Change-Id: I00c67d6ec68c7566c2764aa8d135c101bacc17d7
Change-Id: Idd9599aaed202e106bf6186fa0f4e783f850db0a
Change-Id: Ibde4802b607cf21159797b55514d46461fb1144d
Many platforms are derived from ventana and have different types
of memories. Add a separate array for the emc chips being used on
those platforms.
Be default, the array is not populated with any entries. This
disables memory scaling for that device.
BUG 854226
Reviewed-on: http://git-master/r/43038
(cherry picked from commit de90911c0b7e9a1a58cfb4bd540de5474486bfc6)
Original-Change-Id: I067b272f63cad873a9f25fff3d54151a1b56f479
Reviewed-on: http://git-master/r/46243
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Ching Kuang (Roger) Hsieh <rhsieh@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Rebase-Id: R20685e06fa47f3d006f716d6eff80d8177877aee
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: R956561f60449956126a3885ea8ba25f84965e36e
tegra_init_emc() has been updated to use emc chips to support
generic memory vendor matching. Convert current emc tables to
use emc chips.
Original-Change-Id: Idfee6b903352669d7b04dae897cb848c6a8c26a6
Reviewed-on: http://git-master/r/22042
Reviewed-by: Amit Kamath <akamath@nvidia.com>
Rebase-Id: R4a08df5e089081ad2420b1d5b9ea9ed71b4019e3
add emc register values for 25Mhz frequency
Original-Change-Id: I2fc34166ab34429d48422c5927ba3cfdf7b5b3a8
Reviewed-on: http://git-master/r/16694
Tested-by: Amit Kamath <akamath@nvidia.com>
Rebase-Id: R2b1dfed36f70a7f361a800afa48e9826425f0ea9
add emc config table for 400Mhz elpida ram
bug 776568
Original-Change-Id: I1e35c47260683faf4b80408deb4f710814134bea
Reviewed-on: http://git-master/r/16101
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R63b2b20cb669c96b2336bd6b6a13bcb260e459a3
frequencies 50Mhz and 100Mhz for 333mhz elpida memory
bug 775764
Original-Change-Id: I74cf8081fecd721ce8d23202263ac1cfb34df8f8
Reviewed-on: http://git-master/r/16116
Rebase-Id: Race9856fe78dd9a4a581023bd6103fe66bc20daa
Added memory table for ventana
Enabled emc tables used for emc voltage scaling
Original-Change-Id: I2c46faf1eeea90b7f4097c4128dbec5d08888d13
Reviewed-on: http://git-master/r/14245
Rebase-Id: Rd26dd6d70024e8d38c5225113de5d526807d1a53
