Disabled USB1 VBUS wake up on board revisions prior to E1291-A03 and
E1198-A02. We see repeated LP0 wakeups if the wake source is enabled.
bug 980993
Change-Id: I080696924aaea06f973392fe7682fecc7574bf02
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103627
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Enable vibrator rail in order to support the
vibrator.
bug 1005183
Change-Id: I7133b259df590ad9dd376693b2f3224eb4431ec4
Reviewed-on: http://git-master/r/113635
Allow for DSI panel support to be present in release builds.
Removed CONFIG_TEGRA_CARDHU_DSI config variable.
Bug 978305.
Change-Id: I2b34fa5c5331de897d2b753da90e26278a6b7870
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/106919
Reviewed-by: Simone Willett <swillett@nvidia.com>
* NVC framework provides NVC_CFG_NODEV config for all
NVC compliant camera drivers to make sure to delete
the device nodes which are not found in I2C probing.
This config is not set for all focuser modules on PM269,
which introduces the issue.
* Earlier only sh532u focuser was suppose to be on
cardhu, hence this error condition did not get triggered
but newly added focuser has exposed this error.
* Set NVC_CFG_NODEV for both sh532u and ad5816 focusers.
* Add regulator supply for cam2 ad5816 focuser, it fixes
camera crash on first reboot on E1198 cardhu and I2C
warnings.
Bug 992611
Bug 995072
Change-Id: I3382a896e4e246a0a323bd13ae0889b6701351c7
Signed-off-by: Sudhir vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/106960
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Frank Chen <frankc@nvidia.com>
Bug 949219
Change-Id: I91a67d30869e9800c483f112d58b9f76e2dbe361
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103534
Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Reviewed-on: http://git-master/r/103622
- Add support for new focuser ad5816 driver to
cardhu boards.
- Add regulator for new focuser ad5816.
Bug 947792
Change-Id: I62e89e9188d307704098e2d4e88d276914836d70
Reviewed-on: http://git-master/r/103138
Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I51b17389dbb17b0e94e1635ec6d68acd01c743b4
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102529
Bug 970890
Change-Id: I24c3b1e2c621afbb90ced552194403f147e20a6c
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/102984
GVS: Gerrit_Virtual_Submit
Enabling the sh532u driver feature to not register itself
if it does not identify the sh532u device during probe.
This is for the case where the platform does not populate
the device.
Bug 929133
Change-Id: Ic5ac7fa0ae4c05e4978fe7aebc3fc630ef1c2fd3
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/92340
Bug 949219
Change-Id: I875f8688a272c415ebf345b8f30e4afdf7551b29
Reviewed-on: http://git-master/r/91523
The VDD2 supply the power to three rails: 1.5V, LDO1 and LDO2.
LDO1 is used for PEX and LDO2 is used for SATA.
By default making the VDD2 off and enabling when
consumer requires.
Change-Id: I283f62277246214966e7635bc31b6eb066f9282b
Reviewed-on: http://git-master/r/96451
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
The gpio regulator which is controlled through the gpio, which
is open drain type, is using the gpio_switch regulator.
The open drain support is added into the fixed regulator
and hence moving the regulator to use fixed regulator.
Change-Id: I1428d7e10ff469587c45fe913c4be8b4e35cb5bd
Reviewed-on: http://git-master/r/94196
Adding support for E1198-A03 which have different regulators
and the identification of regulators are done based on board
sku id.
Change-Id: Iee76d2bc493308da5346011232db32b933fd8625
Reviewed-on: http://git-master/r/92284
Bug 953155
Change-Id: I9fbb87f17e590971d5a0bf313e740e8b3b4c890b
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/91871
Specify correct device names for ventana and cardhu speaker
and digital mic regulators.
Bug 956562
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Iaa357b3da52dc9f593558b7f7e0ffda10ce8d938
Reviewed-on: http://git-master/r/91531
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
Bug 941960
Removed CONFIG_TEGRA_INTERNAL_TSENSOR_EDP_SUPPORT.
Add internal tsensor on kai.
Change-Id: Iaefa43112fbbaa42d43a428ecb86ad821e683f85
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/84350
We don't need a static bool here, there's already a function that does
this.
