path: root/arch/arm/mach-sa1100
2019-07-19Merge tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/socLinus Torvalds
Pull ARM SoC platform updates from Olof Johansson: "SoC platform changes. Main theme this merge window: - The Netx platform (Netx 100/500) platform is removed by Linus Walleij-- the SoC doesn't have active maintainers with hardware, and in discussions with the vendor the agreement was that it's OK to remove. - Russell King has a series of patches that cleans up and refactors SA1101 and RiscPC support" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (47 commits) ARM: stm32: use "depends on" instead of "if" after prompt ARM: sa1100: convert to common clock framework ARM: exynos: Cleanup cppcheck shifting warning ARM: pxa/lubbock: remove lubbock_set_misc_wr() from global view ARM: exynos: Only build MCPM support if used arm: add missing include platform-data/atmel.h ARM: davinci: Use GPIO lookup table for DA850 LEDs ARM: OMAP2: drop explicit assembler architecture ARM: use arch_extension directive instead of arch argument ARM: imx: Switch imx7d to imx-cpufreq-dt for speed-grading ARM: bcm: Enable PINCTRL for ARCH_BRCMSTB ARM: bcm: Enable ARCH_HAS_RESET_CONTROLLER for ARCH_BRCMSTB ARM: riscpc: enable chained scatterlist support ARM: riscpc: reduce IRQ handling code ARM: riscpc: move RiscPC assembly files from arch/arm/lib to mach-rpc ARM: riscpc: parse video information from tagged list ARM: riscpc: add ecard quirk for Atomwide 3port serial card MAINTAINERS: mvebu: Add git entry soc: ti: pm33xx: Add a print while entering RTC only mode with DDR in self-refresh ARM: OMAP2+: Make some variables static ...
2019-07-15Merge branch 'for-arm-soc' of git://git.armlinux.org.uk/~rmk/linux-arm into ↵Olof Johansson
arm/soc * 'for-arm-soc' of git://git.armlinux.org.uk/~rmk/linux-arm: (21 commits) ARM: sa1100: convert to common clock framework ARM: riscpc: enable chained scatterlist support ARM: riscpc: reduce IRQ handling code ARM: riscpc: move RiscPC assembly files from arch/arm/lib to mach-rpc ARM: riscpc: parse video information from tagged list ARM: riscpc: add ecard quirk for Atomwide 3port serial card ARM: sa1100/neponset: convert serial to use gpiod APIs ARM: sa1100/hackkit: remove empty serial mctrl functions ARM: sa1100/badge4: remove commented out modem control initialisers ARM: sa1100/h3xxx: convert serial to gpiod APIs ARM: sa1100/assabet: convert serial to gpiod APIs serial: sa1100: add note about modem control signals serial: sa1100: add support for mctrl gpios ARM: riscpc: dma: use __iomem pointers for writing DMA ARM: riscpc: dma: improve address/length writing ARM: riscpc: dma: make state a local variable ARM: riscpc: dma: eliminate "cur_sg" scatterlist usage ARM: riscpc: fix DMA ARM: riscpc: fix ecard printing ARM: riscpc: fix lack of keyboard interrupts after irq conversion ... Signed-off-by: Olof Johansson <olof@lixom.net>
2019-07-03ARM: sa1100: convert to common clock frameworkRussell King
Convert sa1100 to use the common clock framework. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-04ARM: sa1100/neponset: convert serial to use gpiod APIsRussell King
Convert the serial modem control signals to use the gpiod APIs rather than the private platform callbacks. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2019-06-04ARM: sa1100/hackkit: remove empty serial mctrl functionsRussell King
Remove the empty serial modem control signal functions from hackkit as these are unnecessary - the core code can copes fine without these. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2019-06-04ARM: sa1100/badge4: remove commented out modem control initialisersRussell King
Remove the commented out modem control initialisers. These are doing nothing useful. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2019-06-04ARM: sa1100/h3xxx: convert serial to gpiod APIsRussell King
Convert the iPAQ H3xxx serial modem control signals to use the gpiod APIs rather than custom callbacks into platform code. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2019-06-04ARM: sa1100/assabet: convert serial to gpiod APIsRussell King
Convert the Assabet serial modem control signals to use the gpiod APIs rather than custom callbacks into platform code. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 156Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 59 temple place suite 330 boston ma 02111 1307 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1334 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-14treewide: replace #include <asm/sizes.h> with #include <linux/sizes.h>Masahiro Yamada
