path: root/arch/arm/mach-spear/spear300.c
2016-06-23arm: use of_platform_default_populate() to populateKefeng Wang
Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Ray Jui <rjui@broadcom.com> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <robh@kernel.org> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24ARM: spear: Remove init_irq declaration in machine descriptionMaxime Ripard
Commit ebafed7a ("ARM: irq: Call irqchip_init if no init_irq function is specified") removed the need to explictly setup the init_irq field in the machine description when using only irqchip_init. Remove that declaration for spear as well. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-03-12ARM: spear: move generic.h and pl080.h into private dirArnd Bergmann
No file outside of mach-spear includes these files any more, so they don't have to be globally visible now. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-03-12ARM: spear: move all files to mach-spearArnd Bergmann
There are no conflicting files between the three mach-spear* directories and plat-spear any more, so we can now move all file to a common mach-spear directory. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
