path: root/arch/arm/mach-sunxi
2015-02-23ARM: sunxi: Have ARCH_SUNXI select RESET_CONTROLLER for clock driver usageChen-Yu Tsai
As the sunxi usb clocks all contain a reset controller, it is not possible to build the sunxi clock driver without RESET_CONTROLLER enabled. Doing so results in an undefined symbol error: drivers/built-in.o: In function `sunxi_gates_clk_setup': linux/drivers/clk/sunxi/clk-sunxi.c:1071: undefined reference to `reset_controller_register' This is possible if building a minimal kernel without PHY_SUN4I_USB. The dependency issue is made visible at compile time instead of link time by the new A80 mmc clocks, which also use a reset control itself. This patch makes ARCH_SUNXI select ARCH_HAS_RESET_CONTROLLER and RESET_CONTROLLER. Fixes: 559482d1f950 ARM: sunxi: Split the various SoCs support in Kconfig Cc: <stable@vger.kernel.org> # 3.16+ Reported-by: Lourens Rozema <ik@lourensrozema.nl> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-07ARM: sunxi: Register cpufreq-dt for sun[45678]iChen-Yu Tsai
On sun[45678]i, we have one cluster of identical cores sharing a clock, which is ideal for using cpufreq-dt. Register a platform device for cpufreq-dt. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-01-05ARM: sunxi: Add "allwinner,sun6i-a31s" to mach-sunxiHans de Goede
So far the A31s is 100% compatible with the A31, still lets do the same as what we've done for the A13 / A10s and give it its own compatible string, in case we need to differentiate later. Signed-off-by: Hans de Goede <hdegoede@redhat.com> [Maxime: Removed unusude CPU_OF_DECLARE_METHOD] Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-11-16ARM: sunxi: make sun6i SMP ops staticEmilio López
The sun6i SMP ops are currently not marked as static, as reported by sparse. Let's mark it as such. Signed-off-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-10-20ARM: sunxi: Select ARCH_HAS_RESET_CONTROLLER and RESET_CONTROLLER for sun9iChen-Yu Tsai
The A80 SoC has reset controls matching bus clock gates. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-10-20ARM: sunxi: Introduce Allwinner A80 supportChen-Yu Tsai
The Allwinner A80 is a new Cortex octo-core A7/A15 big.LITTLE SoC. While it's processor cores and interconnecting bus are new, it re-uses many peripherals found in earlier Allwinner SoCs. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Tested-by: Andreas Färber <afaerber@suse.de>
2014-09-11ARM: sunxi: Remove sun4i reboot code from mach directoryMaxime Ripard
Now that the restart code has been merged in the watchdog driver, we don't need the restart code in the mach-sunxi directory anymore. Remove it entirely. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-08-07Merge tag 'pinctrl-v3.17-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl updates from Linus Walleij: "This is the bulk pin control changes for the v3.17 merge development cycle: - get rid of the .disable() callback from the driver callback vtable. This callback was abused and counterintuitive since a pin or group of pins can be said to always be in some setting, and never really disabled. We now only enable a certain muxing, and move between some certain muxings, we never "disable" a mux setting - some janitorial moving the MSM, Samsung and Nomadik and drivers to their own subdirectories for a clearer view in the subsystem. This will continue - kill off the use of the return value from gpiochip_remove(), this will be done in parallel in the GPIO subsystem and hopefully not trigger too many unchecked return value warnings before we get rid of this altogether - a huge set of changes and improvements to the Allwinner sunxi drivers especially for their latest A23 and A31 SoCs, and some ground work for the new sun8i platform family - a large set of Rockchip driver improvements adding support for the RK3288 SoC - advances in migration of older Freescale platforms to pin control, especially i.MX1 - Samsung and Exynos improvements - support for the Qualcomm MSM8960 SoC - use the gpiolib irqchip helpers for the ST SPEAr and Intel Baytrail drivers - a bunch of nice janitorial work done with cppcheck" * tag 'pinctrl-v3.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (61 commits) pinctrl: baytrail: Convert to use gpiolib irqchip pinctrl: sunxi: number gpio ranges starting from 0 pinctrl: sunxi: use gpiolib API to mark a GPIO used as an IRQ pinctrl: rockchip: add drive-strength control for rk3288 pinctrl: rockchip: add separate type for rk3288 pinctrl: rockchip: set is_generic in pinconf_ops pinctrl: msm: drop negativity check on unsigned value pinctrl: remove all usage of gpio_remove ret val in driver/pinctl pinctrl: qcom: Make muxing of gpio function explicit pinctrl: nomadik: move all Nomadik drivers to subdir pinctrl: samsung: Group all drivers in a sub-dir sh-pfc: sh73a0: Introduce the use of devm_regulator_register sh-pfc: Add renesas,pfc-r8a7791 to binding documentation pinctrl: msm: move all qualcomm drivers to subdir pinctrl: msm: Add msm8960 definitions pinctrl: samsung: Allow pin value to be initialized using pinfunc pinctrl: samsung: Allow grouping multiple pinmux/pinconf nodes pinctrl: exynos: Consolidate irq_chips of GPIO and WKUP EINTs pinctrl: samsung: Handle GPIO request and free using pinctrl helpers pinctrl: samsung: Decouple direction setting from pinctrl ...