Since commit dccd2304cc90 ("ARM: 7430/1: sizes.h: move from asm-generic to <linux/sizes.h>"), <asm/sizes.h> and <asm-generic/sizes.h> are just wrappers of <linux/sizes.h>. This commit replaces all <asm/sizes.h> and <asm-generic/sizes.h> to prepare for the removal. Link: http://lkml.kernel.org/r/1553267665-27228-1-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-03-08Merge tag 'gpio-v5.1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v5.1 cycle: Core changes: - The big change this time around is the irqchip handling in the qualcomm pin controllers, closely coupled with the gpiochip. This rework, in a classic fall-between-the-chairs fashion has been sidestepped for too long. The Qualcomm IRQchips using the SPMI and SSBI transport mechanisms have been rewritten to use hierarchical irqchip. This creates the base from which I intend to gradually pull support for hierarchical irqchips into the gpiolib irqchip helpers to cut down on duplicate code. We have too many hacks in the kernel because people have been working around the missing hierarchical irqchip for years, and once it was there, noone understood it for a while. We are now slowly adapting to using it. This is why this pull requests include changes to MFD, SPMI, IRQchip core and some ARM Device Trees pertaining to the Qualcomm chip family. Since Qualcomm have so many chips and such large deployments it is paramount that this platform gets this right, and now it (hopefully) does. - Core support for pull-up and pull-down configuration, also from the device tree. When a simple GPIO chip supports an "off or on" pull-up or pull-down resistor, we provide a way to set this up using machine descriptors or device tree. If more elaborate control of pull up/down (such as resistance shunt setting) is required, drivers should be phased over to use pin control. We do not yet provide a userspace ABI for this pull up-down setting but I suspect the makers are going to ask for it soon enough. PCA953x is the first user of this new API. - The GPIO mockup driver has been revamped after some discussion improving the IRQ simulator in the process. The idea is to make it possible to use the mockup for both testing and virtual prototyping, e.g. when you do not yet have a GPIO expander to play with but really want to get something to develop code around before hardware is available. It's neat. The blackbox testing usecase is currently making its way into kernelci. - ACPI GPIO core preserves non direction flags when updating flags. - A new device core helper for devm_platform_ioremap_resource() is funneled through the GPIO tree with Greg's ACK. New drivers: - TQ-Systems QTMX86 GPIO controllers (using port-mapped I/O) - Gateworks PLD GPIO driver (vaccumed up from OpenWrt) - AMD G-Series PCH (Platform Controller Hub) GPIO driver. - Fintek F81804 & F81966 subvariants. - PCA953x now supports NXP PCAL6416. Driver improvements: - IRQ support on the Nintendo Wii (Hollywood) GPIO. - get_direction() support for the MVEBU driver. - Set the right output level on SAMA5D2. - Drop the unused irq trigger setting on the Spreadtrum driver. - Wakeup support for PCA953x. - A slew of cleanups in the various Intel drivers" * tag 'gpio-v5.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (110 commits) gpio: gpio-omap: fix level interrupt idling gpio: amd-fch: Set proper output level for direction_output x86: apuv2: remove unused variable gpio: pca953x: Use PCA_LATCH_INT platform/x86: fix PCENGINES_APU2 Kconfig warning gpio: pca953x: Fix dereference of irq data in shutdown gpio: amd-fch: Fix type error found by sparse gpio: amd-fch: Drop const from resource gpio: mxc: add check to return defer probe if clock tree NOT ready gpio: ftgpio: Register per-instance irqchip gpio: ixp4xx: Add DT bindings x86: pcengines apuv2 gpio/leds/keys platform driver gpio: AMD G-Series PCH gpio driver drivers: depend on HAS_IOMEM for devm_platform_ioremap_resource() gpio: tqmx86: Set proper output level for direction_output gpio: sprd: Change to use SoC compatible string gpio: sprd: Use SoC compatible string instead of wildcard string gpio: of: Handle both enable-gpio{,s} gpio: of: Restrict enable-gpio quirk to regulator-gpio gpio: davinci: use devm_platform_ioremap_resource() ...
