Backlight value was inverted for panels with PM313.
This assumed the panel was the 15", but because the
10.1" (AUO) is more prevalent and doesn't have the
inverted backlight signal we no longer need to
invert it. Note this will fix the backlight issue
for AUO E1198 boards but break it for 15".
Bug 962636
Reviewed-on: http://git-master/r/#change,93965
Signed-off-by: Graziano Misuraca <gmisuraca@nvidia.com>
Change-Id: Icb65592eb2df21e349e5a759a780e4438a0f5b26
Reviewed-on: http://git-master/r/95728
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Change pin used for LVDS_SHTDN_N from GMI_AD9 to VI_D4
Bug 958167
Change-Id: Ie36bbed84746aeea1e84acdbd53d905a8b2bbf20
Reviewed-on: http://git-master/r/#change,108612
Reviewed-on: http://git-master/r/113061
Enable clock gating features for 720p DSI panel on the E1506.
Change-Id: I554c31a6697d5a9e37cab21418fb08477503d82d
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/113030
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Fix for power up/down sequencing for 720p DSI panel on the E1506.
Bug 997484.
Change-Id: Ia65e20b96da3bad0703136839eaf0394f9c7b364
Reviewed-on: http://git-master/r/109918
(cherry picked from commit c6f7033ddbc18a4b780620d1e7d65fe2ce5e4108)
Reviewed-on: http://git-master/r/111945
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
GVS: Gerrit_Virtual_Submit
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/104076
Reviewed-by: Simone Willett <swillett@nvidia.com>
Allow for DSI panel support to be present in release builds.
Removed CONFIG_TEGRA_CARDHU_DSI config variable.
Bug 978305.
Change-Id: I2b34fa5c5331de897d2b753da90e26278a6b7870
Reviewed-on: http://git-master/r/106919
Add support for 720p DSI panel on the E1506.
Bug 978305.
Change-Id: If76d2754eebc9e612c2ce006fa73ead7ebb1a109
Reviewed-on: http://git-master/r/104894
Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I51b17389dbb17b0e94e1635ec6d68acd01c743b4
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102529
1. Change hdmi platform data structure's xres and yres values.
These values were made same as LVDS panel (1366x768). LVDS
runs fix display mode,but HDMI can switch to different modes.
The new values (640x480) are corresponding to HDMI's fallback
mode resolution.
2. Map bootloader's framebuffer content to fb1 also, to
initialize fb1's content, and to avoid black & white
strips when hdmi gets enabled but has no content in fb.
It sometimes causes inconsistency on fb_console mapped on HDMI.
Bug: 930136
Change-Id: Iecf0d8c1cdd6a1baec2aec9c5dded3d73d1347e1
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/103381
Use nvmap.h include file from kernel/include instead of mach-tegra/include.
Bug 854182
Change-Id: Ic82b35d6c2e1c49461575a7bbbfd28ee43921466
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/102723
Set default videomode during the dc probe. This patch enables
HDMI during the probe only and fixes following issues:
1. Until Xinit there was no display on HDMI.
2. Framebuffer console on HDMI needs it to be enabled well before
Xinit.
To avoide un-necessary powering on HDMI,Check HPD and enable HDMI
only if it's present.
Bug: 930136
Bug: 977705
Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738
Reviewed-on: http://git-master/r/100656
This reverts commit 9349cedf17f9b3c10760c8d48f831473f87a3a15.
It is reviewed on http://git-master/r/99635
It will cause HDMI power ON and emc clock bump up to 667Mhz
after resume from LP0.
bug 930136
Change-Id: I130494fdb381b3d322ac0e3fc8be2e44f2c2d7a7
Signed-off-by: Hunk Lin <hulin@nvidia.com>
Reviewed-on: http://git-master/r/100202
Xinit.
Bug: 930136
Change-Id: Ieaf5c69eefa4a6584893425ad4fd772bcd91ea11
Reviewed-on: http://git-master/r/99635
Add 50Hz and 48Hz refresh modes on internal panel.
Choose pll_d as default for internal panel.
Choose pll_d2 as default for HDMI output.
Print a warning when touch panel work around code is being used.
Bug 560152
Change-Id: Ia155e02b4fdc4ea3a749c3f1e9edea94786441ba
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/94890
Bug 953155
Change-Id: I9fbb87f17e590971d5a0bf313e740e8b3b4c890b
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/91871
bpp on PM313 display was 18bpp which caused the
colours to show up incorrectly. Setting it
properly.