2014-07-19Merge tag 'exynos-cpuidle' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc Merge "Samsung exynos cpuidle update for v3.17" from Kukjin Kim: - add callbacks exynos_suspend() and exynos_powered_up() for support cpuidle through mcpm - skip exynos_cpuidle for exynos5420 because is uses cpuidle-big-liggle generic cpuidle driver - add generic functions to calculate cpu number is used for pmu and this is required for exynos5420 multi-cluster - add of_device_id structure for big.LITTLE cpuidle and add "samsung,exynos5420" compatible string for exynos5420 * tag 'exynos-cpuidle' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: populate suspend and powered_up callbacks for mcpm ARM: EXYNOS: do not allow cpuidle registration for exynos5420 cpuidle: big.LITTLE: init driver for exynos5420 cpuidle: big.LITTLE: Add ARCH_EXYNOS entry in config ARM: EXYNOS: add generic function to calculate cpu number cpuidle: big.LITTLE: add of_device_id structure + Linux 3.16-rc5 Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-11pinctrl: sunxi: Remove PINCTRL_SUNXIMaxime Ripard
The PINCTRL_SUNXI configuration was kept only to deal with the introduction of per-machine symbols and the various pintrl drivers through different tree. Now that it's not useful anymore, we can just remove it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-07ARM: sunxi: select MFD_SUN6I_PRCM when sun8i arch support is enabledChen-Yu Tsai
Select the MFD_SUN6I_PRCM option when sun8i arch is enabled in order to get the PRCM (Power/Reset/Clock Management) related drivers compiled. Also select ARCH_HAS_RESET_CONTROLLER and RESET_CONTROLLER to make sure the reset controller drivers are compiled. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-07-04ARM: sunxi: Reintroduce the restart code for A10/A20 SoCsMaxime Ripard
This partly reverts commits 553600502b84 (ARM: sunxi: Remove reset code from the platform) and 5e669ec583e2 (ARM: sunxi: Remove init_machine callback) for the sun4i, sun5i and sun7i families. This is needed because the watchdog counterpart of these commits was dropped, and didn't make it into 3.16. In order to still be able to reboot the board, we need to reintroduce that code. Of course, the long term view is still to get rid of that code in mach-sunxi. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-06-23ARM: sunxi: Introduce Allwinner A23 supportChen-Yu Tsai
The Allwinner A23 is a dual-core Cortex-A7-based SoC. It re-uses most of the IPs found in previous SoCs, notably the A31. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-05-26ARM: sunxi: allow building without reset controllerArnd Bergmann
The sunxi reset controller code is only used with sun6i (a31). After the platform has been split up into per-soc options, it's now possible to build it without the reset controller code, so the base platform init must not call into the reset driver if that is turned off at compile time. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-23ARM: sunxi: Remove init_machine callbackMaxime Ripard
The init_machine hook is now at its default value. We can remove it. Even though the sun4i and sun7i machines are nothing more than generic machines now, leave them in so that we won't have to add them back if needed, and so that the machine is still displayed in /proc/cpuinfo. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-05-23ARM: sunxi: Remove reset code from the platformMaxime Ripard
Now that reset is handled either by the watchdog driver for the sun4i, sun5i and sun7i, and by a driver of its own for sun6i, we can remove it from the platform code. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-05-17ARM: sun6i: Retire the smp field in A31 machineMaxime Ripard
Now that we can rely on the enable-method, remove the smp field declaration from A31 machine. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-05-17ARM: sun6i: Use CPU_METHOD_OF_DECLAREMaxime Ripard
CPU_METHOD_OF_DECLARE allows to bind the smp_ops to a set of cpus through the enable-method property, instead of relying on the machine to define it. Switch to it to get closer to an empty machine. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-05-15ARM: sunxi: select MFD_SUN6I_PRCM when sun6i arch support is enabledBoris BREZILLON
Select the MFD_SUN6I_PRCM option when sun6i arch is enabled in order to get the PRCM (Power/Reset/Clock Management) related drivers compiled. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-05-04ARM: sunxi: Split the various SoCs support in KconfigMaxime Ripard