2019-02-06regulator: fixed/gpio: Pull inversion/OD into gpiolibLinus Walleij
This pushes the handling of inversion semantics and open drain settings to the GPIO descriptor and gpiolib. All affected board files are also augmented. This is especially nice since we don't have to have any confusing flags passed around to the left and right littering the fixed and GPIO regulator drivers and the regulator core. It is all just very straight-forward: the core asks the GPIO line to be asserted or deasserted and gpiolib deals with the rest depending on how the platform is configured: if the line is active low, it deals with that, if the line is open drain, it deals with that too. Cc: Alexander Shiyan <shc_work@mail.ru> # i.MX boards user Cc: Haojian Zhuang <haojian.zhuang@gmail.com> # MMP2 maintainer Cc: Aaro Koskinen <aaro.koskinen@iki.fi> # OMAP1 maintainer Cc: Tony Lindgren <tony@atomide.com> # OMAP1,2,3 maintainer Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> # EM-X270 maintainer Cc: Robert Jarzmik <robert.jarzmik@free.fr> # EZX maintainer Cc: Philipp Zabel <philipp.zabel@gmail.com> # Magician maintainer Cc: Petr Cvek <petr.cvek@tul.cz> # Magician Cc: Robert Jarzmik <robert.jarzmik@free.fr> # PXA Cc: Paul Parsons <lost.distance@yahoo.com> # hx4700 Cc: Daniel Mack <zonque@gmail.com> # Raumfeld maintainer Cc: Marc Zyngier <marc.zyngier@arm.com> # Zeus maintainer Cc: Geert Uytterhoeven <geert+renesas@glider.be> # SuperH pinctrl/GPIO maintainer Cc: Russell King <rmk+kernel@armlinux.org.uk> # SA1100 Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Janusz Krzysztofik <jmkrzyszt@gmail.com> #OMAP1 Amstrad Delta Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2019-01-21arm/mach-sa1100/simpad.c: Remove duplicate headerSouptick Joarder
Remove linux/gpio/machine.h which is included more than once. Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2019-01-05Merge tag 'for-4.21' of git://git.armlinux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this update: - Florian Fainelli noticed that userspace segfaults caused by the lack of kernel-userspace helpers was hard to diagnose; we now issue a warning when userspace tries to use the helpers but the kernel has them disabled. - Ben Dooks wants compatibility for the old ATAG serial number with DT systems. - Some cleanup of assembly by Nicolas Pitre. - User accessors optimisation from Vincent Whitchurch. - More robust kdump on SMP systems from Yufen Wang. - Sebastian Andrzej Siewior noticed problems with the SMP "boot_lock" on RT kernels, and so we convert the Versatile series of platforms to use a raw spinlock instead, consolidating the Versatile implementation. We entirely remove the boot_lock on OMAP systems, where it's unnecessary. Further patches for other systems will be submitted for the following merge window. - Start switching old StrongARM-11x0 systems to use gpiolib rather than their private GPIO implementation - mostly PCMCIA bits. - ARM Kconfig cleanups. - Cleanup a mostly harmless mistake in the recent Spectre patch in 4.20 (which had the effect that data that can be placed into the init sections was incorrectly always placed in the rodata section)" * tag 'for-4.21' of git://git.armlinux.org.uk/~rmk/linux-arm: (25 commits) ARM: omap2: remove unnecessary boot_lock ARM: versatile: rename and comment SMP implementation ARM: versatile: convert boot_lock to raw ARM: vexpress/realview: consolidate immitation CPU hotplug ARM: fix the cockup in the previous patch ARM: sa1100/cerf: switch to using gpio_led_register_device() ARM: sa1100/assabet: switch to using gpio leds ARM: sa1100/assabet: add gpio keys support for right-hand two buttons ARM: sa1111: remove legacy GPIO interfaces pcmcia: sa1100*: remove redundant bvd1/bvd2 setting ARM: pxa/lubbock: switch PCMCIA to MAX1600 library ARM: pxa/mainstone: switch PCMCIA to MAX1600 library and gpiod APIs ARM: sa1100/neponset: switch PCMCIA to MAX1600 library and gpiod APIs ARM: sa1100/jornada720: switch PCMCIA to gpiod APIs pcmcia: add MAX1600 library ARM: sa1100: explicitly register sa11x0-pcmcia devices ARM: 8813/1: Make aligned 2-byte getuser()/putuser() atomic on ARMv6+ ARM: 8812/1: Optimise copy_{from/to}_user for !CPU_USE_DOMAINS ARM: 8811/1: always list both ldrd/strd registers explicitly ARM: 8808/1: kexec:offline panic_smp_self_stop CPU ...
