bug 925600
Change-Id: I2560a0874f5af96a8f59922ab0f267c676662ca1
Reviewed-on: http://git-master/r/78606
Repeat key events reported to android causes keys (e.g power key) to be
treated differently. Disable EV_REP on android platforms for now.
BUG 918758
Change-Id: I62a7c495303a906ef72738465ce5101d244e725d
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/72953
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Configuring the kbc pins such that the row/column is configured
in their respective GPIO number.
bug 804531
Reviewed-on: http://git-master/r/64033
(cherry picked from commit ec1c562461090170ce9515147954185c9a5bda44)
Change-Id: I5242bee91e767151022071022f195f0f1ca7bea2
Change-Id: I3cb02c81b88db4284337177355caaea77ef48e12
Reviewed-on: http://git-master/r/65134
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R2867df551e1c8d81fe4a7cd0034aeed9439f1e09
Setting the number of scans to 30 by keyboard controller after
pressed key released.
Also setting repeat delay time to 1 clock.
bug 876712
Reviewed-on: http://git-master/r/62592
(cherry picked from commit 9afabbf3d72135346b02c9a2cf48e4793fb90d43)
Change-Id: Idec353b68fba82676655125acd7f3d78ff4d0d08
Reviewed-on: http://git-master/r/63198
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Rebase-Id: R20feaf7cd291cd2b404effad4c029dca1a21c57c
Set pin configuration information for required rows and columns.
Enable only required ROW and COL gpio.
bug 889620
Change-Id: Ia9794d6a1af13dd9148ddac81378e961f6ae35f4
Reviewed-on: http://git-master/r/59618
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Shridhar Rasal <srasal@nvidia.com>
Rebase-Id: Re56f1d9384993f544d0bfbbf0e8a457cee0c4913
Change-Id: I3d68c141cb515a024432ff5c2b40481494d178f7
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/50909
Rebase-Id: Rc7e5a79c13087c8f58dc50fa6304206f39dd287e
Enabled Home, Back, Menu are as wakeup source keys
Bug 866078
Original-Change-Id: If009a44f1db5b7d971a61f3cab5ece2ce4c3aefd
Reviewed-on: http://git-master/r/49368
Reviewed-by: Alok Chauhan <alokc@nvidia.com>
Tested-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Rebase-Id: R6fceeb4b43b424ba33d4f125511d1b5d46f7ab07
Added KBC support
Bug 827020
Change-Id: Ieac77376aa086f0151b5db4f9069dc886c8a2491
Reviewed-on: http://git-master/r/31568
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R57011c3e96f4d14a1d53d8376454a7872c26767f
