According to the datasheet, the frequency of the ARM architecture timer
on RZ/G1E depends on the frequency of the ZS clock, just like on R-Car
E2 and V2H.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
When using the new CPG/MSSR bindings, there is no longer a
"renesas,rcar-gen2-cpg-clocks" node, and the code to obtain the external
clock crystal frequency falls back to a default of 20 MHz.
While this is correct for all upstream R-Car Gen2 and RZ/G1 boards, this
is not necessarily the case for out-of-tree third party boards.
Add support for finding the external clock crystal oscillator on RZ/G1M,
and on R-Car H2, M2-W, and M2-N using the new CPG/MSSR bindings, through
the corresponding "renesas,r8a77xx-cpg-mssr" nodes.
Note that this is not needed on R-Car V2H and E2, and on RZ/G1E, as on
those SoCs the arch_timer and generic counter clock is derived from the
ZS clock instead.
The function name is now renamed to 'timer_probe' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
After
1. commit 9f5ce39ddb8f68b3 ("ARM: shmobile: rcar-gen2: Obtain extal
frequency from DT"),
2. commit 80951f04c3f92533 ("ARM: shmobile: rcar-gen2: Stop passing
mode pins state to clock driver"),
3. and handling of debug resource reset,
there are no more users of rcar_gen2_read_mode_pins() left.
Remove the function and its support definitions.
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- Added support for the TI DRA71x family of SoCs in mach-omap2, this
is an new variant of the the DRA72x/DRA74x automotive infotainment
chips we already supported for a while.
- Added support for the ST STM32F746 SoC, the first Cortex-M7 based
microcontroller we support, related to the smaller STM32F4 family.
- Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see
http://elinux.org/RZ-G
- SMP is now supported on the OX820 platform
- A lot of code in mach-omap2 gets removed as a follow-up to removing
support for board files in the previous release
- Davinci has some new work to improve USB support
- For i.MX, the performance monitor now supports profiling the memory
controller using 'perf'"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits)
ARM: davinci: da830-evm: use gpio descriptor for mmc pins
ARM: davinci: da850-evm: use gpio descriptor for mmc pins
ARM: davinci: hawk: use gpio descriptor for mmc pins
ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6
ARM: davinci: da8xx: Fix ohci device name
ARM: oxnas: Add OX820 config and makefile entry
ARM: oxnas: Add OX820 SMP support
ARM: davinci: PM: fix build when da850 not compiled in
ARM: orion5x: remove legacy support of ls-chl
ARM: integrator: drop EBI access use syscon
ARM: BCM5301X: Add back handler ignoring external imprecise aborts
ARM: davinci: PM: support da8xx DT platforms
ARM: davinci: PM: cleanup: remove references to pdata
ARM: davinci: PM: rework init, remove platform device
ARM: Kconfig: Introduce MACH_STM32F746 flag
ARM: mach-stm32: Add a new SOC - STM32F746
ARM: shmobile: document SK-RZG1E board
ARM: shmobile: r8a7745: basic SoC support
ARM: imx: mach-imx6ul: add imx6ull support
ARM: zynq: Reserve correct amount of non-DMA RAM
Add minimal support for the RZ/G1E (R8A7745) SoC.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Rob Herring <robh@kernel.org>
Now the R-Car Gen2 CPG clock driver obtains the state of the mode pins
from the R-Car RST driver, there's no longer a need to pass this state
explicitly. Hence we can just call of_clk_init() instead.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
The four SoCs use identical machine operations, consolidate them into
two machine definitions in a single file.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
The RZ/G1M (r8a7743) uses the R-Car Gen2 core, but not the R-Car Gen2 clock
driver. This is a harbinger of a transition for R-Car Gen2 SoCs. As the
process to get all the required pieces in place is somewhat complex it
seems useful to try to disentangle dependencies where possible.
The approach here is to temporarily disable calling rcar_gen2_clocks_init()
if no R-Car Gen2 SoC are configured and thus the symbol will not be
present.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
on R-Car V2H depends on the frequency of the ZS clock, just like on
R-Car E2.
Tested-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
On some R-Car Gen2 SoCs, the frequency of the ARM architecture timer
depends on the frequency of the external clock crystal. Currently the
latter is determined indirectly from the state of the mode pins, which
is a relic predating DT.