2018-12-04ARM: sa1100/cerf: switch to using gpio_led_register_device()Russell King
Rather than statically declaring the leds-gpio device, use the helper function provided. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-12-04ARM: sa1100/assabet: switch to using gpio ledsRussell King
Switch over to using gpio leds now that we have the gpio driver for the assabet board register in place. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-12-04ARM: sa1100/assabet: add gpio keys support for right-hand two buttonsRussell King
Add gpio keys support for the right-hand two buttons on the Assabet, which can be used to wake up the CPU after PM. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-12-04ARM: sa1100/neponset: switch PCMCIA to MAX1600 library and gpiod APIsRussell King
Convert Neponset to use the gpiod API to specify which GPIOs are used for PCMCIA, and use the MAX1600 power switch library for Neponset, simplifying the neponset pcmcia driver as a result. Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-12-04ARM: sa1100/jornada720: switch PCMCIA to gpiod APIsRussell King
Convert the low level PCMCIA driver to gpiod APIs for controlling the socket power. Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-12-04ARM: sa1100: explicitly register sa11x0-pcmcia devicesRussell King
Simplify the code by getting rid of the conditional automatic registration of the sa11x0 PCMCIA interfaces in sa1100_init(), and require all platforms to explicitly call sa11x0_register_pcmcia(). Only one platform (iPAQ) is affected by this change. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-11-23PCI: consolidate PCI config entry in drivers/pciChristoph Hellwig
There is no good reason to duplicate the PCI menu in every architecture. Instead provide a selectable HAVE_PCI symbol that indicates availability of PCI support, and a FORCE_PCI symbol to for PCI on and the handle the rest in drivers/pci. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Palmer Dabbelt <palmer@sifive.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-17regulator: fixed: Convert to use GPIO descriptor onlyLinus Walleij
As we augmented the regulator core to accept a GPIO descriptor instead of a GPIO number, we can augment the fixed GPIO regulator to look up and pass that descriptor directly from device tree or board GPIO descriptor look up tables. Some boards just auto-enumerate their fixed regulator platform devices and I have assumed they get names like "fixed-regulator.0" but it's pretty hard to guess this. I need some testing from board maintainers to be sure. Other boards are straight forward, using just plain "fixed-regulator" (ID -1) or "fixed-regulator.1" hammering down the device ID. It seems the da9055 and da9211 has never got around to actually passing any enable gpio into its platform data (not the in-tree code anyway) so we can just decide to simply pass a descriptor instead. The fixed GPIO-controlled regulator in mach-pxa/ezx.c was confusingly named "*_dummy_supply_device" while it is a very real device backed by a GPIO line. There is nothing dummy about it at all, so I renamed it with the infix *_regulator_* as part of this patch set. Intel MID portions tested by Andy. Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> # Check the x86 BCM stuff Acked-by: Tony Lindgren <tony@atomide.com> # OMAP1,2,3 maintainer Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Janusz Krzysztofik <jmkrzyszt@gmail.com> Reviewed-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-06-14Merge branch 'i2c/for-4.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: - mainly feature additions to drivers (stm32f7, qup, xlp9xx, mlxcpld, ...) - conversion to use the i2c_8bit_addr_from_msg macro consistently - move includes to platform_data - core updates to allow the (still in review) I3C subsystem to connect - and the regular share of smaller driver updates * 'i2c/for-4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (68 commits) i2c: qup: fix building without CONFIG_ACPI i2c: tegra: Remove suspend-resume i2c: imx-lpi2c: Switch to SPDX identifier i2c: mxs: Switch to SPDX identifier i2c: busses: make use of i2c_8bit_addr_from_msg i2c: algos: make use of i2c_8bit_addr_from_msg i2c: rcar: document R8A77980 bindings i2c: qup: Add command-line parameter to override SCL frequency i2c: qup: Correct duty cycle for FM and FM+ i2c: qup: Add support for Fast Mode Plus i2c: qup: add probe path for Centriq ACPI devices i2c: robotfuzz-osif: drop pointless test i2c: robotfuzz-osif: remove pointless local variable i2c: rk3x: Don't print visible virtual mapping MMIO address i2c: opal: don't check number of messages in the driver i2c: ibm_iic: don't check number of messages in the driver i2c: imx: Switch to SPDX identifier i2c: mux: pca954x: merge calls to of_match_device and of_device_get_match_data i2c: mux: demux-pinctrl: use proper parent device for demux adapter i2c: mux: improve error message for failed symlink ...
