With this patch, the socfpga clk driver is able to query the clock and clock
rates appropriately.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Reviewed-by: Pavel Machek <pavel@denx.de>
Enable a cold or warm reset to the HW from userspace.
Also fix a few sparse errors:
warning: symbol 'sys_manager_base_addr' was not declared. Should it be static?
warning: symbol 'rst_manager_base_addr' was not declared. Should it be static?
All the calls to gic_secondary_init() pass 0 as the first argument.
Since this function is called on each CPU when starting, it can be done
in a platform-independent way via a CPU notifier registered by the GIC
code.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Tested-by: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Barry Song <baohua.song@csr.com>
From Dinh Nguyen, this is a series of patches introducing support for
socfpga hardware (Altera Cyclone5). It also includes a cleanup that
moves some of the ARMv7 cache maintenance functions to a common location,
since three other platforms aready implemented it separately.
* socfpga/hw:
arm: socfpga: Add SMP support for actual socfpga harware
arm: Add v7_invalidate_l1 to cache-v7.S
arm: socfpga: Add entries to enable make dtbs socfpga
arm: socfpga: Add new device tree source for actual socfpga HW
Trivial conflict in arch/arm/mach-tegra/headsmp.S.
Because the CPU1 start address is different for socfpga-vt and
socfpga-cyclone5, we add code to use the correct CPU1 start addr.
Signed-off-by: Pavel Machek <pavel@denx.de>
Cc: Olof Johansson <olof@lixom.net>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Up to this point, support for socfpga has only been on a virtual
platform. Now that actual hardware is available, we add the appropriate
device tree source files.
Tested-by: Pavel Machek <pavel@denx.de>
into next/cleanup
From Rob Herring:
Initial irqchip init infrastructure and GIC and VIC clean-ups
This creates irqchip initialization infrastructure from Thomas
Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips
and adapted to use the new infrastructure. All DT enabled platforms
using GIC and VIC are converted over to use the new irqchip_init.
* tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux:
irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h
ARM: picoxcell: use common irqchip_init function
ARM: spear: use common irqchip_init function
irqchip: Move ARM VIC to drivers/irqchip
ARM: samsung: remove unused tick.h
ARM: remove unneeded vic.h includes
ARM: remove mach .handle_irq for VIC users
ARM: VIC: set handle_arch_irq in VIC initialization
ARM: VIC: shrink down vic.h
irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h
ARM: use common irqchip_init for GIC init
irqchip: Move ARM GIC to drivers/irqchip
ARM: remove mach .handle_irq for GIC users
ARM: GIC: set handle_arch_irq in GIC initialization
ARM: GIC: remove direct use of gic_raise_softirq
ARM: GIC: remove assembly ifdefs from gic.h
ARM: mach-ux500: use SGI0 to wake up the other core
arm: add set_handle_irq() to register the parent IRQ controller handler function
irqchip: add basic infrastructure
irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS
Fixed up massive merge conflicts with the timer cleanup due to adjacent changes:
arch/arm/mach-bcm/board_bcm.c
arch/arm/mach-cns3xxx/cns3420vb.c
arch/arm/mach-ep93xx/adssphere.c
arch/arm/mach-ep93xx/edb93xx.c
arch/arm/mach-ep93xx/gesbc9312.c
arch/arm/mach-ep93xx/micro9.c
arch/arm/mach-ep93xx/simone.c
arch/arm/mach-ep93xx/snappercl15.c
arch/arm/mach-ep93xx/ts72xx.c
arch/arm/mach-ep93xx/vision_ep9307.c
arch/arm/mach-highbank/highbank.c
arch/arm/mach-imx/mach-imx6q.c
arch/arm/mach-msm/board-dt-8960.c
arch/arm/mach-netx/nxdb500.c
arch/arm/mach-netx/nxdkn.c
arch/arm/mach-netx/nxeb500hmi.c
arch/arm/mach-nomadik/board-nhk8815.c
arch/arm/mach-picoxcell/common.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mach-realview/realview_pbx.c
arch/arm/mach-socfpga/socfpga.c
arch/arm/mach-spear13xx/spear1310.c
arch/arm/mach-spear13xx/spear1340.c
arch/arm/mach-spear13xx/spear13xx.c
arch/arm/mach-spear3xx/spear300.c
arch/arm/mach-spear3xx/spear310.c
arch/arm/mach-spear3xx/spear320.c
arch/arm/mach-spear3xx/spear3xx.c
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-tegra/board-dt-tegra20.c
arch/arm/mach-tegra/board-dt-tegra30.c
arch/arm/mach-u300/core.c
arch/arm/mach-ux500/board-mop500.c
arch/arm/mach-ux500/cpu-db8500.c
arch/arm/mach-versatile/versatile_ab.c
arch/arm/mach-versatile/versatile_dt.c
arch/arm/mach-versatile/versatile_pb.c
arch/arm/mach-vexpress/v2m.c
include/asm-generic/vmlinux.lds.h
Now that we have GIC moved to drivers/irqchip and all GIC DT init for
platforms using irqchip_init, move gic.h and update the remaining
includes.
