FOR 12r7 ONLY
Temporary change from LP0 to LP2 for secureos customers
Change-Id: I076fd59e92ab64e9d9c958bc991e2fc3e13de108
Reviewed-on: http://git-master/r/48583
Reviewed-by: Ryan Wong <ryanw@nvidia.com>
Tested-by: Ryan Wong <ryanw@nvidia.com>
The ldo2 power rail should be set to 1200mV on E1208-A03 based
pmu.
bug 863728
Change-Id: I7730443bc052348a082d52a73e4f521ec34202f7
Reviewed-on: http://git-master/r/47491
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Vivek Aseeja <vaseeja@nvidia.com>
Add board support needed for PMU switch off when tsensor
detects temperature > TH3 threshold set.
bug 850047
Change-Id: I7a283cedc735264dd8ea52801f7f1a103e9293cb
Reviewed-on: http://git-master/r/41531
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Wake 3 is used by WiFi for waking up from the suspend mode.GPIO
associated with wake3 is TEGRA_WAKE_GPIO_PB6.This is applicable for
the power configuration LP0.
bug 856515
Change-Id: I014997b9f688475f0f3441136661c03ec3c1b4ba
Reviewed-on: http://git-master/r/43457
Bug 853132
Change-Id: I59cc6b2025926695ebee12d808fb49f556ffaa6d
Reviewed-on: http://git-master/r/42264
- Added table with EDP Capping values for different SKUs/regulator
currents in new file edp.c
- New entry point tegra_init_cpu_edp_limits()
- Added DebugFS entry under debug/edp to list the currently
selected EDP table
- Populated EDP table in edp.c with data from Bug 844268
- edp.c keeps main EDP table; cpu-tegra.c and board-cardhu-power.c
both read from there
Bug 840255
Change-Id: I55c2ee16278be8cd3005218bedebe76846d137d8
Reviewed-on: http://git-master/r/40938
Setting the rail voltage of the AVDD_PLLs to 1.2V and rail voltage
of PLL_SATA to 1.05V.
Change-Id: Ibf5bb1d11b7b15cabb68f90da7e24dd999915c55
Reviewed-on: http://git-master/r/41179
Added the board level suspend/resume and call the console
suspend from board level suspend/resume.
bug 820536
Change-Id: I246265241246dc0682870571c927bd23023e5aca
Reviewed-on: http://git-master/r/41448
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Adding board level suspend/resume for cardhu.
Disabling the clock for console uart port if console_suspend
is enabled.
bug 820536
Change-Id: Iecb78708ff7784dd131ffa83692b2419dba44e88
Reviewed-on: http://git-master/r/41147
Adding the TPS6591x gpio definition in tps6591x core header
files.
bug 849976
Change-Id: I1f7a7cc38e220c091ccf44db5af6e43c34daa1cd
Reviewed-on: http://git-master/r/41040
Remove the hardcoding of the numerical value for different
sku bit and fab definition and using macro for better readability.
Change-Id: Idf70c7a063b5416e170b3b7e61e896250c9ad70c
Reviewed-on: http://git-master/r/37644
Removing the always on in constraints of the power rail of backlights.
bug 850674
Change-Id: I15b835012db75fdf74dc1d7a742da0573c5af06d
Reviewed-on: http://git-master/r/40798
Adding support for the E1256. The configuration is
same as the E1186 board.
bug 849990
Change-Id: Idd89e282627b2f0924fc313a5ba28f9e9a6032be
Reviewed-on: http://git-master/r/40367
The problem with slow PMU was fixed with a hardware
change to reduce capacitance on the power rail, so
delays are no longer needed
Change-Id: Ib66378ca6bf18c112e90d44d3213dd5f6c870c92
Reviewed-on: http://git-master/r/37127
Bug 796825
Change-Id: I91be0bca739a2daf32807306a611671f387a8988
Reviewed-on: http://git-master/r/36096
Adding complete constraints of the regulators.
bug 843566
Change-Id: Ifd07d15d257ff8c89c4a3cc31c9e72d886e6b431
Reviewed-on: http://git-master/r/39633
Enables LP0 to stay asleep on PM269
Bug 848662
Change-Id: Ie29c9f89ee1d3a3b8f3272cdbc2714b05d5b0bbc
Reviewed-on: http://git-master/r/39450
Correct pingroup is DAP3_DOUT
Bug 825778
Change-Id: I252398c4f1d653c73c5fd26a7b5c12410a962ade
Reviewed-on: http://git-master/r/39822
Putting the unused vddio_gmi pins into the low power mode.
bug 833087
Change-Id: I7595d011a61d5993fee167e89ed7eb204d5cb6b6
Reviewed-on: http://git-master/r/37877
Reviewed-by: Matthew Longnecker <mlongnecker@nvidia.com>
Set the default sleep mode to be lp0.
