This patch adds nanoEngine's PCI support.
Signed-off-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Adds Bright Star Engineering's nanoEngine board support to the kernel.
Also:
- Adds the nanoEngine memory chip to arch/arm/mach-sa1100/cpu-sa1110.c
(Micron MT48LC8M16A2TG-75).
- Increase in the sdram_params->name[] field length to accomodate the
name of the memory chip.
- Clean up of header content and order of
Split common h3600.c into three separate files: h3100.c, h3600.c and
h3xxx.c (the latter contains common code for h3100/h3600)
Copyright boilerplates and #includes are copied intact and will be
cleaned up later.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
Both iPaqs h3100 and h3600 currently share the same source
file - h3600.c But Makefile builds it only if CONFIG_SA1100_H3600
selected, so selecting just CONFIG_SA1100_H3100 results in
"no machine record defined" message and aborted compilation.
Fix it.
Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
This patch removes the commented out line for the not available
CONFIG_SA1100_USB option.
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This adds gpiolib support for the SA-1100 arch:
- Move all GPIO API functions from generic.c into gpio.c
- Convert all gpio functions into gpiolib callbacks.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
These patches add full SSP/MCU support for the HP Jornada 720
machine. Its needed to handle keyboard, touchscreen, battery
and backlight/lcd.
The main driver exports functions and the header file exports
the command values. When talking to the MCU the general procedure
is to start MCU, send command (using ssp_inout(command)), the
proper reply is always TXDUMMY. After receiving TXDUMMY you can
send the value you wish pushed (for example brightness level).
End with ssp_end() so the spinlock gets unlocked.
Drivers using this havent been implemented yet, but will shortly.
Signed-off-by: Kristoffer Ericson <Kristoffer.ericson@gmail.com>
infrastructure for it.
Let it rip!
