Remove L3 state from xmm power driver. New usb phy code
allows pm state transition L0->L2 and L2->L0. When the
system goes in LP0/LP1 suspend then the modem power
state is kept at L2 and bus state in suspend controlled by
PMC. At system resume the hsic bus is given back to USB.
Bug 991709
Change-Id: Ib3b74d7da30a5103eddd747726ac7c4423472c76
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/108076
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
baseband_xmm_power has delays related to CP sync-up.
Changing these delays from mdelay() to msleep and
usleep_range.
Adding wait_event mechanism to wait for L2->L0
Bug 932574
Change-Id: Ie33a3f1cc0a798e592f00153435b0135713213ea
Signed-off-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-on: http://git-master/r/102689
GVS: Gerrit_Virtual_Submit
Modify USB structures of platform data. Based on the new
platform data structures modifying the initialization in
board files.
Bug 887361
Change-Id: Ie6347a078c9a596a4debe21a353e127ddde35220
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103597
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
XMM modem first enumeration has timing requirement, so khubd
should perform enum within 1 second. An issue is seen sometimes
when the hub events are not sent on time (on fully loaded system)
and then khubd timesout. This patch adds PM QOS request to bump up
the cpu frequency for 2 seconds.
Bug 946027
Change-Id: I1a43c043d42cfa442517a2a7ad8d69a934d4ab47
Reviewed-on: http://git-master/r/102697
Reviewed-by: Simone Willett <swillett@nvidia.com>
In AP initiated L3->L0 wakeup xmm power state is set BBXMM_PS_L3TOL0
but if CP is also trying to wakeup then ipc_ap_wake_irq with falling
edge treats it incorrectly as CP wakeup pending - new race condition.
Adding a check to fix this scenario for both L3 and L3TOL0 states.
Bug 966077
Change-Id: I3af3538b48745588f17e4c13a3e23e4033f21821
Reviewed-on: http://git-master/r/102698
- Platform data is treated as const and not modified in driver.
- Driver specific data is stored and used from a new structure.
- Remove support for older firmware version of XMM modem (<1130).
- Shortening of names for compliance and to fit in 80 characters.
- Organize irq function to reduce indentation.
Change-Id: I269401aa0a2efc685d7a630b4952cb31cbca6a4f
Reviewed-on: http://git-master/r/101587
check return value of usb_autopm_get_interface().
if return value is not success, usb_autopm_put_interface() should
not be called to make up the reference count.
Bug 936094
Signed-off-by: Shawn Joo <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/85974
(cherry picked from commit aad2bf5c8fef639465c4bb895b73a23c3f0c0403)
Change-Id: Ifd1deb1e0953eae1fd8d41f48989b650d6951fed
Reviewed-on: http://git-master/r/97647
Reviewed-by: Shawn Joo <sjoo@nvidia.com>
Tested-by: Shawn Joo <sjoo@nvidia.com>
Bug 949219
Change-Id: I875f8688a272c415ebf345b8f30e4afdf7551b29
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/91523
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
AVDD_DSI_CSI is shared by modem and dsi. If DSI turns
off this rail then HSIC fails after wakeup from modem.
This patch provides a way to turn on this rail from
modem as well as from DSI. Create two virtual power rails
from avdd_csi_dsi to control it from both the drivers separately.
This is enterprise specific change as per the power rail layout.
Bug 920881
(cherry picked from commit ab52b51c59f776ae770d48a28a2744e2db2e5d2f)
Reviewed-on: http://git-master/r/85656
Change-Id: I2e9c04a8f4e8d6fd20584b4e75657c1cb6d5c8bd
Reviewed-on: http://git-master/r/89134
Reviewed-by: Puneet Saxena <puneets@nvidia.com>
add shutdown handler to turn off CP when power off
and disable irq for ap wake.
Bug 942968
Signed-off-by: Seongho Joo <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/88188
(cherry picked from commit d37a1900afb9982115f18989b0114bad8f2602bd)
Change-Id: I1541453e21b46149bba08eafb0eadf9a598aa182
Reviewed-on: http://git-master/r/96455
modify CP power sequence timing based on modem vendor
spec information.
> 20 ms : REST low and ON low
> 400 us : RESET high and ON low
> 60 us : RESEET high and ON high
Bug 943280
Reviewed-on: http://git-master/r/85964
(cherry picked from commit 8a6e64228f11d46f502c654bd9a1b508af93a67b)
Change-Id: I01f4fae493627d46707ebfcad676fc0a25b5258d
Reviewed-on: http://git-master/r/96453
Check for valid interface after system resume and before
enabling runtime pm.