Note: This change only affects Tegra3-A02. For A01, the default sleep mode is
still lp1.
Bug 802410
Change-Id: Idef6ab46c13a9aca24982c6b39ebe481bad46b9a
Reviewed-on: http://git-master/r/38408
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Tested-by: Chih-Lung Huang <lhuang@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Enable PMU only features for LP0. System-wise LP0 is not enable by default yet.
1. Allow pmu SLEEP state
2. Keep 32KHz clk out from PMU enabled on LP0
3. Set core_power_req to be high enable
4. Turn off VDD1 (power for Vcore) on LP0
Change-Id: Id6babdfc36de1a597f8df5d2943ef048699013d4
Reviewed-on: http://git-master/r/32853
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
change the input supply to master 5v to enable VDDIO_HDMI
signal for HDMI.
Bug 825778
Bug 823160
Change-Id: I2d6360ab3769ff876bdb7d0e0b34d9298aa780d0
Reviewed-on: http://git-master/r/35904
The core_pwr_req signal need to be make high for the PMU A03 and A04.
bug 829846
Change-Id: Ie568a29e76823e86743893ea59953b0429cc027a
Reviewed-on: http://git-master/r/36544
The E1291-A04 power rails are different then the A02/A03 version of E1291.
Supporting the A04 power rails properly.
Change-Id: I4c7dc0afa5b6bb1a7350418ef07f4ee7192cff30
Reviewed-on: http://git-master/r/35722
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Configuring the tps6591x into DEV_SLP mode and
gpio2 of tps6591x into sleep mode for E1291-A04 board.
This is required in order to have the gpio2 follow the
'CORE_PWR_REQ' pin in E1291-A04. GPIO2 of tps6591x is
connected to the EN of the DC-DC converter which supply
core voltage.
bug 821295
Change-Id: I01a8fa6c056872cff84dd0f2ae7601cee298ebcf
Reviewed-on: http://git-master/r/32614
This reverts commit 0885c8037152e4b11d669c845ddf09ba49e5c8b6.
Change-Id: I254ca2966cdf28d548368340efb64617ce274a74
Reviewed-on: http://git-master/r/32698
Change-Id: I57f033f44cfdf19d61bc5bab41cec23e51b40c11
Reviewed-on: http://git-master/r/32089
1. Set core_power_req to be high enable
2. Turn off VDD1 (power for Vcore) on LP0
Change-Id: I81aedb4332c9e7ccd97def546a9a0611253f744a
Reviewed-on: http://git-master/r/32277
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Change-Id: I6282bbb63c34b8cc0d503cdd6eafe575fb78ef5f
Reviewed-on: http://git-master/r/31342
Adding platform data entry for the tps6236x device and registering
this device if board info has sku with bit0 as 1.
bug 821295
Change-Id: I18618ef75eca66a1f699c003c787dcb1f06e7659
Reviewed-on: http://git-master/r/31388
Adding GPIO_REG for power rails of PM269 board.
Bug 823160
Change-Id: Idbb889420e033780900b1b1b700637017640414e
Reviewed-on: http://git-master/r/30366
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Setting SATA & PCIE power rails (ldo1 & ldo2) off by default since
they are not enabled on Cardhu.
Bug 793780, 790141
Change-Id: If905f156b99314271874536d61fe384715f2412a
Reviewed-on: http://git-master/r/31292
Adding the camera autofocus power rail infomration.
Removing non-existant peripheral entry from i2c4 bus.
Adding deselect mux option after each i2c transfer
through mux i2c.
bug 802264
Change-Id: Id87178666e4d8c4c5db3f8be708fc5fc85b3e2e4
Reviewed-on: http://git-master/r/29998
Change-Id: Ic30a091dd634b1857cdbfc5a0c47d34bc496b04f
Reviewed-on: http://git-master/r/29884
Setting CORE_PWR_REQ to high.
This is require to enable tracking regulator to supply more than
2A current for cardhu A03 board.
bug 805454
Change-Id: I4ff9d4d2bf106dc0d3d708fe9e1a7f7158dce27e
Reviewed-on: http://git-master/r/29623
Internal and PMU RTC data are enabled only when respective
macros are defined in the Cardhu defconfig file.
bug 793949
Change-Id: Iefc074877b263f3620c5ad08026435b3232ae3aa
Reviewed-on: http://git-master/r/29637
Adding power rail details for Vibrator on E118x board.
bug 810072
Change-Id: Ibf50c986b843fb36515f36493b5a07323ac940ab
Reviewed-on: http://git-master/r/29631
Added board level tuning parameter to specify minimum LP2 residency
time (previous policy allows down to zero residency targets limited
only by LP2 exit latency).
