path: root/arch/arm/mach-shmobile/smp-sh73a0.c
2011-05-24ARM: mach-shmobile: sh73a0 twd_base fixMagnus Damm
Fix the case of too late twd_base initialization for SMP on sh73a0 which bas been broken because sh73a0 specific smp_prepare_cpu() and percpu_timer_setup() changed order in the commits: 05c74a6cbcfb416286a947668ba32f63d99fe74a c413521eb4e2d7ffd5ce432a144708d479054bd3 Without this fix the sh73a0 SMP kernel panics on boot. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-07ARM: mach-shmobile: update for GIC changes.Paul Mundt
This fixes up the SMP support to use the refactored GIC APIs. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-14ARM: mach-shmobile: sh73a0 SMP supportMagnus Damm
Add SMP support for ag5evm and the sh73a0 processor. Onlining and offlining works well, but at this point offlined processor cores are not put into sleep mode. There is no spinlock for syncing the secondary core with the first one in this implementation. The code instead relies on the cpu_online() check in __cpu_up(). Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
