Signed-off-by: Bryan Wu <pengw@nvidia.com>
Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55
Reviewed-on: http://git-master/r/419070
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Enable OV5650 and OV5640 sensor in Cardhu board file with the help of
Tegra V4L2 SoC camera interface.
To use V4L2 driver, we need to disable old camera HAL driver.
Bug 1240806
Bug 1369083
Change-Id: I0dc529d44fba4d80b45690e384e8bf81b29f69e5
Reviewed-on: http://git-master/r/246266
(cherry picked from commit 6b2f7cc4117208dc992478f27d5873ea38071fdc)
Reviewed-on: http://git-master/r/279988
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
This change is intended to add a few modifications to
cardhu board file (which is also used for beaver)
to get rid of NACK errors occuring due to the absence
of certain hardware components on beaver
Bug 1217572
Change-Id: I1df7b7f777014610e4d64695d89324808ea4f266
Signed-off-by: Darbha Sriharsha <dsriharsha@nvidia.com>
Reviewed-on: http://git-master/r/215983
GVS: Gerrit_Virtual_Submit
Reviewed-by: Ramalingam C <ramalingamc@nvidia.com>
This change is intended to add modifications to
Bug 1217572
Change-Id: I36dfcda1b133c983ce25d56729505bce8b99fdf1
Reviewed-on: http://git-master/r/193667
Enable OV5650 sensor in Cardhu board file with the help of Tegra
Change-Id: I6ff8456941267c05986760f46f658962a940d07e
Reviewed-on: http://git-master/r/200226
Add support for PM315
Bug 1217569
Change-Id: I230fcec04eb5a96441e2c19b304d608d86eaf996
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/191555
Bug 1171138
Change-Id: I2e5461c656c41d4172aca60525655cb780eaa17e
Original-author: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Mike Thompson <mikthompson@nvidia.com>
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/143506
(cherry picked from commit 4e66142b6990ca586e085aa88ae0bd6b819da0c4)
Reviewed-on: http://git-master/r/166814
To fix an instability issue, the power sequence is updated to match
the specification for this device.
bug 1031318
Change-Id: I3970af7ae8ed2baa6060f548242b0093040afb53
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/122867
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Added skin prediction algorithm.
bug 1007726
Change-Id: Ia76f73cb818aa02e608e1fc69ab4d8277a5825eb
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/104814
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
* NVC config change added to make code inline with
generic NVC framework, but it is introducing camera
crash after reboot issue on pm269.
* Make code identical to what was there earlier to fix
above regression.
Bug 998465
Change-Id: I8510ef3427b218481c5e36c952056dda799080f6
Signed-off-by: Sudhir vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/109523
(cherry picked from commit 7e642946895848829bb6405bc675062c86907eb4)
Reviewed-on: http://git-master/r/110087
* NVC framework provides NVC_CFG_NODEV config for all
NVC compliant camera drivers to make sure to delete
the device nodes which are not found in I2C probing.
This config is not set for all focuser modules on PM269,
which introduces the issue.
* Earlier only sh532u focuser was suppose to be on
cardhu, hence this error condition did not get triggered
but newly added focuser has exposed this error.
* Set NVC_CFG_NODEV for both sh532u and ad5816 focusers.
* Add regulator supply for cam2 ad5816 focuser, it fixes
camera crash on first reboot on E1198 cardhu and I2C
warnings.
Bug 992611
Bug 995072
Change-Id: I3382a896e4e246a0a323bd13ae0889b6701351c7
Reviewed-on: http://git-master/r/106960
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Reviewed-by: Frank Chen <frankc@nvidia.com>
- Add support for new focuser ad5816 driver to
cardhu boards.
- Add regulator for new focuser ad5816.
