Integrate ADV7180 video decoder support.
While at it prepare for ADV7180 as well as MAX9526 drivers as module.
Add a comment about conflicting use of SODIMM pin 150 as GPIO K0 resp.
GMI_ADV_N used for multiplexed address/data bus courtesy of Stéphane
Gonnella from Multitel ASBL.
Enable the back key as a wake-up source as well.
Due to a strong pull-down on the menu-key multiplexed ACC1_DETECT pin
Android unintentionally entered safe-mode. Fix this by making the
menu-key active-high as well.
SODIMM-59, SODIMM-67 is no longer a GPIO and thus the PWM are usable again.
PWM<D>
Fix null pointer during USB OTG host to peripheral transition caused by
freeing the platform data twice. See the following Tegra OTG driver
commit for reference:
8acf989d5896b152cc88f8b29afd11d522f903e3
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in
MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its
built-in SJA1000 CAN controller connected to the GMI bus.
The following kernel configuration needs to be enabled as well:
CONFIG_CAN
CONFIG_CAN_RAW
CONFIG_CAN_BCM
CONFIG_CAN_DEV
Plus depending on the Evaluation Board revision:
CONFIG_CAN_MCP251X
or
CONFIG_CAN_SJA1000
CONFIG_CAN_SJA1000_PLATFORM
Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for
Colibri T20 is provided via commented defines in
arch/arm/mach-tegra/board-colibri_t20.h.
Integrate MAX9526 video decoder support as found on our analogous
camera module (ACM) connected to a Colibri Evaluation carrier board.
The following kernel configuration options are required to be enabled:
CONFIG_VIDEO_V4L2=y
CONFIG_SOC_CAMERA=y
CONFIG_SOC_CAMERA_MAX9526=y
CONFIG_VIDEO_TEGRA=y
Move GPIO defines to header file.
While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
Rename UARTs to be consistent with Colibri FF/BT/STDUART naming.
Rename PWM LEDs to be consistent with Colibri PWM<X> naming.
Migrate from static TEGRA_GPIO_TO_IRQ macro to run-time gpio_to_irq
function.
While at it clean-up some comments and fix some long lines in order to
adhere to Linux kernel coding style.
This patch integrates multi-touch for the TouchRevolution Fusion 7 and
10 panels connected to Iris as follows:
Iris X16-5, SODIMM pin 194, I2C SDA
Iris X16-6, SODIMM pin 196, I2C SCL
Iris X16-15, SODIMM pin 103, pen down interrupt
Iris X16-16, SODIMM pin 101, reset
The following kernel configuration needs to be enabled:
Device Drivers -> Input device support -> Touchscreens
-> TouchRevolution Fusion F0710A Touchscreens
Please note that level shifters are required.
Please further note that our current OpenEmbedded BSP does not yet
integrate multi-touch support in the XInput as well as X server layers.
Well commit bfd8d6dc27ccf00bf89b0a7bb3d359bab2142376 got rid of the w1
include a little prematurely.
Now simply enabling CONFIG_TEGRA_CAMERA resp. not explicitly disabling
it will make L4T's nv_omx_vip Gstreamer plug-in work with analogue video
decoders like the ADV7180 or MAX9526.
Commit 39ca35e4610f1307247815ec5268b5072172d24a mixed up the SCL/SDA
GPIOs. This fixes it again.
Shorten GPL license header.
Get rid of obsolete includes.
Get rid of spurious comments.
Fix indentation.
Add some clarifying comments.
Rename board level init_machine and reserve functions.
Adjust thermal throttling to latest lm95245 evolution and wait with the
interrupt registration until we get the LM95245 drivers probe callback.
While at it add some clarifying comments and wrap RTC stuff with a
define.
As our hardware only allows triggering an interrupt on over-temperature
shutdown we first use it to catch entering throttle limit and only then
set it up to catch an actual over-temperature shutdown.
While throttling we setup a workqueue to catch leaving it again.
We support the same sysfs interface as on NVIDIA Ventana:
root@colibri-t20:~# cat /sys/kernel/debug/thermal/shutdown
115000
root@colibri-t20:~# cat /sys/kernel/debug/thermal/throttle
90000
As follows some output of before and during a throttling run:
root@colibri-t20:~# tegrastats
RAM 159/345MB (lfb 36x4MB) Carveout 11/128MB (lfb 116MB) GART 0/32MB
(lfb 32MB) IRAM 4/255kB(lfb 248kB) cpu [51%,23%]@216 EMC 666 AVP 72 VDE
240 EDP limit -1 Temperatures CPU 48.7 Board 43.2
root@colibri-t20:~# cat /sys/devices/system/cpu/cpu0/cpufreq/throttle
0
root@colibri-t20:~# cat /sys/bus/i2c/devices/4-004c/temp2_os
90000
115000
90000
RAM 66/345MB (lfb 5x32kB) Carveout 75/128MB (lfb 53MB) GART 8/32MB
(lfb 24MB) IRAM 20/255kB(lfb 232kB) cpu [85%,83%]@912 EMC 666 AVP 216
VDE 240 EDP limit -1 Temperatures CPU 90.1 Board 77.9
1
115000
Integrate remote over-temperature shutdown ROS pin handling.
