Bug: 1039342
Reviewed-on: http://git-master/r/127868
(cherry picked from commit 92f2d2099e3411dfa1966e8ead58dc5654f3124c)
Change-Id: Ibe7dd39a06170766ec043ccbf18df0078ee9e7cb
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/128508
Reviewed-by: Niranjan Wartikar <nwartikar@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bug 1031990
Change-Id: I9410bc0347544701a753287713f9537710e7533f
Signed-off-by: Seema Khowala <seemaj@nvidia.com>
Reviewed-on: http://git-master/r/127620
Reviewed-by: Michael Hsu <mhsu@nvidia.com>
Tested-by: Michael Hsu <mhsu@nvidia.com>
Bug 1002637
Change-Id: I1271f95e8c174422bcb93eed3cc2bd7df8012479
Reviewed-on: http://git-master/r/123537
Pinmux configurations updated according to the schematics of
Enterprise A04. The unused pins are marked Tristate and turned
low. The directions are updated for other pins.
Bug 990845
Change-Id: I787bdd77848af59b5c33d030f0c040e7431d6c06
Signed-Off-By: Karthik Ramakrishnan <karthikr@nvidia.com>
Reviewed-on: http://git-master/r/105205
Reviewed-by: Simone Willett <swillett@nvidia.com>
Due to a hardware issue, Audio Baseband lines are changed
for A04 board from DAP3 to DAP5. All other boards retain
the same older line
Bug 980383
Change-Id: If9ecfaa7328a9a7148f95d604926975172c0886a
Signed-off-by: Tom Cherry <tcherry@nvidia.com>
Reviewed-On: http://git-master/r/#change,109067
(cherry picked from commit c3de03de4d97937e6a989ae6c79c8c430afd300e)
Reviewed-on: http://git-master/r/105168
Bug 987713
Change-Id: I4e6fb47007e337ec992d5ee58510c664957b448d
Signed-off-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-on: http://git-master/r/117592
GVS: Gerrit_Virtual_Submit
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Bug 995402
Change-Id: I53e9f1801d3b37626abb89c67b4e63662dab8c65
Reviewed-on: http://git-master/r/111306
Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I011fc1ec52b31b1b0602d577f02a6d20f37e402d
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102773
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
LCD_D8 used for BAT_REMOVAL staus from PMU to be
programmed as input/tristate to in line with hardware
schematics. It is connected VIO_IN
Bug 955519
(Cherry picked from I692d8d805c54da3996c33b9837b197a6995689c8)
Change-Id: I68e6566249675cd5fce8aa954983478e4fc29a4c
Reviewed-On: http://git-master/r/#change,91589
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
Reviewed-on: http://git-master/r/99742
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Bug 939799
Reviewed-on: http://git-master/r/90824
(cherry-picked from commit 8c556f816196c17e059db2c11b966ca89848efa3)
Change-Id: I67b26958862b8b60217c2750fe0b2eef3013d9b3
Reviewed-on: http://git-master/r/92409
configuring wf_wakeup gpio
Change-Id: I05e907c36847da07990d440357b9ef4ae3a857be
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/90994
Reviewed-by: Narayan Reddy <narayanr@nvidia.com>
Remove the pinmux conflicts by moving the unused pins
in reserved options.
bug 920706
Reviewed-on: http://git-master/r/78172
(cherry picked from commit fb30d2d39e39f2effb7ea39ea6d9ff16d55de99c)
Change-Id: Ieea78535a58707dec9dc9dbe74c6ec25a40d2b26
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/79978
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Add GMI_CLK to unused enterprise pinmux list.
Add TEGRA_GPIO_PK0 and PK1 to enterprise unused GPIO pins list.
Bug 855629
(cherry-picked from d3770f94fe6d2eca02fbe8da31a975298ee976ce)
Change-Id: Id5e7c4bdb9c798f554c4bc42b60d7097c17a851a
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-on: http://git-master/r/74343
Reviewed-on: http://git-master/r/75152
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Setting the SPDIF_OUT pinmux option to valid option.
bug 919759
Change-Id: I359b947814e008cbaa9c6e22e496839b5f139b13
Reviewed-on: http://git-master/r/72014
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Bug 878736
Bug 886459
(cherry picked from commit b840e235505829d7e11f2a984fb39d34bfb8f8d9)
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Change-Id: I08e48d03eced6e24f2b005d6f6a73cd4fec5c368
Reviewed-on: http://git-master/r/68295
- Disabling HDMI CEC, which is generally not supported by T30.
- Clear APBDEV_PMC_DPD_PADS_ORIDE_0_BLINK at boot time
- Pull down CLK_32K_OUT/BLINK
Bug 898597
Cherry-picked From: http://git-master/r/#change,63408
Change-Id: Ic6e6a5ddf16adf9e8f5a847a31ce7c902e3df9bc
Reviewed-on: http://git-master/r/68558
XMM modem requires GPIO power on sequence before modem
software can be downloaded to it.
