Now debug resource reset is handled properly, allow booting secondary
CPU cores when hardware debug mode is enabled (MD21=1, SW8-4=OFF on
koelsch) on legacy r8a7791.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Writes to /sys/.../cpuX/online fail if we determine the platform
doesn't support hotplug for that CPU. Furthermore, if the cpu_die
op isn't specified the system hangs when we try to offline a CPU
and it comes right back online unexpectedly. Let's figure this
stuff out before we make the sysfs nodes so that the online file
doesn't even exist if it isn't (at least sometimes) possible to
hotplug the CPU.
Add a new 'cpu_can_disable' op and repoint all 'cpu_disable'
implementations at it because all implementers use the op to
indicate if a CPU can be hotplugged or not in a static fashion.
With PSCI we may need to add a 'cpu_disable' op so that the
secure OS can be migrated off the CPU we're trying to hotplug.
In this case, the 'cpu_can_disable' op will indicate that all
CPUs are hotpluggable by returning true, but the 'cpu_disable' op
will make a PSCI migration call and occasionally fail, denying
the hotplug of a CPU. This shouldn't be any worse than x86 where
we may indicate that all CPUs are hotpluggable but occasionally
we can't offline a CPU due to check_irq_vectors_for_cpu_disable()
failing to find a CPU to move vectors to.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Dave Martin <Dave.Martin@arm.com>
Acked-by: Simon Horman <horms@verge.net.au> [shmobile portion]
Tested-by: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: <linux-sh@vger.kernel.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
The pm code for R-Car Gen2 is scatterd in each SoC. These files
(pm-r8a7790.c/pm-r8a7791.c) have some overlap code. This change
consolidate the pm code for R-Car Gen2 into one.
Signed-off-by: Gaku Inami <gaku.inami.xw@bp.renesas.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Documentation says the last register is at 0x184 (CAxCPUCMCR), so use
proper length. Current APMU code accesses CAxCPUnCR which is currently
outside of the remapped area.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
The r8a7791 only has 2 CPU CA15 cores, not 4 CA15 and 4 CA7 cores.
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>
APMU resources are not common to all R-Car SoCs so don't share this data.
A subsequent patch will correct the CPU cores for the r8a7791.
Build the APMU for r8a7791 even though SMP is
disabled in the kernel config. Also initialize
Suspend-to-RAM from pm-r8a7791.c to in the future
cover both UP and SMP use cases of the APMU.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Move r8a7791 specific reset vector setup code from the
SMP glue code to PM code. This makes the code one step
closer to allow PM operations such as Suspend-to-RAM
in the case when SMP is disabled in the kernel config.
[horms+renesas@verge.net.au: updated for recent header file changes]
Change location of r8a7791.h so it can be included as "r8a7791.h"
instead of the old style <mach/r8a7791.h>
Add r8a7791 Core-Standby state for Suspend to RAM support.
Signed-off-by: Keita Kobayashi <keita.kobayashi.ym@renesas.com>
Add r8a7791 SYSC power management support.
Acked-by: Magnus Damm <damm+renesas@opensource.se>
[horms+renesas@verge.net.au: rebased]
Change location of rcar-gen2.h so it can be used as #include "rcar-gen2.h"
instead of the old style #include <mach/rcar-gen2.h>. Also clean up
the r8a7790 case to follow the same style as r8a7791.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Change location for common.h so it can be used as #include "common.h"
instead of the old style #include <mach/common.h>.
On r8a7791 the hardware boot mode bit MD21 indicates if hardware
debug mode is enabled or not. In case hardware debug mode is enabled
print a warning and refrain from booting secondary CPU cores.
Without this patch Koelsch with SW8-4 set to OFF will hang at SMP boot.
Signed-off-by: Magnus Damm <damm@opensource.se>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tie in the APMU SMP code on r8a7791. When used together
with the secondary CPU device node and smp_ops in the
board specific code then this will allow use of the
two Cortex-A15 cores in the r8a7791 SoC.