2018-05-26ARM: Fix i2c-gpio GPIO descriptor tablesLinus Walleij
I used bad names in my clumsiness when rewriting many board files to use GPIO descriptors instead of platform data. A few had the platform_device ID set to -1 which would indeed give the device name "i2c-gpio". But several had it set to >=0 which gives the names "i2c-gpio.0", "i2c-gpio.1" ... Fix the offending instances in the ARM tree. Sorry for the mess. Fixes: b2e63555592f ("i2c: gpio: Convert to use descriptors") Cc: Wolfram Sang <wsa@the-dreams.de> Cc: Simon Guinot <simon.guinot@sequanux.org> Reported-by: Simon Guinot <simon.guinot@sequanux.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2018-05-17i2c: gpio: move header to platform_dataWolfram Sang
This header only contains platform_data. Move it to the proper directory. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: James Hogan <jhogan@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org>
2018-04-06ARM: sa1100/simpad: switch simpad CF to use gpiod APIsRussell King
Switch simpad's CF implementation to use the gpiod APIs. The inverted detection is handled using gpiolib's native inversion abilities. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-04-06ARM: sa1100/shannon: convert to generic CF socketsRussell King
Convert shannon to use the generic CF socket support. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-04-06ARM: sa1100/nanoengine: convert to generic CF socketsRussell King
Convert nanoengine to use the generic CF socket support. Makefile fix from Arnd Bergmann <arnd@arndb.de>. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-03-24ARM: sa1100/h3xxx: switch h3xxx PCMCIA to use gpiod APIsRussell King
Switch h3xxx's PCMCIA implementation to use the gpiod APIs where possible. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-03-24ARM: sa1100/cerf: convert to generic CF socketsRussell King
Convert Cerf to use the generic CF socket support. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-03-24ARM: sa1100/assabet: convert to generic CF socketsRussell King
Convert Assabet to use the generic CF socket support. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-03-24ARM: sa1100: provide infrastructure to support generic CF socketsRussell King
Provide the SoC-level infrastructure to support the generic CF sockets. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-01-01ARM: sa1100/neponset: add GPIO drivers for control and modem registersRussell King
The NCR, MDM_CTL* and AUD registers manipulate the state of external signals (eg, the RTS, DTR signals and the ethernet oscillator enable signal) or indicate the state of external signals (eg, CTS, DSR). Where these registers can be written, the current value can be read back, which relieves us from having to maintain a software copy of the current state. Model these registers as fixed-direction GPIO registers. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2018-01-01ARM: sa1100/assabet: add BCR/BSR GPIO driverRussell King
Add a GPIO driver for the board control register/board status register for the sa1100/assabet platform. This allows us to transition a range of drivers to use the gpiod APIs rather than the platform private ASSABET_BCR_* interfaces. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2017-11-14Merge branch 'i2c/for-4.15' of ↵Linus Torvalds
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "This contains two bigger than usual tree-wide changes this time. They all have proper acks, caused no merge conflicts in linux-next where they have been for a while. They are namely: - to-gpiod conversion of the i2c-gpio driver and its users (touching arch/* and drivers/mfd/*) - adding a sbs-manager based on I2C core updates to SMBus alerts (touching drivers/power/*) Other notable changes: - i2c_boardinfo can now carry a dev_name to be used when the device is created. This is because some devices in ACPI world need fixed names to find the regulators. - the designware driver got a long discussed overhaul of its PM handling. img-scb and davinci got PM support, too. - at24 driver has way better OF support. And it has a new maintainer. Thanks Bartosz for stepping up! The rest is regular driver updates and fixes" * 'i2c/for-4.15' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (55 commits) ARM: sa1100: simpad: Correct I2C GPIO offsets i2c: aspeed: Deassert reset in probe eeprom: at24: Add OF device ID table MAINTAINERS: new maintainer for AT24 driver i2c: nuc900: remove platform_data, too i2c: thunderx: Remove duplicate NULL check i2c: taos-evm: Remove duplicate NULL check i2c: Make i2c_unregister_device() NULL-aware i2c: xgene-slimpro: Support v2 i2c: mpc: remove useless variable initialization i2c: omap: Trigger bus recovery in lockup case i2c: gpio: Add support for named gpios in DT dt-bindings: i2c: i2c-gpio: Add support for named gpios i2c: gpio: Local vars in probe i2c: gpio: Augment all boardfiles to use open drain i2c: gpio: Enforce open drain through gpiolib gpio: Make it possible for consumers to enforce open drain i2c: gpio: Convert to use descriptors power: supply: sbs-message: fix some code style issues power: supply: sbs-battery: remove unchecked return var ...