BUG 828389
Change-Id: Ib8cf2a16a8b05a586d2f0b3bb57bad106a889cd1
Reviewed-on: http://git-master/r/46801
(cherry picked from commit 675f98979d6c6a281631d6590be5c7b6e5352b6f)
Reviewed-on: http://git-master/r/65958
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Red280cdd7669487e2368b75d4e1cd1c2130b3829
BUG 828389
Change-Id: I56847ff0c002b9b6858c16ecca1bb9e9b18e3a60
Reviewed-on: http://git-master/r/62772
Rebase-Id: Re8d8478d1c96ff6a405c19aaf5b8d14659134c2f
Bug 907141
Change-Id: I799421d640c25151edcb6a2bb72f941cd4ce1c2a
Signed-off-by: Om Prakash Singh <omp@nvidia.com>
Reviewed-on: http://git-master/r/66890
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Rebase-Id: R8325d47e49ea11988f42251fa75211e6c129315a
SND_HDA_CODEC_REALTEK config by default gets enabled when SND_HDA_INEL
config is enabled. Just enabling realek HDA codec compilation flag
does not mean board has same installed. Remove code which switches
DAP2-I2s21 path to DAP2-HDA based on CONFIG_SND_HDA_CODEC_REALTEK
check.
Bug 872652
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Change-Id: I5334d156ed50dfa37fa4b5b6b2e1f34049b762a0
Reviewed-on: http://git-master/r/64402
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: Rd8d2a638041c18f4e04e58423a45eb4efad4c9d9
1) configuring pinmux
2) create pn544_i2c_platform_data
3) register i2c device info using i2c_register_board_info
Bug 846684
Bug 873017
Change-Id: I6cc370d3ee6cc5df6b75db19bb719275e465f344
Reviewed-on: http://git-master/r/62746
Rebase-Id: R334a9cc8f86c90214b2415b3b855d5f234ad7a11
Add I2C mux driver instance to support two rear sensors.
Add new GPIO pin to control reset for I2C mux.
If board doesn't have I2C mux, it falls back to previous I2C tree.
Bug 871860
Reviewed-on: http://git-master/r/54763
(cherry picked from commit c53f8fc9d5d05427684aafb4ad6552eb6cff7ff7)
Reviewed-on: http://git-master/r/55799
(cherry picked from commit c5fe68c1b4b1ed1e283526c8ac057efb3a2af5af)
Change-Id: I40a35cbd301e53a8d70700043142d5cac0655b5c
Reviewed-on: http://git-master/r/57414
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Tested-by: Jihoon Bang <jbang@nvidia.com>
Rebase-Id: Re59baf9b13c653c366f992913622d1a46c8aecde
Bug 862023
Change-Id: I0ba560f471088302d6197c564f02606a25f2a5db
Reviewed-on: http://git-master/r/51072
Rebase-Id: Rfeed9cb02b08e8673c0b4784d2eedc672c3b4bfc
Add the pull-up for ddc i2c pins because there is
no internall pull-up present for ddc i2c pins.
Disable the output drain also for ddc i2c pins.
bug 833992
Original-Change-Id: Ibbc2011b74baff9177d0f26a381113a3e6a1cf7a
Reviewed-on: http://git-master/r/40541
Rebase-Id: R9b58d1485d786bc82773a2e5f2afdc92837b30e1
Fixing pinmux warning during kernel boot.
bug 856474
Original-Change-Id: Id3bc46a10ba37943544ee287a1b4bbd007056194
Reviewed-on: http://git-master/r/43458
Rebase-Id: Rbfa3de0f991a6f0aa974dbfc11e418eb1e8b94b7
Set unused pins to tristate, pull_down, output and gpio mode
to minimize power consumption.
Special case for bootstrap pins, of which pull_up/ pull_down
is set to to normal as they are tugged to ground to the enterpise board.
BUG 836834
Original-Change-Id: If878d4d2c4999b24dfd4cfbec7bad479e4e942a5
Reviewed-on: http://git-master/r/40465
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Tested-by: Chih-Lung Huang <lhuang@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Rc70aed0f74f9baea7cb88daaab2d8b539f7ec418
Removed the setting of the DAP2 pingroup to maximum
driver strength. This was a WAR for audio noise issues
on Verbier and should not be set on Enterprise.
Bug 853161
Original-Change-Id: Ia9bc4021ee1713f0be14e77c984d2266efb06b12
Reviewed-on: http://git-master/r/43084
Tested-by: Scott Peterson <speterson@nvidia.com>
Reviewed-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Rebase-Id: R7e2f0d70770e53188a783d0ca90476e5b1287714
setting UART3 signal drive strength to maximum.
Bug 847748
Bug 819411
Original-Change-Id: I29685142088579cf0eeeb41686a61c3d87a06a64
Reviewed-on: http://git-master/r/41218
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Rebase-Id: R54a99cf40c169a6e100593780216feeebf95aaf0
Selecting proper pinmux option for sdmmc3_dat6, sdmmc_dat7, ulpi_data3
from the valid list of pinmux option to avoid any warning.
bug 849973
Original-Change-Id: I6c554e3d399afef10fd837291a808496f0f8b811
Reviewed-on: http://git-master/r/39562
Rebase-Id: Rf1826cc64c5b531e7827592dd78ea6ce967a6264
Configuring correct pinmux. platform_device_add for bluesleep.
this feature will be enabled with CONFIG_BT_BLUESLEEP.
bug 841489
Original-Change-Id: Ib2e86b4090e0e0b1b8256a32b049f6741d8d2648
Reviewed-on: http://git-master/r/38015
Rebase-Id: Rb8ccadc62fbba8e27c9c1a121a3f1d95220b9c7a
Add and enable rear camera sensor.
