commit a06f916b7a9b57447ceb875eb0a89f1a66b31bca upstream.
Rather than clipping the number of CPUs using the compile-time NR_CPUS
constant, use the runtime nr_cpu_ids value instead. This allows the
nr_cpus command line option to work as expected.
Reported-by: Mark Salter <msalter@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x
* 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x:
ARM: mach-shmobile: sh7372 CMT3 and CMT4 clock support
ARM: mach-shmobile: sh7372 MSIOF clock support
ARM: mach-shmobile: clock-sh7372: fixup USB-DMAC1 settings
ARM: mach-shmobile: clock-sh73a0: tidyup CKSCR main clock selecter
ARM: mach-shmobile: Remove 3DG/SGX from sh7372 INTCS
ARM: mach-shmobile: mackerel: Add USB-DMA ID
mmc: sdhi, mmcif: zboot: Correct clock disable logic
ARM: mach-shmobile: ag5evm: SDHI requires waiting for idle
ARM: static should be at beginning of declaration
ARM: mach-shmobile: Use CMT2 for timer on sh7372
ARM: mach-shmobile: sh7372: Add USB-DMAC support
Add clock control support for sh7372 CMT hardware blocks.
No upstream sh7372 boards are making use of CMT3 + CMT4,
but the sh7372 hardware happens to come out of reset with
all CMT MSTP clocks _enabled_, so to save power we need
to implement a fix in software to shut down unused clocks.
This patch relies on the recently merged
794d78f drivers: sh: late disabling of clocks V2
to make sure the unused clocks get disabled as expected.
Signed-off-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add clock control support for sh7372 MSIOF hardware blocks.
No upstream sh7372 boards are making use of MSIOF0->2,
all MSIOF MSTP clocks _enabled_, so to save power we need
USB-DMAC1 needs SMSTPCR4/MSTP407 controls, not MSTP214
this patch tested on mackerel board
Reported-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
MAINCKSEL is [29:28], not [27:24]
This patch removes support for the SGX interrupt source in
the sh7372 INTCS controller.
The SGX hardware block included in sh7372 is already hooked
up to the ARM Cortex-A8 core using the INTCA controller,
so SGX users are encouraged to make use of that interrupt
source instead.
Removing support for the SGX interrupt source in INTCS
simplifies the sh7372 power management code by allowing
us to assume that only INTCA needs to be powered on to
operate the SGX hardware.
If the INTCS interrupt source would be kept then the kernel
would be forced to deal with additional dependencies that does
not follow the regular power domain hiearachy. With this
patch in place we can safely power down INTCS while the
SGX is operating.
This patch updates the recently submitted
"Associate the HDMI clock together with LCDC1 on sh7372"
to V2 with the following change:
- Use lcdc1_device on AP4EVB to build properly.
Associate the HDMI clock together with LCDC1 on sh7372.
Without this patch Suspend-to-RAM hangs on the boards
AP4EVB and Mackerel. The code hangs in the LCDC driver
where the software is waiting forever for the hardware to
power down. By explicitly associating the HDMI clock with
LCDC1 we can make sure the HDMI clock is enabled using
Runtime PM whenever the driver is accessing the hardware.
This HDMI and LCDC1 dependency is documented in the sh7372
data sheet. Older kernels did work as expected but the
recently merged (3.1-rc)
introduced code to turn off clocks lacking software reference
which happens to include the HDMI clock that is needed by
LCDC1 to operate as expected.
