If the local critical temperature is reached the power is
unconditionally switched off. At 70°C ambient the default of 85°C
can be reached. So increase the limit in the hwmon chip to 95°C.
Integrate ADV7180 and MAX9526 video decoder support and prepare for
drivers as modules.
Remove tegra_aes_device from the platform device list as it was listed
twice.
Add a comment about conflicting use of SODIMM pin 150 as GPIO K0 resp.
GMI_ADV_N used for multiplexed address/data bus courtesy of Stéphane
Gonnella from Multitel ASBL.
Added skeleton code to define userspace accessable gpio.
Export gpios which are unlikely to be used for other functions.
Fix null pointer during USB OTG host to peripheral transition caused by
freeing the platform data twice. See the following Tegra OTG driver
commit for reference:
8acf989d5896b152cc88f8b29afd11d522f903e3
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in
MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its
built-in SJA1000 CAN controller connected to the GMI bus.
The following kernel configuration needs to be enabled as well:
CONFIG_CAN
CONFIG_CAN_RAW
CONFIG_CAN_BCM
CONFIG_CAN_DEV
Plus depending on the Evaluation Board revision:
CONFIG_CAN_MCP251X
or
CONFIG_CAN_SJA1000
CONFIG_CAN_SJA1000_PLATFORM
Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for
Colibri T20 is provided via commented defines in
arch/arm/mach-tegra/board-colibri_t20.h.
Unless HDA driver is enabled device enters safe mode upon start-up.
NVIDIA's Android for their Cardhu developer tablet is looking for the
machine name in order to initialise certain things. For now just hack
it to be able to use their regular initrd.
Integrate MAX9526 video decoder support as found on our analogous
camera module (ACM) connected to a Colibri Evaluation carrier board.
The following kernel configuration options are required to be enabled:
CONFIG_VIDEO_V4L2=y
CONFIG_SOC_CAMERA=y
CONFIG_SOC_CAMERA_MAX9526=y
CONFIG_VIDEO_TEGRA=y
Move GPIO defines to header file.
While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
Explicitly configure MMC/SD card as 4-bit only by default.
Rename UARTs to be consistent with Colibri FF/BT/STDUART naming.
Rename PWM LEDs to be consistent with Colibri PWM<X> naming.
Migrate from static TEGRA_GPIO_TO_IRQ macro to run-time gpio_to_irq
function.
While at it clean-up some comments and fix some long lines in order to
adhere to Linux kernel coding style.
Enable back key wake-up source.
This patch integrates multi-touch for the TouchRevolution Fusion 7 and
10 panels connected to Iris as follows:
Iris X16-5, SODIMM pin 194, I2C SDA
Iris X16-6, SODIMM pin 196, I2C SCL
Iris X16-15, SODIMM pin 103, pen down interrupt
Iris X16-16, SODIMM pin 101, reset
The following kernel configuration needs to be enabled:
Device Drivers -> Input device support -> Touchscreens
-> TouchRevolution Fusion F0710A Touchscreens
Please note that level shifters are required.
Please further note that our current OpenEmbedded BSP does not yet
integrate multi-touch support in the XInput as well as X server layers.
set DD pins to push/pull if not used for I2C in open drain mode
Add one-wire platform data. Still requires explicitly enabling the
following two kernel configuration options:
CONFIG_W1
CONFIG_W1_MASTER_TEGRA
Make PWM B, C, D accessible from userspace. e.g as
/sys/class/leds/pwm_b.
Implement the following GPIO keys:
- find (SODIMM pin 77)
- home (SODIMM pin 127)
- back (SODIMM pin 133, Iris X16-14)
- volume up (SODIMM pin 22)
- volume down (SODIMM pin 24)
- power (SODIMM pin 45, Iris X16-20)
- menu (SODIMM pin 135)
Now simply enabling CONFIG_TEGRA_CAMERA resp. not explicitly disabling
it will make L4T's nv_omx_vip Gstreamer plug-in work with analogue video
decoders like the ADV7180 or MAX9526.
Booting with a bare USB hub (e.g. EvalBoard V3.1A) and later plugging
in a USB device completely hang the system. This fixes it.
Shorten GPL license header.
Get rid of obsolete includes.
Get rid of spurious comments.
Fix indentation.
Add some clarifying comments.
