Removing tegra_gpio_enable and disable calls
from board files as they are supported through
set direction calls in the driver
Bug 984439
Change-Id: I011fc1ec52b31b1b0602d577f02a6d20f37e402d
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/102773
GVS: Gerrit_Virtual_Submit
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Limit eMMC, SD and SDIO DDR mode clock to 41MHz.
Bug 967719
Change-Id: Iaccc5b771b81b15226f87684b547ad1fb7dd38d3
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/101173
Tap delay value of 0x0F is recommended by HW team
Bug 911075
Change-Id: I9b73e7203c0dcb1971073b1d7251d11d71eddff3
Reviewed-on: http://git-master/r/98796
(cherry picked from commit 637b073d6ff7d7d71c2e0e632b222ecc6850be23)
Reviewed-on: http://git-master/r/98763
Tested-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
For SDMMC4 GMI interface, tap delay value of 0xF
is recommended by HW team.
Bug 911075
Change-Id: I2cdf90f34341cb8062dbded52ff1739c0c84cb0d
Reviewed-on: http://git-master/r/97668
fix typo in pre-power wifi code
Bug 956238
Change-Id: Iee794da508d39131e3166bba71b1c46c60d19a3b
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/96821
Reviewed-by: Allen Martin <amartin@nvidia.com>
power up WiFi chip, if Kconfig option
TEGRA_PREPOWER_WIFI is turned on.
Bug 956238
Change-Id: I26ef92fee30f8d18a47c3968b9b01b97e52a9382
Reviewed-on: http://git-master/r/90671
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
embedded_sdio is used, iff MMC_EMBEDDED_SDIO
Kconfig is on. This CL makes it explicit.
Additionally, for SDIO sdhci always keep the power on.
Bug 956238
Change-Id: I44e484b0705b50f942f177ee8d95fb363f38b8c1
Reviewed-on: http://git-master/r/90670
Disable built_in flag for enterprise to make
multiple turn ON/OFF of WiFi.
Change-Id: I6ee4fd8448fba49b00946d086d0df31609bdf501
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/68237
Limit the wifi clk on PM269, enterprise and
whistler to prevent CRC errors during data
transfers over wifi.
Bug 908560
Change-Id: I46087d98c4ed9d3606ae401de4a3bab9c835bc23
Reviewed-on: http://git-master/r/68161
1) configuring wf_wakeup gpio
2) create resource wifi_resource and provide it to wifi driver
Bug 820860
Change-Id: I640b5abafd1df8d93ed480dd1661eef83d3d1677
Reviewed-on: http://git-master/r/62168
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
Reviewed-by: Narayan Reddy <narayanr@nvidia.com>
Tested-by: Narayan Reddy <narayanr@nvidia.com>
Rebase-Id: R8c2155dbfa419b33d364051bb7edd90d1df7a5be
Making built_in=1 in the mmc platform data for Internal eMMC and SDIO card.
Change-Id: I9caa697a60b823733b953f99bf774a4aec41c61a
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/53404
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Rebase-Id: R9149c7382bbea22c119d75fcc5eaf9d931069ae4
Proper order of registration for sdmmc3 so as to mount the external SD card.
Bug 873188
Change-Id: Icfc896209066fb608628f7a1bb4618c141e1c0e3
Reviewed-on: http://git-master/r/52303
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Rebase-Id: Rbe6f6512eaae78a5ff970fd43d62df29d324128c
Typo in sdhci device registration
Original-Change-Id: I783e72ca6481f6b713371b34d34453763ce19748
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R621a628e641636e34cbe22430d2ffbe7f8bc769e
Rebase-Id: R89944b2cad270c88704ab35364fa0aa709455ade
fixed pinmux,clock and sdhci instance for WiFi/BT
Change-Id: Ifa192d8dcd4321754843aae6e47e1204d5cf074e
Reviewed-on: http://git-master/r/30344
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R66d4aaf962f1547c1285fbe3a9f89ffd7ca0899e
Creating initial board files and config files for tegra_enterprise board.
Original-Change-Id: I77dcd612421167b9c6441d5d6fb779bb51491efa
Reviewed-on: http://git-master/r/20852
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Change-Id: I498fe3cde454657c22fb1c1bc2212eb5e2f7fd6e
Rebase-Id: Rc408b20c823411b73b88e3da92492410a91ecaef
bug 896706
Change-Id: I232a616680553a668638ec252a3ff2a7b6c874b8
Reviewed-on: http://git-master/r/64081
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R9f7a494f9b2d2c020693fa1fc218cca98b5bfc7c
This causes linux-tegra-nv-2.6.39 not to compile, because
tegra_sdhci_device0 is only defined in android-tegra-nv-2.6.39
This reverts commit 8606f1e00b908326e0717e29a1c8bcbb635a3610.
Change-Id: I432e6320fb85d32ba3be0541bae69baa6e744d39
Reviewed-on: http://git-master/r/51861
Rebase-Id: Ree5ef819b752677afe744662be97006813edbc53
Bug 873188
Change-Id: If73aa94d2700ce3fa27992ea61a2a317a6600ea1
Reviewed-on: http://git-master/r/51581
Rebase-Id: Ra7454edc9263cb2f2b3531f33721692c016887c6
Change-Id: I156af0bdd8b37cb23aec214c3e158027252e27e1
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/51157
Rebase-Id: R795bf03590a76b6c494afd37603ed951dc2cd082
Change-Id: I7c92f95981ca666229df90aacf704b9bb1c3731a
Reviewed-on: http://git-master/r/49288
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R4ca8ae91b3f1b6f6be8d961cb893cb06bb8346cb
Rebase-Id: R0ce2f32451e4fdef46917bd4a6c54b979c24d258
Enterprise board uses SDMMC3 slot for External SD and SDMMC1 slot
for WiFi.
Bug 822432
Change-Id: Ifa13d69fa65f974c8457b9ffec231579b356a810
Reviewed-on: http://git-master/r/30514
Rebase-Id: R91d9ad73d0abe5a4943b8d41648d8e24a012c69a
Build Fix.
Bug 822432
Change-Id: Ia9d2d3ddc9aa9b2c00761ceb30a2bdcda8d261cf
Reviewed-on: http://git-master/r/30718
Reviewed-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Rebase-Id: R9f6c1953031d39ab4d10283c3be0d9ff6216de02
Renamed tegra_enterprise board name to enterprise
Original-Change-Id: If4bfe61ef086f980b81ca4fedd30d760e89befad
Reviewed-on: http://git-master/r/28324
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Change-Id: I27173743eedba2d964b33d17136318f93f1e3afc
Rebase-Id: Rbc65b62d51cb7249bcf2d07291c93c223c231369
Rebase-Id: Rcf164609f08780297a383d040e934a1ecd3c86b5
