Remove TEGRA_FB_VGA defines and use VGA as default. Since initial
mode is now configureable through kernel cmd line parameter, we
don't need those compile time helpers.
Use new modedb based framebuffer settings by defining default_mode
in the display controllers platform data. Also impelmented the
fallback logic to this default_mode in case no kernel cmd line
parameter was set.
Remove vdd_hdmi_con regulator from dc1 since we don't have a dedicated
regulator for this connector on our baseboards.
Clean-up GPIO definitions and names (e.g. use LVDS_ defines, BKL1_ON
rather than BL_ON and HDMI1_HPD rather than hdmi_hpd).
By default configure for LG LP156WF1 15.6 inch full HD dual channel
LVDS panel.
Activate 24 bpp RGB output.
Please not that this is just the backend configuration. For true 24 bpp
output the framebuffer as well as driver have to be configured for 24
resp. 32 bpp as well.
This patch contains updated display timings for the TouchRevolution
Fusion 10 aka Chunghwa Picture Tubes CLAA101NC05 10.1 inch 1024x600@60
single channel LVDS panel.
While at it add a note that the backlight brightness polarity is
display model specific.
This patch adds display timings for the Chunghwa Picture Tubes
CLAA101NC05 10.1 inch 1024x600@60 single channel LVDS panel.
This patch adds display timings for the LG LP156WF1 15.6 inch full HD
dual channel LVDS panel.
Tested on early prototype Apalis T30 V1.0a module.
Known issues:
- ADC not integrated yet.
- HDA not integrated yet.
- CEC not integrated yet.
- IrDA not integrated yet.
- Keys not integrated yet therefore no way to wake from suspend.
- 8-bit MMC1 slot card detection interrupt not working despite
detection GPIO successfully being tested with GPIOConfig.
Note: even 8-bit cards work fine if already plugged-in during boot.
- PCIe limited to internal Gigabit Ethernet chip for now due to our
proprietary way of resetting other ports which requires further
integration into NVIDIA's driver.