Obtain the external clock crystal frequency from DT instead, removing
the dependency on the mode pins.
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk updates from Stephen Boyd:
"The clk changes for this release cycle are mostly dominated by new
device support in terms of LoC, but there has been some cleanup in the
core as well as the usual minor clk additions to various drivers.
Core:
- parent tracking has been simplified
- CLK_IS_ROOT is now a no-op flag, cleaning up drivers has started
- of_clk_init() doesn't consider disabled DT nodes anymore
- clk_unregister() had an error path bug squashed
- of_clk_get_parent_count() has been fixed to only return unsigned ints
- HAVE_MACH_CLKDEV is removed now that the last arch user (ARM) is gone
New Drivers:
- NXP LPC18xx creg
- QCOM IPQ4019 GCC
- TI dm814x ADPLL
- i.MX6QP
Updates:
- Cyngus audio clks found on Broadcom iProc devices
- Non-critical fixes for BCM2385 PLLs
- Samsung exynos5433 updates for clk id errors, HDMI support,
suspend/resume simplifications
- USB, CAN, LVDS, and FCP clks on shmobile devices
- sunxi got support for more clks on new SoCs and went through a
minor refactoring/rewrite to use a simpler factor clk construct
- rockchip added some more clk ids and added suport for fraction
dividers
- QCOM GDSCs in msm8996
- A new devm helper to make adding custom actions simpler (acked by Greg)"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (197 commits)
clk: bcm2835: fix check of error code returned by devm_ioremap_resource()
clk: renesas: div6: use RENESAS for #define
clk: renesas: Rename header file renesas.h
clk: max77{686,802}: Remove CLK_IS_ROOT
clk: versatile: Remove CLK_IS_ROOT
clk: sunxi: Remove use of variable length array
clk: fixed-rate: Remove CLK_IS_ROOT
clk: qcom: Remove CLK_IS_ROOT
doc: dt: add documentation for lpc1850-creg-clk driver
clk: add lpc18xx creg clk driver
clk: lpc32xx: fix compilation warning
clk: xgene: Add missing parenthesis when clearing divider value
clk: mb86s7x: Remove CLK_IS_ROOT
clk: x86: Remove clkdev.h and clk.h includes
clk: x86: Remove CLK_IS_ROOT
clk: mvebu: Remove CLK_IS_ROOT
clk: renesas: move drivers to renesas directory
clk: si5{14,351,70}: Remove CLK_IS_ROOT
clk: scpi: Remove CLK_IS_ROOT
clk: s2mps11: Remove CLK_IS_ROOT
This is part of an ongoing process to migrate from ARCH_SHMOBILE to
ARCH_RENESAS the motivation for which being that RENESAS seems to be a more
appropriate name than SHMOBILE for the majority of Renesas ARM based SoCs.
Along with the above mentioned Kconfig changes it seems appropriate
to also rename files.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
make C=1:
arch/arm/mach-shmobile/setup-rcar-gen2.c:186:12: warning: symbol 'rcar_gen2_dma_contiguous' was not declared. Should it be static?
Make it static, and move it inside the function to avoid a "defined but
not used" warning if CONFIG_DMA_CMA=n.
Seeing the 'of' characters in a symbol that is being called from
ACPI seems to freak out people. So let's do a bit of pointless
renaming so that these folks do feel at home.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Since commit e042681894b62d60 ("ARM: shmobile: r8a7790: Remove legacy
code"), all R-Car Gen2 SoCs are supported by multiplatform kernels only.
As CONFIG_ARCH_SHMOBILE_MULTI is always set for shmobile multiplatform
kernels, we can remove related #ifdefs in code specific to R-Car Gen2
SoCs.