Support only one sensor for now.
Original-Change-Id: I97a1067ab7d40ef434409b5a4175681248f85d90
Reviewed-on: http://git-master/r/36778
Rebase-Id: Rc9829ef590136f09c942d76bf48d6b76993c8be7
Adds userspace control for 3d barrier on 3d panel found on enterprise.
Provides 2 sysfs files:
/sys/devices/nvhost/tergradc/stereo_mode
/sys/devices/nvhost/tergradc/stereo_orientation
These are used to enable/disable 3d barrier and control it's
orientation, respectively.
Original-Change-Id: I580f0992c19cbee9a695bac9bef503c9888abc83
Reviewed-on: http://git-master/r/32575
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: Rf97ba4335f3f79697159c574ef00cbdd8330b1b6
Registering the dc-pwm based backlight control driver.
bug 831073
Change-Id: Ib77c1ee206bb95276b6f28a6d09ce33629f7d9a5
Reviewed-on: http://git-master/r/34735
Rebase-Id: Rd6617d0c4646463c1250326ebd969fd9813c3419
Fix UART A pinmux on enterprise board.
Bug 832780
Change-Id: I533abf43d5dd199270cd49eb450801bdaca2fb60
Reviewed-on: http://git-master/r/34804
Rebase-Id: Rfc83eca20259a61b7d62182856166224924b2ffd
fixed pinmux,clock and sdhci instance for WiFi/BT
Change-Id: Ifa192d8dcd4321754843aae6e47e1204d5cf074e
Reviewed-on: http://git-master/r/30344
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R3339e0c208fabb677768a39f2cc1a98bb9556438
Add PH450 modem init and reset functions for Tegra Enterprise.
Bug 800301
Change-Id: I7068fa87118c2388badb664da3d1a83a3eb49dae
Reviewed-on: http://git-master/r/30920
Rebase-Id: R5c93eca6b9fd9d45afbc5d42b49d779f6a027a9a
Enable UART4 as debug uart.
Bug 814271
Bug 822432
Change-Id: I73f01191d5f1e0fe979eb804028e0a7956eb93df
Reviewed-on: http://git-master/r/30513
Rebase-Id: R6e542cab4c70d962a2960a1708b10167ff161083
Fix mux entry for CAM_MCLK to use VI_ALT2.
bug 821540
Change-Id: I7d68af22eb65b5e2ee20bf521cc73587e41b1c37
Reviewed-on: http://git-master/r/29981
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Tested-by: Prayas Mohanty <pmohanty@nvidia.com>
Reviewed-by: Shantanu Nath <snath@nvidia.com>
Reviewed-by: Danielle Sun <dsun@nvidia.com>
Tested-by: Danielle Sun <dsun@nvidia.com>
Rebase-Id: R01e37ba5c127da48e8c6708e9f6de896ed7945e6
On tegra3 TRM, some of the pin mux option for a given
pin group is not recommended and so not exposed in the
TRM reference table.
Updating the pinmux table accordingly. The non-recommended
pin option is set as TEGRA_MUX_INVALID.
bug 817099
Change-Id: I572ee84912fe065a73e59d4f9ba0ce01223ead85
Reviewed-on: http://git-master/r/29626
Rebase-Id: R2c6d6b065075ca47761bbc7d156e129efa02c50b
Renamed tegra_enterprise board name to enterprise
Original-Change-Id: If4bfe61ef086f980b81ca4fedd30d760e89befad
Reviewed-on: http://git-master/r/28324
Change-Id: I27173743eedba2d964b33d17136318f93f1e3afc
Rebase-Id: Rbc65b62d51cb7249bcf2d07291c93c223c231369
Remove executable permission bit from source files.
Generated with:
find \( -name "*.c" -or -name "*.h" -or -name "*akefile" -or \
-name "*\.mk" \) -type f -perm /+x | xargs chmod -x
Original-Change-Id: If459d180238b8dd4cc40f92f74a56d01c81a2768
Reviewed-on: http://git-master/r/27916
Tested-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: If96e5e61c9f3b60ceaf9dcf88c0c7d7d1d8f343a
Rebase-Id: Rd8088a9b0813bc443a08548271e6586479b99886
Creating initial board files and config files for tegra_enterprise board.
Original-Change-Id: I77dcd612421167b9c6441d5d6fb779bb51491efa
Reviewed-on: http://git-master/r/20852
Change-Id: I498fe3cde454657c22fb1c1bc2212eb5e2f7fd6e
Rebase-Id: Rcf164609f08780297a383d040e934a1ecd3c86b5