This will allow to better isolate various options, and reduce the overall kernel size if we're interested in only one of the SoCs. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-04-05Merge tag 'soc-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "Lots of changes specific to one of the SoC families. Some that stick out are: - mach-qcom gains new features, most importantly SMP support for the newer chips (Stephen Boyd, Rohit Vaswani) - mvebu gains support for three new SoCs: Armada 375, 380 and 385 (Thomas Petazzoni and Free-electrons team) - SMP support for Rockchips (Heiko Stübner) - Lots of i.MX changes (Shawn Guo) - Added support for BCM5301x SoC (Hauke Mehrtens) - Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn and Sebastian Hesselbarth doing the final part of a long journey) - Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd Bergmann)" * tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits) ARM: sunxi: Select HAVE_ARM_ARCH_TIMER ARM: cache-tauros2: remove ARMv6 code ARM: mvebu: don't select CONFIG_NEON ARM: davinci: fix DT booting with default defconfig ARM: configs: bcm_defconfig: enable bcm590xx regulator support ARM: davinci: remove tnetv107x support MAINTAINERS: Update ARM STi maintainers ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE ARM: bcm21664: Add board support. ARM: sunxi: Add the new watchog compatibles to the reboot code ARM: enable ARM_HAS_SG_CHAIN for multiplatform ARM: davinci: remove da8xx_omapl_defconfig ARM: davinci: da8xx: fix multiple watchdog device registration ARM: davinci: add da8xx specific configs to davinci_all_defconfig ARM: davinci: enable da8xx build concurrently with older devices ARM: BCM5301X: workaround suppress fault ARM: BCM5301X: add early debugging support ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU ARM: mach-bcm: Remove GENERIC_TIME ARM: shmobile: APMU: Fix warnings due to improper printk formats ...
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-03-27ARM: sunxi: Select HAVE_ARM_ARCH_TIMERMaxime Ripard
In order for the architected timers support to be enabled in the kernel, this option has to be enabled. Otherwise, the architected timers driver won't be compiled in, and we will not get to use them. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-03-22ARM: sunxi: fix build for THUMB2_KERNELArnd Bergmann
Building an SMP kernel for the sunxi platform with THUMB2 instructions fails with this error at the moment: headsmp.S:7: Error: Thumb encoding does not support an immediate here -- `msr cpsr_fsxc,#0xd3' Since the generic secondary_startup function already does the same thing in a safe way, we can just drop the private sunxi implementation and jump straight to secondary_startup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-03-17Merge tag 'sunxi-core-for-3.15' of https://github.com/mripard/linux into ↵Arnd Bergmann
next/soc Merge "Allwinner core additions for 3.15" from Maxime Ripard: Just a minor commit to adjust the restart code to take into account the new compatibles * tag 'sunxi-core-for-3.15' of https://github.com/mripard/linux: ARM: sunxi: Add the new watchog compatibles to the reboot code Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-03-13ARM: sunxi: Add the new watchog compatibles to the reboot codeMaxime Ripard
Now that the watchdog driver has new compatibles, we need to support them in the machine reboot code. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-02-19ARM: select HAVE_SMP for V7 multi-platformRob Herring
All V7 platforms can run SMP kernels, so make CONFIG_SMP visible for V7 multi-platform builds. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-01-23Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New core SoC-specific changes. New platforms: * Introduction of a vendor, Hisilicon, and one of their SoCs with some random numerical product name. * Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m, i.e. !MMU). * Marvell Berlin series of SoCs, which include the one in Chromecast. * MOXA platform support, ARM9-based platform used mostly in industrial products * Support for Freescale's i.MX50 SoC. Other work: * Renesas work for new platforms and drivers, and conversion over to more multiplatform-friendly device registration schemes. * SMP support for Allwinner sunxi platforms. * ... plus a bunch of other stuff across various platforms" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits) ARM: tegra: fix tegra_powergate_sequence_power_up() inline ARM: msm_defconfig: Update for multi-platform ARM: msm: Move MSM's DT based hardware to multi-platform support ARM: msm: Only build timer.c if required ARM: msm: Only build clock.c on proc_comm based platforms ARM: ux500: Enable system suspend with WFI support ARM: ux500: turn on PRINTK_TIME in u8500_defconfig ARM: shmobile: r8a7790: Fix I2C controller names ARM: msm: Simplify ARCH_MSM_DT config ARM: msm: Add support for MSM8974 SoC ARM: sunxi: select ARM_PSCI MAINTAINERS: Update Allwinner sunXi maintainer files ARM: sunxi: Select RESET_CONTROLLER ARM: imx: improve the comment of CCM lpm SW workaround ARM: imx: improve status check of clock gate ARM: imx: add necessary interface for pfd ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100 ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support ARM: imx: Add cpu frequency scaling support ARM i.MX35: Add devicetree support. ...