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Convert all GIC DT initialization over to use common irqchip_init
function.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Cc: Dinh Nguyen <dinguyen@altera.com>
Now that the GIC initialization sets up the handle_arch_irq pointer, we
can remove it for all machines and make it static.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Olof Johansson <olof@lixom.net>
In preparation of moving gic code to drivers/irqchip, remove the direct
platform dependencies on gic_raise_softirq. Move the setup of
smp_cross_call into the gic code and use arch_send_wakeup_ipi_mask
function to trigger wake-up IPIs.
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
The socfpga_boot_secondary is correctly marked as __cpuinit but references
secondary_trampoline, which was introduced into the init section, causing
this build warning:
WARNING: vmlinux.o(.cpuinit.text+0xf90): Section mismatch in reference from the function socfpga_boot_secondary() to the variable .init.text:secondary_trampoline
The function __cpuinit socfpga_boot_secondary() references
a variable __init secondary_trampoline.
If secondary_trampoline is only used by socfpga_boot_secondary then
annotate secondary_trampoline with a matching annotation.
The solution is to mark secondary_trampoline as cpuinit as well.
Early printk code needs UART to be mapped early during
boot. early_printk() is left there during the start-up; it is useful
as our emulators are fairly slow.
Acked-by: Dinh Nguyen <dinguyen@altera.com>
[olof: removed redundant newlines]
Building a multiplatform kernel with combined armv7 and armv6
kernel does not work with the socfpga smp code, which contains
v7-only instructions. Since this code never runs on armv6,
we can annotate the assmebly with .arch armv7-a, as suggested
by Russell King.
[arnd: reword commit message]
Enable SMP for the SOCFPGA platform.
Reviewed-by: Rob Herring <rob.herring@calxeda.com>
This lets us build a multiplatform kernel for experimental purposes.
However, it will not be useful for any real work, because it relies
on a number of useful things to be disabled for now:
* SMP support must be turned off because of conflicting symbols.
Marc Zyngier has proposed a solution by adding a new SOC
operations structure to hold indirect function pointers
for these, but that work is currently stalled
* We turn on SPARSE_IRQ unconditionally, which is not supported
on most platforms. Each of them is currently in a different
state, but most are being worked on.
* A common clock framework is in place since v3.4 but not yet
being used. Work on this is on its way.
* DEBUG_LL for early debugging is currently disabled.
* THUMB2_KERNEL does not work with allyesconfig because the
kernel gets too big
[Rob Herring]: Rebased to not be dependent on the mass mach header rename.
As a result, omap2plus, imx, mxs and ux500 are not converted. Highbank,
picoxcell, mvebu, and socfpga are converted.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Acked-by: Jamie Iles <jamie@jamieiles.com>
Move socfpga debug-macro.S over to common debug macro directory.
Adding core definitions for Altera's SOCFPGA ARM platform.
Mininum support for Altera's SOCFPGA Cyclone 5 hardware.
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