2017-11-10ARM: sa1100: simpad: Correct I2C GPIO offsetsLinus Walleij
Arnd reported the following build bug bug: In file included from arch/arm/mach-sa1100/simpad.c:20:0: arch/arm/mach-sa1100/include/mach/SA-1100.h:1118:18: error: large integer implicitly truncated to unsigned type [-Werror=overflow] (0x00000001 << (Nb)) ^ include/linux/gpio/machine.h:56:16: note: in definition of macro 'GPIO_LOOKUP_IDX' .chip_hwnum = _chip_hwnum, ^~~~~~~~~~~ arch/arm/mach-sa1100/include/mach/SA-1100.h:1140:21: note: in expansion of macro 'GPIO_GPIO' ^~~~~~~~~ arch/arm/mach-sa1100/simpad.c:331:27: note: in expansion of macro 'GPIO_GPIO21' GPIO_LOOKUP_IDX("gpio", GPIO_GPIO21, NULL, 0, This is what happened: commit b2e63555592f81331c8da3afaa607d8cf83e8138 "i2c: gpio: Convert to use descriptors" commit 4d0ce62c0a02e41a65cfdcfe277f5be430edc371 "i2c: gpio: Augment all boardfiles to use open drain" together uncovered an old bug in the Simpad board file: as theGPIO_LOOKUP_IDX() encodes GPIO offsets on gpiochips in an u16 (see <linux/gpio/machine.h>) these GPIO "numbers" does not fit, since in arch/arm/mach-sa1100/include/mach/SA-1100.h it is defined as: #define GPIO_GPIO(Nb) (0x00000001 << (Nb)) (...) #define GPIO_GPIO21 GPIO_GPIO(21) /* GPIO [21] */ This is however provably wrong, since the i2c-gpio driver uses proper GPIO numbers, albeit earlier from the global number space, whereas this GPIO_GPIO21 is the local line offset in the GPIO register, which is used in other code but certainly not in the gpiolib GPIO driver in drivers/gpio/gpio-sa1100.c, which has code like this: static void sa1100_gpio_set(struct gpio_chip *chip, unsigned offset, int value) { int reg = value ? R_GPSR : R_GPCR; writel_relaxed(BIT(offset), sa1100_gpio_chip(chip)->membase + reg); } So far everything however compiled fine as an unsigned int was used to pass the GPIO numbers in struct i2c_gpio_platform_data. We can trace the actual error back to commit dbd406f9d0a1d33a1303eb75cbe3f9435513d339 "ARM: 7025/1: simpad: add GPIO based device definitions." This added the i2c_gpio with the wrong offsets. This commit was before the SA1100 was converted to use the gpiolib, but as can be seen from the contemporary gpio.c in mach-sa1100, it was already using: static int sa1100_gpio_get(struct gpio_chip *chip, unsigned offset) { return GPLR & GPIO_GPIO(offset); } And GPIO_GPIO() is essentially the BIT() macro. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-30i2c: gpio: Augment all boardfiles to use open drainLinus Walleij
We now handle the open drain mode internally in the I2C GPIO driver, but we will get warnings from the gpiolib that we override the default mode of the line so it becomes open drain. We can fix all in-kernel users by simply passing the right flag along in the descriptor table, and we already touched all of these files in the series so let's just tidy it up. Cc: Steven Miao <realmz6@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Wu, Aaron <Aaron.Wu@analog.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-10-30i2c: gpio: Convert to use descriptorsLinus Walleij
This converts the GPIO-based I2C-driver to using GPIO descriptors instead of the old global numberspace-based GPIO interface. We: - Convert the driver to unconditionally grab two GPIOs from the device by index 0 (SDA) and 1 (SCL) which will work fine with device tree and descriptor tables. The existing device trees will continue to work just like before, but without any roundtrip through the global numberspace. - Brutally convert all boardfiles still passing global GPIOs by registering descriptor tables associated with the devices instead so this driver does not need to keep supporting passing any GPIO numbers as platform data. There is no stepwise approach as elegant as this, I strongly prefer this big hammer over any antsteps for this conversion. This way the old GPIO numbers go away and NEVER COME BACK. Special conversion for the different boards utilizing I2C-GPIO: - EP93xx (arch/arm/mach-ep93xx): pretty straight forward as all boards were using the same two GPIO lines, just define these two in a lookup table for "i2c-gpio" and register these along with the device. None of them define any other platform data so just pass NULL as platform data. This platform selects GPIOLIB so all should be smooth. The pins appear on a gpiochip for bank "G" as pins 1 (SDA) and 0 (SCL). - IXP4 (arch/arm/mach-ixp4): descriptor tables have to be registered for each board separately. They all use "IXP4XX_GPIO_CHIP" so it is pretty straight forward. Most board define no other platform data