Change-Id: I7e5f13fc706b44f87ee7032860b31a8d8f622f21
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83624
Just set the opt in booleans in the platform data instead of checking
which function to register for pm_power_off.
Change-Id: If336ff69e4b61b4220e6766b2643c5fba74d01cc
Reviewed-on: http://git-master/r/83597
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Use the mainline's regulator driver tps62360 for core power
in place of NV's tps6236x driver.
Change-Id: Ibfa0ef8f4d59f48b31867dc1b1b0635d39a738ef
Reviewed-on: http://git-master/r/78413
Using fixed regulator in place of gpio-switch regulator.
Fixed regulator is very similar to gpio-switch regulator
and it is available by default in linux kernel.
gpio-switch-regulator will be used only for the open
collector load switches.
bug 923713
Change-Id: I42480cb314135d475b4d4b56bb5e8e73eba2f77e
Reviewed-on: http://git-master/r/74536
Reviewed-on: http://git-master/r/76465
mach-tegra/tegra3_tsensor.h is used for the parameterized initialization
of the tsensor device. mach-tegra/include/mach/tsensor.h is used for the
tsensor device driver.
Really, mach-tegra/tegra3_tsensor.c should go away - probably becoming a
device driver.
Change-Id: I16edae878f1e97d1654252cfee49cd9dd7f77db7
Reviewed-on: http://git-master/r/72481
Enabled vbus1 & vbus3 for PM311 & PM305 boards. In PM311 & PM305 the gpios
used to enable vbu1 and vbus3 are TEGRA_GPIO_PCC7 & TEGRA_GPIO_PCC6
Bug: 914114
Change-Id: Id52cf6399526cb135968370478b5ac1bd53fe364
Signed-off-by: Preetham Chandru R
Reviewed-on: http://git-master/r/72409
'en_ddr' should be 'always on' and enabled when boot.
'en_3v3_sys' should be enabled when boot.
Signed-off-by: Haley Teng <hteng@nvidia.com>
Reviewed-on: http://git-master/r/60426
Reviewed-on: http://git-master/r/66590
(cherry picked from commit 28ed5f661ecd55de42688e565c65ff9c0bd3bdda)
Change-Id: I86edb0d3317b02da964fc89b8d593d1d0d3b75b0
Reviewed-on: http://git-master/r/71963
Tested-by: Haley Teng <hteng@nvidia.com>
Bug 888679
Change default regulator current to 6A on cardhu to support T33 based
board without VF
Change-Id: Ica8c1a9a4276ae1fb140c6a2ad1db04bd96c9471
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/70187
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Bug 860351
Bug 850614
Bug 852480
Bug 872156
Bug 824459
Change-Id: I60366c7eb918a76860dbbc087407d3f89663c00d
Reviewed-on: http://git-master/r/66166
Enabling output capacitor discharge for the core power
supplied from tps62361x.
bug 871944
Reviewed-on: http://git-master/r/64838
(cherry picked from commit 8dfc169da3f7af3072956f766fb760830cf8b8ad)
Change-Id: Ib996d63a2b0e0ed43e1a76286e84266bf4ab4c72
Reviewed-on: http://git-master/r/68426
Bug 865305
Change-Id: I1e300db033a22935bcc0cd6c24f8d9d3460b3475
Reviewed-on: http://git-master/r/66120
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R54cebc69c16bbedb4ed2dbf3fc33dbc34456cb57
Corrected the range check for enabling gpio for TSP62361B because
tegra_gpio_enable() is for tegra gpio only
Bug 897387
Reviewed-on: http://git-master/r/65123
(cherry picked from commit f7ef3d5a8a56a5050174383da1818c80a65729bd)
Change-Id: I66e08170596678a267f25602f0daf79a3e0d34bd
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/66609
Rebase-Id: R14092c5f0f254e11358349e9ecfc84faa0228cb8
Based on characterization, at high temperatures Tegra will
draw more than 1mA, which is what the datasheet reports for
the low-power mode of LDO4.