This patch use channel0 as Tx, and channel1 as Rx
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into rmobile-latest
* 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: (39 commits)
SH: static should be at beginning of declaration
sh: move CLKDEV_xxx_ID macro to sh_clk.h
sh: clock-shx3: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7786: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7785: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7757: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7366: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7343: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7722: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7724: add CLKDEV_ICK_ID for cleanup
sh: clock-sh7366: modify I2C clock settings
sh: clock-sh7343: modify I2C clock settings
sh: clock-sh7723: modify I2C clock settings
sh: clock-sh7722: modify I2C clock settings
sh: clock-sh7724: modify I2C clock settings
serial: sh-sci: Fix up pretty name printing for port IRQs.
serial: sh-sci: Kill off per-port enable/disable callbacks.
serial: sh-sci: Add missing module description/author bits.
serial: sh-sci: Regtype probing doesn't need to be fatal.
sh: Tidy up pre-clkdev clk_get() error handling.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
Now that v4l2 subdevices have got their own device objects, having
one more device in soc-camera clients became redundant and confusing.
This patch removes those devices and the soc-camera bus, they used to
reside on.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Paul Mundt <lethal@linux-sh.org>
This moves us one more step closer to eliminating the soc-camera bus
and devices on it. Besides, as a side effect, CSI-2 runtime PM on
sh-mobile secomes finer grained now: we only have to power on the
interface, when the device nodes are open.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
The SDHI block on the ag5evm requires waiting for idle
before writing to some registers.
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Magnus Damm <magnus.damm@gmail.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (237 commits)
ARM: 7004/1: fix traps.h compile warnings
ARM: 6998/2: kernel: use proper memory barriers for bitops
ARM: 6997/1: ep93xx: increase NR_BANKS to 16 for support of 128MB RAM
ARM: Fix build errors caused by adding generic macros
ARM: CPU hotplug: ensure we migrate all IRQs off a downed CPU
ARM: CPU hotplug: pass in proper affinity mask on IRQ migration
ARM: GIC: avoid routing interrupts to offline CPUs
ARM: CPU hotplug: fix abuse of irqdesc->node
ARM: 6981/2: mmci: adjust calculation of f_min
ARM: 7000/1: LPAE: Use long long printk format for displaying the pud
ARM: 6999/1: head, zImage: Always Enter the kernel in ARM state
ARM: btc: avoid invalidating the branch target cache on kernel TLB maintanence
ARM: ARM_DMA_ZONE_SIZE is no more
ARM: mach-shark: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-sa1100: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-realview: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-pxa: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-h720x: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-davinci: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
'mmci', 'suspend' and 'vfp' into for-next
Since the A4LC should only be powered off if the A3RV is off, make
the A4LC's power down routine return -EBUSY if A3RV is not off to
indicate to the core that it doesn't want to power off the domain in
that case. This will cause the core to regard A4LC as active, so
the pm_genpd_poweron() in pd_power_down_a3rv() is not necessary any
more.
Acked-by: Magnus Damm <damm@opensource.se>
Make pd_power_down_a3rv() use genpd_queue_power_off_work() to queue
up the powering off of the A4LC domain to avoid queuing it up when
it is pending.
Make shmobile use pm_genpd_poweroff_unused() instead of the
open-coded powering off PM domains without devices in use.
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Make sure that the 'static' keywork is at the beginning of declaration
for arch/arm/mach-shmobile/board-ap4evb.c
This gets rid of warnings like
warning: ‘static’ is not at beginning of declaration
when building with -Wold-style-declaration (and/or -Wextra which also
enables it).
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
enables it).
Switch the sh7372 CPU support to use CMT2 instead
of CMT1 for system timer.
CMT1 is located in the A3SP power domain while CMT2
is located in the always-on power domain C5.
This improves our PM situation - with CMT2 as timer
we can power down A3SP and still access the timer.
Add a power domain workaround for the VPU and A3RV on sh7372.
The sh7372 data sheet mentions that the VPU is located in the
A3RV power domain. The A3RV power domain is not related to A4LC
in any way, but testing shows that unless A3RV _and_ A4LC are
powered on the VPU test program will bomb out.
This issue may be caused by a more or less undocumented dependency
on the MERAM block that happens to be located in A4LC. So now we
know that the out-of-reset requirement of the VPU is that the MERAM
is powered on.