Pull ARM SoC platform updates from Olof Johansson:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. In this case, that includes:
- support for the new Annapurna Labs "Alpine" platform
- a rework greatly simplifying adding new platform support to the
MCPM subsystem (Multi-cluster power management)
- cpuidle and PM improvements for Exynos3250
- misc updates for Renesas, OMAP, Meson, i.MX. Some of these could
have gone in other branches but ended up here for various reasons"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
ARM: alpine: add support for generic pci
ARM: Exynos: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: DCSCB: tighten CPU validity assertion
ARM: vexpress: migrate TC2 to the new MCPM backend abstraction
ARM: MCPM: move the algorithmic complexity to the core code
ARM: EXYNOS: allow cpuidle driver usage on Exynos3250 SoC
ARM: EXYNOS: add AFTR mode support for Exynos3250
ARM: EXYNOS: add code for setting/clearing boot flag
ARM: EXYNOS: fix CPU1 hotplug on Exynos3250
ARM: S3C64XX: Use fixed IRQ bases to avoid conflicts on Cragganmore
ARM: cygnus: fix const declaration bcm_cygnus_dt_compat
ARM: DRA7: hwmod: Fix the hwmod class for GPTimer4
ARM: DRA7: hwmod: Add data for GPTimers 13 through 16
ARM: EXYNOS: Remove left over 'extra_save'
ARM: EXYNOS: Constify exynos_pm_data array
ARM: EXYNOS: use static in suspend.c
ARM: EXYNOS: Use platform device name as power domain name
ARM: EXYNOS: add support for async-bridge clocks for pm_domains
ARM: omap-device: add missed callback for suspend-to-disk
As CONFIG_COMMON_CLK is always set for multiplatform kernels, we can
remove related #ifdefs in code specific to R-Car Gen2 SoCs.
Allow R-Car Gen2 platforms to boot with CMA enabled
and HIGHMEM disabled. This patch adds code to check
if the R-Car Gen2 specific memory reservation window
is included in the kernel memory range or not. When
HIGHMEM is disabled the R-Car Gen2 reservation area is
outside the kernel memory range and in such case the
memory reservation is simply skipped over.
Without this patch the kernel boot hangs when CMA is
enabled and HIGHMEM is disabled on the r8a7791 Koelsch
hardware platform:
WARNING: CPU: 1 PID: 1 at mm/cma.c:113 cma_init_reserved_areas+0x88/0x1d4()
WARNING: CPU: 1 PID: 1 at mm/cma.c:121 cma_init_reserved_areas+0xf8/0x1d4()
Unable to handle kernel NULL pointer dereference at virtual address 00000160
pgd = c0003000
[00000160] *pgd=80000040004003, *pmd=00000000
Internal error: Oops: 206 [#1] SMP ARM
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Tainted: G W
3.19.0-rc4-koelsch-01450-g7f9b6075ce12c3ea-dirty #735
Hardware name: Generic R8A7791 (Flattened Device Tree)
task: edc553c0 ti: edc56000 task.ti: edc56000
PC is at set_pfnblock_flags_mask+0x54/0xa0
LR is at 0x440
In the current shmobile_defconfig HIGHMEM is enabled
while CMA is disabled, so to trigger this the kernel
configuration for both CMA and HIGHMEM needs to be
adjusted.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Also included are some cleanups where
the platform maintainers hadn't separated cleanups from new developent
in separate branches.
Some of the larger things worth pointing out:
- A large set of changes from Alexandre Belloni and Nicolas Ferre
preparing at91 platforms for multiplatform and cleaning up quite a
bit in the process.
- Removal of CSR's "Marco" SoC platform that never made it out to the
market. We love seeing these since it means the vendor published
support before product was out, which is exactly what we want!
New platforms this release are:
- Conexant Digicolor (CX92755 SoC)
- Hisilicon HiP01 SoC
- CSR/sirf Atlas7 SoC
- ST STiH418 SoC
- Common code changes for Nvidia Tegra132 (64-bit SoC)
We're seeing more and more platforms having a harder time labelling
changes as cleanups vs new development -- which is a good sign that
we've come quite far on the cleanup effort. So over time we might
start combining the cleanup and new-development branches more"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits)
ARM: at91/trivial: unify functions and machine names
ARM: at91: remove at91_dt_initialize and machine init_early()
ARM: at91: change board files into SoC files
ARM: at91: remove at91_boot_soc
ARM: at91: move alternative initial mapping to board-dt-sama5.c
ARM: at91: merge all SOC_AT91SAM9xxx
ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init()
ARM: digicolor: select syscon and timer
ARM: zynq: Simplify SLCR initialization
ARM: zynq: PM: Fixed simple typo.