Bug 947532
Change-Id: Iccc99b67fea417b12d7bcc9f59055b60689be568
Reviewed-on: http://git-master/r/88214
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
- the suspend order of devices is governed by the order
in which devices are registered
- this commit ensures that nvhost master is registered before
any of the graphics devices
- previously this was done in rootfs_init call which is
later than arch_init calls of board-xxx-panel.c
- this caused tegra-dc device to be registered *before* nvhost
master device. as a result it was suspended *later* than nvhost
master device. this is a clear violation of dependency rule
for nvhost. this caused suspend-resume to fail for L4T
- this worked on android as it has CONFIG early suspend enabled
while it failed for L4T which doesn't have CONFIG early suspend
enabled
Bug 947617
Change-Id: I6cd405f3ba23d004e7659140019f5130e6c25159
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/87756
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
- tegra_grhost is a platform device that represents host1x
- nvhost has device host1x which represents the same hardware
- merge these two device structs
- as the new struct is a nvhost_device, platform_driver
is also converted into a nvhost_driver
- register nvhost device before other graphics devices.
this ensures that nvhost_probe() is called as soon as
nvhost_driver is registered with the core.
- this also ensures that nvmap is probed first, followed
by nvhost, followed by tegra-dc and nvavp (if they
are enabled).
Change-Id: Ic420a6516a9cb20d6f481692a4db10fa6053dd90
Reviewed-on: http://git-master/r/82631
Since not all possible PLLP output rates (216MHz, 408MHz or 204MHz)
can provide accurate enough pixel clock rate for cardhu panel, use
PLLD2 as backup clock source.
Bug 928260
Change-Id: I767e621606e849cb7d1976fbed198b9427660544
Reviewed-on: http://git-master/r/76034
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/76816
Because of incorrect struct member name. This is the left over from
the previous commit.
Change-Id: Ia4a824761bce69ad8f740ed7525c58affca7d1fb
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/75281
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This registers iommu_heap to be used by Ion memory manager.
If iommu_heap isn't supported with CONFIG_ION_IOMMU disabled, this
entry should be ignored.
Change-Id: Iabe072369eecdec4ca25396127c3720915b2eefd
Reviewed-on: http://git-master/r/72830
Add Ion device and its resources.
Change-Id: I77718dda4acc62074dc859a95441ef04181ae4a7
Reviewed-on: http://git-master/r/71114
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
Create nvmap dev and related resources only when CONFIG_TEGRA_NVMAP
is defined.
Change-Id: Iee9e43de79767353a750f73cddd6550a74315cff
Reviewed-on: http://git-master/r/70699
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
This change fixes the compilation error.
The error happens when CONFIG_TEGRA_DC is not defined
Bug 916044
Change-Id: Icddd959f1ad9d9d9acad66e478e84c2bc96687b2
Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Reviewed-on: http://git-master/r/70191
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Cardhu does not require conservative governor on early
suspend. It is also disabled in the defconfig
Change-Id: I5daa0fdcb8ef697bed83756e97f06747e5c89f8c
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
Reviewed-on: http://git-master/r/67326
continue to play HDMI audio past earlysuspend (when internal screen is
powered down). this is accomplished by using FB_BLANK_NORMAL on HDMI
display in earlysuspend instead of FB_BLANK_POWERDOWN.
bug 857117
bug 868916
Reviewed-on: http://git-master/r/53609
(cherry picked from commit 31edf6de69113e9895d495c5b584e1af6375cfed)
Change-Id: I692f862e9ad9b98193419c5f684114b9c6171875
Reviewed-on: http://git-master/r/56491
Tested-by: Jon Mayo <jmayo@nvidia.com>
Rebase-Id: R4a915b0116b209f161ce6878665d627828757285
In <board>_panel_late_resume() first switch to default
governor before fb_blank().
Bug 843845
Original-Change-Id: Ic6e3bc1da10631fc8a4525e57039c94ee552f7d2
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/39193
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Rebase-Id: R8339db8cd0669a0ae84fea09a3e5bb74a361e52a
The new parameters help cpu frequency stay in low level
clock as much as possible. This helps reduce power consumption
when display is off.
