path: root/arch/arm/mach-sa1100/collie.c
2015-02-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: - clang assembly fixes from Ard - optimisations and cleanups for Aurora L2 cache support - efficient L2 cache support for secure monitor API on Exynos SoCs - debug menu cleanup from Daniel Thompson to allow better behaviour for multiplatform kernels - StrongARM SA11x0 conversion to irq domains, and pxa_timer - kprobes updates for older ARM CPUs - move probes support out of arch/arm/kernel to arch/arm/probes - add inline asm support for the rbit (reverse bits) instruction - provide an ARM mode secondary CPU entry point (for Qualcomm CPUs) - remove the unused ARMv3 user access code - add driver_override support to AMBA Primecell bus * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits) ARM: 8256/1: driver coamba: add device binding path 'driver_override' ARM: 8301/1: qcom: Use secondary_startup_arm() ARM: 8302/1: Add a secondary_startup that assumes ARM mode ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip ARM: kprobes: Fix compilation error caused by superfluous '*' ARM: 8297/1: cache-l2x0: optimize aurora range operations ARM: 8296/1: cache-l2x0: clean up aurora cache handling ARM: 8284/1: sa1100: clear RCSR_SMR on resume ARM: 8283/1: sa1100: collie: clear PWER register on machine init ARM: 8282/1: sa1100: use handle_domain_irq ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver ARM: 8280/1: sa1100: switch to irq_domain_add_simple() ARM: 8279/1: sa1100: merge both GPIO irqdomains ARM: 8278/1: sa1100: split irq handling for low GPIOs ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code ARM: 8290/1: decompressor: fix a wrong comment ARM: 8286/1: mm: Fix dma_contiguous_reserve comment ARM: 8248/1: pm: remove outdated comment ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X) ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX ...
2015-01-29ARM: 8283/1: sa1100: collie: clear PWER register on machine initDmitry Eremin-Solenikov
Let kernel drivers to control wakeup sources instead of hardcoding them in the collie.c board file. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-12-30arm: sa1100: move irda header to linux/platform_dataDmitry Eremin-Solenikov
In the end asm/mach/irda.h header is not used by anybody except sa1100. Move the header to the platform data includes dir and rename it to irda-sa11x0.h. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-27ARM: 8217/1: sa1100 collie: use gpio-charger instead of pda-powerDmitry Eremin-Solenikov
Use gpio-charger driver instead of pda-power: it automatically cares about used gpio and since collie does not differentiate between usb and ac chargers, pda-power is an overkill for it. As a bonus this allows us to remove gpio_to_irq calls from machine init call - it is fragile. These gpio_to_irq calls will fail if gpios are registered later, via device driver mechanisms. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8085/1: sa1100: collie: add top boot mtd partitionAndrea Adami
The CFI mapping is now perfect so we can expose the top block, read only. There isn't much to read, though, just the sharpsl_params values. Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8084/1: sa1100: collie: revert back to cfi_probeAndrea Adami
Reverts commit d26b17edafc45187c30cae134a5e5429d58ad676 ARM: sa1100: collie.c: fall back to jedec_probe flash detection Unfortunately the detection was challenged on the defective unit used for tests: one of the NOR chips did not respond to the CFI query. Moreover that bad device needed extra delays on erase-suspend/resume cycles. Tested personally on 3 different units and with feedback of two other users. Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-02-12ARM: 7936/1: sa1100: collie: add support for IrDA transceiverDmitry Eremin-Solenikov
Collie has onboard IrDA transceiver controlled via active-low gpio. Add corresponding platform data. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-01-11ARM: 7935/1: sa1100: collie: add gpio-keys configurationDmitry Eremin-Solenikov
collie has several GPIO lines that act like keys - Sync/Wakeup button on dock station is connected to GPIO line. Another one is connected to on/off button. Add corresponding gpio-keys configuration. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-09-18ARM: sa1100: collie.c: fall back to jedec_probe flash detectionAndrea Adami
Zaurus collie contains 2 LH28F640BFHE-PTTL90 (64M 4Mx16) and at the moment cfi will not detect the collie NOR. In the meanwhile we can revert to the jedec-probe map which has been fixed with following commit: mtd: jedec_probe: fix LH28F640BF definition fe2f4c8e0bf2756b670ee78fa9772613a2ea8495 Somehow this is unsatisfactory because the flash is mounted READ ONLY (as from factory, with a RO cramfs) Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-16ARM: move serial_sa1100.h header file to linux/platform_dataRussell King
This is really driver platform data, so move it to the appropriate directory. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-09-14ARM: sa1100: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the sa1100 include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Jochen Friedrich <jochen@scram.de>