This patch adds a workaround for A3RV to make sure A4LC is powered
on - this so we can use the VPU even though the LCDCs are in blanking
state and A4LC is supposed to be off.
Add sh7372 specific code to power down unused pm domains.
This should really be replaced by some generic PM core
code IMO, but until that happens this patch makes sure
we don't waste power by leaving unused power domains on.
Add a mach-shmobile specific callback for SoC-specific code
to hook into. By having the late_initcall() in a common place
we can have multi-SoC/board support in the same kernel binary.
Add support for the sh7372 D4 power domain. This power domain
contains the Coresight-ETM hardware block.
Add support for the sh7372 A4MP power domain
and hook up the FSI/SPU2 device.
FSI act as peripheral circuits of the SPU2.
If an ARM system has multiple cpus in the same socket and the
kernel is booted with maxcpus=1, secondary cpus are possible but
not present due to how platform_smp_prepare_cpus() is called.
Since most typical ARM processors don't actually support physical
hotplug, initialize the present map to be equal to the possible
map in generic ARM SMP code. Also, always call
platform_smp_prepare_cpus() as long as max_cpus is non-zero (0
means no SMP) to allow platform code to do any SMP setup.
After applying this patch it's possible to boot an ARM system
with maxcpus=1 on the command line and then hotplug in secondary
cpus via sysfs. This is more in line with how x86 does things.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@stericsson.com>
Add support for the sh7372 A3SG power domain. This domain contains
the SGX hardware block, but there is no open source driver available.
Add support for the sh7372 A3RI power domain. This domain contains
the ISP hardware block, but there is no driver available.
Add support for the sh7372 A3RV power domain and hook
up the VPU device.
The AP4EVB board is also using a sh7372 SoC, so tie in
A4LC support on that board as well.
Use the generic power domains support introduced by the previous
patch to implement support for power domains on SH7372.
The common PM clock management functions may be used for system
suspend/resume as well as for runtime PM, so rename them
accordingly. Modify kerneldoc comments describing these functions
and kernel messages printed by them, so that they refer to power
management in general rather that to runtime PM.
Reviewed-by: Kevin Hilman <khilman@ti.com>
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b
(PM: Add support for device power domains), which introduced the
struct dev_power_domain type for representing device power domains,
evidently confuses some developers who tend to think that objects
of this type must correspond to "power domains" as defined by
hardware, which is not the case. Namely, at the kernel level, a
struct dev_power_domain object can represent arbitrary set of devices
that are mutually dependent power management-wise and need not belong
to one hardware power domain. To avoid that confusion, rename struct
dev_power_domain to struct dev_pm_domain and rename the related
pointers in struct device and struct pm_clk_notifier_block from
pwr_domain to pm_domain.
Acked-by: Kevin Hilman <khilman@ti.com>
struct soc_camera_link imx074_link in board-ap4evb.c doesn't have
to be global.
This allows a ROM-able zImage to be written to eSD and for SuperH Mobile
ARM to boot directly from the SDHI hardware block.
This is achieved by the MaskROM loading the first portion of the image into
MERAM and then jumping to it. This portion contains loader code which
copies the entire image to SDRAM and jumps to it. From there the zImage
boot code proceeds as normal, uncompressing the image into its final
location and then jumping to it.
Acked-by: Magnus Damm <magnus.damm@gmail.com>
Name the SDHI1 instance sh_sdhi1_info to be consistent with sh_sdhi0_info.
USB1 can use IRQ interrupt and notify function for usbhs driver,
but USB0 is using polling for it.
The priority of usbhs devices order USB1 > USB0 is good idea
Reviewed-by: Simon Horman <horms@verge.net.au>
- usb0 pipe is same as default. own pipe config is not needed
- usb1 lost get_id function
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
While SH7377 and others were updated to properly use SCIFA/B port types,
SH7367 was left behind. Fix it up accordingly.