2014-01-01ARM: sunxi: select ARM_PSCIZalan Blenessy
On Allwinner sun7i (A20) SoCs, the SMP operations are implemented in u-boot, and exposed to the kernel through PSCI. We thus need to enable PSCI support for Allwinner SoCs so that the kernel uses it to bring up the additionnal cores. Signed-off-by: Signed-off-by: Zalan Blenessy <zalan.blenessy@gmail.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-01-01ARM: sunxi: Select RESET_CONTROLLERMaxime Ripard
The current code selects ARCH_HAS_RESET_CONTROLLER, that enables the RESET_CONTROLLER option by default, but doesn't select it, so a configuration might unselect it, leading to compilation error. Explictly select RESET_CONTROLLER so that we can't have this breakage anymore. Reported-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-12-16ARM: sun6i: Add SMP support for the Allwinner A31Maxime Ripard
The A31 is a quad Cortex-A7. Add the logic to use the IPs used to control the CPU configuration and the CPU power so that we can bring up secondary CPUs at boot. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-12-11clocksource: Add Allwinner SoCs HS timers driverMaxime Ripard
Most of the Allwinner SoCs (at this time, all but the A10) also have a High Speed timers that are not using the 24MHz oscillator as a source but rather the AHB clock running much faster. The IP is slightly different between the A10s/A13 and the one used in the A20/A31, since the latter have 4 timers available, while the former have only 2 of them. [dlezcano] : Fixed conflict with b788beda "Order Kconfig options alphabetically" Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Tested-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2013-11-22ARM: sunxi: Register the A31 reset IP in init_timeMaxime Ripard
The A31 has a reset IP that maintains a few other IPs in reset by default. Among these IPs are the UARTs, and most notably the timers. We thus need to register the reset driver before initializing the timers so that the reset timer can use the reset framework. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
2013-11-22ARM: sunxi: Select ARCH_HAS_RESET_CONTROLLERMaxime Ripard
The A31 has a reset controller, and we have to select this option to have access to the reset controller framework. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
2013-10-28ARM: sunxi: remove .init_time hooksOlof Johansson
The machine entries were split up, but the cleanup to remove .init_time removed the function that the new/split entries refer to. Remove them since they are no longer needed. Cc: Maxime Ripard <mripard@free-electrons.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-28Merge tag 'sunxi-core-for-3.13' of https://github.com/mripard/linux into ↵Olof Johansson
next/soc From Maxime Ripard: Allwinner sunXi SoCs machine additions for 3.13 Nothing outstanding here, mostly some documentation cleanup, and the split of the previous generic machine declaration into three different machines to handle the sun4i/sun5i, sun6i and sun7i separately. * tag 'sunxi-core-for-3.13' of https://github.com/mripard/linux: Documentation: dt: Remove clock gates IDs list for Allwinner SoCs Documentation: dt: Remove interrupt sources list for Allwinner SoCs Documentation: sunxi: Update Allwinner SoC documentation Documentation: sunxi: Update A13 user manual dead link ARM: sunxi: Order Kconfig options alphabetically ARM: sunxi: Simplify restart setup code ARM: sunxi: Split out the DT machines for sun6i and sun7i Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-05ARM: sunxi: Order Kconfig options alphabeticallyMaxime Ripard
2013-09-29ARM: sunxi: remove custom .init_time hookSebastian Hesselbarth
With arch/arm calling of_clk_init(NULL) from time_init(), we can now remove custom .init_time hooks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-09-29clk: sunxi: declare OF clock providerSebastian Hesselbarth
Common clock framework allows to register clock providers to get called on of_clk_init() by using CLK_OF_DECLARE. This converts sunxi clock providers to make use of it and get rid of the mach specific clk init call. As sunxi has a bunch of independent clk provider nodes, we hook current clock init to board compatible to make it called once. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-09-27ARM: sunxi: Simplify restart setup codeMaxime Ripard