As our hardware only allows triggering an interrupt on over-temperature
shutdown we setup a workqueue to catch leaving it again.
For Tegra 3 NVIDIA relies on the regular Linux thermal subsystem.
As follows some output during a thermal throttling run:
root@colibri-t30:~# cat /sys/bus/i2c/devices/4-004c/temp2_os
45000
RAM 400/980MB (lfb 135x4MB) IRAM 0/255kB(lfb 255kB)
cpu [12%,2%,3%,6%]@475 EMC 533 AVP 81 VDE 400 EDP limit 1300000
Temperatures CPU 42.4 Board 36.4
60000
cpu [14%,5%,4%,4%]@1300 EMC 533 AVP 81 VDE 400 EDP limit 1300000
Temperatures CPU 54.2 Board 47.8
cpu [100%,100%,100%,100%]@1200 EMC 533 AVP 81 VDE 400 EDP limit 1200000
Temperatures CPU 70.4 Board 56.6
75000
cpu [54%,49%,48%,48%]@1200 EMC 533 AVP 81 VDE 400 EDP limit 1200000
Temperatures CPU 70.9 Board 57.1
cpu [100%,100%,100%,100%]@1100 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 75.3 Board 60.5
85000
RAM 401/980MB (lfb 135x4MB) IRAM 0/255kB(lfb 255kB)
cpu [65%,61%,61%,61%]@1100 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 75.2 Board 61.0
cpu [100%,100%,100%,100%]@1000 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 85.1 Board 69.8
cpu [100%,100%,100%,100%]@760 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 85.1 Board 69.9
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/cur_state
0
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/max_state
10
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/type
balanced
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/cdev0_trip_point
0
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/temp
84531
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/trip_point_0_temp
85000
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/trip_point_0_type
passive
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/type
lm95245_remote
Our platform data erroneously used the forth (bus number 3) rather than
the first (bus number 0) controller instance.
Get rid of obsolete NAND aka Colibri T30 v1.0a prototype handling.
Integrate spidev support straight from Colibri T20.
Clean-up I2C platform data.
Validate pin-muxing for latest Colibri T30 v1.1a and v1.1b module
hardware.
This fixes the following build issue:
arch/arm/mach-tegra/board-colibri_t30.c:276:41: error:
'colibri_t30_emmc_platform_data' defined but not used
[-Werror=unused-variable]
cc1: all warnings being treated as errors
Verify standard GPIO usage for latest v1.1a samples.
While at it get rid of some commented out obsolete stuff.
Integrate proper Ethernet initialisation analogous to how it is done
for the Colibri T20.
Add a commented out define for v1.0a modules with optional NAND
variants which are auto detected.
As we don't want to exclusively reserve the detection GPIO temporarily
enabling it is still required.
Integrate USB OTG functionality similar to Colibri T20.
Clean up various comments, indentation and white space issues.
Use the existing boardfile for everything, just match using DT.
See df80522dd557e2759552b6c6b0f1f1c8ad1c5614.
Add configurability support for i2s parameters.
See 907bac80691c7df5b5b57cbf27f91e8bb1dcf434.
This is a WAR solution that allows for the turning on SD DPD feature.
The original issue is that enabling SD DPD immediately after device
comes out of LP0 causes ULPI disconnect. The root cause of that is not
known.
The WAR is to delay the enabling of SD DPD for 100ms after
device comes out of LP0.
While at it remove commented out tegra_reserve stuff.
See 5e07056dc8b922b8b43a01b60a949c1dda75d9a9.
Enable touch interrupt GPIO and tune STMPE811 platform parameters for
better touch responsiveness.
Integrate ALSA SoC SGTL5000 codec on Toradex Colibri T30.
Tested on early prototype Colibri T30 V1.0a eMMC module.
Known issues:
- spurious boot hang after following kernel message
[ 5.595219] Timed out waiting for lock bit on pll pll_a
- no audio (SGTL5000) support integrated yet
- NAND detection/support disabled for now due to boot hang
- USB OTG support disabled for now due to boot hang
- trying to spawn L4T R16 X driver seems to hang
Note: requires uImage with adjusted entry point/load address as follows
mkimage -A arm -C none -O linux -T kernel -a 0x82008000 -e 0x82008000 -n 'Linux-3.1.10-colibri_t30' -d zImage uImage