Clean-up I2C platform data and bring it more in line with Colibri T30.
Avoid the following issue on both /dev/ttyHS1 as well as /dev/ttyHS3:
[ 4419.708332] tegra_uart tegra_uart.1: Setting clk_src pll_m
[ 4419.714361] Failed to set parent pll_m for uartb (violates clock
limit 600000000)
[ 4427.469124] tegra_uart tegra_uart.3: Setting clk_src pll_m
[ 4427.476177] Failed to set parent pll_m for uartd (violates clock
limit 600000000)
As the new Colibri Evaluation carrier board v3.1a uses SODIMM pin 45 as
IrDA transceiver SD with a 100 K pull-down we revert to using the power
key as high active.
GPIO keys configured as active-low either require pull-ups on the
carrier board or via pin-muxing. We enable the later for now.
Use GPIO inputs for function tri-stating rather than pin group
tri-stating to avoid influencing neighbouring pins.
While at it get rid of most pull-up/downs and a lot of commented out
stuff.
Rename CAMERA_INTERFACE to COLIBRI_T20_VI which stands for video input
to be more in-line with Colibri T30.
Get rid of optional CAM/GEN3_I2C on SODIMM pin 127/133.
Verify standard GPIO usage for latest v1.2a modules.
The Iris carrier board by default uses SODIMM pin 73 as DAC power save.
Note: This conflicts with the CAN interrupt on the new EvalBoard v3.1a.
Enable device tree support for Colibri T20 by adding board compatible
table.
See 293b009a282e1508a4947d84463fdfe820445a50.
Since there is no PMC available in tegra2 we will not be able to get
any remote wakeup events. Hence do not power of the phy during usb
suspend.
See c4a5c51e493a8d4154c15c95d2bd93b348090892.
SODIMM pin 135 is really GPIO K6 multiplexed with ACC1_DETECT. Unfortunately the later can't be tri-stated but since it is anyway always an input it should not interfere. Please note however that this SODIMM pin is rather low resistance.
Implement the following GPIO keys:
- find (SODIMM pin 77)
- home (SODIMM pin 127)
- back (SODIMM pin 133, Iris X16-14)
- volume up (SODIMM pin 22)
- volume down (SODIMM pin 24)
- power (SODIMM pin 45, Iris X16-20)
- menu (SODIMM pin 135)
After fixing Ethernet detection faults in the T20 BSP V1.x based Linux kernel 2.6.36.2 and U-Boot 2011.06 unify the Ethernet initialisation.
While at it fix some minor white space issue plus add some clarifying ifdef comments.
NVIDIA's Android for their Ventana developer tablet is looking for the
machine name in order to initialise certain things. For now just hack
it to be able to use their regular initrd.
NVIDIA's Android employs its own proprietary camera stack therefore
make sure no V4L2 sensor drivers are registered.
Fix Android RAM console by reserving 1 MB of memory.
Add Samsung K9K8G08U0B NAND parameters usded for TSOP testing.
Backlight PWM now runs at 1 kHZ rather than 500kHz.
Make PWM B, C, D accessible from userspace. e.g as /sys/class/leds/pwm_b.
Make PWM A or C a led PWM depending on MECS_TELLURIUM.
While the ADC platform data passing worked just fine in kernel 2.6.36.2
this currently fails. Therefore introduce an ugly hack to explicitly
get said data via a board level call back.
Clean-up ADC platform data.
While at it fix some white space in the clock initialisation table and
add some comment concerning missing AC97 clock mux availability.
Clean-up some of the early clock initialisation hacks.
Fix PWM backlight by using PWM<A> rather than PWM<C> by default.
Invert brightness value due to unified TFT interface displays (e.g. EDT
ET070080DH6) inverted LEDCTRL pin behaviour (e.g. 0V brightest vs. 3.3V
darkest) and use PWM frequency of 1 kHz as recommended.
Add comment about PWM pin muxing.
While at it do some ifdef and indentation clean-up.
Incorporate L4T R16 changes from NVIDIA Ventana.
Note: USB OTG port not functional as of yet.
Re-enable USB Ethernet gadget.
Clean-up USB platform data.
The I2C2 controller is used for display EDID via DDC_CLOCK/DATA on X3 pin 15/16.
The regular GEN2_I2C pins can not be used for I2C functionality on the Colibri T20.
The I2C3 controller can optionally be used via CAM/GEN3_I2C on SODIMM pin 127/133.
Looks like the older modules prior to V1.2 using Micron MT29F8G08ABCBB NAND flash parts have some timing issue.
Decreasing the NAND flash controller clock from 144 back to 108 MHz seems to make it work again.
Further investigation pending (e.g. explicitly setting timing mode 4).
Clean-up some obsolete init stuff while at it.
Add note that V1.1c modules require proper BCT setting 666 rather than 721.5 MHz EMC clock in order for EMC scaling not to crash.
Specify zero carveout argument to tegra_reserve() for special handling due to already reserved fbmem/nvmem.
Requires our latest U-Boot 2011.06 from today which is compatible to both V1.x as well as V2.x images.
