path: root/arch/arm/mach-shark
2005-07-16[PATCH] ARM: 2815/1: Shark: new defconfig, fixes with __io and serial portsAlexander Schulz
Patch from Alexander Schulz This patch brings a new default config file for the shark and fixes a compilation issue with io addressing and a runtime problem with the serial ports, where I corrected a wrong regshift value. These are all shark specific files so I hope it is ok to put them in one patch. Signed-off-by: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: Add SA_TIMER flag to timer interruptsRussell King
VST needs to know which timer handler is for the timer interrupt. Mark all timer interrupts with the SA_TIMER flag. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
