Add the following tested (e.g. framebuffer console and X) video modes:
- 1280x1024@60
- 1600x1200@60
- 1680x1050@60
- 1920x1080p
- 1920x1200
And the following portrait modes:
- 480x640
- 540x960
- 720x1280
The define TEGRA_FB_VGA in board-colibri_t20.h can be used to switch
between VGA and 800x480.
While at it fix rename of CAMERA_INTERFACE to COLIBRI_T20_VI as well.
The Iris carrier board by default uses SODIMM pin 73 as DAC power save.
Note: This conflicts with the CAN interrupt on the new EvalBoard v3.1a.
VESA VGA mode defines hsync/vsync to be of polarity low rather than
high.
The HDMI power rail configuration used to be done within the LVDS aka
TFTLCD panel enable function. Now moving it to the platform power
initialisation where it really belongs. This avoids any
duplicate/spurious regulator configuration.
Instead of copying the boot loader frame buffer which currently neither
displays anything worth preserving nor even what it has in the right
resolution make sure both LVDS as well as HDMI frame buffers get
cleared during initialisation to avoid displaying random garbled stuff.
The boot logo and framebuffer console where displayed with a wrong
stride caused by a colour depth mismatch. Fix this by initially
configuring the display controllers to 16 bpp.
Using 720p as Android's default none VGA TFTLCD resolution allows for
the default tablet mode layout to be run which makes most sense for
evaluation purpose on regular monitors.
Due to a pin muxing conflict between the regular backlight PWM and the
camera we do have to make this code not CAMERA_INTERFACE define
dependant.
- 800x480@60 (e.g. for EDT ET070080DH6)
- 800x600@60
- 1024x768@60
- 1024x768@75
- 1280x720@70 aka 720p
- 1366x768@60
Fix PWM backlight by using PWM<A> rather than PWM<C> by default.
Invert brightness value due to unified TFT interface displays (e.g. EDT
ET070080DH6) inverted LEDCTRL pin behaviour (e.g. 0V brightest vs. 3.3V
darkest) and use PWM frequency of 1 kHz as recommended.
Add comment about PWM pin muxing.
While at it do some ifdef and indentation clean-up.
Incorporate L4T R16 changes from NVIDIA Ventana.
Note: USB OTG port not functional as of yet.
Default to VESA VGA resolution rather than 1366x768.
Remove come debug prints and comments while at it.
