from qt602240 to mxt to reflect that the driver supports whole line of mXT touchscreens. Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-21Input: qt602240_ts - rename to atmel_mxt_tsDmitry Torokhov
Since the driver will be supporting whole range of Atmels mXT touchscreen controllers we better rename it to atmel_mxt_ts. Acked-by: Iiro Valkonen <iiro.valkonen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-02-18ARM: S5PV210: Fix regulator namesMarek Szyprowski
Since commit 1130e5b3ff4 regulators are exported to debugfs. The names of the regulators that contains slash ('/') causes an ops during kernel boot. This patch fixes this issue. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-18ARM: S5PV210: Update max8998_platform_dataMarek Szyprowski
Max8998 PMIC driver's platform data has been changed once again in commit 735a3d9efdc. This patch fixes build break caused by that commit. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-17ARM: P2V: avoid initializers and assembly using PHYS_OFFSETRussell King
As PHYS_OFFSET will be becoming a variable, we can't have it used in initializers nor assembly code. Replace those in generic code with a run-time initialization. Replace those in platform code using the individual platform specific PLAT_PHYS_OFFSET. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: S5PV210: Cleanup map.h fileKukjin Kim
2011-01-18ARM: S5PV210: Add missing virtual ASoC DMA deviceJassi Brar
Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-13Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-01-05Merge branch 'dev/cleanup-clocks' into for-nextKukjin Kim
2011-01-04ARM: S5PV210: Tidy init+disable clock usage and s3c24xx_register_clocks cleanupKukjin Kim
This patch changes the clock registration code to use the s3c_register_clocks() followed by s3c_disable_clocks() instead of the loops it was using and cleanups the return of s3c24xx_register_clocks() because it includes it. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30Merge branch 'next-s5pv210' into for-next-newKukjin Kim
Conflicts: arch/arm/mach-s5pv210/mach-smdkv210.c
2010-12-30Merge branch 'next-s5p' into for-next-newKukjin Kim
2010-12-30ARM: S5PV210: Add resource definitions for MIPI CSISSylwester Nawrocki
Naming changed for consistency with s5pv310 where there are two instances of the device. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: S5PV210: Add DM9000 support on SMDKV210Thomas Abraham
This patch adds DM9000 Ethernet Controller device support for SMDKV210. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: S5PV210: Add SROM controller clockThomas Abraham
This patch adds the SROM controller clock to the list of clocks to be enabled at boot time. It is required to be enabled at boot time since the modules connected over the SROM interface such as the Ethernet controller need an operational SROM. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: S5P: Move SROM controller IO mapping to plat-s5p for S5P SoCsThomas Abraham
This patch modifies the following. 1. Moves the SROM controller mapping from S5PV210 specific code to S5P common code. The SROM controller mapping can be used for all S5P SoCs. 2. Define the SROM controller physical address for S5P64X0, S5P6442, S5PC100, S5PV210 and S5PV310. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: S5PV210: Add frame buffer display support for SMDKV210Thomas Abraham
Enable frame buffer display support for SMDKV210 board. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Reviewed-by: Jonghun Han <jonghun.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: S5PV210: Enable I2S device to work on SMDKV210Jassi Brar
Add missing virtual ASoC DMA device and WM8580 as I2C slave, so that the I2S can work on SMDKV210. [kgene.kim@samsung.com: removed virtual ASoC DMA device to avoid build error and it will be added next time] Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-30ARM: S5PV210: Enable I2S device to work on SMDKC110Jassi Brar
Add missing virtual ASoC DMA device and WM8580 as I2C slave, so that the I2S can work on SMDKC110. [kgene.kim@samsung.com: removed virtual ASoC DMA device to avoid build error and it will be added next time] Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> [kgene.kim@samsung.com: minor changed title] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-12-22Merge branch 'next-samsung-asoc' into next-samsung-asoc2Kukjin Kim