Bug 947792
Change-Id: I62e89e9188d307704098e2d4e88d276914836d70
Reviewed-on: http://git-master/r/103138
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I51b17389dbb17b0e94e1635ec6d68acd01c743b4
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102529
Reviewed-by: Simone Willett <swillett@nvidia.com>
bug 980184
Change-Id: I376a62ada8f7e825693a4cdd87942edaa92b8fc4
Reviewed-on: http://git-master/r/102309
bug 921322
Change-Id: If7f05c632816abac54852293ebd3834b5b3984d8
Reviewed-on: http://git-master/r/99508
Enabling the sh532u driver feature to not register itself
if it does not identify the sh532u device during probe.
This is for the case where the platform does not populate
the device.
Bug 929133
Change-Id: Ic5ac7fa0ae4c05e4978fe7aebc3fc630ef1c2fd3
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/92340
If board_info.sku is 0xb11 this board has ltr558 ALS on it
else isl29028 sensor.
Bug 901133
Change-Id: Id0fb5b59b55393e52147e7f9d8d114651a5e0561
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/89977
Registering LTR558 Ambient light and Proximity sensor on I2C bus.
Bug 901133
Change-Id: I34b996813a409229a1baa25a069f0ba4758b154e
Reviewed-on: http://git-master/r/88228
Bug 941960
Removed CONFIG_TEGRA_INTERNAL_TSENSOR_EDP_SUPPORT.
Add internal tsensor on kai.
Change-Id: Iaefa43112fbbaa42d43a428ecb86ad821e683f85
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/84350
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Invensense board files for MPU6050. MPL version 4.1.1.
Bug 825602
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/70373
(cherry picked from commit 2839895906a9c822e5c9f8abab68e33e9982c5a9)
Change-Id: I97eb4dcc075ab8b6f2bb583756dd10128924f10a
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82717
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/77400
Change-Id: Idbc213bb17d0e006c9a4cdaf500a94dbae1007d0
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/78011
Add PM269 board support for sh532u focuser by adding regulator
defines and the PM269 reset GPIO's.
Bug 923072
Change-Id: Ic042d2c9c2cf78a38a1b72fab2db0289fb1d9909
Reviewed-on: http://git-master/r/73877
Reviewed-on: http://git-master/r/75146
Instead of using 0C as default low temp in thermal
algorithm, query the thermal device driver for
lowest supported temperature.
Change-Id: Id1f70380ba476dec80e36ce79b42ab6f24a5d5ba
Reviewed-on: http://git-master/r/70935
Added name paramater per therm device so that is
easy to tell which therm device is being used
from sysfs
Change-Id: I58488b4c50ac6dc58dc00e270b613458f61a9fd6
Reviewed-on: http://git-master/r/70929
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Since front and back right camera are multiplexed,
back right camera needs to be selected on power on.
Bug 890780
Change-Id: I6c9ecb95c42b3faedfede98b7e7de7e778d720b6
Signed-off-by: Anton Kondratenko <akondratenko@nvidia.com>
Reviewed-on: http://git-master/r/69662
Bug 860351
Bug 850614
Bug 852480
Bug 872156
Bug 824459
Change-Id: I60366c7eb918a76860dbbc087407d3f89663c00d
Reviewed-on: http://git-master/r/66166
Bug 825602
Bug 834422
Bug 843573
Change-Id: I50ded8cafb228b216f4e3a899f50336c8450698b
Reviewed-on: http://git-master/r/66084
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Having moved a lot of thermal functionality out of
the nct1008 driver, cleaned up all the unnecessary
code.
Reviewed-on: http://git-master/r/58849
Reviewed-on: http://git-master/r/63340
(cherry picked from commit eeee660eea54ddf76881587246bb9c59c6f0ad07)
Change-Id: I39ed5683ddc5df068e11d21680863f9ba979f862
Reviewed-on: http://git-master/r/66553
Refactored Thermal module so that thermal device
drivers themselves are agnostic of the thermal
framework. Also separated throttle limit constraints
from EDP table.
Reviewed-on: http://git-master/r/57990
Reviewed-on: http://git-master/r/63338
Cherry-picked from 8d0610bdd03c3490b718f11bc2108f45cd868533.
