path: root/arch/arm/mach-tegra/board-p1852.h
2012-07-30arm: tegra: p1852: Fixes for I2S master modeNitin Pai
Change the Drive strength of DAP1 for I2S to operate in both master and slave mode. Changed the Pull Up/Down mechanism for I2S4 to operate in master/slave mode. Bug 1009249 Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/114587 (cherry picked from commit 29ec5dfb81b823880f393bece5daf5396ef77629) Change-Id: I24a252370b993150a553c9f81fb44e6d8f86589a Reviewed-on: http://git-master/r/118251 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-07-16ARM: tegra: p1852: Dual-display support for all SKUsDongfang Shi
Ported Peter's original change 86413 to main. board-p1852-panel.c: Add support for primary and secondary LVDS displays, and secondary HDMI display. board-p1852-pinmux.c: Add configuration for HDMI and LVDS board-p1852.c: board-p1852.h: Support for determining which p1852 sku is in use hdmi.c:If no edid retrieved, but there's a hardwired mode, enable it (used to support HDMI->LVDS output on p1852 sku 2) devices.c:added secondary display data. Bug 977859 Bug 994011 Change-Id: Ide8fb6bf7dd873b1d50269fb98d7c1687e4d9073 Signed-off-by: Dongfang Shi <dshi@nvidia.com> Reviewed-on: http://git-master/r/100438 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-12arm: tegra: p1852: drive touch panel with resolution 1366x768Dongfang Shi
Enable WXGA display and touch input for p1852 touch panel. board-p1852-panel.c: added WXGA timing for atmel touch panel. board-p1852.c: initialize touch panel if touch input is defined. board-p1852.h: added p1852 touch panel GPIO and bus. tegra_p1852_gnu_linux_defconfig: added touch panel flags, not defined by default. bug 936232 Change-Id: Ia50b991f6aa5ed0ece458ad3871a68684a9234a6 Signed-off-by: Dongfang Shi <dshi@nvidia.com> Reviewed-on: http://git-master/r/101348 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-02-14tegra: p1852: Fix build breakManoj Chourasia
linux/gpio.h header was missing in p1852 board files causing build break. Adding header fixes the break. bug 938667 Change-Id: Ie5b471432af2501d74d2dcaa9fe786b1c616107c Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com> Reviewed-on: http://git-master/r/83081 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Preetham Chandru <pchandru@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-02-09ARM: tegra: p1852: Add board support files for p1852Amlan Kundu
bug 871603 P1852 is a T30 based Automotive platform. Signed-off-by: Amlan Kundu <akundu@nvidia.com> Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com> Reviewed-on: http://git-master/r/72253 (cherry picked from commit 98d50016e70a22ae7e8e109cfb6633a8fe75f905) Change-Id: Iede9881fc1168bb6802694e233554d84adfb8f44 Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Reviewed-on: http://git-master/r/79981 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