So removing the LOW_POWER mode flag which makes LDO4 in low
power mode in suspend.
bug 890770
Reviewed-on: http://git-master/r/64825
(cherry picked from commit f4263c693e235c52d7ad4ad32d2508b4a6393508)
Change-Id: I9289a504af71fa488d30d77aa6cbb6e1d7dd05a4
Reviewed-on: http://git-master/r/65456
Rebase-Id: R3cf4b2dfa2b5fea9fe281cad769fb5addc241abd
Integrating MAX77663 PMIC based PM269 board into the Cardhu board.
The system will be find the correct PMIC using the Board ID of PMIC
in the Cardhu init phase.
Bug 849360
Reviewed-on: http://git-master/r/56354
(cherry picked from commit 4d7da62a829de4d051c458caa052a6d612f642fa)
Change-Id: I41a52b70d27378e6240522c16256f8c7e42144b5
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/64399
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R6baa5408a249a41d577f22da8476ad020600b12d
used when the chip SKU is T33/T33S (cardhu case) or AP33 (enterprise case) to
initialize edp with a higher cpu regulator max_curr value.
bug 888679
Change-Id: Icb50b33b1fc9b1248886e040f4b9b927feee4242
(cherry picked from commit ea572ebf71bbced17f2df2313f03e032949fac68)
Reviewed-on: http://git-master/r/64210
Rebase-Id: R248e17bf5ab3541dac91815b3cabd0d1dfab8a13
Putting the LDO7 and LDO8 to OFF in sleep state.
bug 892613
Reviewed-on: http://git-master/r/63500
(cherry picked from commit 52897937e5c30cd7e0e6c096f166936a0d396a4f)
Change-Id: Ie51594f739e5e581dec17733550ebd4e8d28e040
Reviewed-on: http://git-master/r/64046
Rebase-Id: R58fc9d4c16f990658da18822505d0d9dbe7a31a5
supplied_to battery driver name is used to link charger
driver with battery driver. Using that upon
power_supply_changed() of charger, external_power_changed()
of battery driver get called.
Bug 872590
Change-Id: Ib80c1770a5a519d21430b3fad5759a848f5db1f3
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/64078
Rebase-Id: Rced3500a496746d8186f44e2948a37f6b1cb66b8
Registering the ricoh583 pmu driver.
Change-Id: I3547522d661852826185e50b6958234a04ca0b4b
Reviewed-on: http://git-master/r/62948
Rebase-Id: R458057614dd9db4aeb34d37de20c6753e78b3e51
The ramp voltage for the ldo3 for PM269 is around 1mV/us.
Setting this value.
bug 872382
Reviewed-on: http://git-master/r/51364
(cherry picked from commit aa84b06982dbea58b815fc99bbbf84c7bdaddc78)
Change-Id: I2b7cd8883c06250490c3e27dd28384985706aa68
Reviewed-on: http://git-master/r/62341
Rebase-Id: R74b6d629197cc9b1cc591a4ac318f7105c7f28c5
Configuring the LDO4, LDO7 and LDO8 in low power mode in suspend.
bug 890770
Reviewed-on: http://git-master/r/60411
(cherry picked from commit 5c65acbba9526f66679ed6934e008c4205c7fd88)
Change-Id: I519e99ba02eac08fc93b69422fd129eea85eec3a
Reviewed-on: http://git-master/r/61439
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Rebase-Id: Rd5f3000c7845e3967b542268feaeeff169ad7498
Enable LP0 for cardhu family boards.
BUG 893759
Change-Id: Ic5cceeb1034104eefb3243036fbc2c3dc0125b43
Reviewed-on: http://git-master/r/60335
Rebase-Id: Rd7c4a6633a428895ebdb1e98932c696e7587271e
This change supports PM313 with 19X12 panel.
The change uses PM313 in "Single input to Dual output" mode
Bug ID : 822980
Reviewed-on: http://git-master/r/50215
(cherry picked from commit b83e795747fa860b5b7fb66b2067ebe4f15bcfd0)
Change-Id: Iabf707ded2976e9877481c215d0b1f1940781f14
Reviewed-on: http://git-master/r/60085
Rebase-Id: Re8eadc35c75fa21b0a5f3cb3bee0e8cb77dc3238
These initcalls weren't ensuring that they're actually running on the
board they care about, which breaks on a multi-board kernel.