than SCL/SDA so they can drop the #include of <linux/i2c-gpio.h> and assign NULL to platform data. The "goramo_mlr" (Goramo Multilink Router) board is a bit worrisome: it implements its own I2C bit-banging in the board file, and optionally registers an I2C serial port, but claims the same GPIO lines for itself in the board file. This is not going to work: there will be competition for the GPIO lines, so delete the optional extra I2C bus instead, no I2C devices are registered on it anyway, there are just hints that it may contain an EEPROM that may be accessed from userspace. This needs to be fixed up properly by the serial clock using I2C emulation so drop a note in the code. - KS8695 board acs5k (arch/arm/mach-ks8695/board-acs5.c) has some platform data in addition to the pins so it needs to be kept around sans GPIO lines. Its GPIO chip is named "KS8695" and the arch selects GPIOLIB. - PXA boards (arch/arm/mach-pxa/*) use some of the platform data so it needs to be preserved here. The viper board even registers two GPIO I2Cs. The gpiochip is named "gpio-pxa" and the arch selects GPIOLIB. - SA1100 Simpad (arch/arm/mach-sa1100/simpad.c) defines a GPIO I2C bus, and the arch selects GPIOLIB. - Blackfin boards (arch/blackfin/bf533 etc) for these I assume their I2C GPIOs refer to the local gpiochip defined in arch/blackfin/kernel/bfin_gpio.c names "BFIN-GPIO". The arch selects GPIOLIB. The boards get spiked with IF_ENABLED(I2C_GPIO) but that is a side effect of it being like that already (I would just have Kconfig select I2C_GPIO and get rid of them all.) I also delete any platform data set to 0 as it will get that value anyway from static declartions of platform data. - The MIPS selects GPIOLIB and the Alchemy machine is using two local GPIO chips, one of them has a GPIO I2C. We need to adjust the local offset from the global number space here. The ATH79 has a proper GPIO driver in drivers/gpio/gpio-ath79.c and AFAICT the chip is named "ath79-gpio" and the PB44 PCF857x expander spawns from this on GPIO 1 and 0. The latter board only use the platform data to specify pins so it can be cut altogether after this. - The MFD Silicon Motion SM501 is a special case. It dynamically spawns an I2C bus off the MFD using sm501_create_subdev(). We use an approach to dynamically create a machine descriptor table and attach this to the "SM501-LOW" or "SM501-HIGH" gpiochip. We use chip-local offsets to grab the right lines. We can get rid of two local static inline helpers as part of this refactoring. Cc: Steven Miao <realmz6@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Ben Dooks <ben.dooks@codethink.co.uk> Cc: Heiko Schocher <hs@denx.de> Acked-by: Wu, Aaron <Aaron.Wu@analog.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Tested-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-07-27ARM: sa1100: normalize clk APIArnd Bergmann
sa1100 provides its own variant of the clk API rather than using the generic COMMON_CLK API. This generally works, but it causes some link errors with drivers using the clk_set_rate, clk_get_parent, clk_set_parent or clk_round_rate functions when a platform lacks those interfaces. This adds trivial stub implementations for each of them, based on the behavior of the COMMON_CLK implementation: - set_rate() and set_parent() report success without doing anything - round_rate() returns the clk rate - get_parent() returns NULL. This adds the minimal bloat and should do the right thing for the simple clock hardware in this SoC. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-07-27ARM: sa1100/pxa: fix MTD_XIP buildArnd Bergmann
In commit 3169663ac5902 "ARM: sa11x0/pxa: convert OS timer registers to IOMEM", the definition of the OSCR macro was changed to be an __iomem pointer, but the same register is also used by the XIP code. This patch does the corresponding change here as well. On PXA, the IRQ register definitions were removed even earlier, in commit 5d284e353eb1 ("ARM: pxa: avoid accessing interrupt registers directly"). This patch unfortunately brings some of that back. An earlier version of my patch moved the code into an external function, which could not work for CONFIG_XIP_KERNEL+CONFIG_MTD_XIP, so this restores something close to the original code. Link: http://lists.infradead.org/pipermail/linux-arm-kernel/2014-March/241716.html Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-07-12ARM: HP Jornada 7XX: move inline before return typeJoe Perches