BUG 817727
Original-Change-Id: I030319d78e793a0372008a5c0640dce3720a47d8
Reviewed-on: http://git-master/r/35266
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R72ba82c3403f37721b95617989247e24b371c5fe
To improve the power consumption situation for MP3 playback
the scaling governor is set to conservative when display
is turned off and the default governor is saved. The governor
is restored when display is turned on.
Bug 817727
Original work done by "Wen Yi <wyi@nvidia.com>"
Original-Change-Id: I43ffb0d508cc6d0a80eeeffcbab77526b644c437
Reviewed-on: http://git-master/r/32194
Rebase-Id: Rffc94033789079726dad27ff5c65e20001478862
use FB_BLANK_POWERDOWN on hdmi device in earlysuspend to cause
tegra_dc_disable.
use new hotplug_init / postsuspend callbacks to manage +5V hdmi power
pin. this pin should be enabled whenever the device is active, and off
when the device is suspended.
bug 812083 bug 811523
Original-Change-Id: I6e8a2ae2683c79d5271aef9580df68c11628c823
Reviewed-on: http://git-master/r/27571
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Original-Change-Id: I6d98bdd58c90e02085d13bf29f2046baf144722e
Rebase-Id: Ra8e3c0247a16fdcba0c2a0a8795b2b1e6e9155bb
trigger display FB_BLANK_POWERDOWN during earlysuspend.
Original-Change-Id: I21c75bca28bd599730b93b84d2c5de1dcb40a74e
Reviewed-on: http://git-master/r/22472
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Original-Change-Id: I1a9bc8b499ab39cebea0a1435bfe519dba7c55c0
Rebase-Id: R63cbab44f6fb4b09f4396e238ef84f9a810c57b6
PM313 SKU0001 supports selecting BPP ( 18bpp or 24bpp )
Bug 822980
Reviewed-on: http://git-master/r/61005
(cherry picked from commit c6f9f5ebfe5f85bc56298092dce142980bed5d71)
Change-Id: Ifa25704d91bdd9de164b2baac835c38f0cdc0813
Reviewed-on: http://git-master/r/66576
Reviewed-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Tested-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Rebase-Id: Ra8e388176b4d7d35915809d5272524ad0fa02cae
Turns on phase_in_adjustments on for Cardhu / Enterprise and
updates flicker control
Reviewed-on: http://git-master/r/64522
(cherry picked from commit 9b217486322c4da8ba0df0ec6710caf94efbd721)
Change-Id: I1fc4ef0b04881c9f2b34b0ab2c88d6b97c88815c
Reviewed-on: http://git-master/r/65626
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R1e8eb79e658556337666186e416f7fccc5a4508b
This change supports PM313 with 19X12 panel.
The change uses PM313 in "Single input to Dual output" mode
Bug ID : 822980
Reviewed-on: http://git-master/r/50215
(cherry picked from commit b83e795747fa860b5b7fb66b2067ebe4f15bcfd0)
Change-Id: Iabf707ded2976e9877481c215d0b1f1940781f14
Reviewed-on: http://git-master/r/60085
Rebase-Id: Re8eadc35c75fa21b0a5f3cb3bee0e8cb77dc3238
Cuts dependencies to nvhost by adding a Kconfig dependency from DC to
GRHOST and from HD Audio to DC. Configure out calls to nvhost in board
panel files if GRHOST is not present.
Bug 870898
Change-Id: If7830528e321e951bcadc2a10515e6cab58a6cdf
Reviewed-on: http://git-master/r/56370
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Tested-by: Antti Miettinen <amiettinen@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Chris Dragan <kdragan@nvidia.com>
Rebase-Id: R16d9286d67235b0697c914476e7d6462eec7f3ac
Adding support for E1257 platform.
bug 864294
Reviewed-on: http://git-master/r/50662
(cherry picked from commit 8217615021a6ffeb992327f6b010ea9deebc34e7)
Change-Id: I3429da1bca38e1ddc5b3c2156a0db6b23aeb5555
Reviewed-on: http://git-master/r/57806
Rebase-Id: R7fadbdc30bdca30e41e0b7fdb88628dbc8c32e82
Adding support for PM311 based system.
bug 870139
Reviewed-on: http://git-master/r/50012
(cherry picked from commit d319d9980b6b225735ac97160fdee18fbabba2f0)
Change-Id: Iaa28921761e035e8fa29956b776f9379ae326b42
Reviewed-on: http://git-master/r/57251
Rebase-Id: R50fc9a079bd46a050084afed2b0f460e2916ebc9
Also re-arranged tegra_nvavp code so that it is common accross boards
Bug 880623
Change-Id: I7d634a718e07e07e945fb512466b3a0672aea7e2
Reviewed-on: http://git-master/r/54487
Rebase-Id: R78e4af97d967003560e80efce79d6b22d6d66c4f
Adding support for PM305.
bug 846246
Original-Change-Id: Ib036c67c12984668e0b7153f76a1a1d44c5be14f
Reviewed-on: http://git-master/r/49820
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: R9e9eb93ddcea487159854533eead3fe8eb74e42b
configure ordered dithering for 18bpp internal lcd.