Bug 944052
Reviewed-on: http://git-master/r/85330
(cherry picked from commit a32495671f104e1ba0f5a4940bde17d34b9c87f2)
Change-Id: I77dc559ac0d4b31be756d3e770c04b8e5e7bfe36
Reviewed-on: http://git-master/r/96332
To handle race condition between CP wakeup and system suspend
following policy enforced:
1. If system suspend happens first, then buffer the CP wake
request and will abort the suspend at the end of device suspend
complete.
2. If CP wakeup happens first, then system suspend starts then abort
the system suspend immediately.
Bug 938553
Bug 948198
Bug 943035
Signed-off-by: Seshendra Gadagottu<sgadagottu@nvidia.com>
Reviewed-on: http://git-master/r/83130
(cherry picked from commit b2bd06368d3f6e16e5a7dd81c76dda0293de301b)
Change-Id: Ic7024aa739472a666f1274ccd7c9722259d54fa5
Reviewed-on: http://git-master/r/93384
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
Tested-by: Vinayak Pane <vpane@nvidia.com>
1.reduce CP ack timeout to 1000 ms, based on modem vendor spec.
expected timing is 10ms, but modem vendor recommend to wait less than 1 sec.
2.move log print after spinlock section.
log in spinlock could waste cpu resource.
Bug 932104
Reviewed-on: http://git-master/r/86003
(cherry picked from commit de853a886153cfb35cafcf797df490207187cc33)
Change-Id: I4b1ea80d25e0aa1f93599c08eedf306dbed00d63
Reviewed-on: http://git-master/r/91934
BUG 928909
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/82756
(cherry picked from commit f24375055ecba7c40c740a6b88ad03e38ea8b10c)
Change-Id: I2b3d59ea433555f595a1468cae3242b7dc54958a
Reviewed-on: http://git-master/r/89565
After flight mode on/off, EHCI phy power and modem power on sequences
not correct. For first enumeration HSIC phy should be power and then
modem needs to be powered before sending any hub events. Also
corrected initial state for ipc_ap_wake_state.
Bug 946027
Change-Id: I84edbebaa408fd6830adc09ebd0c67cb288a2626
Reviewed-on: http://git-master/r/86297
(cherry picked from commit 700c7bc52b26b370ff2449a9a9f91b22188a9aee)
Reviewed-on: http://git-master/r/88008
since irq function has printk and long context.
change the handler to irq thread for stable running.
Bug 937413
Signed-off-by: shawn joo <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/83350
(cherry picked from commit 1bf117669ed8b4fdb854074aef26d1a568544616)
Change-Id: Ib760e19903b7e9975a1ac7b8275537c75830764d
Reviewed-on: http://git-master/r/87633
sysfs xmm_onoff is called from userspace.
If it is called twice with same value it could cause a problem.
if it happens, this change will ignore the case.
Bug 943018
Reviewed-on: http://git-master/r/85721
(cherry picked from commit e722f73d1eed055682dbfeeedfa9c73173a7b3b6)
Change-Id: Ief96b667242a9af3df078cf62c9e9a9531b80f45
Reviewed-on: http://git-master/r/87639
Add enable_irq_wake in probe to enable gpio irq wake.
Bug 928950
Reviewed-on: http://git-master/r/85972
(cherry picked from commit e81069047c14a0ab9a3e1eb5588060959d550c49)
Change-Id: Ic513179670661ddc8a75d73a0afaa6264847cb1a
Reviewed-on: http://git-master/r/87644
Mutex protection is added on xmm_onoff
Bug 938553
Change-Id: I260847861a56f612f06c20cd7429c19c9001ac99
Reviewed-on: http://git-master/r/84751
(cherry picked from commit 14ac86297c4faa6a9cbf95877b782c997698347c)
Reviewed-on: http://git-master/r/87506
Tested-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Avoid unwanted xmm power state changes.
Added missing spin_unlock_irqrestore.
Bug 935834
Bug 938553
Reviewed-on: http://git-master/r/82796
(cherry picked from commit 8af674aadfc1196851d5a2ecd1ecdd2cfe2d4148)
Change-Id: Ic5b354376c0239773762d1b0f6e8848491e74e08
Reviewed-on: http://git-master/r/87503
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Fixed linux warnings in baseband_xmm_power.c file.
BUG 921565
Reviewed-on: http://git-master/r/77964
Change-Id: I6d0c6ef0c30351d6bfc77a733d306ab581ad9ea6
Reviewed-on: http://git-master/r/78712
baseband_xmm_power driver is updated with suspend/resume noirq callbacks.
If any CP wake-up is pending during suspen_noirq callback, then ongoing
system suspend will be aborted. With this mechanism, CP wakeup after
baseband_xmm_power driver suspend is handled.
BUG 904762
Reviewed-on: http://git-master/r/72933
Change-Id: Iae6f638885118c73d6154aad9daefee0cfc8e7d4
Reviewed-on: http://git-master/r/78435
Configure wake irq for waking up AP from xmm modem.