Original-Change-Id: I4ae7d458fba78f35a40f138cf9489bf938715b22
Reviewed-on: http://git-master/r/28162
Change-Id: I38e798ca6d242d136ea2353d90cc961de14f25b6
With this change, Jan 1, 2000 is being set as
default date on PMU RTC
Original-Change-Id: Ib1930970c6b58d5fa820a77eedd7b61dab731ee7
Reviewed-on: http://git-master/r/28029
Change-Id: Iddfaea12cf2329238c48939d7686c98694703e64
Fix for bug 816031: We need to have appropriate delays to make
DVS work on all boards we support.
Original-Change-Id: I60db0832f2591dcbf2a3904474440996f032bc28
Reviewed-on: http://git-master/r/27966
Change-Id: I2421b73909edb469f1caaaf74a7213902d02c080
Remove executable permission bit from source files.
Generated with:
find \( -name "*.c" -or -name "*.h" -or -name "*akefile" -or \
-name "*\.mk" \) -type f -perm /+x | xargs chmod -x
Original-Change-Id: If459d180238b8dd4cc40f92f74a56d01c81a2768
Reviewed-on: http://git-master/r/27916
Tested-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: If96e5e61c9f3b60ceaf9dcf88c0c7d7d1d8f343a
Changes required for waking up system, when RTC alarm
is triggered.
bug 793949
Original-Change-Id: Idcc536a819e977fe35bafeebdffddf57d5388f21
Reviewed-on: http://git-master/r/27359
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: I68bb747cb965d14af9918ad6086ac2e9888f7136
The E1291-A03 uses the following pins for the different power rail
controls:
EN_VDD_BL1 --->PEX_L0_CLKREQ_N
EN_VDD_BL2 --->PEX_L0_PRSNT_N
EN_USB1_VBUS_EN_OC --->PEX_L1_CLKREQ_N
ENUSB3_VBUS_EN_OC --->PEX_L1_PRSNT_N
bug 807504
bug 797021
Original-Change-Id: Id3703bc799373e714501b60588298a2f1e052852
Reviewed-on: http://git-master/r/24269
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Change-Id: I9d7aafa7794e6d9e05f01db6bde7ed4c91e9050e
Supporting the power off of device through the adb shell
"reboot -p" or from GUI with power off.
bug 787957
Original-Change-Id: I8bc65707a8c19b0d7cc8c506dfd5327f23c01511
Reviewed-on: http://git-master/r/24112
Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com>
Change-Id: I9e30bd5d143bad276f7bc2ee57e7887dcfd48233
Cleanup in the configuration related to board is done so that
it will be easier to add another board configuration on same
build configuration.
Original-Change-Id: Id030d70e4893b886ee73aaf944450526e7722e7e
Reviewed-on: http://git-master/r/22392
Reviewed-by: Mohit Singh <mpsingh@nvidia.com>
Tested-by: Mohit Singh <mpsingh@nvidia.com>
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Change-Id: Id737a2668ce13470be80086e3d3764c4f9ac6096
Enabling suspend power state(LP1) by default for Cardhu
Original-Change-Id: I6d39702307a7629ad7cf8b569e7fc9c520f6653e
Reviewed-on: http://git-master/r/22092
Tested-by: Narendra Damahe <ndamahe@nvidia.com>
Change-Id: Ic22bda19616a61c5e4781b9e32b0dd4dfdd3a110
Masking all interrupts from tps6591x by default and configuring
the PMU interrupt to active low.
Original-Change-Id: I2a40bb5f50d7f749debe1a8a478680acf69767a4
Reviewed-on: http://git-master/r/22066
Change-Id: I676785668026e4ef02a076f70bdb9d292263b346
Cardhu board file is updated with TPS6591x RTC entry.
Original-Change-Id: I5207f5d943c6e94a871961a959a019fbcad391b2
Reviewed-on: http://git-master/r/21497
Change-Id: Ic11ed608b13366657da4ef32fe3fbb782d6fadb2
Defining the irq base address for the tps6591x through cardhu
header file.
Original-Change-Id: Iebd6ef863a994e4552f358b31b104c6e40a6446e
Reviewed-on: http://git-master/r/20755
Change-Id: I6c758f61913644ea804f1cd8a4e6c84ebdb45f64
Original-Change-Id: Ie2b9c7bb441c72c105ca3205bdd42a8dcd76d9ef
Reviewed-on: http://git-master/r/20230
Reviewed-by: Hoang Pham <hopham@nvidia.com>
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Change-Id: I9896c0568ee5103a2608cf4abcab36f592a83f21
