Integrate MAX9526 video decoder support as found on our analogous
camera module (ACM) connected to a Colibri Evaluation carrier board.
The following kernel configuration options are required to be enabled:
CONFIG_VIDEO_V4L2=y
CONFIG_SOC_CAMERA=y
CONFIG_SOC_CAMERA_MAX9526=y
CONFIG_VIDEO_TEGRA=y
Move GPIO defines to header file.
While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
Now simply enabling CONFIG_TEGRA_CAMERA resp. not explicitly disabling
it will make L4T's nv_omx_vip Gstreamer plug-in work with analogue video
decoders like the ADV7180 or MAX9526.
Rename CAMERA_INTERFACE to COLIBRI_T20_VI which stands for video input
to be more in-line with Colibri T30.
The Iris carrier board by default uses SODIMM pin 73 as DAC power save.
Note: This conflicts with the CAN interrupt on the new EvalBoard v3.1a.
Activate parallel camera interface aka video input port (VIP) which
conflicts with the default Colibri pinmux configuration.
Actually enable none VGA TFTLCD resolution to activate previously
commited 720p Android resolution.
Incorporate L4T R16 changes from NVIDIA Ventana.
Note: USB OTG port not functional as of yet.
Integrate EMC memory frequency scaling.
Note: currently only seems to work on latest production V1.2x modules.
Disable camera support by commenting CAMERA_INTERFACE define.
Clean-up obsolete 12/13 MHz oscillator selection.