Also enable/disable this wake source base on flight mode
off/on setting.
Reviewed-on: http://git-master/r/69701
Change-Id: Iad274da9869102874efab27312fe8a182ab55bf3
Reviewed-on: http://git-master/r/78026
Re-enable usb auto suspend on system resume by making
get_interface() and put_interface() calls.
BUG 921565
Reviewed-on: http://git-master/r/73468
Change-Id: Ieb7c82e73a7134e1d3bb8b0b3e96a42ed6672afe
Reviewed-on: http://git-master/r/77763
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Check the state machine before poweron the modem by device
attribute change routine. Maintain the state machine to
avoid crash after writing state change to
/sys/devices/platform/baseband_xmm_power/xmm_onoff
Also cancel workqueue at module unload to avoid
possible crash.
Bug 898008
Reviewed-on: http://git-master/r/72934
Change-Id: I0d8286774040f155c930ecb0bb69778de6c606ac
Reviewed-on: http://git-master/r/77744
power_onff flag updated correctly for flashed modem.
BUG 905931
Change-Id: I383b1e01e380c04d8fd0179c50c77e4adf6f2a0b
Reviewed-on: http://git-master/r/72894
(cherry picked from commit c70dc7a8bc0c0bff5b09b5099d5ac3a1a1b2299d)
Reviewed-on: http://git-master/r/73960
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
ehci on/off mechanism is replaced with dynamic
add/removel of ehci-hcd driver.
BUG 787270
Reviewed-on: http://git-master/r/65091
(cherry picked from commit 50381a027547354140d599876f452ff6a304e330)
Change-Id: Ic9827c23fdbf367b87bb4ba153b65e7c867576d3
Reviewed-on: http://git-master/r/68391
Implemented L2 power management using autopm.
Added code for AP/CP initiated L2->L0 resume.
BUG 828389
BUG 873401
Reviewed-on: http://git-master/r/62115
(cherry picked from commit 14de0dc3ba9637b82a600693730752f2cbfebc66)
Change-Id: I233b777e96592fbf25e3c0a92d2d74dc7162eb40
Reviewed-on: http://git-master/r/66503
Tested-by: Michael Hsu <mhsu@nvidia.com>
Rebase-Id: R6779d1c8045deee78111d2b5b32a0400a7c3b4b0
XMM modem version 1130 (or later) changes the GPIO power up
sequence. Add module variable to support pre-1130 and post-1130
modem versions.
BUG 828389
Reviewed-on: http://git-master/r/58240
(cherry picked from commit 0639c200face90d6dd0144acc7362c02909fa66c)
Change-Id: If3a3486741d72d1251deeca3759af6b39c2031f1
Reviewed-on: http://git-master/r/62750
Rebase-Id: Rf848b30671a8739c11a376011165db6165f0a259
Used a wakelock to follow L0->L2->L3 state transition for modem
power states. Added code for AP initiated L2->L0.
BUG 828389
Original-Change-Id: Iad90364d27a0fac204c12880d6aa17a6e032b7d2
Reviewed-on: http://git-master/r/45486
Rebase-Id: R3f9c890584fbf626bac8e36e1fa0561376ffff94
Added the changes required for CP initiated L3 -> L0 resume.
BUG 828389
Reviewed-on: http://git-master/r/49462
(cherry picked from commit 58de177d5eb9ad81c6bfb25195a88011ce8622b9)
Change-Id: I423a7ff7cd6d5b1679b6f643337b28d2af5ce602
Reviewed-on: http://git-master/r/54198
Rebase-Id: R7a831e137f784d10c0914ac9226b86f2c99ee2b1
Now xmm power module made static part of the kernel.
xmm modem can be on/off using the sysfs interface.
BUG 828389
Original-Change-Id: Icfbe83beeac43f88418eee29f71ccd58d9b840c2
Reviewed-on: http://git-master/r/47773
Rebase-Id: R3adb92f2a3f3523c1006969a42499263dd0fa6fb
Add baseband power drivers to manage gpio for turning on modem,
and re-enumerating modem after modem's boot rom has transferred
control to downloaded modem software.
BUG 828389
Original-Change-Id: Ide96a28b8f0183d8328751d3b3dec92b8068a3c8
Reviewed-on: http://git-master/r/39435
Rebase-Id: Rb3d170a5460bff29550d664c3f783134d2a3a41f
Add power management for HSIC baseband power module.
Currently the power module implemented state handling for
L0->L3 and L3->L0 state transitions.
BUG 828389
Original-Change-Id: I46b7da66bfa85fac57261ec68668435855739981
Reviewed-on: http://git-master/r/33065
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R2d04847c5dc12db17b49ec62a4e12f061bca29fe