Now that we have different machine definitions for different SoCs, we can remove the DT lookup to get the restart hook we should be using, and hardcode it in the machine definition instead. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-09-27ARM: sunxi: Split out the DT machines for sun6i and sun7iMaxime Ripard
The A20 and A31 SMP code have a different way of bringing up a new core. This will prevent us from using the same set of smp_operations for the two SoCs family. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-08-16ARM: sunxi: Introduce Allwinner A20 supportMaxime Ripard
The Allwinner A20 is a dual-core Cortex-A7-based SoC. It is pin-compatible with the A10, and re-uses most of the IPs found in it, plus some additional ones like a Gigabit Ethernet controller. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-08-16ARM: sun6i: Add restart code for the A31Maxime Ripard
The Allwinner A31 has a different watchdog, with a slightly different register layout, that requires a different restart code. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-08-16ARM: sunxi: Add the Allwinner A31 compatible to the machine definitionMaxime Ripard
The Allwinner A31 is a quad-Cortex-A7 based SoC, which shares a lot of IPs with the previous SoCs from Allwinner, like the PIO, I2C, UARTs, timers, watchdog IPs, but also differs by dropping the WEMAC ethernet controller and most notably dropping the in-house IRQ controller in favor of a ARM GIC one. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-07-29ARM: sunxi: Remove Makefile.boot fileMaxime Ripard
Since we've been a multi-platform enabled kernel from the beginning, Makefile.boot has always been dead code. Remove it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-02Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "These changes are all to SoC-specific code, a total of 33 branches on 17 platforms were pulled into this. Like last time, Renesas sh-mobile is now the platform with the most changes, followed by OMAP and EXYNOS. Two new platforms, TI Keystone and Rockchips RK3xxx are added in this branch, both containing almost no platform specific code at all, since they are using generic subsystem interfaces for clocks, pinctrl, interrupts etc. The device drivers are getting merged through the respective subsystem maintainer trees. One more SoC (u300) is now multiplatform capable and several others (shmobile, exynos, msm, integrator, kirkwood, clps711x) are moving towards that goal with this series but need more work. Also noteworthy is the work on PCI here, which is traditionally part of the SoC specific code. With the changes done by Thomas Petazzoni, we can now more easily have PCI host controller drivers as loadable modules and keep them separate from the platform code in drivers/pci/host. This has already led to the discovery that three platforms (exynos, spear and imx) are actually using an identical PCIe host controller and will be able to share a driver once support for spear and imx is added." * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (480 commits) ARM: integrator: let pciv3 use mem/premem from device tree ARM: integrator: set local side PCI addresses right ARM: dts: Add pcie controller node for exynos5440-ssdk5440 ARM: dts: Add pcie controller node for Samsung EXYNOS5440 SoC ARM: EXYNOS: Enable PCIe support for Exynos5440 pci: Add PCIe driver for Samsung Exynos ARM: OMAP5: voltagedomain data: remove temporary OMAP4 voltage data ARM: keystone: Move CPU bringup code to dedicated asm file ARM: multiplatform: always pick one CPU type ARM: imx: select syscon for IMX6SL ARM: keystone: select ARM_ERRATA_798181 only for SMP ARM: imx: Synertronixx scb9328 needs to select SOC_IMX1 ARM: OMAP2+: AM43x: resolve SMP related build error dmaengine: edma: enable build for AM33XX ARM: edma: Add EDMA crossbar event mux support ARM: edma: Add DT and runtime PM support to the private EDMA API dmaengine: edma: Add TI EDMA device tree binding arm: add basic support for Rockchip RK3066a boards arm: add debug uarts for rockchip rk29xx and rk3xxx series arm: Add basic clocks for Rockchip rk3066a SoCs ...
2013-06-20Merge tag 'sunxi-core-for-3.11-2' of git://github.com/mripard/linux into ↵Arnd Bergmann
next/soc From Maxime Ripard: Allwinner platform additions, take 2 Adds machine support for the Allwinner A10s SoC * tag 'sunxi-core-for-3.11-2' of git://github.com/mripard/linux: ARM: sunxi: Add Allwinner A10s machine compatible Depends on the sunxi/cleanup branch Signed-off-by: Arnd Bergmann <arnd@arndb.de>