Bug 869395
Original-Change-Id: I4e9391773f783992820e85a201d29403455bc100
Reviewed-on: http://git-master/r/49508
Rebase-Id: R5ff8b01be9412151a51553004cd0040d70bddc4c
Change-Id: Ie1ec67106ffb4cf38415095a8db31d01fe1d5e10
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/49274
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R23e65a63d3f2869217af5cc7952ea64931ba4924
Do not request backlight enable GPIO pin
in backlight notify. It is already
acquired in backlight init.
Bug 865058
Change-Id: Ic6a0fc804d87590b17851c0a79cb19509068c32d
Reviewed-on: http://git-master/r/48442
Rebase-Id: Ra7e7c9f128f9101f8a6e4457ef668ab0d123604a
Cardhu has both an internal panel (on fb0) and external HDMI (on
fb1). One of the devices might be blanked while another is unblanked.
In order for the backlight blanking logic to know whether to turn off
the backlight for a particular framebuffer's blanking notification, it
needs to be able to check if a given framebuffer device corresponds to
the backlight.
This implements a check_fb pwm_backlight hook to make the internal
panel's backlight only toggle on fb0 blank changes.
Bug 864592
Original-Change-Id: Ieafb8269c8bf5e030181b332d965b40d374efc1e
Reviewed-on: http://git-master/r/47637
Tested-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Chetan Hooli <chooli@nvidia.com>
Tested-by: Chetan Hooli <chooli@nvidia.com>
Rebase-Id: R989fd6e64a339d3efec360789805e4392e8468af
Change clock source for pwm modules and increase backlight pwm frequency
to 1kHz.
Bug 858358
Original-Change-Id: I8e69de79e77e1c88aec8913d304b40013113fc22
Reviewed-on: http://git-master/r/46854
Rebase-Id: R867c966b3aa005501ee3678f257e243a5632e9c5
To prepare for kernel modularization, nvhost include files need to be
moved from mach-tegra/include to kernel/include. At the same time
user space specific part is split into nvhost_ioctl.h.
Bug 854182
Original-Change-Id: I3694a40d786028733310ecf5b59341282af571be
Reviewed-on: http://git-master/r/43211
Rebase-Id: Rc4fadf65d59ddfb5bb924e7adfccd39e86a0b2c7
Default to DIDIM on with aggressiveness 1
Set use_vid_luma = false on init
Bug 859226
Original-Change-Id: Ibd12bad8a15e3f09b197c424325df2ec8239d821
Reviewed-on: http://git-master/r/44671
Rebase-Id: R123f8454f2f38b1f6c551272b364c97a7c5d7a20
A debug message shows up 50+ times a second when smartdimmer is active.
Original-Change-Id: I36c4956dca0f41d40d3c02cacfdb0558bd2cb059
Reviewed-on: http://git-master/r/46424
Rebase-Id: R45b531a1306231937b66bfdfa9c12ec96ccadcf9
Use different display refresh rates for some boards that are more
sensitive to touch screen interference.
Bug 861062
Original-Change-Id: I76a31107b2111d4a0d6d5f072ead877a35cd59a0
Reviewed-on: http://git-master/r/45874
Rebase-Id: R5605962a8d026d775af9f7d166daa697c5e6d4d5
Original-Change-Id: I3ad643db67c62c57320e94f193317078ad919b9c
Reviewed-on: http://git-master/r/45691
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Rebase-Id: R452d613de364d2bdf41af1e048f4586e202fa028
Adjust display timings to reduce noise that interfers with touch panels.
Bug 853676
Original-Change-Id: I9869e9ad6111fda6e0e629d98bb4977a5f0c3df7
Reviewed-on: http://git-master/r/44167
Rebase-Id: R687a4bcc0ee8d96a9e6ed39ccee15b035aa9077a