2012-05-08ARM: sa1100: use machine specific hook for late initShawn Guo
Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-04-02ARM: fix lcd power build failure in collie_defconfigPaul Gortmaker
Commit 086ada54abaa4316e8603f02410fe8ebc9ba2de1 "FB: sa1100: remove global sa1100fb_.*_power function pointers" got rid of all instances but one in locomolcd.c -- which was conditional on CONFIG_SA1100_COLLIE. The associated .power field which replaces the global is populated in mach-sa1100/collie.c so move the assignment there, but make it conditional on the locomolcd support, so use CONFIG_BACKLIGHT_LOCOMO in that file. Cc: arm@kernel.org Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-25ARM: 7342/2: sa1100: prepare for sparse irq conversionRob Herring
In preparation to convert SA1100 to sparse irq, set .nr_irqs for each machine and explicitly include mach/irqs.h as needed. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-25Merge branch 'sa11x0-mcp' into sa11x0Russell King
Conflicts: arch/arm/mach-sa1100/assabet.c arch/arm/mach-sa1100/collie.c arch/arm/mach-sa1100/generic.c arch/arm/mach-sa1100/lart.c arch/arm/mach-sa1100/shannon.c
2012-03-25Merge branch 'sa11x0-lcd' into sa11x0Russell King
2012-02-21FB: sa1100: move platform data to platform filesRussell King
Move platform data out of the sa1100fb driver into the various platform files themselves. Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-18MFD: mcp/ucb1x00: separate ucb1x00 driver data from the MCP dataRussell King
Patch taken from 5dd7bf59e0 (ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus.) by Jochen Friedrich <jochen@scram.de>. This adds just the codec data part of the patch. Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-09ARM: sa11x0: convert to use DEFINE_RES_xxx macrosRussell King
Convert StrongARM-11x0 platforms and core SoC code to use the DEFINE_RES_xxx macros. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-03MFD: mcp-sa11x0: move setup of PPC unit out of mcp-sa11x0.cRussell King
Patch taken from af9081ae64 (ARM: sa1100: Refactor mcp-sa11x0 to use platform resources.) by Jochen Friedrich <jochen@scram.de>, and consolidated to use a common function. Move the setup of the PPC unit out of mcp-sa11x0 into the core SA11x0 code, and call it from each platforms initialization file. This centralizes the setup of the PPC unit while not polluting the mcp-sa11x0 driver with these details. Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-26Merge branch 'sa11x0-mcp-fixes' into fixesRussell King
2012-01-20Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp ↵Russell King
bus." This reverts commit 5dd7bf59e0e8563265b3e5b33276099ef628fcc7. Conflicts: scripts/mod/file2alias.c This change is wrong on many levels. First and foremost, it causes a regression. On boot on Assabet, which this patch gives a codec id of 'ucb1x00', it gives: ucb1x00 ID not found: 1005 0x1005 is a valid ID for the UCB1300 device. Secondly, this patch is way over the top in terms of complexity. The only device which has been seen to be connected with this MCP code is the UCB1x00 (UCB1200, UCB1300 etc) devices, and they all use the same driver. Adding a match table, requiring the codec string to match the hardware ID read out of the ID register, etc is completely over the top when we can just read the hardware ID register.
2012-01-20Revert "ARM: sa1100: Refactor mcp-sa11x0 to use platform resources."Russell King
This reverts commit af9081ae64b941d32239b947882cd59ba855c5db. This revert is necessary to revert 5dd7bf59e0e8563265b3e5b33276099ef628fcc7.
2012-01-19ARM: sa11x0: fix collie build errorRussell King
f408c985cefc (GPIO: sa1100: implement proper gpiolib gpio_to_irq conversion) made gpio_to_irq() a function. This breaks collie where it's used to initialize some static data. Fix that by moving the initialization to the init code. arch/arm/mach-sa1100/collie.c:139: error: initializer element is not constant arch/arm/mach-sa1100/collie.c:139: error: (near initialization for 'collie_power_resource[0].start') arch/arm/mach-sa1100/collie.c:140: error: initializer element is not constant arch/arm/mach-sa1100/collie.c:140: error: (near initialization for 'collie_power_resource[0].end') Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits) rtc: max8925: Add function to work as wakeup source mfd: Add pm ops to max8925 mfd: Convert aat2870 to dev_pm_ops mfd: Still check other interrupts if we get a wm831x touchscreen IRQ mfd: Introduce missing kfree in 88pm860x probe routine mfd: Add S5M series configuration mfd: Add s5m series irq driver mfd: Add S5M core driver mfd: Improve mc13xxx dt binding document mfd: Fix stmpe section mismatch mfd: Fix stmpe build warning mfd: Fix STMPE I2c build failure mfd: Constify aat2870-core i2c_device_id table gpio: Add support for stmpe variant 801 mfd: Add support for stmpe variant 801 mfd: Add support for stmpe variant 610 mfd: Add support for STMPE SPI interface mfd: Separate out STMPE controller and interface specific code misc: Remove max8997-muic sysfs attributes mfd: Remove unused wm831x_irq_data_to_mask_reg() ... Fix up trivial conflict in drivers/leds/Kconfig due to addition of LEDS_MAX8997 and LEDS_TCA6507 next to each other.