Convert 'u8 inline' to 'inline u8' to be the same style used by the rest of the kernel. Miscellanea: jornada_ssp_reverse is an odd function. It is declared inline but is also EXPORT_SYMBOL. It is also apparently only used by jornada720_ssp.c Likely the EXPORT_SYMBOL could be removed and the function converted to static. The addition of static and removal of EXPORT_SYMBOL was not done. Link: http://lkml.kernel.org/r/5bd3b2bf39c6c9caf773949f18158f8f5ec08582.1499284835.git.joe@perches.com Signed-off-by: Joe Perches <joe@perches.com> Cc: Russell King <linux@armlinux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-28ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbolFlorian Fainelli
All low-level PM/SMP code using virt_to_phys() should actually use __pa_symbol() against kernel symbols. Update code where relevant to move away from virt_to_phys(). Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Reviewed-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2016-12-15Merge branch 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: - an update for clkdev registration error detection to simplify users - add cpu capacity parsing from DT - support for larger cachelines found on UniPhier caches - documentation for udelay constants - properly tag assembly function declarations - remove unnecessary indirection of asm/mach-types.h - switch to syscall table based generation to simplify future additions of system calls, along with correpsonding commit for pkey syscalls - remove redundant sa1101 header file - RONX protect modules when they're in the vmalloc region * 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: ARM: mm: allow set_memory_*() to be used on the vmalloc region ARM: mm: fix set_memory_*() bounds checks ARM: 8631/1: clkdev: Detect errors in clk_hw_register_clkdev() for mass registration ARM: 8629/1: vfp: properly tag assembly function declarations in C code ARM: 8622/3: add sysfs cpu_capacity attribute ARM: 8621/3: parse cpu capacity-dmips-mhz from DT ARM: 8623/1: mm: add ARM_L1_CACHE_SHIFT_7 for UniPhier outer cache ARM: Update mach-types ARM: sa1100: remove SA-1101 header file ARM: 8619/1: udelay: document the various constants ARM: wire up new pkey syscalls ARM: convert to generated system call tables ARM: remove indirection of asm/mach-types.h
2016-10-19ARM: sa1100: remove SA-1101 header fileRussell King
Remove the completely unused SA-1101 header file. Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
2016-10-18ARM: sa11x0/pxa: get rid of get_clock_tick_rateRobert Jarzmik
The last user of this function is gone, so remove it. The clock API should now be used to get clock rates. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
2016-10-18ARM: sa11x0/pxa: acquire timer rate from the clock rateRobert Jarzmik
As both pxa and sa1100 provide a clock to the timer, the rate can be inferred from the clock rather than hard encoded in a functional call. This patch changes the pxa timer to have a mandatory clock which is used as the timer rate. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
2016-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "You will get - a new driver for Elan eKTF2127 touchscreen controllers - a new "gpio-decoder" driver to read and report state of several GPIO lines - an ADC resistor ladder driver - the ft6326 driver is removed because edt-ft5x06 handles the same devices just fine. .. plus the regular slew of driver fixes/enhancements" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (26 commits) Input: elan_i2c - fix return tests of i2c_smbus_read_block_data() Input: ektf2127 - mark PM functions as __maybe_unused Input: snvs_pwrkey - drop input_free_device call if input_register_device fails Input: add support for Elan eKTF2127 touchscreen controller Input: serio - add hangup support Input: tps65218-pwrbutton - add support for tps65217 variant Input: jornada720_ts - get rid of mach/irqs.h and mach/hardware.h includes Input: jornada720_kbd - remove unneeded mach/hardware.h include Input: focaltech - mark focaltech_set_resolution() static Input: wdt87xx_i2c - fix the flash erase issue Input: gpio-keys-polled - don't use unit-address with button nodes Input: add generic input driver to read encoded GPIO lines Input: add ADC resistor ladder driver Input: pegasus_notetaker - directly include workqueue header Input: elants_i2c - get product id on recovery mode for FW update Input: wm97xx - remove deprecated create_singletheread_workqueue Input: mc13783_ts - remove deprecated create_singletheread_workqueue Input: psmouse - remove deprecated create_singletheread_workqueue Input: jornada720_kbd - switch to using dev_dbg Input: jornada720_kbd - get rid of mach/irqs.h include ...