Change-Id: I4f87889c9cdc88daac1e6173043bab1f2e7cebfd
Reviewed-on: http://git-master/r/66551
Bug 865305
Change-Id: I1e300db033a22935bcc0cd6c24f8d9d3460b3475
Reviewed-on: http://git-master/r/66120
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R54cebc69c16bbedb4ed2dbf3fc33dbc34456cb57
Earlier value of 75 had unnecessary double guardbanding.
Changed 90C row in EDP table down to 85C to get throttling alert.
Bug 862301
Reviewed-on: http://git-master/r/50544
(cherry picked from commit 9f2693a80274bcd9eb8e7424bca87f34cc190741)
Change-Id: If7204150013e7894fc310a2f7e8fd46baf11d869
Reviewed-on: http://git-master/r/62773
Rebase-Id: R6ef35feeaad04bea897d9343d9d3a21a988f3dde
Bug 844025
Reviewed-on: http://git-master/r/51443
(cherry picked from commit 1abdcb266a1fa22fd766549d5eddcca92e1fb17e)
Change-Id: Ie9b405482eebf40923f8de20c897f20bebdb84ba
Reviewed-on: http://git-master/r/61681
Rebase-Id: R73990d76e2030664cb7cc6b6c7c36052f4c64bdb
These initcalls weren't ensuring that they're actually running on the
board they care about, which breaks on a multi-board kernel.
Change-Id: Ifd8a3e523c2523b68ec4d7e30c2b87969b939931
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/60010
Rebase-Id: R2a4547ecd3b25da494799af15e42df89700b9fde
Support for OV14810 sensor on cardhu
Bug 839441
Reviewed-on: http://git-master/r/51985
(cherry picked from commit f1aea025b145a884ac4cc507c86c647ca65e348f)
Change-Id: I9db882aab6f8ae89c4d463b9d6825e7c7cfd2928
Reviewed-on: http://git-master/r/58660
Reviewed-by: Krupal Divvela <kdivvela@nvidia.com>
Tested-by: Krupal Divvela <kdivvela@nvidia.com>
Rebase-Id: R8f2a1692deba888e2d0476ea2159a1e36722cc63
Adding support for E1257 platform.
bug 864294
Reviewed-on: http://git-master/r/50662
(cherry picked from commit 8217615021a6ffeb992327f6b010ea9deebc34e7)
Change-Id: I3429da1bca38e1ddc5b3c2156a0db6b23aeb5555
Reviewed-on: http://git-master/r/57806
Rebase-Id: R7fadbdc30bdca30e41e0b7fdb88628dbc8c32e82
Adding support for PM311 based system.
bug 870139
Reviewed-on: http://git-master/r/50012
(cherry picked from commit d319d9980b6b225735ac97160fdee18fbabba2f0)
Change-Id: Iaa28921761e035e8fa29956b776f9379ae326b42
Reviewed-on: http://git-master/r/57251
Rebase-Id: R50fc9a079bd46a050084afed2b0f460e2916ebc9
Bug 872590
Change-Id: I7e5bfe68a4f299f771b4af7094754e4167a44f29
Reviewed-on: http://git-master/r/54663
Rebase-Id: R9dce2ca60c88531d5b16ed669404b3f1a25a9e81
E-Compass does not show correct North-South direction
Fix orientation in board file
Bug 842788
Original-Change-Id: I6a492719afc79f8268f27fb82ee488952ffc9813
Reviewed-on: http://git-master/r/50313
Rebase-Id: R469ffa6c1996eefcc260d4125c1cada9b2c15704
Adding support for PM305.
bug 846246
Original-Change-Id: Ib036c67c12984668e0b7153f76a1a1d44c5be14f
Reviewed-on: http://git-master/r/49820
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Rebase-Id: R9e9eb93ddcea487159854533eead3fe8eb74e42b
Fix regulator_get error and reset the sensor/focuser properly
in the camera power on routine for PM269.
