Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103534
Reviewed-by: Simone Willett <swillett@nvidia.com>
Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103622
Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I51b17389dbb17b0e94e1635ec6d68acd01c743b4
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102529
Enabling the sh532u driver feature to not register itself
if it does not identify the sh532u device during probe.
This is for the case where the platform does not populate
the device.
Bug 929133
Change-Id: Ic5ac7fa0ae4c05e4978fe7aebc3fc630ef1c2fd3
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/92340
The gpio regulator which is controlled through the gpio, which
is open drain type, is using the gpio_switch regulator.
The open drain support is added into the fixed regulator
and hence moving the regulator to use fixed regulator.
Change-Id: I1428d7e10ff469587c45fe913c4be8b4e35cb5bd
Reviewed-on: http://git-master/r/94196
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Just set the opt in booleans in the platform data instead of checking
which function to register for pm_power_off.
Change-Id: If336ff69e4b61b4220e6766b2643c5fba74d01cc
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83597
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Using fixed regulator in place of gpio-switch regulator.
Fixed regulator is very similar to gpio-switch regulator
and it is available by default in linux kernel.
gpio-switch-regulator will be used only for the open
collector load switches.
bug 923713
Change-Id: I42480cb314135d475b4d4b56bb5e8e73eba2f77e
Reviewed-on: http://git-master/r/74536
Reviewed-on: http://git-master/r/76465
Add PM269 board support for sh532u focuser by adding regulator
defines and the PM269 reset GPIO's.
Bug 923072
Change-Id: Ic042d2c9c2cf78a38a1b72fab2db0289fb1d9909
Reviewed-on: http://git-master/r/73877
Reviewed-on: http://git-master/r/75146
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
mach-tegra/tegra3_tsensor.h is used for the parameterized initialization
of the tsensor device. mach-tegra/include/mach/tsensor.h is used for the
tsensor device driver.
Really, mach-tegra/tegra3_tsensor.c should go away - probably becoming a
device driver.
Change-Id: I16edae878f1e97d1654252cfee49cd9dd7f77db7
Reviewed-on: http://git-master/r/72481
PM298 what MAX77663 PMIC supports for PM305, PM311 and E1257 based
systems.
Reviewed-on: http://git-master/r/56365
(cherry picked from commit 7ed6615501bf406e0fca79e559e60e896b07bea2)
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Change-Id: Ie4e376fdadf530d25bc3d446d925fde08f42e2b1
Reviewed-on: http://git-master/r/65067
Tested-by: Jinyoung Park <jinyoungp@nvidia.com>
Rebase-Id: Rf6feb97cfccb4993e40b95ae2ff07a2822fef80a
The SDMMC_VDD control is generated from the cpld programming for pm269
and so it is not require to have gpio control for this.
This change is came from commit e92b10299b329f9df29ae23099b8f2f5f2eee1d7.
Reviewed-on: http://git-master/r/56367
(cherry picked from commit b30687a50bb2bf520d71e02339d01481c2d418bd)
Change-Id: I24d37dec2fa064c8a25526352247bcc9d3a002f9
Reviewed-on: http://git-master/r/65066
Rebase-Id: R86cfccdc962147722f40b6dbcd4d6c81d9afb169
Use the device driver name instead of encoding the SDMMC controller
in the regulator supply name.
This change is came from commit 676dd57f8eb252ce61807c02e5153b4ee4e29418,
and it was reviewd on http://git-master/r/#change,53783.
Reviewed-on: http://git-master/r/56368
(cherry picked from commit 03aa6082f7db7006de6e9c357fcf04e0d395fb16)
Change-Id: If80057e52feb29598e2b6bff2e729277f7828531
Reviewed-on: http://git-master/r/65065
Rebase-Id: Rdb7c61e477e59a56237e0ea89c37848552842323
Previously it is configured SD1 min_uV to 1.05V to avoid voltage
under-shooting issue on SD1 power rail.
But it doesn't need after safe voltage scaling step patch for
max77663 regulator driver.
Reviewed-on: http://git-master/r/56962
(cherry picked from commit 3ea4ea8a5594cb8b5781bfd06816993b0a3e90cf)
Change-Id: Ied2b8e54f2ac05182b1e0d256e48cda2b6aab0b4
Reviewed-on: http://git-master/r/65064
Rebase-Id: Rd4e1d0ea5f087fe223bb8bb5722c972031012678
Adding regulator supply "vdd" for NCT1008 into PM298 what MAX77663 PMIC.
Reviewed-on: http://git-master/r/56366
(cherry picked from commit 3db418ee3342f70cb8bfbb7edc0e897d69a826c9)
Change-Id: Iba41fac3e8a92bc0e9f6ed4037b48bfded32e271
Reviewed-on: http://git-master/r/65063
Rebase-Id: Rd14450aeff9bcd71c086266aa41114fcd6446970
Use platform_data instead
Rebase-Id: R74c46fcb0c04961a8e91382da503679db2fede0b
Integrating MAX77663 PMIC based PM269 board into the Cardhu board.
The system will be find the correct PMIC using the Board ID of PMIC
in the Cardhu init phase.
Bug 849360
Reviewed-on: http://git-master/r/56354
(cherry picked from commit 4d7da62a829de4d051c458caa052a6d612f642fa)
Change-Id: I41a52b70d27378e6240522c16256f8c7e42144b5
Reviewed-on: http://git-master/r/64399
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R6baa5408a249a41d577f22da8476ad020600b12d