ARM: zynq: Setup default gpio number for Xilinx Zynq
ARM: digicolor: add low level debug support
ARM: initial support for Conexant Digicolor CX92755 SoC
ARM: OMAP2+: Add dm816x hwmod support
ARM: OMAP2+: Add clock domain support for dm816x
ARM: OMAP2+: Add board-generic.c entry for ti81xx
ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage
ARM: at91: remove unused mach/system_rev.h
ARM: at91: stop using HAVE_AT91_DBGUx
ARM: at91: fix ordering of SRAM and PM initialization
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes
Merge "Third Round of Renesas ARM Based SoC Fixes for v3.19" from Simon Horman:
* Instantiate GIC from C board code in legacy builds on r8a7790 and r8a73a4
* tag 'renesas-soc-fixes3-for-v3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: r8a7790: Instantiate GIC from C board code in legacy builds
ARM: shmobile: r8a73a4: Instantiate GIC from C board code in legacy builds
As of commit 9a1091ef0017c40a ("irqchip: gic: Support hierarchy irq
domain."), the Lager legacy board support is known to be broken.
The IRQ numbers of the GIC are now virtual, and no longer match the
hardcoded hardware IRQ numbers in the legacy platform board code.
To fix this issue specific to non-multiplatform r8a7790 and Lager:
1) Instantiate the GIC from platform board code and also
2) Skip over the DT arch timer as well as
3) Force delay setup based on DT CPU frequency
With these 3 fixes in place interrupts on Lager are now unbroken.
Partially based on legacy GIC fix by Geert Uytterhoeven, thanks to
him for the initial work.
Fix "is_e2" warning introduced by:
9ce3fa6 ARM: shmobile: rcar-gen2: Add CA7 arch_timer initialization for r8a7794
Only triggers on kernel configurations that have ARCH_ARM_TIMER=n.
Pull ARM SoC platform changes from Arnd Bergmann:
"New and updated SoC support, notable changes include:
- bcm:
brcmstb SMP support
initial iproc/cygnus support
- exynos:
Exynos4415 SoC support
PMU and suspend support for Exynos5420
PMU support for Exynos3250
pm related maintenance
- imx:
new LS1021A SoC support
vybrid 610 global timer support
- integrator:
convert to using multiplatform configuration
- mediatek:
earlyprintk support for mt8127/mt8135
- meson:
meson8 soc and l2 cache controller support
- mvebu:
Armada 38x CPU hotplug support
drop support for prerelease Armada 375 Z1 stepping
extended suspend support, now works on Armada 370/XP
- omap:
hwmod related maintenance
prcm cleanup
- pxa:
initial pxa27x DT handling
- rockchip:
SMP support for rk3288
add cpu frequency scaling support
- shmobile:
r8a7740 power domain support
various small restart, timer, pci apmu changes
- sunxi:
Allwinner A80 (sun9i) earlyprintk support
- ux500:
Overall, a significant chunk of changes, coming mostly from the usual
suspects: omap, shmobile, samsung and mvebu, all of which already
contain a lot of platform specific code in arch/arm"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits)
ARM: mvebu: use the cpufreq-dt platform_data for independent clocks
soc: integrator: Add terminating entry for integrator_cm_match
ARM: mvebu: add SDRAM controller description for Armada XP
ARM: mvebu: adjust mbus controller description on Armada 370/XP
ARM: mvebu: add suspend/resume DT information for Armada XP GP
ARM: mvebu: synchronize secondary CPU clocks on resume
ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume
ARM: mvebu: Armada XP GP specific suspend/resume code
ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume
ARM: mvebu: implement suspend/resume support for Armada XP
clk: mvebu: add suspend/resume for gatable clocks
bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration
bus: mvebu-mbus: suspend/resume support
clocksource: time-armada-370-xp: add suspend/resume support
irqchip: armada-370-xp: Add suspend/resume support
ARM: add lolevel debug support for asm9260
ARM: add mach-asm9260
ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf
power: reset: imx-snvs-poweroff: add power off driver for i.mx6
ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A
The information is already included in the COPYING file in the kernel
sources root directory, we don't want to modify all source files when
the FSF will move to a new address, and I'm tired of seeing the related
checkpatch.pl warnings.
On E2, the arch timer is hooked up to a different clock, and the CA7's arch
timer CNTVOFF register must be initialized.
Based on work by Hisashi Nakamura.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Commit 5ea3b1b2f8ad 'cma: add placement specifier for "cma=" kernel parameter'
adds a new 'fixed' parameter to dma_contiguous_reserve_area(). Update
rcar_gen2_reserve() accordingly.