Bug 842713
Original-Change-Id: Ia3820ec9e7bcca850b090a48963606af855f5ad2
Reviewed-on: http://git-master/r/49101
Rebase-Id: R5623445c753a3e8ffaaef38a5b105c8330e21b49
use fractional guardband accurately per chip sku
bug 844025
Original-Change-Id: I1137e39b5aa9babae740d2c9e438275183683756
Reviewed-on: http://git-master/r/49317
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R184cddb8dbb46433e2f8ae7f36bd58f0da6f8ec9
Enabling NCT1008 temp sensor for PM269 board also.
Original-Change-Id: I8cea3e87f18b6d4f73f3142445daed15ab65cf96
Reviewed-on: http://git-master/r/47519
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: R8956472b2adb83310298adda4c3454093b36f5b8
The sh532u focuser is added to pair with the stereo right camera with the
required power control configurations.
Bug #827897
Original-Change-Id: I5ca836a51b03cb9550eb468270af5bbf350aa957
Reviewed-on: http://git-master/r/34820
Rebase-Id: Rad6137ec52951c560c67135595d560910eb97aa0
MPU sensors were disabled for boards other than cardhu e1291.
This was because of a bug in the sensor device code, which
is fixed in change Ib86327c4. The commit re-enables MPU sensors for
other boards.
Bug 845739
Bug 828100
Original-Change-Id: Idcad7c07b48560b8876a589b1d6dee4b401b1141
Reviewed-on: http://git-master/r/41962
Tested-by: Alon Farchy <afarchy@nvidia.com>
Rebase-Id: R49f9c3c52c39d3763b1f3e6b1a888701744b9937
Bug ID: 844882
- Set throttling temperature in ext temp sensor nct1008 for cardhu to 75C
- Fix bug in nct1008 temp sensor driver in disable throttling logic
Original-Change-Id: I2ed8aab63186f16c554ca459e71f3437119bd4e6
Reviewed-on: http://git-master/r/42707
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Rf31aea08df5ebd2d2895cc40f9d8c591f6a0fae8
- Added table with EDP Capping values for different SKUs/regulator
currents in new file edp.c
- New entry point tegra_init_cpu_edp_limits()
- Added DebugFS entry under debug/edp to list the currently
selected EDP table
- Populated EDP table in edp.c with data from Bug 844268
- edp.c keeps main EDP table; cpu-tegra.c and board-cardhu-power.c
both read from there
Bug 840255
Original-Change-Id: I55c2ee16278be8cd3005218bedebe76846d137d8
Reviewed-on: http://git-master/r/40938
Rebase-Id: R9a5f2bcfc1e6e0b5aee37cd700d75f9ef5cea30b
Adding support for the E1256. The configuration is
same as the E1186 board.
bug 849990
Original-Change-Id: Idd89e282627b2f0924fc313a5ba28f9e9a6032be
Reviewed-on: http://git-master/r/40367
Rebase-Id: R3b1f22dc222f4ce000d2e84a48b7e2f379159750
nct1008 temperature sensor extended range support enabled
for cardhu and enterprise boards.
Bug 850512
Original-Change-Id: Ibb88207c6cc4581ed30d73e576ac4d41d386facd
Reviewed-on: http://git-master/r/40560
Rebase-Id: Rac49b9ba16d50e0db4adc4b70bfb397aee5fd81f
Bug 844025
- Guardband to account for hotspot offset and sensor accuracy.
- Throttling point specified independent of EDP, but constrained to be
one of the specified EDP points.
Original-Change-Id: Ic9231ad6887ca282bb520ea23229526ac7a243be
Reviewed-on: http://git-master/r/40566
Rebase-Id: Rb582312d40da8f1cc753666bdef6068138358cd0
Bug 794431
Original-Change-Id: I889c224b184d099339ccdb438326a2037f85cdf6
Reviewed-on: http://git-master/r/34214
Rebase-Id: R4427050d243067273f1035b4d7f18db3c8c0ee51