Change-Id: Ifd8a3e523c2523b68ec4d7e30c2b87969b939931
Reviewed-on: http://git-master/r/60010
Rebase-Id: R2a4547ecd3b25da494799af15e42df89700b9fde
Support for E1291-A05 board.
bug 881745
Reviewed-on: http://git-master/r/58053
(cherry picked from commit be104b795f0c46b8bbe1e45ca618fed74d81a7c6)
Change-Id: I0137f9e13ee9c01bd60125589b16023c899389c9
Reviewed-on: http://git-master/r/59287
Rebase-Id: R6450506e02427f4bae13857a52ed43dd530e720a
Adding support for E1257 platform.
bug 864294
Reviewed-on: http://git-master/r/50662
(cherry picked from commit 8217615021a6ffeb992327f6b010ea9deebc34e7)
Change-Id: I3429da1bca38e1ddc5b3c2156a0db6b23aeb5555
Reviewed-on: http://git-master/r/57806
Rebase-Id: R7fadbdc30bdca30e41e0b7fdb88628dbc8c32e82
bug 875709
Reviewed-on: http://git-master/r/56632
(cherry picked from commit b7077b25dfaa7c92c5f05f50688d26710eb57348)
Change-Id: I46b0bd4d939e5ffbce9599ad2c437a7d424b1d87
Reviewed-on: http://git-master/r/57258
Rebase-Id: Rb192b1590af659143cf62938ce5ab468526216ee
The SDMMC_VDD control is generated from the cpld programming
for pm269 and so it is not require to have gpio control for this.
bug 880984
Reviewed-on: http://git-master/r/56627
(cherry picked from commit 38ad9be02578b64d3f5eab8c6146abfc6c842d35)
Change-Id: Id7cae7a724c02754b3abbc937a7e80b9a51d7977
Reviewed-on: http://git-master/r/57254
Rebase-Id: R34a8cb39a5c557461ebbb540692487d357798eca
Adding support for PM311 based system.
bug 870139
Reviewed-on: http://git-master/r/50012
(cherry picked from commit d319d9980b6b225735ac97160fdee18fbabba2f0)
Change-Id: Iaa28921761e035e8fa29956b776f9379ae326b42
Reviewed-on: http://git-master/r/57251
Rebase-Id: R50fc9a079bd46a050084afed2b0f460e2916ebc9
Specify device names for ventana and cardhu speaker and digital mic
regulators. Also use same regulator name for ventana and cardhu
speaker supply.
Bug 872652
Change-Id: I5a254eee2037c86e208818f34cdff24aee0edad9
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/55668
Rebase-Id: R81411e5e595ec1d9e700d08410a9d3e49f24cbee
Bug 872590
Change-Id: I7e5bfe68a4f299f771b4af7094754e4167a44f29
Reviewed-on: http://git-master/r/54663
Rebase-Id: R9dce2ca60c88531d5b16ed669404b3f1a25a9e81
bug 869217
Reviewed-on: http://git-master/r/51291
(cherry picked from commit bdf107203561935aa8d1eb1be36cfbbd36adfbe4)
Change-Id: I3a342c87c65e586942396f12193726f0d60d17f1
Reviewed-on: http://git-master/r/54225
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R3bafcc8fc90f59d4559f33c526f8b914f1550c77
Use the device driver name instead of encoding the SDMMC controller in
the regulator supply name.
Change-Id: I08fb807c5a13eedd70bb9a5d47633334d51133d6
Reviewed-on: http://git-master/r/52502
Rebase-Id: R2966fc597604a2c8a0e5b2c9f507a4566e3400f9
http://nvbugs/876007
Change-Id: Id060bcc5ef20c0bc553bc171a3b96699140b2161
Reviewed-on: http://git-master/r/52136
Reviewed-by: Jin Qian <jqian@nvidia.com>
Tested-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R6496b91629af42d4b6ac9a623cd63d03c14abab2