This fixes the following compilation error:
arch/arm/mach-shmobile/setup-rcar-gen2.c: In function ‘rcar_gen2_reserve’:
arch/arm/mach-shmobile/setup-rcar-gen2.c:182:10: error: too few arguments to function ‘dma_contiguous_reserve_area’
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Open Firmware in the CHRP LongTrail does not support plugging in ARM CPUs
in its PPC 603e/604e-compatible CPU socket ;-)
Acked-by: Magnus Damm <damm+renesas@opensource.se>
Casts are evil
Commit 9d0c4dfedd96ee54fc075b16d02f82499c8cc3a6 ("of/fdt: update
of_get_flat_dt_prop in prep for libfdt") changed the function prototypes
of of_get_flat_dt_prop():
- The return type was made const,
- The last parameter was changed from "unsigned long *" to "int *".
and dt_mem_next_cell():
- The second parameter was made const.
This causes the following compiler warnings:
arch/arm/mach-shmobile/setup-rcar-gen2.c: In function 'rcar_gen2_scan_mem':
arch/arm/mach-shmobile/setup-rcar-gen2.c:125:15: warning: initialization discards 'const' qualifier from pointer target type [enabled by default]
arch/arm/mach-shmobile/setup-rcar-gen2.c:142:2: warning: passing argument 3 of 'of_get_flat_dt_prop' from incompatible pointer type [enabled by default]
include/linux/of_fdt.h:53:20: note: expected 'int *' but argument is of type 'long unsigned int *'
arch/arm/mach-shmobile/setup-rcar-gen2.c:142:6: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
arch/arm/mach-shmobile/setup-rcar-gen2.c:144:3: warning: passing argument 3 of 'of_get_flat_dt_prop' from incompatible pointer type [enabled by default]
arch/arm/mach-shmobile/setup-rcar-gen2.c:144:7: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
arch/arm/mach-shmobile/setup-rcar-gen2.c:152:3: warning: passing argument 2 of 'dt_mem_next_cell' from incompatible pointer type [enabled by default]
include/linux/of_fdt.h:69:12: note: expected 'const __be32 **' but argument is of type '__be32 **'
arch/arm/mach-shmobile/setup-rcar-gen2.c:153:3: warning: passing argument 2 of 'dt_mem_next_cell' from incompatible pointer type [enabled by default]
Update the variable types in rcar_gen2_scan_mem() to fix this.
[horms+renesas@verge.net.au: rebased]
Add R-Car Gen2 CMA memory reservation code that can be
shared between multiple SoCs and boards. At this point
r8a7790 and r8a7791 are supported.
The top 256MiB of the legacy 32-bit physical memory space
is assigned to a separate CMA area that may be assigned
to various devices later on.
Change location of rcar-gen2.h so it can be used as #include "rcar-gen2.h"
instead of the old style #include <mach/rcar-gen2.h>. Also clean up
the r8a7790 case to follow the same style as r8a7791.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Change location for common.h so it can be used as #include "common.h"
instead of the old style #include <mach/common.h>.
The MD pins are sampled at reset time, hence the read value will always be
the same, and we can avoid the overhead of ioremapping the register on
every read.
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Remove __init from rcar_gen2_read_mode_pins() to allow
it to be used after boot. For instance the R-Car Gen2
MD21 check is needed even in the case of CPU Hotplug.
Signed-off-by: Magnus Damm <damm@opensource.se>
When CONFIG_COMMON_CLOCK is enabled, call rcar_gen2_clocks_init() in the
timer init function to initialize the common clock framework before
initializing the clock sources. This will take care of clock
initialization when the r8a779[01] boards will be switched to
multiplatform kernels.
If the system has been started in non-secure mode, then the ARM generic
timer is not configurable during the kernel initialisation. Currently
the only thing we can check for is if the timer has been correctly
configured during the boot process.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Reviewed-by: Ian Molton <ian.molton@codethink.co.uk>
Acked-by: Magnus Damm <damm@opensource.se>
Move arch timer workaround code and boot mode pin
handling from setup-r8a7790.c to setup-rcar-gen2.c.
With this in place the same code can be used on
other R-Car Generation 2 devices such as r8a7791.
[horms+renesas@verge.net.au trivial rebase of board-lager.c
for introduction of lager_add_standard_devices()]