2012-01-09ARM: sa1100: Refactor mcp-sa11x0 to use platform resources.Jochen Friedrich
Make use of memory resources rather than hardcoded IO adresses. This is a first step towards DT support. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-01-09ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus.Jochen Friedrich
2012-01-05ARM: restart: sa1100: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-31arm: fix implicit use of page.h in several arch/arm filesPaul Gortmaker
Add the include to fix things like this: arch/arm/mach-sa1100/jornada720.c:278: error: 'PAGE_SHIFT' undeclared here (not in a function) arch/arm/mach-bcmring/mm.c:32: error: 'PAGE_SHIFT' undeclared here (not in a function) arch/arm/mach-sa1100/collie.c:361: error: 'PAGE_SHIFT' undeclared here (not in a function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-11ARM: 6658/1: collie: do actually pass locomo_info to locomo driverDmitry Eremin-Solenikov
locomo_info isn't actually used as a platform_data on collie platform: arm/mach-sa1100/collie.c:237: warning: ‘locomo_info’ defined but not used So locomo driver doesn't setup IRQs correctly. Pass locomo_info to the driver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-07-19update email addressPavel Machek
pavel@suse.cz no longer works, replace it with working address. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-02[ARM] locomo: allow cascaded IRQ base to be specified by platformsEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-06Merge branch 'for-lak' of git://git.linuxtogo.org/home/thesing/collie into ↵Russell King
sa1100
2009-12-06ARM: sa11x0: convert set_xxx_data() to register_xxx()Russell King
Only register devices if we have platform data for those which require platform data. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-27collie: support pda_power driverThomas Kunze
This add the pda-power platform device to collie.
2009-11-27collie: convert to gpiolib for ucb1x00Thomas Kunze
Only the parts used for collie_battery are converted. The rest will be cleaned up later.
2009-11-27collie: prepare for gpiolib useThomas Kunze
prefix gpio definitions for direct register access with '_' so we can use the other names for gpio_request & co
2009-11-27collie: fix scoop convesion to new apiThomas Kunze
2009-03-25[ARM] collie: fix two minor formatting nitsRussell King
2009-03-25[ARM] 5429/1: collie: start scoop converton to new apiDmitry Baryshkov
Start converting scoop gpio access to new API instead of old deprecated one. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-01[ARM] 5336/1: Formatting/Whitespace cleanups in mach-sa1100Kristoffer Ericson
This patch fixes bad formatting found in mach-sa1100 files. What it does is to replace/delete things like excessive spaces (start || endline). The code looks the same just alot less junk. Signed-off-by: Kristoffer Ericson <Kristoffer.Ericson@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[ARM] 5025/2: fix collie cpu initialisationThomas Kunze
collie.h: * add some meaningfull names to some gpios collie.c: * initialize cpu registers correctly Signed-off-by: Thomas Kunze <thommycheck@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3847/2: Convert LOMOMO to use struct device for GPIOsRichard Purdie
Convert LOMOMO to use struct device * for GPIOs instead of struct locomo_dev. This enables access to the GPIOs from code which is not a locomo device itself (such as audio). Access for gpio 31 is removed for error handling (no such hardware exists). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-11[ARM] 3727/1: fix ucb initialization on colliePavel Machek
Patch from Pavel Machek From: Dirk Opfer <Dirk@Opfer-Online.de> Fix ucb initialization on collie. Wrong frequency was used and that led to things not working quite correctly. (I had to actually disable checks in my tree to get it to boot). It now includes all the neccessary parts to get it to compile :-). Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-01[ARM] 3436/1: 2.6.16-git18: collie_defconfig brokenPavel Machek
Patch from Pavel Machek > The kautobuild found the following error while trying to build 2.6.16-git18 > using collie_defconfig: > > arch/arm/mach-sa1100/collie.c:92: error: 'collie_uart_set_mctrl' undeclared here (not in a function) > arch/arm/mach-sa1100/collie.c:93: error: 'collie_uart_get_mctrl' undeclared here (not in a function) > make[1]: *** [arch/arm/mach-sa1100/collie.o] Error 1 > make: *** [arch/arm/mach-sa1100] Error 2 > make: Leaving directory `/var/tmp/kernel-orig' This fixes above compile error by adding missing pieces of uart support, and fixes compilation. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
