path: root/arch/arm/mach-tegra/board-kai-kbc.c
2012-06-14ARM: tegra: resolve compilation time warningsSanjay Singh Rawat
- Adding flag to treat warning as error. - Handling warnings of unused variable, structures and functions, wrong return type, wrong type comparision. Bug 949219 Change-Id: I9d02387ce1073c4e46f69d01669285aa3754f1d9 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/104968 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-06-01ARM: tegra: kai: Remove tegra_gpio_enable/disableAshwini Ghuge
Removing tegra_gpio_enable and disable calls from board files as they are supported thorugh set direction calls in the driver Bug 984439 Change-Id: I4ec51c8eb68c373b7cec6903bf52539cd520b227 Reviewed-on: http://git-master/r/102813 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-01arm: tegra: kai: do not enable wakeup for interrupt keysJohnny Qiu
Bug 975433 MAX77663 driver hasn't implemented irq_set_wake(). Actually its interrupt always wakes up AP. Set wakeup = false to reduce warning messages in kernel. Change-Id: Id4f43d7d2ba879c92846091e2062765de7ea477e Signed-off-by: Johnny Qiu <joqiu@nvidia.com> Reviewed-on: http://git-master/r/99536 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-03-30ARM: tegra: cardhu/Kai: Use gpio_keys driver for int keyLaxman Dewangan
gpio_keys driver support for the key which can generates only interrupt and not mapped to any gpio functionality. Using this feature to support the onkey which generates interrupt only when key is pressed. Change-Id: I502a45a1c510b92f4114ded713f7706b7a2c85d3 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/92460 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-02-13arm: tegra: kai: add functionality of power buttonJohnny Qiu
Change-Id: I8c454f465ded68606a29e5dc0cc939cbb9afc96f Signed-off-by: Johnny Qiu <joqiu@nvidia.com> Reviewed-on: http://git-master/r/82764 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-01-30arm: tegra: kai: create board filesJohnny Qiu
Create initial board files and config files for Kai. Reviewed-on: http://git-master/r/74441 Change-Id: I4b07607da85fe4bcb00e5fce2ddbc2a83471b1de Signed-off-by: Johnny Qiu <joqiu@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/77296 Reviewed-by: Automatic_Commit_Validation_User
